Flickering issue ( rx 570)
I have a strange issue for which i’ve found no solution. My Screen randomly flickers(goes black for 1s then returns to normal) while i’m in fullscreen mode watching videos or gaming. It’s a gpu issue of that im certain cause i’ve got older gpu i used to test this and it works fine. Thing is my gpu works perfectly fine in Windows but not in Linux. If anyone has any ideas i’d appreciate them, thanks! :slight_smile:
Start here:
  Kernel: 5.8.16-2-MANJARO x86_64 bits: 64 compiler: N/A
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
  root=UUID=a761237c-df31-4203-a5ec-def1e94b53ee rw quiet apparmor=1
  Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4
  dm: LightDM 1.30.0 Distro: Manjaro Linux
  Type: Desktop Mobo: ASRock model: B450M-HDV R4.0 serial: <filter>
  UEFI: American Megatrends v: P3.20 date: 07/31/2019
  Topology: 8-Core model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+
  family: 17 (23) model-id: 8 stepping: 2 microcode: 800820D
  L2 cache: 4096 KiB
  bogomips: 118209
  Speed: 1889 MHz min/max: 2200/3700 MHz boost: enabled Core speeds (MHz):
  1: 1887 2: 1885 3: 2064 4: 2064 5: 1912 6: 1953 7: 2192 8: 2191 9: 1890
  10: 1889 11: 2042 12: 1885 13: 2189 14: 2151 15: 1986 16: 2189
  disabled, RSB filling
  Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
  vendor: Sapphire Limited driver: amdgpu v: kernel bus ID: 09:00.0
  chip ID: 1002:67df
  Display: x11 server: X.Org 1.20.9 driver: amdgpu,ati unloaded: modesetting
  alternate: fbdev,vesa display ID: :0.0 screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: DVI-D-0 res: 1920x1080 dpi: 102 size: 476x268mm (18.7x10.6")
  diag: 546mm (21.5")
  OpenGL: renderer: Radeon RX 570 Series (POLARIS10 DRM 3.38.0
  5.8.16-2-MANJARO LLVM 10.0.1)
  v: 4.6 Mesa 20.1.8 direct render: Yes
  Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
  vendor: Sapphire Limited driver: snd_hda_intel v: kernel bus ID: 09:00.1
  chip ID: 1002:aaf0
  Device-2: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel
  v: kernel bus ID: 0b:00.3 chip ID: 1022:1457
  Sound Server: ALSA v: k5.8.16-2-MANJARO
  vendor: ASRock driver: r8169 v: kernel port: f000 bus ID: 08:00.0
  chip ID: 10ec:8168
  IF: enp8s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 465.76 GiB used: 12.77 GiB (2.7%)
  ID-1: /dev/nvme0n1 vendor: Kingston model: SKC2000M8500G size: 465.76 GiB
  block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
  serial: <filter> rev: S2780101 scheme: GPT
  ID-1: / raw size: 465.46 GiB size: 457.16 GiB (98.22%)
  used: 12.77 GiB (2.8%) fs: ext4 dev: /dev/nvme0n1p2
  System Temperatures: cpu: 49.1 C mobo: N/A gpu: amdgpu temp: 35 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 1570
  Processes: 319 Uptime: 36m Memory: 15.56 GiB used: 2.61 GiB (16.8%)
  Init: systemd v: 246 Compilers: gcc: N/A Packages: pacman: 1089 lib: 338
  flatpak: 0 Shell: Bash v: 5.0.18 running in: xfce4-terminal inxi: 3.1.05
:+1: Welcome to Manjaro! :+1:
As the AMD drivers are built into the kernel, you should try another kernel version and as you seem to have a rather new CPU, 5.9 and 5.4 LTS would be high on my list.
  • Print this page so you have it as a reference while in TTY2
  • Log off
  • Switch to TTY2 by pressing Ctrl+Alt+F2
  • Log in there
  • Execute:
    sudo mhwd-kernel --install linux54
    sudo mhwd-kernel --install linux59
  • to ensure grub is showing, execute:
     sudo nano --backup /etc/default/grub
  • Change (or add?) the following 3 lines:
    GRUB_TIMEOUT=3
    #GRUB_HIDDEN_TIMEOUT=0
    #GRUB_TIMEOUT_STYLE=hidden
    (3 or higher is fine, add the # before the lines above if those lines are present)
  • Ctrl+X Y Enter to save if there is anything to save
  • If you did save, execute:
     sudo update-grub
  • Reboot
  • Go to grub’s Advanced options
  • Choose these kernels one by one and try them out one by one and see if that helps.
:+1:
