journalctl -b0 -p4 --no-pager
юл 25 11:41:15 hp kernel: Spectre V2 : WARNING: Unprivileged eBPF is enabled with eIBRS on, data leaks possible via Spectre v2 BHB attacks!
июл 25 11:41:15 hp kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
июл 25 11:41:15 hp kernel: #5 #6 #7
июл 25 11:41:15 hp kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
июл 25 11:41:15 hp kernel: acpi PNP0A08:00: MMCONFIG is disabled, can't access extended PCI configuration space under this bridge.
июл 25 11:41:15 hp kernel: hpet_acpi_add: no address or irqs in _CRS
июл 25 11:41:15 hp kernel: nvme nvme0: failed to set APST feature (2)
июл 25 11:41:15 hp kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
июл 25 11:41:15 hp kernel: usb: port power management may be unreliable
июл 25 11:41:15 hp systemd-journald[265]: File /var/log/journal/931e10d2758348e385683960fd38dacb/system.journal corrupted or uncleanly shut down, renaming and replacing.
июл 25 11:41:15 hp kernel: ACPI BIOS Error (bug): Could not resolve symbol [\DPPP], AE_NOT_FOUND (20210730/psargs-330)
июл 25 11:41:15 hp kernel: ACPI Error: Aborting method \_SB.IETM.IDSP due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
июл 25 11:41:15 hp kernel: wmi_bus wmi_bus-PNP0C14:01: WQ data block query control method not found
июл 25 11:41:15 hp kernel: acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:03)
июл 25 11:41:15 hp kernel: acpi PNP0C14:05: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:03)
июл 25 11:41:15 hp kernel: wmi_bus wmi_bus-PNP0C14:05: WQBJ data block query control method not found
июл 25 11:41:16 hp kernel: iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
июл 25 11:41:16 hp kernel: r8169 0000:07:00.0: can't disable ASPM; OS doesn't have ASPM control
июл 25 11:41:16 hp kernel: nvidia: loading out-of-tree module taints kernel.
июл 25 11:41:16 hp kernel: nvidia: module license 'NVIDIA' taints kernel.
июл 25 11:41:16 hp kernel: Disabling lock debugging due to kernel taint
июл 25 11:41:16 hp kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 515.57 Wed Jun 22 22:44:07 UTC 2022
июл 25 11:41:16 hp kernel: thermal thermal_zone8: failed to read out thermal zone (-61)
июл 25 11:41:17 hp kernel: nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
июл 25 11:41:18 hp kernel: hp_wmi: query 0x4c returned error 0x6
июл 25 11:41:19 hp kernel: ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210730/nsarguments-61)
июл 25 11:41:21 hp kernel: kauditd_printk_skb: 28 callbacks suppressed
июл 25 11:41:21 hp systemd[572]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
июл 25 11:41:21 hp systemd[572]: Failed to start Update XDG user dir configuration.
июл 25 11:41:21 hp sddm-greeter[580]: QFont::fromString: Invalid description '(empty)'
июл 25 11:41:21 hp sddm-greeter[580]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffe650f7940), parent's thread is QThread(0x563f8d4d26a0), current thread is QThread(0x563f8d5ef3b0)
июл 25 11:41:21 hp sddm-greeter[580]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
июл 25 11:41:22 hp sddm-greeter[580]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
июл 25 11:41:22 hp sddm-greeter[580]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
июл 25 11:41:22 hp sddm-greeter[580]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
июл 25 11:41:22 hp sddm-greeter[580]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
июл 25 11:41:22 hp sddm-greeter[580]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.17'
июл 25 11:41:26 hp systemd-xdg-autostart-generator[625]: /home/lxtr/.config/autostart/org.flameshot.Flameshot.desktop:1: Unknown section 'Desktop Action Capture'. Ignoring.
июл 25 11:41:26 hp systemd-xdg-autostart-generator[625]: /home/lxtr/.config/autostart/org.flameshot.Flameshot.desktop:6: Unknown section 'Desktop Action Configure'. Ignoring.
