av8r
13 March 2021 19:13
1
Hi, I’m not sure if this is the right section to ask this question, admin please feel free to move it to where it belongs if not right.
I updated my system using -Syu command. The next day when I go to boot-up my computer, I type in my passcode as usually on my Numpad, Manjaro stops and thinks for a minute and says I’m locked out for 10 min. after 10 minutes.
I type my code on the Numpad again and it logs me in.
This has become a standard feature now on the first boot. sometimes I have to use the number keys on my keyboard(not Numpad) on the first login, other times I do not.
to summarize after the computer has been shut-down, and the first boot-up, I type in my correct passcode and it tells me I’m locked out for 10 minutes. usually after 10 minutes without changing anything, I can type my passcode again and it logs me in like normal.
any help/advice to get this fixed?
I’m a newbie on Linux so I appreciate it if you can explain in layman’s terms. lol
av8r
21 March 2021 01:34
3
Thank you for your reply! with good instructions, I’m trying to learn as much as I can as fast as I can.
the output of the inixi command is:
Kernel: 5.11.6-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
root=UUID=f55d4adf-49b2-422b-b6ff-1cdc34e31ec3 rw quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4
Type: Desktop Mobo: Micro-Star model: MEG X570 UNIFY (MS-7C35) v: 2.0
serial: <filter> BIOS: American Megatrends v: A.60 date: 09/07/2020
RAM: total: 31.34 GiB used: 3.68 GiB (11.7%)
Array-1: capacity: 128 GiB slots: 4 EC: None max-module-size: 32 GiB
note: est.
Device-1: DIMM 0 size: No Module Installed
Device-2: DIMM 1 size: 16 GiB speed: 3600 MT/s type: DDR4
detail: synchronous unbuffered (unregistered) bus-width: 64 bits
total: 64 bits manufacturer: N/A part-no: F4-3600C16-16GTZNC serial: N/A
Device-3: DIMM 0 size: No Module Installed
Device-4: DIMM 1 size: 16 GiB speed: 3600 MT/s type: DDR4
Info: 16-Core (2-Die) model: AMD Ryzen 9 3950X socket: AM4 bits: 64
type: MT MCP MCM arch: Zen 2 family: 17 (23) model-id: 71 (113)
stepping: N/A microcode: 8701021 cache: L1: 1024 KiB L2: 8 MiB L3: 64 MiB
bogomips: 224085
Speed: 2075 MHz min/max: 2200/3500 MHz base/boost: 3500/4725 boost: enabled
volts: 1.1 V ext-clock: 100 MHz Core speeds (MHz): 1: 2075 2: 2757 3: 2105
4: 2072 5: 2199 6: 2199 7: 2195 8: 2196 9: 2186 10: 3169 11: 3202 12: 2141
13: 2075 14: 2177 15: 2057 16: 2054 17: 3813 18: 2092 19: 3654 20: 2056
21: 2072 22: 2199 23: 2200 24: 2090 25: 2201 26: 2198 27: 2143 28: 2131
29: 2153 30: 4332 31: 2097 32: 3037
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es sha_ni
skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload
vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
xsaveopt xsaves
conditional, RSB filling
Device-1: AMD Vega 20 [Radeon VII] driver: amdgpu v: kernel bus-ID: 2f:00.0
chip-ID: 1002:66af class-ID: 0300
Display: server: X.Org 1.20.10 driver: loaded: amdgpu,ati
unloaded: modesetting,radeon alternate: fbdev,vesa display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x571mm (40.0x22.5")
s-diag: 1165mm (45.9")
Monitor-1: DisplayPort-2 res: 3840x2160 hz: 60 dpi: 163
size: 600x340mm (23.6x13.4") diag: 690mm (27.2")
OpenGL:
renderer: AMD Radeon VII (VEGA20 DRM 3.40.0 5.11.6-1-MANJARO LLVM 11.1.0)
v: 4.6 Mesa 20.3.4 direct render: Yes
Device-1: AMD Vega 20 HDMI Audio [Radeon VII] driver: snd_hda_intel
v: kernel bus-ID: 2f:00.1 chip-ID: 1002:ab20 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 31:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-3: Bose Bose USB Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-4.2:3 chip-ID: 05a7:1020
class-ID: 0300
Sound Server-1: ALSA v: k5.11.6-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.23 running: no
Device-1: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel port: f000 bus-ID: 27:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp39s0 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: f000
bus-ID: 28:00.0 chip-ID: 8086:2723 class-ID: 0280
IF-ID-1: br10 state: down mac: <filter>
IF-ID-2: pan1 state: down mac: <filter>
IP v4: <filter> scope: global
IF-ID-3: wg1 state: unknown speed: N/A duplex: N/A mac: N/A
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:2
Message: No LVM data was found.
Local Storage: total: 5.57 TiB used: 1.35 TiB (24.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: Rocket 4.0 1TB
lanes: 4 rotation: SSD serial: <filter> rev: RKT401.2 temp: 30.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: A-Data model: SU650NS38 size: 111.79 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD
serial: <filter> rev: 202a scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Seagate model: BUP Slim BL
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
serial: <filter> rev: 0107 scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Western Digital
model: WD My Book 25EE size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B serial: <filter> rev: 4009 scheme: GPT
ID-1: / raw-size: 111.79 GiB size: 109.53 GiB (97.98%)
used: 66.38 GiB (60.6%) fs: ext4 block-size: 4096 B dev: /dev/sda1
maj-min: 8:1 label: N/A uuid: f55d4adf-49b2-422b-b6ff-1cdc34e31ec3
ID-2: /run/media/kds/WD 4TB raw-size: 3.64 TiB size: 3.64 TiB (100.00%)
used: 1.28 TiB (35.3%) fs: ntfs block-size: 4096 B dev: /dev/sdc1
maj-min: 8:33 label: WD 4TB uuid: 01D68FBDCF67DE10
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
uuid: 8ADF-ABF3
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: N/A label: N/A
uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 930.9 GiB fs: ntfs
label: Sabrent_m2 uuid: 067A0C297A0C17D7
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 505 MiB fs: ntfs label: N/A
uuid: E81E0D2A1E0CF37C
ID-5: /dev/sdb1 maj-min: 8:17 size: 931.51 GiB fs: ntfs
label: Kim's 1T Movies uuid: 1A80F61480F5F5DB
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Device-1: 1-4:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Device-1: 2-1:2 info: Western Digital My Book 25EE type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s power: 8mA
chip-ID: 1058:25ee class-ID: 0806 serial: <filter>
Device-2: 2-2:3 info: Seagate RSS LLC Backup Plus Slim Portable Drive 1 TB
type: Mass Storage driver: uas interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 896mA chip-ID: 0bc2:ab26 class-ID: 0806 serial: <filter>
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Hub-4: 3-3:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 3-3.3:4 info: EVGA USB Keyboard type: Keyboard,Mouse
power: 100mA chip-ID: 3842:2001 class-ID: 0301
Device-2: 3-4:19 info: Samsung Galaxy A5 (MTP) type: Still Imaging
driver: usbfs interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 64mA
chip-ID: 04e8:6860 class-ID: 0601 serial: <filter>
Device-3: 3-5:3 info: Micro Star MYSTIC LIGHT type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 1462:7c35 class-ID: 0300 serial: <filter>
Hub-5: 3-6:5 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-7: 4-3:2 info: Genesys Logic Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 05e3:0612 class-ID: 0900
Hub-8: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-9: 5-4:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
Device-1: 5-4.2:3 info: Bose Bose USB Audio type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.0
speed: 12 Mb/s chip-ID: 05a7:1020 class-ID: 0300
Hub-10: 5-4.4:4 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
Hub-11: 5-4.4.4:5 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
Device-1: 5-4.4.4.3:6 info: Microdia USB Keyboard type: Keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 0c45:7603 class-ID: 0301
Device-2: 5-4.4.4.4:7 info: Pixart Imaging Gaming Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 093a:2530 class-ID: 0301
Hub-12: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-13: 6-4:2 info: Genesys Logic USB3.1 Hub ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 05e3:0620 class-ID: 0900
Device-1: 6-4.3:3 info: ATECH FLASH USB3.0 Media Reader type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 800mA
chip-ID: 11b0:6348 class-ID: 0806 serial: <filter>
Hub-14: 6-4.4:4 info: Genesys Logic USB3.1 Hub ports: 4 rev: 3.1
speed: 5 Gb/s chip-ID: 05e3:0620 class-ID: 0900
Hub-15: 6-4.4.4:5 info: Genesys Logic USB3.1 Hub ports: 4 rev: 3.1
System Temperatures: cpu: 53.9 C mobo: N/A gpu: amdgpu temp: 34.0 C
mem: 34.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 846
Processes: 591 Uptime: 6h 08m wakeups: 0 Init: systemd v: 247
tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: 1446
pacman: 1426 lib: 412 flatpak: 7 snap: 13 Shell: Bash (sudo) v: 5.1.0
running-in: terminator inxi: 3.3.03
The contents of system-auth are:
auth required pam_faillock.so preauth
# Optionally use requisite above if you do not want to prompt for the password
# on locked accounts.
auth [success=2 default=ignore] pam_unix.so try_first_pass nullok
-auth [success=1 default=ignore] pam_systemd_home.so
auth [default=die] pam_faillock.so authfail
auth optional pam_permit.so
auth required pam_env.so
auth required pam_faillock.so authsucc
# If you drop the above call to pam_faillock.so the lock will be done also
# on non-consecutive authentication failures.
-account [success=1 default=ignore] pam_systemd_home.so
account required pam_unix.so
account optional pam_permit.so
account required pam_time.so
-password [success=1 default=ignore] pam_systemd_home.so
password required pam_unix.so try_first_pass nullok shadow
password optional pam_permit.so
session required pam_limits.so
session required pam_unix.so
session optional pam_permit.so
The output of faillog is:
sudo faillog --user=kds
faillog: Cannot open /var/log/faillog: No such file or directory
What do I do now?
omano
21 March 2021 01:46
4
Make your terminal output readable as per the instruction in the thread linked above. Edit your message and select the terminal output in your message and click the </> button. Without doing that it makes it hard on the eye and most people like me will not even bother trying to help.
av8r
22 March 2021 01:13
6
Thank you very much for fixing that for me, and it’s duly noted!
I will try your solution. and report back.
as far as I know, all I did was “sudo pacman -Syyu” and on the next reboot, it started happening.
but I’m sure I must have done something else wrong.
the only other thing I’ve been trying to do is to make rclone mount automatically on startup, and have wireguard start automatically on startup as well. but no luck with that yet. I might have to make a different post on that. but I have not been doing anything in the /var/directorie
av8r
22 March 2021 01:47
7
I tried your solution, but nothing has changed. I still have to wait 10 min on startup and it’s telling me my passcode is wrong but works after 10 minutes.
These are the new results after trying your solution fabby.
What are the contents of /etc/pam.d/system-auth
#%PAM-1.0
Output of sudo faillog --user=kds
Login Failures Maximum Latest On
kds 0 0 12/31/69 18:00:00 -0600
Do you have any other tricks or tips to help me remedy this problem? I really apreachiate all y’alls help!
Fabby
22 March 2021 09:35
8
Can you log into TTY2 as a first logon without these problems???
This is weird!
av8r
22 March 2021 15:37
9
I had to duckduckgo how to get in to TTY2 (Ctrl+Alt+F2) I hope that’s correct?
but the results are the same when I type in my username and hit Enter, it tells me I have had 3 failed login attempts and need to wait 10 min. I can still type in my passcode but I have to wait the 10min before it lets me log-in.
Do you have any other ideas?
Fabby
22 March 2021 21:19
10
Does this also happen when you create a new user and log in there (E.G. kds2)
This (failed attempts) should appear in the system log.
journalctl -r
in dmesg as well
sudo dmesg
but this will not work - because of the timeout - but after the timeout, it will work and it will look something like:
audit: type=1100 audit(1616448955.656:223): pid=8000 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=? acct="username" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=failed'`
Are there messages to that effect?
If there are - and you didn’t do it … there is something fishy going on.
av8r
23 March 2021 00:13
12
@Fabby I made a new user profile and it works like a charm there. No wait 10 min to log in.
I have not tried with a new user. I’m going to read up on how to make one and test that.
av8r
23 March 2021 02:09
13
Hi Nachlese, thank you for trying to help me with this problem. this will be in a few post seeing that all the audit lines from journlctl -r is massive.
these are all the audit lines from sudo dmesg:
[ 0.343712] audit: initializing netlink subsys (disabled)
[ 0.343716] audit: type=2000 audit(1616439499.199:1): state=initialized audit_enabled=0 res=1
[ 2.433930] audit: type=1400 audit(1616457502.354:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="firejail-default" pid=528 comm="apparmor_parser"
[ 2.449454] audit: type=1400 audit(1616457502.371:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=523 comm="apparmor_parser"
[ 2.470399] audit: type=1400 audit(1616457502.391:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=522 comm="apparmor_parser"
[ 2.471078] audit: type=1400 audit(1616457502.391:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=522 comm="apparmor_parser"
[ 2.484068] audit: type=1400 audit(1616457502.404:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="mysqld_akonadi" pid=529 comm="apparmor_parser"
[ 2.485439] audit: type=1400 audit(1616457502.404:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="postgresql_akonadi" pid=527 comm="apparmor_parser"
[ 2.496689] audit: type=1400 audit(1616457502.417:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/akonadiserver" pid=524 comm="apparmor_parser"
[ 2.497809] audit: type=1400 audit(1616457502.417:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-script-login" pid=530 comm="apparmor_parser"
[ 2.504301] audit: type=1400 audit(1616457502.424:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="mariadbd_akonadi" pid=526 comm="apparmor_parser"
[ 5.586000] kauditd_printk_skb: 178 callbacks suppressed
[ 5.586004] audit: type=1130 audit(1616457505.507:79): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.592555] audit: type=1127 audit(1616457505.511:80): pid=1660 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
[ 5.596091] audit: type=1130 audit(1616457505.517:81): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.600816] audit: type=1130 audit(1616457505.521:82): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journal-catalog-update comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.630287] audit: type=1130 audit(1616457505.551:83): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.688224] audit: type=1130 audit(1616457505.607:84): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ldconfig comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.691958] audit: type=1130 audit(1616457505.611:85): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-update-done comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.696966] audit: type=1130 audit(1616457505.617:86): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.699534] audit: type=1130 audit(1616457505.621:87): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.704634] audit: type=1334 audit(1616457505.624:88): prog-id=7 op=LOAD
[ 11.930883] kauditd_printk_skb: 205 callbacks suppressed
[ 11.930888] audit: type=1131 audit(1616457511.851:188): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 12.153427] audit: type=1130 audit(1616457512.074:189): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 12.153436] audit: type=1131 audit(1616457512.074:190): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 12.154411] audit: type=1130 audit(1616457512.074:191): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 12.166963] audit: type=1100 audit(1616457512.087:192): pid=2300 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 13.924971] audit: type=1131 audit(1616457513.844:193): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 14.153430] audit: type=1130 audit(1616457514.074:194): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 14.153440] audit: type=1131 audit(1616457514.074:195): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 14.154439] audit: type=1130 audit(1616457514.074:196): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 14.166695] audit: type=1100 audit(1616457514.087:197): pid=2303 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 17.115876] kauditd_printk_skb: 7 callbacks suppressed
[ 17.115881] audit: type=1112 audit(1616457517.034:205): pid=2264 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=login acct="kds" exe="/usr/bin/lightdm" hostname=kds-Ryzen addr=? terminal=/dev/tty7 res=failed'
[ 18.390408] audit: type=1131 audit(1616457518.311:206): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 18.653707] audit: type=1130 audit(1616457518.574:207): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 18.653717] audit: type=1131 audit(1616457518.574:208): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 18.654872] audit: type=1130 audit(1616457518.574:209): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 18.666265] audit: type=1100 audit(1616457518.587:210): pid=2310 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 20.248237] audit: type=1131 audit(1616457520.167:211): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 20.403436] audit: type=1130 audit(1616457520.324:212): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 20.403444] audit: type=1131 audit(1616457520.324:213): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 20.404469] audit: type=1130 audit(1616457520.324:214): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 22.604414] kauditd_printk_skb: 1 callbacks suppressed
[ 22.604419] audit: type=1131 audit(1616457522.524:216): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 22.903286] audit: type=1130 audit(1616457522.824:217): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 22.903293] audit: type=1131 audit(1616457522.824:218): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 22.904642] audit: type=1130 audit(1616457522.824:219): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 22.917027] audit: type=1100 audit(1616457522.837:220): pid=2316 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 24.715005] audit: type=1131 audit(1616457524.634:221): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 24.903732] audit: type=1130 audit(1616457524.824:222): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 24.903741] audit: type=1131 audit(1616457524.824:223): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 24.905150] audit: type=1130 audit(1616457524.824:224): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 24.918213] audit: type=1100 audit(1616457524.837:225): pid=2319 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 28.930987] kauditd_printk_skb: 5 callbacks suppressed
[ 28.930991] audit: type=1131 audit(1616457528.851:231): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 29.153765] audit: type=1130 audit(1616457529.074:232): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 29.153771] audit: type=1131 audit(1616457529.074:233): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 29.154953] audit: type=1130 audit(1616457529.074:234): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 29.166288] audit: type=1100 audit(1616457529.087:235): pid=2325 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 30.924294] audit: type=1131 audit(1616457530.844:236): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 31.153752] audit: type=1130 audit(1616457531.074:237): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 31.153757] audit: type=1131 audit(1616457531.074:238): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 31.154975] audit: type=1130 audit(1616457531.074:239): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 31.167148] audit: type=1100 audit(1616457531.087:240): pid=2328 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 35.390587] kauditd_printk_skb: 5 callbacks suppressed
[ 35.390591] audit: type=1131 audit(1616457535.311:246): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 35.653786] audit: type=1130 audit(1616457535.574:247): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 35.653792] audit: type=1131 audit(1616457535.574:248): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 35.654947] audit: type=1130 audit(1616457535.574:249): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 35.666603] audit: type=1100 audit(1616457535.587:250): pid=2334 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 36.044627] audit: type=1131 audit(1616457535.964:251): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 36.159786] audit: type=1334 audit(1616457536.081:252): prog-id=12 op=UNLOAD
[ 36.159792] audit: type=1334 audit(1616457536.081:253): prog-id=11 op=UNLOAD
[ 36.912816] audit: type=1131 audit(1616457536.834:254): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 37.153695] audit: type=1130 audit(1616457537.074:255): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 41.631086] kauditd_printk_skb: 8 callbacks suppressed
[ 41.631090] audit: type=1131 audit(1616457541.551:264): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 41.903551] audit: type=1130 audit(1616457541.824:265): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 41.903558] audit: type=1131 audit(1616457541.824:266): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 41.904292] audit: type=1130 audit(1616457541.824:267): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 41.916336] audit: type=1100 audit(1616457541.837:268): pid=2346 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 43.322440] audit: type=1131 audit(1616457543.241:269): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 43.653536] audit: type=1130 audit(1616457543.574:270): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 43.653542] audit: type=1131 audit(1616457543.574:271): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 43.654280] audit: type=1130 audit(1616457543.574:272): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 43.666142] audit: type=1100 audit(1616457543.587:273): pid=2349 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 47.870617] kauditd_printk_skb: 5 callbacks suppressed
[ 47.870621] audit: type=1131 audit(1616457547.791:279): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 48.153695] audit: type=1130 audit(1616457548.074:280): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 48.153701] audit: type=1131 audit(1616457548.074:281): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 48.154840] audit: type=1130 audit(1616457548.074:282): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 48.166687] audit: type=1100 audit(1616457548.087:283): pid=2355 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 50.200462] audit: type=1131 audit(1616457550.121:284): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 50.403684] audit: type=1130 audit(1616457550.324:285): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 50.403691] audit: type=1131 audit(1616457550.324:286): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 50.404812] audit: type=1130 audit(1616457550.324:287): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 50.416887] audit: type=1100 audit(1616457550.337:288): pid=2358 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 52.903147] kauditd_printk_skb: 1 callbacks suppressed
[ 52.903150] audit: type=1130 audit(1616457552.824:290): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 52.903155] audit: type=1131 audit(1616457552.824:291): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 52.904221] audit: type=1130 audit(1616457552.824:292): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 52.916716] audit: type=1100 audit(1616457552.837:293): pid=2361 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 55.166082] audit: type=1131 audit(1616457555.087:294): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 55.403698] audit: type=1130 audit(1616457555.324:295): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 55.403705] audit: type=1131 audit(1616457555.324:296): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 55.404849] audit: type=1130 audit(1616457555.324:297): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 55.416702] audit: type=1100 audit(1616457555.337:298): pid=2364 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 57.410420] audit: type=1131 audit(1616457557.331:299): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 59.600727] kauditd_printk_skb: 4 callbacks suppressed
[ 59.600732] audit: type=1131 audit(1616457559.521:304): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 59.903689] audit: type=1130 audit(1616457559.824:305): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 59.903696] audit: type=1131 audit(1616457559.824:306): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 59.904858] audit: type=1130 audit(1616457559.824:307): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 59.916706] audit: type=1100 audit(1616457559.837:308): pid=2370 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 61.795003] audit: type=1131 audit(1616457561.714:309): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 61.903725] audit: type=1130 audit(1616457561.824:310): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 61.903731] audit: type=1131 audit(1616457561.824:311): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 61.904946] audit: type=1130 audit(1616457561.824:312): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 61.916534] audit: type=1100 audit(1616457561.837:313): pid=2373 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 66.010646] kauditd_printk_skb: 5 callbacks suppressed
[ 66.010650] audit: type=1131 audit(1616457565.931:319): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 66.153726] audit: type=1130 audit(1616457566.074:320): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 66.153733] audit: type=1131 audit(1616457566.074:321): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 66.154960] audit: type=1130 audit(1616457566.074:322): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 66.166881] audit: type=1100 audit(1616457566.087:323): pid=2379 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 68.005260] audit: type=1131 audit(1616457567.924:324): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 68.153750] audit: type=1130 audit(1616457568.074:325): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 68.153758] audit: type=1131 audit(1616457568.074:326): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 68.155254] audit: type=1130 audit(1616457568.074:327): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 68.165832] audit: type=1100 audit(1616457568.084:328): pid=2382 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 72.221001] kauditd_printk_skb: 5 callbacks suppressed
[ 72.221005] audit: type=1131 audit(1616457572.141:334): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 72.403731] audit: type=1130 audit(1616457572.324:335): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 72.403738] audit: type=1131 audit(1616457572.324:336): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 72.404982] audit: type=1130 audit(1616457572.324:337): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 72.418313] audit: type=1100 audit(1616457572.337:338): pid=2388 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 74.080931] audit: type=1131 audit(1616457574.001:339): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 74.403734] audit: type=1130 audit(1616457574.324:340): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 74.403745] audit: type=1131 audit(1616457574.324:341): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 74.404999] audit: type=1130 audit(1616457574.324:342): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 74.416936] audit: type=1100 audit(1616457574.337:343): pid=2391 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 79.126871] kauditd_printk_skb: 5 callbacks suppressed
[ 79.126873] audit: type=1131 audit(1616457579.047:349): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 79.403729] audit: type=1130 audit(1616457579.324:350): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 79.403735] audit: type=1131 audit(1616457579.324:351): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 79.404997] audit: type=1130 audit(1616457579.324:352): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 79.416881] audit: type=1100 audit(1616457579.337:353): pid=2397 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 81.039624] audit: type=1131 audit(1616457580.961:354): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 81.153535] audit: type=1130 audit(1616457581.074:355): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 81.153550] audit: type=1131 audit(1616457581.074:356): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 81.154818] audit: type=1130 audit(1616457581.074:357): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 81.166789] audit: type=1100 audit(1616457581.087:358): pid=2400 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 85.755460] kauditd_printk_skb: 5 callbacks suppressed
[ 85.755463] audit: type=1131 audit(1616457585.674:364): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 85.903730] audit: type=1130 audit(1616457585.824:365): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 85.903737] audit: type=1131 audit(1616457585.824:366): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 85.904969] audit: type=1130 audit(1616457585.824:367): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 85.916859] audit: type=1100 audit(1616457585.837:368): pid=2406 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 88.031050] audit: type=1131 audit(1616457587.951:369): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 88.153532] audit: type=1130 audit(1616457588.074:370): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 88.153543] audit: type=1131 audit(1616457588.074:371): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 88.154799] audit: type=1130 audit(1616457588.074:372): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 88.166775] audit: type=1100 audit(1616457588.087:373): pid=2409 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 90.903713] kauditd_printk_skb: 1 callbacks suppressed
[ 90.903717] audit: type=1130 audit(1616457590.824:375): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 90.903721] audit: type=1131 audit(1616457590.824:376): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 90.904970] audit: type=1130 audit(1616457590.824:377): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 90.916724] audit: type=1100 audit(1616457590.837:378): pid=2412 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 92.715361] audit: type=1131 audit(1616457592.634:379): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 92.903725] audit: type=1130 audit(1616457592.824:380): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 92.903732] audit: type=1131 audit(1616457592.824:381): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 92.904973] audit: type=1130 audit(1616457592.824:382): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 92.916808] audit: type=1100 audit(1616457592.837:383): pid=2415 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 94.991154] audit: type=1131 audit(1616457594.911:384): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 96.655315] kauditd_printk_skb: 4 callbacks suppressed
[ 96.655319] audit: type=1131 audit(1616457596.574:389): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 96.903730] audit: type=1130 audit(1616457596.824:390): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 96.903737] audit: type=1131 audit(1616457596.824:391): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 96.904998] audit: type=1130 audit(1616457596.824:392): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 96.916697] audit: type=1100 audit(1616457596.837:393): pid=2421 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 98.539401] audit: type=1131 audit(1616457598.461:394): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 98.653722] audit: type=1130 audit(1616457598.574:395): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 98.653729] audit: type=1131 audit(1616457598.574:396): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 98.654981] audit: type=1130 audit(1616457598.574:397): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 98.668334] audit: type=1100 audit(1616457598.587:398): pid=2424 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 103.422734] kauditd_printk_skb: 5 callbacks suppressed
[ 103.422738] audit: type=1131 audit(1616457603.344:404): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 103.653788] audit: type=1130 audit(1616457603.574:405): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 103.653795] audit: type=1131 audit(1616457603.574:406): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 103.655049] audit: type=1130 audit(1616457603.574:407): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 103.667061] audit: type=1100 audit(1616457603.587:408): pid=2430 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 105.585527] audit: type=1131 audit(1616457605.504:409): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 105.903762] audit: type=1130 audit(1616457605.824:410): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 105.903774] audit: type=1131 audit(1616457605.824:411): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 105.905028] audit: type=1130 audit(1616457605.824:412): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 105.916423] audit: type=1100 audit(1616457605.837:413): pid=2433 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 108.442006] audit: type=1131 audit(1616457608.361:414): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 108.653732] audit: type=1130 audit(1616457608.574:415): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 108.653739] audit: type=1131 audit(1616457608.574:416): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 108.655024] audit: type=1130 audit(1616457608.574:417): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 108.666785] audit: type=1100 audit(1616457608.587:418): pid=2436 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 110.269470] audit: type=1131 audit(1616457610.191:419): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 110.403512] audit: type=1130 audit(1616457610.324:420): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 110.403522] audit: type=1131 audit(1616457610.324:421): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 110.404752] audit: type=1130 audit(1616457610.324:422): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 110.416722] audit: type=1100 audit(1616457610.337:423): pid=2439 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 114.902301] kauditd_printk_skb: 5 callbacks suppressed
[ 114.902305] audit: type=1131 audit(1616457614.821:429): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 115.153736] audit: type=1130 audit(1616457615.074:430): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 115.153743] audit: type=1131 audit(1616457615.074:431): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 115.155007] audit: type=1130 audit(1616457615.074:432): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 115.166712] audit: type=1100 audit(1616457615.087:433): pid=2445 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 117.065250] audit: type=1131 audit(1616457616.984:434): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 117.403714] audit: type=1130 audit(1616457617.324:435): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 117.403721] audit: type=1131 audit(1616457617.324:436): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 117.405059] audit: type=1130 audit(1616457617.324:437): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 117.416998] audit: type=1100 audit(1616457617.337:438): pid=2448 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 119.903737] kauditd_printk_skb: 1 callbacks suppressed
[ 119.903741] audit: type=1130 audit(1616457619.824:440): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 119.903745] audit: type=1131 audit(1616457619.824:441): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 119.904994] audit: type=1130 audit(1616457619.824:442): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 119.916266] audit: type=1100 audit(1616457619.837:443): pid=2451 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 122.030610] audit: type=1131 audit(1616457621.951:444): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 122.153544] audit: type=1130 audit(1616457622.074:445): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 122.153554] audit: type=1131 audit(1616457622.074:446): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 122.154819] audit: type=1130 audit(1616457622.074:447): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 122.166907] audit: type=1100 audit(1616457622.087:448): pid=2454 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 124.025464] audit: type=1131 audit(1616457623.944:449): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 126.235420] kauditd_printk_skb: 4 callbacks suppressed
[ 126.235423] audit: type=1131 audit(1616457626.154:454): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=libvirtd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 126.968239] audit: type=1131 audit(1616457626.887:455): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 127.153665] audit: type=1130 audit(1616457627.074:456): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 127.153672] audit: type=1131 audit(1616457627.074:457): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 127.154906] audit: type=1130 audit(1616457627.074:458): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 127.166964] audit: type=1100 audit(1616457627.087:459): pid=2461 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 129.045473] audit: type=1131 audit(1616457628.964:460): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 129.153487] audit: type=1130 audit(1616457629.074:461): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 129.153494] audit: type=1131 audit(1616457629.074:462): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 129.154746] audit: type=1130 audit(1616457629.074:463): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 131.321172] kauditd_printk_skb: 1 callbacks suppressed
[ 131.321176] audit: type=1131 audit(1616457631.241:465): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 131.653675] audit: type=1130 audit(1616457631.574:466): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 131.653681] audit: type=1131 audit(1616457631.574:467): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 131.654924] audit: type=1130 audit(1616457631.574:468): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 131.669262] audit: type=1100 audit(1616457631.591:469): pid=2467 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 133.763722] audit: type=1131 audit(1616457633.684:470): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 133.903677] audit: type=1130 audit(1616457633.824:471): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 133.903684] audit: type=1131 audit(1616457633.824:472): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 133.904953] audit: type=1130 audit(1616457633.824:473): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 133.916850] audit: type=1100 audit(1616457633.837:474): pid=2470 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 138.226938] kauditd_printk_skb: 5 callbacks suppressed
[ 138.226942] audit: type=1131 audit(1616457638.147:480): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 138.403627] audit: type=1130 audit(1616457638.324:481): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 138.403634] audit: type=1131 audit(1616457638.324:482): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 138.404879] audit: type=1130 audit(1616457638.324:483): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 138.416658] audit: type=1100 audit(1616457638.337:484): pid=2476 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 140.139654] audit: type=1131 audit(1616457640.061:485): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 140.403667] audit: type=1130 audit(1616457640.324:486): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 140.403674] audit: type=1131 audit(1616457640.324:487): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 140.405019] audit: type=1130 audit(1616457640.324:488): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 140.416766] audit: type=1100 audit(1616457640.337:489): pid=2479 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 145.522732] kauditd_printk_skb: 5 callbacks suppressed
[ 145.522736] audit: type=1131 audit(1616457645.444:495): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 145.653660] audit: type=1130 audit(1616457645.574:496): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 145.653667] audit: type=1131 audit(1616457645.574:497): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 145.654913] audit: type=1130 audit(1616457645.574:498): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 145.668199] audit: type=1100 audit(1616457645.587:499): pid=2485 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 147.350692] audit: type=1131 audit(1616457647.271:500): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 147.653669] audit: type=1130 audit(1616457647.574:501): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 147.653676] audit: type=1131 audit(1616457647.574:502): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 147.654881] audit: type=1130 audit(1616457647.574:503): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 147.666936] audit: type=1100 audit(1616457647.587:504): pid=2488 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 152.119774] kauditd_printk_skb: 5 callbacks suppressed
[ 152.119778] audit: type=1131 audit(1616457652.041:510): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 152.403661] audit: type=1130 audit(1616457652.324:511): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 152.403667] audit: type=1131 audit(1616457652.324:512): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 152.404884] audit: type=1130 audit(1616457652.324:513): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 152.416913] audit: type=1100 audit(1616457652.337:514): pid=2494 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 154.395565] audit: type=1131 audit(1616457654.314:515): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 154.653658] audit: type=1130 audit(1616457654.574:516): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 154.653665] audit: type=1131 audit(1616457654.574:517): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 154.654942] audit: type=1130 audit(1616457654.574:518): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 154.669137] audit: type=1100 audit(1616457654.587:519): pid=2497 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 157.255171] audit: type=1131 audit(1616457657.174:520): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 157.403665] audit: type=1130 audit(1616457657.324:521): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 157.403672] audit: type=1131 audit(1616457657.324:522): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 157.404925] audit: type=1130 audit(1616457657.324:523): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 157.416875] audit: type=1100 audit(1616457657.337:524): pid=2500 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 159.079702] audit: type=1131 audit(1616457659.001:525): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 159.403648] audit: type=1130 audit(1616457659.324:526): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 159.403654] audit: type=1131 audit(1616457659.324:527): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 159.404886] audit: type=1130 audit(1616457659.324:528): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 159.417182] audit: type=1100 audit(1616457659.337:529): pid=2503 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 163.849565] kauditd_printk_skb: 5 callbacks suppressed
[ 163.849569] audit: type=1131 audit(1616457663.771:535): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 164.153655] audit: type=1130 audit(1616457664.074:536): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 164.153662] audit: type=1131 audit(1616457664.074:537): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 164.154885] audit: type=1130 audit(1616457664.074:538): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 164.166810] audit: type=1100 audit(1616457664.087:539): pid=2514 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 166.125519] audit: type=1131 audit(1616457666.044:540): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 166.403653] audit: type=1130 audit(1616457666.324:541): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 166.403660] audit: type=1131 audit(1616457666.324:542): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 166.404890] audit: type=1130 audit(1616457666.324:543): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 166.417986] audit: type=1100 audit(1616457666.337:544): pid=2517 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 168.983679] audit: type=1131 audit(1616457668.904:545): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 169.153590] audit: type=1130 audit(1616457669.074:546): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 169.153597] audit: type=1131 audit(1616457669.074:547): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 169.154844] audit: type=1130 audit(1616457669.074:548): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 169.166933] audit: type=1100 audit(1616457669.087:549): pid=2520 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 171.145644] audit: type=1131 audit(1616457671.064:550): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 171.403670] audit: type=1130 audit(1616457671.324:551): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 171.403677] audit: type=1131 audit(1616457671.324:552): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 171.404908] audit: type=1130 audit(1616457671.324:553): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 171.416942] audit: type=1100 audit(1616457671.337:554): pid=2523 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 176.778523] kauditd_printk_skb: 5 callbacks suppressed
[ 176.778527] audit: type=1131 audit(1616457676.697:560): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 176.903755] audit: type=1130 audit(1616457676.824:561): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 176.903765] audit: type=1131 audit(1616457676.824:562): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 176.904993] audit: type=1130 audit(1616457676.824:563): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 176.916758] audit: type=1100 audit(1616457676.837:564): pid=2529 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 178.855454] audit: type=1131 audit(1616457678.774:565): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 179.153700] audit: type=1130 audit(1616457679.074:566): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 179.153707] audit: type=1131 audit(1616457679.074:567): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 179.154939] audit: type=1130 audit(1616457679.074:568): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 179.166651] audit: type=1100 audit(1616457679.087:569): pid=2532 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 183.625530] kauditd_printk_skb: 5 callbacks suppressed
[ 183.625533] audit: type=1131 audit(1616457683.544:575): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 183.903673] audit: type=1130 audit(1616457683.824:576): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 183.903686] audit: type=1131 audit(1616457683.824:577): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 183.905037] audit: type=1130 audit(1616457683.824:578): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 183.916310] audit: type=1100 audit(1616457683.837:579): pid=2538 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 186.150459] audit: type=1131 audit(1616457686.071:580): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 186.403686] audit: type=1130 audit(1616457686.324:581): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 186.403696] audit: type=1131 audit(1616457686.324:582): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 186.404878] audit: type=1130 audit(1616457686.324:583): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 186.416185] audit: type=1100 audit(1616457686.337:584): pid=2541 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 188.653687] kauditd_printk_skb: 1 callbacks suppressed
[ 188.653692] audit: type=1130 audit(1616457688.574:586): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 188.653699] audit: type=1131 audit(1616457688.574:587): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 188.654899] audit: type=1130 audit(1616457688.574:588): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 188.666509] audit: type=1100 audit(1616457688.587:589): pid=2544 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 190.585256] audit: type=1131 audit(1616457690.504:590): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 190.903677] audit: type=1130 audit(1616457690.824:591): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 190.903685] audit: type=1131 audit(1616457690.824:592): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 190.905125] audit: type=1130 audit(1616457690.824:593): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 190.916560] audit: type=1100 audit(1616457690.837:594): pid=2547 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 193.111087] audit: type=1131 audit(1616457693.031:595): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 195.691110] kauditd_printk_skb: 4 callbacks suppressed
[ 195.691113] audit: type=1131 audit(1616457695.611:600): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 195.903679] audit: type=1130 audit(1616457695.824:601): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 195.903687] audit: type=1131 audit(1616457695.824:602): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 195.905122] audit: type=1130 audit(1616457695.824:603): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 195.916924] audit: type=1100 audit(1616457695.837:604): pid=2553 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 198.131691] audit: type=1131 audit(1616457698.051:605): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 198.403672] audit: type=1130 audit(1616457698.324:606): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 198.403680] audit: type=1131 audit(1616457698.324:607): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 198.405121] audit: type=1130 audit(1616457698.324:608): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 198.416618] audit: type=1100 audit(1616457698.337:609): pid=2556 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 202.565801] kauditd_printk_skb: 5 callbacks suppressed
[ 202.565805] audit: type=1131 audit(1616457702.484:615): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 202.903640] audit: type=1130 audit(1616457702.824:616): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 202.903650] audit: type=1131 audit(1616457702.824:617): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 202.904858] audit: type=1130 audit(1616457702.824:618): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 202.917184] audit: type=1100 audit(1616457702.837:619): pid=2562 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 204.760338] audit: type=1131 audit(1616457704.681:620): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 204.903486] audit: type=1130 audit(1616457704.824:621): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 204.903496] audit: type=1131 audit(1616457704.824:622): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 204.904722] audit: type=1130 audit(1616457704.824:623): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 204.917002] audit: type=1100 audit(1616457704.837:624): pid=2565 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 208.975865] kauditd_printk_skb: 5 callbacks suppressed
[ 208.975869] audit: type=1131 audit(1616457708.894:630): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 209.153654] audit: type=1130 audit(1616457709.074:631): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 209.153664] audit: type=1131 audit(1616457709.074:632): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 209.154884] audit: type=1130 audit(1616457709.074:633): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 209.166735] audit: type=1100 audit(1616457709.087:634): pid=2571 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 211.637200] audit: type=1131 audit(1616457711.557:635): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 211.903644] audit: type=1130 audit(1616457711.824:636): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 211.903653] audit: type=1131 audit(1616457711.824:637): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 211.904876] audit: type=1130 audit(1616457711.824:638): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 211.916984] audit: type=1100 audit(1616457711.837:639): pid=2574 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 215.935980] kauditd_printk_skb: 5 callbacks suppressed
[ 215.935985] audit: type=1131 audit(1616457715.857:645): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 216.153652] audit: type=1130 audit(1616457716.074:646): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 216.153663] audit: type=1131 audit(1616457716.074:647): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 216.154881] audit: type=1130 audit(1616457716.074:648): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 216.166539] audit: type=1100 audit(1616457716.087:649): pid=2580 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 217.929670] audit: type=1131 audit(1616457717.851:650): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 218.153666] audit: type=1130 audit(1616457718.074:651): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 218.153675] audit: type=1131 audit(1616457718.074:652): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 218.154909] audit: type=1130 audit(1616457718.074:653): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 218.167022] audit: type=1100 audit(1616457718.087:654): pid=2583 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 223.063557] kauditd_printk_skb: 5 callbacks suppressed
[ 223.063562] audit: type=1131 audit(1616457722.984:660): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 223.403644] audit: type=1130 audit(1616457723.324:661): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 223.403654] audit: type=1131 audit(1616457723.324:662): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 223.404867] audit: type=1130 audit(1616457723.324:663): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 223.417160] audit: type=1100 audit(1616457723.337:664): pid=2589 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 225.140492] audit: type=1131 audit(1616457725.061:665): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 225.403639] audit: type=1130 audit(1616457725.324:666): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 225.403649] audit: type=1131 audit(1616457725.324:667): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 225.404878] audit: type=1130 audit(1616457725.324:668): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 225.417102] audit: type=1100 audit(1616457725.337:669): pid=2592 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 229.691800] kauditd_printk_skb: 5 callbacks suppressed
[ 229.691804] audit: type=1131 audit(1616457729.611:675): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 229.903658] audit: type=1130 audit(1616457729.824:676): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 229.903668] audit: type=1131 audit(1616457729.824:677): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 229.904914] audit: type=1130 audit(1616457729.824:678): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 229.918289] audit: type=1100 audit(1616457729.837:679): pid=2598 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 232.132633] audit: type=1131 audit(1616457732.054:680): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 232.403650] audit: type=1130 audit(1616457732.324:681): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 232.403659] audit: type=1131 audit(1616457732.324:682): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 232.404847] audit: type=1130 audit(1616457732.324:683): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 232.416635] audit: type=1100 audit(1616457732.337:684): pid=2601 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 235.042823] audit: type=1131 audit(1616457734.964:685): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 235.153459] audit: type=1130 audit(1616457735.074:686): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 235.153469] audit: type=1131 audit(1616457735.074:687): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 235.154699] audit: type=1130 audit(1616457735.074:688): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 235.167081] audit: type=1100 audit(1616457735.087:689): pid=2604 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 236.538686] audit: type=1131 audit(1616457736.457:690): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 236.653648] audit: type=1130 audit(1616457736.574:691): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 236.653658] audit: type=1131 audit(1616457736.574:692): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 236.654849] audit: type=1130 audit(1616457736.574:693): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 236.668289] audit: type=1100 audit(1616457736.587:694): pid=2607 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 240.450103] kauditd_printk_skb: 5 callbacks suppressed
[ 240.450107] audit: type=1131 audit(1616457740.371:700): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 240.653657] audit: type=1130 audit(1616457740.574:701): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 240.653667] audit: type=1131 audit(1616457740.574:702): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 240.654886] audit: type=1130 audit(1616457740.574:703): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 240.666873] audit: type=1100 audit(1616457740.587:704): pid=2613 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 242.725856] audit: type=1131 audit(1616457742.644:705): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 242.903647] audit: type=1130 audit(1616457742.824:706): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 242.903657] audit: type=1131 audit(1616457742.824:707): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 242.904877] audit: type=1130 audit(1616457742.824:708): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 242.916888] audit: type=1100 audit(1616457742.837:709): pid=2616 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 247.577354] kauditd_printk_skb: 5 callbacks suppressed
[ 247.577358] audit: type=1131 audit(1616457747.497:715): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 247.903756] audit: type=1130 audit(1616457747.824:716): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 247.903766] audit: type=1131 audit(1616457747.824:717): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 247.904995] audit: type=1130 audit(1616457747.824:718): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 247.919968] audit: type=1100 audit(1616457747.841:719): pid=2622 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 249.607475] audit: type=1131 audit(1616457749.527:720): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 249.903733] audit: type=1130 audit(1616457749.824:721): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 249.903743] audit: type=1131 audit(1616457749.824:722): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 249.904956] audit: type=1130 audit(1616457749.824:723): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 249.919430] audit: type=1100 audit(1616457749.841:724): pid=2625 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 254.569039] kauditd_printk_skb: 5 callbacks suppressed
[ 254.569044] audit: type=1131 audit(1616457754.487:730): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 254.903669] audit: type=1130 audit(1616457754.824:731): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 254.903679] audit: type=1131 audit(1616457754.824:732): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 254.904894] audit: type=1130 audit(1616457754.824:733): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 254.916711] audit: type=1100 audit(1616457754.837:734): pid=2631 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 256.895685] audit: type=1131 audit(1616457756.814:735): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 257.153652] audit: type=1130 audit(1616457757.074:736): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 257.153661] audit: type=1131 audit(1616457757.074:737): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 257.154897] audit: type=1130 audit(1616457757.074:738): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 257.166753] audit: type=1100 audit(1616457757.087:739): pid=2634 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 261.084376] kauditd_printk_skb: 5 callbacks suppressed
[ 261.084380] audit: type=1131 audit(1616457761.004:745): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 261.403650] audit: type=1130 audit(1616457761.324:746): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 261.403660] audit: type=1131 audit(1616457761.324:747): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 261.404891] audit: type=1130 audit(1616457761.324:748): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 261.419700] audit: type=1100 audit(1616457761.341:749): pid=2640 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 263.027147] audit: type=1131 audit(1616457762.947:750): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 263.153567] audit: type=1130 audit(1616457763.074:751): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 263.153577] audit: type=1131 audit(1616457763.074:752): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 263.154815] audit: type=1130 audit(1616457763.074:753): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 263.166138] audit: type=1100 audit(1616457763.087:754): pid=2644 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 267.739754] kauditd_printk_skb: 5 callbacks suppressed
[ 267.739759] audit: type=1131 audit(1616457767.661:760): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 267.903506] audit: type=1130 audit(1616457767.824:761): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 267.903516] audit: type=1131 audit(1616457767.824:762): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 267.904236] audit: type=1130 audit(1616457767.824:763): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 267.916823] audit: type=1100 audit(1616457767.837:764): pid=2650 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 270.347078] audit: type=1131 audit(1616457770.267:765): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 270.653500] audit: type=1130 audit(1616457770.574:766): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 270.653512] audit: type=1131 audit(1616457770.574:767): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 270.654280] audit: type=1130 audit(1616457770.574:768): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 270.666792] audit: type=1100 audit(1616457770.587:769): pid=2653 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 274.118398] kauditd_printk_skb: 5 callbacks suppressed
[ 274.118403] audit: type=1131 audit(1616457774.037:775): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 274.403646] audit: type=1130 audit(1616457774.324:776): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 274.403656] audit: type=1131 audit(1616457774.324:777): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 274.404799] audit: type=1130 audit(1616457774.324:778): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 274.418345] audit: type=1100 audit(1616457774.337:779): pid=2659 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 276.477198] audit: type=1131 audit(1616457776.397:780): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 276.653499] audit: type=1130 audit(1616457776.574:781): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 276.653509] audit: type=1131 audit(1616457776.574:782): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 276.654310] audit: type=1130 audit(1616457776.574:783): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 276.666716] audit: type=1100 audit(1616457776.587:784): pid=2662 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 281.190662] kauditd_printk_skb: 5 callbacks suppressed
