The brightness change buttons on the laptop keyboard do not work. The brightness is changing using the slider in the kde plasma and using commands in terminal, only buttons on the keyboard do not work (f2, f3). but when I launch system settings and go to the input devices section everything starts working until I close the system settings app, how to fix it?
Welcome to the forum! ![]()
Please post your system info as outlined here:
System: Kernel: 5.13.11-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-dk0xxx
v: Type1ProductConfigId serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 85FB v: 42.34 serial: <filter> UEFI: Insyde v: F.20 date: 11/22/2019
Battery: ID-1: BAT1 charge: 36.2 Wh (89.6%) condition: 40.4/52.5 Wh (76.9%) volts: 12.9 min: 11.6
model: Hewlett-Packard PABAS0241231 type: Li-ion serial: <filter> status: Charging
Memory: RAM: total: 7.61 GiB used: 2.03 GiB (26.6%)
CPU: Info: Quad Core model: Intel Core i5-9300H bits: 64 type: MT MCP arch: Kaby Lake
note: check rev: A cache: L2: 8 MiB bogomips: 38408
Speed: 800 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art avx avx2
bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl
dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase
fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc
nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti
pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Graphics: Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Hewlett-Packard driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Hewlett-Packard
driver: nvidia v: 470.63.01 bus-ID: 01:00.0 chip-ID: 10de:2191 class-ID: 0300
Device-3: Quanta HP Wide Vision HD Camera type: USB driver: uvcvideo bus-ID: 1-5:2
chip-ID: 0408:5300 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: modesetting
unloaded: intel alternate: fbdev,vesa resolution: 1920x1080~60Hz s-dpi: 96
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.1.6
direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA TU116 High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:1aeb class-ID: 0403
Sound Server-1: ALSA v: k5.13.11-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.19 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.33 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel port: 4000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter vendor: Hewlett-Packard
driver: rtw_8822be v: N/A port: 3000 bus-ID: 05:00.0 chip-ID: 10ec:b822 class-ID: 0280
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Bluetooth: Device-1: Realtek Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-14:3 chip-ID: 0bda:b00b class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block:
hardware: no software: yes address: see --recommends
Logical: Message: No logical block device data found.
RAID: Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0
port: 6060 bus-ID: 00:17.0 chip-ID: 8086.282a rev: 10 class-ID: 0104
Drives: Local Storage: total: 238.47 GiB used: 71.8 GiB (30.1%)
ID-1: /dev/nvme0n1 vendor: KIOXIA model: N/A size: 238.47 GiB speed: 15.8 Gb/s lanes: 2
type: SSD serial: <filter> rev: ADHA0102 temp: 40.9 C scheme: GPT
Partition: ID-1: / size: 229.37 GiB used: 71.8 GiB (31.3%) fs: btrfs dev: /dev/nvme0n1p2 label: N/A
uuid: a8138b61-f4bc-4d17-b2b4-0e6c28e0b6f2
ID-2: /boot/efi size: 299.4 MiB used: 568 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1
label: NO_LABEL uuid: C3B1-9F8E
ID-3: /home size: 229.37 GiB used: 71.8 GiB (31.3%) fs: btrfs dev: /dev/nvme0n1p2
label: N/A uuid: a8138b61-f4bc-4d17-b2b4-0e6c28e0b6f2
ID-4: /run/timeshift/backup size: 229.37 GiB used: 71.8 GiB (31.3%) fs: btrfs
dev: /dev/nvme0n1p2 label: N/A uuid: a8138b61-f4bc-4d17-b2b4-0e6c28e0b6f2
ID-5: /var/cache size: 229.37 GiB used: 71.8 GiB (31.3%) fs: btrfs dev: /dev/nvme0n1p2
ID-6: /var/log size: 229.37 GiB used: 71.8 GiB (31.3%) fs: btrfs dev: /dev/nvme0n1p2
Swap: ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 label: swap uuid: 1aec63ac-3282-4c3c-8407-e1964d2da303
Unmounted: Message: No unmounted partitions found.
USB: Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0 speed: 480 Mb/s
Device-1: 1-5:2 info: Quanta HP Wide Vision HD Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0408:5300 class-ID: 0e02
serial: <filter>
Device-2: 1-14:3 info: Realtek Realtek Bluetooth 4.2 Adapter type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA chip-ID: 0bda:b00b
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
Sensors: System Temperatures: cpu: 48.0 C mobo: 29.8 C
Info: Processes: 252 Uptime: 5m wakeups: 1 Init: systemd v: 248 Compilers: gcc: 11.1.0
Packages: note: see --pkg pacman: 1262 Shell: Bash v: 5.1.8 running-in: konsole
inxi: 3.3.06
Someone didn’t read the tutorial. Help us help you.
Thanks for updating your post. Searching the internet for 15-dk0xxx linux brightness keys yields open bug reports for the same issue.
https://www.mail-archive.com/kernel-packages@lists.launchpad.net/msg452180.html