июл 25 11:41:26 hp systemd-xdg-autostart-generator[625]: /home/lxtr/.config/autostart/org.flameshot.Flameshot.desktop:11: Unknown section 'Desktop Action Launcher'. Ignoring.
июл 25 11:41:26 hp systemd-xdg-autostart-generator[625]: /home/lxtr/.config/autostart/org.flameshot.Flameshot.desktop:16: Unknown key name 'Actions' in section 'Desktop Entry', ignoring.
июл 25 11:41:26 hp systemd-xdg-autostart-generator[625]: /home/lxtr/.config/autostart/io.crow_translate.CrowTranslate.desktop:1: Unknown section 'Desktop Action CopyTranslatedSelection'. Ignoring.
июл 25 11:41:26 hp systemd-xdg-autostart-generator[625]: /home/lxtr/.config/autostart/io.crow_translate.CrowTranslate.desktop:6: Unknown section 'Desktop Action Open'. Ignoring.
июл 25 11:41:26 hp systemd-xdg-autostart-generator[625]: /home/lxtr/.config/autostart/io.crow_translate.CrowTranslate.desktop:12: Unknown section 'Desktop Action SpeakSelection'. Ignoring.
июл 25 11:41:26 hp systemd-xdg-autostart-generator[625]: /home/lxtr/.config/autostart/io.crow_translate.CrowTranslate.desktop:18: Unknown section 'Desktop Action SpeakTranslatedSelection'. Ignoring.
июл 25 11:41:26 hp systemd-xdg-autostart-generator[625]: /home/lxtr/.config/autostart/io.crow_translate.CrowTranslate.desktop:24: Unknown section 'Desktop Action StopSpeaking'. Ignoring.
июл 25 11:41:26 hp systemd-xdg-autostart-generator[625]: /home/lxtr/.config/autostart/io.crow_translate.CrowTranslate.desktop:30: Unknown section 'Desktop Action TranslateSelectedText'. Ignoring.
июл 25 11:41:26 hp systemd-xdg-autostart-generator[625]: /home/lxtr/.config/autostart/io.crow_translate.CrowTranslate.desktop:37: Unknown key name 'Actions' in section 'Desktop Entry', ignoring.
июл 25 11:41:26 hp systemd-xdg-autostart-generator[664]: /home/lxtr/.config/autostart/org.flameshot.Flameshot.desktop:1: Unknown section 'Desktop Action Capture'. Ignoring.
июл 25 11:41:26 hp systemd-xdg-autostart-generator[664]: /home/lxtr/.config/autostart/org.flameshot.Flameshot.desktop:6: Unknown section 'Desktop Action Configure'. Ignoring.
июл 25 11:41:26 hp systemd-xdg-autostart-generator[664]: /home/lxtr/.config/autostart/org.flameshot.Flameshot.desktop:11: Unknown section 'Desktop Action Launcher'. Ignoring.
июл 25 11:41:26 hp systemd-xdg-autostart-generator[664]: /home/lxtr/.config/autostart/org.flameshot.Flameshot.desktop:16: Unknown key name 'Actions' in section 'Desktop Entry', ignoring.
июл 25 11:41:26 hp systemd-xdg-autostart-generator[664]: /home/lxtr/.config/autostart/io.crow_translate.CrowTranslate.desktop:1: Unknown section 'Desktop Action CopyTranslatedSelection'. Ignoring.
июл 25 11:41:26 hp systemd-xdg-autostart-generator[664]: /home/lxtr/.config/autostart/io.crow_translate.CrowTranslate.desktop:6: Unknown section 'Desktop Action Open'. Ignoring.
июл 25 11:41:26 hp systemd-xdg-autostart-generator[664]: /home/lxtr/.config/autostart/io.crow_translate.CrowTranslate.desktop:12: Unknown section 'Desktop Action SpeakSelection'. Ignoring.
июл 25 11:41:26 hp systemd-xdg-autostart-generator[664]: /home/lxtr/.config/autostart/io.crow_translate.CrowTranslate.desktop:18: Unknown section 'Desktop Action SpeakTranslatedSelection'. Ignoring.
июл 25 11:41:26 hp systemd-xdg-autostart-generator[664]: /home/lxtr/.config/autostart/io.crow_translate.CrowTranslate.desktop:24: Unknown section 'Desktop Action StopSpeaking'. Ignoring.
июл 25 11:41:26 hp systemd-xdg-autostart-generator[664]: /home/lxtr/.config/autostart/io.crow_translate.CrowTranslate.desktop:30: Unknown section 'Desktop Action TranslateSelectedText'. Ignoring.
июл 25 11:41:26 hp systemd-xdg-autostart-generator[664]: /home/lxtr/.config/autostart/io.crow_translate.CrowTranslate.desktop:37: Unknown key name 'Actions' in section 'Desktop Entry', ignoring.
июл 25 11:41:26 hp kernel: kauditd_printk_skb: 32 callbacks suppressed
июл 25 11:41:26 hp ksplashqml[654]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
июл 25 11:41:26 hp ksplashqml[654]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:82:29: Unable to assign int to QEasingCurve
июл 25 11:41:26 hp klauncher[686]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
июл 25 11:41:26 hp kcminit_startup[690]: QDBusConnection: error: could not send signal to service "" path "//home/lxtr/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: //home/lxtr/.kde4/share/config/kdeglobals
июл 25 11:41:27 hp kwin_x11[701]: Warning: Setting a new default format with a different version or profile after the global shared context is created may cause issues with context sharing.
июл 25 11:41:27 hp kwin_x11[701]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
июл 25 11:41:27 hp kwin_x11[701]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
июл 25 11:41:27 hp kwin_x11[701]: kwin_core: XCB error: 147 (BadOutput), sequence: 477, resource id: 64, major code: 140 (RANDR), minor code: 9 (GetOutputInfo)
июл 25 11:41:27 hp kwin_x11[701]: kwin_core: XCB error: 147 (BadOutput), sequence: 478, resource id: 0, major code: 140 (RANDR), minor code: 9 (GetOutputInfo)
июл 25 11:41:27 hp ksmserver[731]: Qt: Session management error: networkIdsList argument is NULL
июл 25 11:41:27 hp kwin_x11[701]: kwin_core: XCB error: 10 (BadAccess), sequence: 829, resource id: 2409, major code: 142 (Composite), minor code: 2 (RedirectSubwindows)
июл 25 11:41:27 hp kwin_x11[701]: kf.config.core: "\"fsrestore1\" - conversion of \"481,481,0,0\" to QRect failed"
июл 25 11:41:27 hp kwin_x11[701]: kf.config.core: "\"fsrestore2\" - conversion of \"0,0,0,0\" to QRect failed"
июл 25 11:41:27 hp kwin_x11[701]: kf.config.core: "\"fsrestore3\" - conversion of \"0,0,0,0\" to QRect failed"
июл 25 11:41:27 hp kwin_x11[701]: kf.config.core: "\"fsrestore4\" - conversion of \"481,481,0,0\" to QRect failed"
июл 25 11:41:27 hp kwin_x11[701]: kf.config.core: "\"fsrestore5\" - conversion of \"0,0,0,0\" to QRect failed"
июл 25 11:41:27 hp kded5[698]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.10'
июл 25 11:41:27 hp kwin_x11[701]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 916, resource id: 10485765, major code: 18 (ChangeProperty), minor code: 0
июл 25 11:41:27 hp kwin_x11[701]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 996, resource id: 31457288, major code: 18 (ChangeProperty), minor code: 0
июл 25 11:41:27 hp org_kde_powerdevil[771]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
июл 25 11:41:27 hp kded5[698]: kscreen.kded: PowerDevil SuspendSession action not available!
июл 25 11:41:27 hp org_kde_powerdevil[771]: org.kde.powerdevil: Handle button events action could not check for screen configuration
июл 25 11:41:27 hp kwin_x11[701]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1212, resource id: 31457289, major code: 18 (ChangeProperty), minor code: 0
июл 25 11:41:28 hp plasmashell[772]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
июл 25 11:41:28 hp kwin_x11[701]: Module 'org.kde.kwin.decoration' does not contain a module identifier directive - it cannot be protected from external registrations.
июл 25 11:41:28 hp kalendarac[918]: Attribute Qt::AA_EnableHighDpiScaling must be set before QCoreApplication is created.
июл 25 11:41:28 hp plasmashell[772]: Error: cannot change the containment to AppletsLayout
июл 25 11:41:28 hp kwin_x11[701]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1939, resource id: 31457291, major code: 18 (ChangeProperty), minor code: 0
июл 25 11:41:28 hp kwin_x11[701]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2012, resource id: 31457292, major code: 18 (ChangeProperty), minor code: 0
июл 25 11:41:28 hp akonadi_control[938]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
июл 25 11:41:28 hp pulseaudio[793]: stat('/etc/pulse/default.pa.d'): Нет такого файла или каталога
июл 25 11:41:28 hp kdeconnectd[783]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
июл 25 11:41:28 hp plasmashell[772]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:530:9: QML Label: Binding loop detected for property "height"
июл 25 11:41:28 hp plasmashell[772]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:495:13: QML Label: Binding loop detected for property "height"
июл 25 11:41:28 hp plasmashell[772]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
июл 25 11:41:28 hp plasmashell[772]: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x5560e88cd200)
июл 25 11:41:28 hp plasmashell[772]: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x5560e8992ca0)
июл 25 11:41:28 hp plasmashell[772]: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x5560e894c830)
июл 25 11:41:28 hp plasmashell[772]: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x5560e894c990)
июл 25 11:41:28 hp plasmashell[772]: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x5560e88cd250)
июл 25 11:41:28 hp plasmashell[772]: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x5560e894c560)
июл 25 11:41:28 hp bluetoothd[480]: Failed to set mode: Blocked through rfkill (0x12)
июл 25 11:41:28 hp kded5[698]: kf.bluezqt: PendingCall Error: "Blocked through rfkill"
июл 25 11:41:28 hp plasmashell[772]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:552:5: QML Label: Binding loop detected for property "height"
июл 25 11:41:28 hp plasmashell[772]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/main.qml:18:1: QML DropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
июл 25 11:41:28 hp plasmashell[772]: Both point size and pixel size set. Using pixel size.
июл 25 11:41:28 hp plasmashell[772]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/Tooltip.qml:54:9: QML GridLayout (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
июл 25 11:41:28 hp kwin_x11[701]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2674, resource id: 31457293, major code: 18 (ChangeProperty), minor code: 0
июл 25 11:41:28 hp kwin_x11[701]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2678, resource id: 31457294, major code: 18 (ChangeProperty), minor code: 0
июл 25 11:41:28 hp plasmashell[772]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
июл 25 11:41:28 hp kwin_x11[701]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2811, resource id: 31457295, major code: 18 (ChangeProperty), minor code: 0
июл 25 11:41:28 hp kwin_x11[701]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2823, resource id: 31457296, major code: 18 (ChangeProperty), minor code: 0
июл 25 11:41:28 hp kwin_x11[701]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2843, resource id: 31457297, major code: 18 (ChangeProperty), minor code: 0
июл 25 11:41:28 hp akonadiserver[958]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
июл 25 11:41:28 hp plasmashell[772]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:165:9: QML HiddenItemsView: Binding loop detected for property "implicitHeight"
июл 25 11:41:29 hp plasmashell[772]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:17:1: QML MouseArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
июл 25 11:41:29 hp plasmashell[772]: Both point size and pixel size set. Using pixel size.
июл 25 11:41:29 hp plasmashell[772]: Error: cannot change the containment to AppletsLayout
июл 25 11:41:29 hp plasmashell[772]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
июл 25 11:41:29 hp kmail[945]: Error loading text-to-speech plug-in "speechd"
июл 25 11:41:29 hp akonadiserver[958]: org.kde.pim.akonadiserver: Cannot connect to agent instance with identifier 'akonadi_maildir_resource_0', error message: ''
июл 25 11:41:29 hp kmail[945]: Cannot initialize model with data QJsonObject(). missing: QJsonValue(string, "urls")
июл 25 11:41:30 hp plasmashell[772]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
июл 25 11:41:30 hp kwin_x11[701]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5635, resource id: 31457298, major code: 18 (ChangeProperty), minor code: 0
июл 25 11:41:30 hp kwin_x11[701]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5648, resource id: 31457299, major code: 18 (ChangeProperty), minor code: 0
июл 25 11:41:30 hp crow[1307]: "Ошибка: Выбранный язык исходного текста не поддерживается для Google"
июл 25 11:41:30 hp kwin_x11[701]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5751, resource id: 31457300, major code: 18 (ChangeProperty), minor code: 0
июл 25 11:41:30 hp kmail[945]: kf.xmlgui: Index 22 is not within range (0 - 20 )
июл 25 11:41:32 hp plasmashell[772]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
июл 25 11:41:32 hp kwin_x11[701]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 8333, resource id: 4194357, major code: 18 (ChangeProperty), minor code: 0
июл 25 11:41:32 hp kwin_x11[701]: kwin_core: XCB error: 152 (BadDamage), sequence: 8335, resource id: 18874413, major code: 143 (DAMAGE), minor code: 3 (Subtract)
июл 25 11:41:32 hp kwin_x11[701]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 8387, resource id: 113246213, major code: 18 (ChangeProperty), minor code: 0
июл 25 11:41:32 hp kalendarac[1314]: Attribute Qt::AA_EnableHighDpiScaling must be set before QCoreApplication is created.
июл 25 11:41:32 hp plasmashell[772]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5560e963f0d0) QQmlContext(0x5560e8b5d630) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
июл 25 11:41:32 hp plasmashell[772]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
июл 25 11:41:32 hp plasmashell[772]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
июл 25 11:41:32 hp plasmashell[772]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/SelectableLabel.qml:38:5: QML TextArea: Binding loop detected for property "implicitHeight"
июл 25 11:41:32 hp plasmashell[772]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ScrollView.qml:45:27: QML ScrollBar: Binding loop detected for property "visible"
июл 25 11:41:32 hp plasmashell[772]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5560e9758120) QQmlContext(0x5560e8b5d630) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
июл 25 11:41:33 hp plasmashell[772]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
июл 25 11:41:34 hp kmail[945]: kf.xmlgui: Index 24 is not within range (0 - 20 )
июл 25 11:41:35 hp kwin_x11[701]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 12701, resource id: 46137477, major code: 20 (GetProperty), minor code: 0
июл 25 11:41:35 hp kwin_x11[701]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 12702, resource id: 46137477, major code: 15 (QueryTree), minor code: 0
июл 25 11:41:35 hp kernel: atkbd serio0: Unknown key pressed (translated set 2, code 0xab on isa0060/serio0).
июл 25 11:41:35 hp kernel: atkbd serio0: Use 'setkeycodes e02b <keycode>' to make it known.
июл 25 11:41:35 hp kernel: atkbd serio0: Unknown key released (translated set 2, code 0xab on isa0060/serio0).
июл 25 11:41:36 hp kernel: atkbd serio0: Unknown key released (translated set 2, code 0xab on isa0060/serio0).
июл 25 11:41:36 hp kernel: atkbd serio0: Use 'setkeycodes e02b <keycode>' to make it known.
июл 25 11:41:36 hp kernel: atkbd serio0: Unknown key pressed (translated set 2, code 0xab on isa0060/serio0).
июл 25 11:41:37 hp kwin_x11[701]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13388, resource id: 46137510, major code: 18 (ChangeProperty), minor code: 0
июл 25 11:41:37 hp plasmashell[772]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:370: Unable to assign [undefined] to QString
июл 25 11:41:37 hp plasmashell[772]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