[ 281.190667] audit: type=1131 audit(1616457781.111:790): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 281.403659] audit: type=1130 audit(1616457781.324:791): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 281.403669] audit: type=1131 audit(1616457781.324:792): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 281.404825] audit: type=1130 audit(1616457781.324:793): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 281.419318] audit: type=1100 audit(1616457781.341:794): pid=2668 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 283.774093] audit: type=1131 audit(1616457783.694:795): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 283.903494] audit: type=1130 audit(1616457783.824:796): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 283.903504] audit: type=1131 audit(1616457783.824:797): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 283.904315] audit: type=1130 audit(1616457783.824:798): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 283.916606] audit: type=1100 audit(1616457783.837:799): pid=2671 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 287.569145] kauditd_printk_skb: 5 callbacks suppressed
[ 287.569150] audit: type=1131 audit(1616457787.487:805): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 287.903500] audit: type=1130 audit(1616457787.824:806): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 287.903510] audit: type=1131 audit(1616457787.824:807): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 287.904294] audit: type=1130 audit(1616457787.824:808): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 287.916776] audit: type=1100 audit(1616457787.837:809): pid=2677 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 290.427235] audit: type=1131 audit(1616457790.347:810): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 290.653501] audit: type=1130 audit(1616457790.574:811): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 290.653510] audit: type=1131 audit(1616457790.574:812): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 290.654297] audit: type=1130 audit(1616457790.574:813): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 290.666497] audit: type=1100 audit(1616457790.587:814): pid=2680 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 292.589889] audit: type=1131 audit(1616457792.511:815): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 292.903647] audit: type=1130 audit(1616457792.824:816): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 292.903655] audit: type=1131 audit(1616457792.824:817): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 292.905054] audit: type=1130 audit(1616457792.824:818): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 292.916695] audit: type=1100 audit(1616457792.837:819): pid=2683 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 294.780123] audit: type=1131 audit(1616457794.701:820): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 294.903316] audit: type=1130 audit(1616457794.824:821): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 294.903324] audit: type=1131 audit(1616457794.824:822): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 294.904134] audit: type=1130 audit(1616457794.824:823): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 294.916759] audit: type=1100 audit(1616457794.837:824): pid=2686 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 298.078453] kauditd_printk_skb: 5 callbacks suppressed
[ 298.078457] audit: type=1131 audit(1616457797.997:830): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 298.403721] audit: type=1130 audit(1616457798.324:831): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 298.403729] audit: type=1131 audit(1616457798.324:832): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 298.404923] audit: type=1130 audit(1616457798.324:833): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 298.417094] audit: type=1100 audit(1616457798.337:834): pid=2692 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 301.103705] audit: type=1131 audit(1616457801.024:835): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 301.403565] audit: type=1130 audit(1616457801.324:836): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 301.403573] audit: type=1131 audit(1616457801.324:837): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 301.404942] audit: type=1130 audit(1616457801.324:838): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 301.416947] audit: type=1100 audit(1616457801.337:839): pid=2695 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 303.184585] audit: type=1131 audit(1616457803.104:840): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 303.403550] audit: type=1130 audit(1616457803.324:841): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 303.403558] audit: type=1131 audit(1616457803.324:842): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 303.404580] audit: type=1130 audit(1616457803.324:843): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 303.416891] audit: type=1100 audit(1616457803.337:844): pid=2700 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 305.124658] audit: type=1131 audit(1616457805.044:845): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 305.403561] audit: type=1130 audit(1616457805.324:846): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 305.403570] audit: type=1131 audit(1616457805.324:847): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 305.404850] audit: type=1130 audit(1616457805.324:848): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 305.419294] audit: type=1100 audit(1616457805.341:849): pid=2703 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 309.840441] kauditd_printk_skb: 5 callbacks suppressed
[ 309.840444] audit: type=1131 audit(1616457809.761:855): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 310.153557] audit: type=1130 audit(1616457810.074:856): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 310.153565] audit: type=1131 audit(1616457810.074:857): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 310.154858] audit: type=1130 audit(1616457810.074:858): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 310.166962] audit: type=1100 audit(1616457810.087:859): pid=2709 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 312.502235] audit: type=1131 audit(1616457812.421:860): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 312.653649] audit: type=1130 audit(1616457812.574:861): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 312.653659] audit: type=1131 audit(1616457812.574:862): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 312.654890] audit: type=1130 audit(1616457812.574:863): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 312.667017] audit: type=1100 audit(1616457812.587:864): pid=2712 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 314.903619] kauditd_printk_skb: 1 callbacks suppressed
[ 314.903624] audit: type=1130 audit(1616457814.824:866): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 314.903631] audit: type=1131 audit(1616457814.824:867): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 314.904845] audit: type=1130 audit(1616457814.824:868): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 314.917181] audit: type=1100 audit(1616457814.837:869): pid=2716 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 316.800697] audit: type=1131 audit(1616457816.721:870): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 316.903452] audit: type=1130 audit(1616457816.824:871): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 316.903462] audit: type=1131 audit(1616457816.824:872): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 316.904678] audit: type=1130 audit(1616457816.824:873): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 316.916877] audit: type=1100 audit(1616457816.837:874): pid=2719 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 319.076319] audit: type=1131 audit(1616457818.997:875): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 321.320489] kauditd_printk_skb: 4 callbacks suppressed
[ 321.320493] audit: type=1131 audit(1616457821.241:880): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 321.653746] audit: type=1130 audit(1616457821.574:881): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 321.653756] audit: type=1131 audit(1616457821.574:882): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 321.655003] audit: type=1130 audit(1616457821.574:883): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 321.669544] audit: type=1100 audit(1616457821.591:884): pid=2725 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 324.180356] audit: type=1131 audit(1616457824.101:885): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 324.403574] audit: type=1130 audit(1616457824.324:886): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 324.403584] audit: type=1131 audit(1616457824.324:887): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 324.404326] audit: type=1130 audit(1616457824.324:888): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 324.416707] audit: type=1100 audit(1616457824.337:889): pid=2729 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 326.340259] audit: type=1131 audit(1616457826.261:890): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 326.653547] audit: type=1130 audit(1616457826.574:891): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 326.653557] audit: type=1131 audit(1616457826.574:892): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 326.654328] audit: type=1130 audit(1616457826.574:893): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 326.666783] audit: type=1100 audit(1616457826.587:894): pid=2732 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 328.199069] audit: type=1131 audit(1616457828.117:895): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 328.403539] audit: type=1130 audit(1616457828.324:896): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 328.403549] audit: type=1131 audit(1616457828.324:897): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 328.404323] audit: type=1130 audit(1616457828.324:898): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 328.416125] audit: type=1100 audit(1616457828.337:899): pid=2736 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 332.328606] kauditd_printk_skb: 5 callbacks suppressed
[ 332.328610] audit: type=1131 audit(1616457832.247:905): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 332.653489] audit: type=1130 audit(1616457832.574:906): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 332.653498] audit: type=1131 audit(1616457832.574:907): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 332.654268] audit: type=1130 audit(1616457832.574:908): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 332.666202] audit: type=1100 audit(1616457832.587:909): pid=2743 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 334.353650] audit: type=1131 audit(1616457834.274:910): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 334.653502] audit: type=1130 audit(1616457834.574:911): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 334.653512] audit: type=1131 audit(1616457834.574:912): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 334.654269] audit: type=1130 audit(1616457834.574:913): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 334.666560] audit: type=1100 audit(1616457834.587:914): pid=2746 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 338.488872] kauditd_printk_skb: 5 callbacks suppressed
