iason
5 March 2022 12:47
1
Since Manjaro update 2022-02-05 (I think!) all my Flatpaks are very slow to start. They take about 30 seconds. Only Flatpaks are affected. Appimages and other apps start up very quickly. I re-installed Manjaro Gnome and still the same issue (I had to re-install the Flatpaks as they were deleted during the re-installation. My Home directory is on a separate partition and so was not deleted.)
I created a new User with admin privileges and installed some Flatpaks on that account and they start up just fine.
Any ideas on what is going on?
Hi @iason ,
If it works fine for another user, it’s obviously a configuration problem. Start the Flatak from a terminal:
$ flatpak run <package.name>
Where, <package.name> is the Application Id of the Flatpak you wish to run.
And provide the output.
Also, see [HowTo] Provide System Information
iason
5 March 2022 15:04
3
Hi @Mirdarthos , thanks for the reply!
This is my inxi output:
Kernel: 5.15.25-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=bd2a9365-128c-4471-b1c5-99744c8c65aa rw quiet splash apparmor=1
Desktop: GNOME 41.4 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
Type: Mini-pc System: Intel Client Systems product: NUC8i7BEH v: J72992-306
serial: <superuser required> Chassis: Intel Corporation type: 35 v: 2.0
Mobo: Intel model: NUC8BEB v: J72688-306 serial: <superuser required>
UEFI: Intel v: BECFL357.86A.0085.2020.1007.1917 date: 10/07/2020
RAM: total: 15.49 GiB used: 4.14 GiB (26.7%)
RAM Report:
Info: model: Intel Core i7-8559U bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xEC
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 901 high: 911 min/max: 400/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 900 2: 900 3: 900 4: 900
5: 900 6: 901 7: 900 8: 911 bogomips: 43214
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Device-1: Intel CoffeeLake-U GT3e [Iris Plus Graphics 655] driver: i915
v: kernel ports: active: DP-1 empty: DP-2,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:3ea5 class-ID: 0300
Device-2: Focusrite-Novation Scarlett 2i2 Camera type: USB
driver: snd-usb-audio bus-ID: 1-3.4:10 chip-ID: 1235:8210 class-ID: 0102
serial: <filter>
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.0
compositor: gnome-shell driver: X: loaded: intel gpu: i915 display-ID: 0
Monitor-1: DP-1 model: Dell U2412M serial: <filter> built: 2013
res: 1920x1200 dpi: 94 gamma: 1.2 size: 518x324mm (20.4x12.8")
diag: 611mm (24.1") ratio: 16:10 modes: max: 1920x1200 min: 720x400
Message: Wayland GBM/EGL data currently not available.
Device-1: Intel Cannon Point-LP High Definition Audio driver: snd_hda_intel
chip-ID: 8086:9dc8 class-ID: 0403
serial: <filter>
Sound Server-1: ALSA v: k5.15.25-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.47 running: yes
Device-1: Intel Ethernet I219-V driver: e1000e v: kernel port: N/A
bus-ID: 00:1f.6 chip-ID: 8086:15be class-ID: 0200
IP v4: <filter> scope: global
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-10:6 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 698.65 GiB used: 517.25 GiB (74.0%)
model: SSD 970 EVO Plus 250GB size: 232.89 GiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 35.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
type: SSD serial: <filter> rev: 3B6Q scheme: GPT
ID-1: / raw-size: 39.06 GiB size: 38.15 GiB (97.67%) used: 12.86 GiB (33.7%)
fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1 label: root
uuid: bd2a9365-128c-4471-b1c5-99744c8c65aa
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3 label: BOOT
uuid: F311-5BDC
ID-3: /home raw-size: 189.42 GiB size: 185.94 GiB (98.17%)
used: 119.54 GiB (64.3%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
label: home uuid: aefb6540-806f-441a-92b7-63241646e0e2
ID-4: /run/media/iason/Samsung EVO 860 raw-size: 465.76 GiB
size: 457.45 GiB (98.22%) used: 384.84 GiB (84.1%) fs: ext4 dev: /dev/sda1
maj-min: 8:1 label: Samsung EVO 860
uuid: 2aa20fde-9696-43c4-a5f8-4c494d432ce5
ID-1: swap-1 type: partition size: 3.91 GiB used: 2.2 MiB (0.1%)
priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2 label: swap
uuid: f9d1ecc4-dca7-4fad-9741-8e413abfad87
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Hub-2: 1-3:7 info: Microchip (formerly SMSC) USB 2.0 Hub ports: 4 rev: 2.0
speed: 480 Mb/s power: 2mA chip-ID: 0424:2514 class-ID: 0900
Device-1: 1-3.1:8 info: Logitech Keyboard K120 type: Keyboard,HID
power: 90mA chip-ID: 046d:c31c class-ID: 0300
Device-2: 1-3.2:9 info: Logitech Unifying Receiver type: Keyboard,Mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c534 class-ID: 0301
Device-3: 1-3.4:10 info: Focusrite-Novation Scarlett 2i2 Camera
type: Audio driver: snd-usb-audio interfaces: 4 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 1235:8210 class-ID: 0102 serial: <filter>
Device-4: 1-10:6 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-3: 2-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 33.0 C pch: 31.0 C mobo: 27.8 C
Processes: 296 Uptime: 5h 17m wakeups: 9 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.2.0 Packages: 1213 pacman: 1195 lib: 312
flatpak: 18 Shell: Zsh v: 5.8.1 running-in: gnome-terminal inxi: 3.3.13
I ran 4 Flatpak apps using the “faltpak run” command: Zoom, VLC, Handbrake and AbiWord.