[ 338.488876] audit: type=1131 audit(1616457838.407:920): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 338.653506] audit: type=1130 audit(1616457838.574:921): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 338.653514] audit: type=1131 audit(1616457838.574:922): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 338.654274] audit: type=1130 audit(1616457838.574:923): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 338.668135] audit: type=1100 audit(1616457838.587:924): pid=2752 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 340.179950] audit: type=1131 audit(1616457840.101:925): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 340.403504] audit: type=1130 audit(1616457840.324:926): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 340.403512] audit: type=1131 audit(1616457840.324:927): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 340.404247] audit: type=1130 audit(1616457840.324:928): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 340.417998] audit: type=1100 audit(1616457840.337:929): pid=2755 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 344.394363] kauditd_printk_skb: 5 callbacks suppressed
[ 344.394367] audit: type=1131 audit(1616457844.314:935): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 344.653494] audit: type=1130 audit(1616457844.574:936): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 344.653502] audit: type=1131 audit(1616457844.574:937): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 344.654240] audit: type=1130 audit(1616457844.574:938): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 344.666787] audit: type=1100 audit(1616457844.587:939): pid=2761 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 346.334886] audit: type=1131 audit(1616457846.254:940): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 346.653494] audit: type=1130 audit(1616457846.574:941): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 346.653503] audit: type=1131 audit(1616457846.574:942): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 346.654330] audit: type=1130 audit(1616457846.574:943): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 346.666788] audit: type=1100 audit(1616457846.587:944): pid=2764 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 350.469294] kauditd_printk_skb: 5 callbacks suppressed
[ 350.469298] audit: type=1131 audit(1616457850.391:950): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 350.653531] audit: type=1130 audit(1616457850.574:951): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 350.653540] audit: type=1131 audit(1616457850.574:952): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 350.654453] audit: type=1130 audit(1616457850.574:953): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 350.666876] audit: type=1100 audit(1616457850.587:954): pid=2770 uid=1000 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 352.159025] audit: type=1131 audit(1616457852.077:955): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 352.403534] audit: type=1130 audit(1616457852.324:956): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 352.403542] audit: type=1131 audit(1616457852.324:957): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wireguard comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 494.458940] audit: type=1100 audit(1616457994.377:958): pid=2308 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=failed'
[ 496.235511] audit: type=1112 audit(1616457996.157:959): pid=2308 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=login acct="kds" exe="/usr/bin/lightdm" hostname=kds-Ryzen addr=? terminal=/dev/tty7 res=failed'
[ 559.962519] audit: type=1100 audit(1616458059.884:960): pid=2774 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=failed'
[ 561.829491] audit: type=1112 audit(1616458061.751:961): pid=2774 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=login acct="kds" exe="/usr/bin/lightdm" hostname=kds-Ryzen addr=? terminal=/dev/tty7 res=failed'
[ 589.802271] audit: type=1100 audit(1616458089.721:962): pid=2775 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=failed'
[ 592.261192] audit: type=1112 audit(1616458092.181:963): pid=2775 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=login acct="kds" exe="/usr/bin/lightdm" hostname=kds-Ryzen addr=? terminal=/dev/tty7 res=failed'
[ 629.155006] audit: type=2206 audit(1616458129.074:964): pid=2776 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='pam_faillock uid=1000 exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 629.155031] audit: type=1100 audit(1616458129.074:965): pid=2776 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="kds" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=failed'
[ 631.869784] audit: type=1112 audit(1616458131.791:966): pid=2776 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=login acct="kds" exe="/usr/bin/lightdm" hostname=kds-Ryzen addr=? terminal=/dev/tty7 res=failed'
[ 636.098965] audit: type=1100 audit(1616458136.017:967): pid=2779 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="kds" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 636.100141] audit: type=1101 audit(1616458136.021:968): pid=2779 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="kds" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 636.244152] audit: type=1106 audit(1616458136.164:969): pid=2153 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 636.244197] audit: type=1104 audit(1616458136.164:970): pid=2153 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 636.246729] audit: type=1103 audit(1616458136.167:971): pid=2779 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="kds" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 636.246796] audit: type=1006 audit(1616458136.167:972): pid=2779 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[ 636.246807] audit: type=1300 audit(1616458136.167:972): arch=c000003e syscall=1 success=yes exit=4 a0=9 a1=7ffc963b6880 a2=4 a3=3e8 items=0 ppid=1712 pid=2779 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="lightdm" exe="/usr/bin/lightdm" subj==unconfined key=(null)
[ 636.246810] audit: type=1327 audit(1616458136.167:972): proctitle=6C69676874646D002D2D73657373696F6E2D6368696C64003132003139
[ 636.263179] audit: type=1130 audit(1616458136.184:973): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 636.267081] audit: type=1101 audit(1616458136.187:974): pid=2784 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="kds" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 646.415145] kauditd_printk_skb: 32 callbacks suppressed
[ 646.415149] audit: type=1131 audit(1616458147.954:995): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 646.421677] audit: type=1131 audit(1616458147.960:996): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 648.011348] audit: type=1131 audit(1616458149.550:997): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 655.274022] audit: type=1100 audit(1616458156.814:998): pid=3492 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 655.275230] audit: type=1101 audit(1616458156.814:999): pid=3492 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 668.637916] audit: type=1131 audit(1616458170.177:1000): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 792.650499] audit: type=1100 audit(1616458294.195:1001): pid=4407 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 792.651610] audit: type=1101 audit(1616458294.198:1002): pid=4407 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="kds" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 792.651749] audit: type=1110 audit(1616458294.198:1003): pid=4407 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 792.652913] audit: type=1105 audit(1616458294.198:1004): pid=4407 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
av8r
23 March 2021 02:15
14
@Nachlese the journactl -r output is to big to be able to post it here. (even with just the “audit” lines)
not sure what I need to look for or how I can post it here. I think I have to upload it to the cloud and share a link to be able to get you that output.
and you didn’t find anything in
journalctl -r
I used the -r flag because that will show the log in reverse - the most recent events will be displayed first
and that way your issue - if there is one - should be easy to spot because, when you log in and can see the log - not many events have taken place and it should be one of the first things you see.
The output is also colored red in case of failed attempts.
As for the dmesg output - you could filter it for “res=failed”
for instance
or for any terms that appear in my sample output
like
username
where that is obviously your own username
That example was created by me, intentionally typing the wrong password three times
so that I would experience the same 10 minute lockout and have the system generate the failure log.
for example
sudo dmesg -e | grep res=failed
sudo dmesg -e | grep acct=\"username\"
You have a lot of wireguard related messages in the dmesg output.
Filter for that as well - and you should probably also do something about them.
av8r
23 March 2021 23:14
16
@Nachlese There was a whole lot of stuff in the Journalctl -r command. even if I just filtered out the audit lines it was to much, this forum told me It’s to big so I could not post it.
I will try it again with your filters. and post the result if I can.
I should probably just format this drive and reinstall Manjaro on it agian, I’m sure I have made a bunch of mistakes trying to learn how to use and operate an (Arch) Linux distro for the first time. I just wanted to find out why this had happen.
av8r
23 March 2021 23:46
17
@Nachlese @Fabby I think I found the problem. or to be fair my brother told me to try something even though it seemed wired.
I had made a wireguard.service script and put it in /etc/systemd/system/ to try and make wireguard start automatically when I log-on the computer. I thought I had disabled the service when I removed the .service script because it did not work. I put the script back in /etc/systemd/system and disabled the service with sudo systemctl disable wireguard.service and then removed the .service file again. rebooted the computer and now it logs me in on the first try.
I’m very sorry for having wasted y’alls time, but I’m really grateful because you have thought me a lot about troubleshooting
Fabby
24 March 2021 00:48
18
So that’s very specific to your setup. As creating a new user solved the problem for you, I’ve set that as the solution so someone else having a similar problem to yours will do that as well and then find the ultimate solution for them as well as my next step was going to be:
start copying over documents, videos, … to your new user
start copying settings
until it stops working and then revert back your last setting. (which in your very specific case was wireguard)
system
Closed
8 April 2021 00:49
19