With Zoom and AbiWord , I got no output in the terminal.
With Hanbrake , I got the following output:
(ghb:2): Gtk-WARNING **: 16:48:33.392: Theme parsing error: gtk.css:2:108: Failed to import: Error opening file /usr/share/gnome-shell/extensions/unite@hardpixel.eu/styles/gtk3/buttons-right/maximized.css: No such file or directory
With VLC I got the following:
VLC media player 3.0.16 Vetinari (revision 3.0.13-8-g41878ff4f2)
[000056107cbc70e0] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
Gtk-Message: 17:01:01.263: Failed to load module "canberra-gtk-module"
Qt: Session management error: None of the authentication protocols specified are supported
[000056107cc5bc50] main playlist: playlist is empty
QObject::~QObject: Timers cannot be stopped from another thread
I hope this sheds some light on my issue!
OK, I have searched, but couldn’t find a reason for this.
So I’m recommending you do:
sudo flatpak repair
And see if that repairs it.
Or see if there is something in the logs:
journalctl --unit=<flatpak.unit>
Where <flatpak.unit> is the uit for flatpak which can theoretically be obtained using :
journalctl --field _SYSTEMD_UNIT | grep --ignore-case flat
Note: I say theoretically because I don’t use, or even have, Flatpak(s), so can not give you tried and tested information. Instead, it’s all educated guessing.
iason
6 March 2022 20:59
5
The command
sudo flatpak repair
did not ameliorate the issue.
The command
revealed
flatpak-system-helper.service
so I ran
journalctl --unit=flatpak-system-helper.service
and got
Mar 06 19:12:57 iason-manjaro systemd[1]: Starting flatpak system helper...
Mar 06 19:12:57 iason-manjaro systemd[1]: Started flatpak system helper.
Mar 06 19:12:57 iason-manjaro flatpak-system-helper[2402]: system: Pulled appstream2/x86_64 from /var/tmp/flatpak-cache-5U3ZI1/repo-dC9LjR
Mar 06 19:22:58 iason-manjaro systemd[1]: flatpak-system-helper.service: Deactivated successfully.
and I have no idea what all that means!
I have the feeling that it may be easier to create a new user, move all my personal files there and reinstall the flatpaks I use… That way I will hopefully not transfer the problem over to the new user account.
Me neither. So I also suspect that’s probably the best option, yes.
iason
7 March 2022 07:23
7
Thanks for your help… Much appreciated!
iason
7 March 2022 10:12
8
Update:
It looks like Flatpaks are working normally now. This is what I did:
I removed all Flatpaks through Pamac and them disabled Flatpaks in the Pamac settings.
I then ran the command
flatpak uninstall --unused
and then ran
flatpak repair
Finally, I deleted the ~/.local/share/flatpak folder with
rm -r ~/.local/share/flatpak
Note that I did not remove the /var/lib/flatpak folder. I first wanted to see if flatpaks were working and they were. I did, however, make sure that the folder /var/lib/flatpak/app was empty (which it was).
This post helped:
https://forum.manjaro.org/t/how-to-completely-remove-snapd-and-flatpak-from-manjaro/6172/4?u=iason
system
Closed
10 March 2022 00:13
9
