When I try to open the containing folder of downloaded files in Firefox, it opens Thunar instead of Nemo. I already set Nemo as the default File Browser, but Firefox still uses Thunar.
After googling the issue i tried to run xdg-mime query default inode/directory to verify that it outputs nemo.desktop
How can I resolve this issue?
What happens if you run
xdg-mime default nemo.desktop inode/directory
in a terminal window?
Does it solve your issue?
I already tried that and it did not solve it.
I have the same problem but instead of Nemo it’s Nautilus.
I just noticed something.
When I go into Session and Startup and I quit Thunar there, Firefox then opens the download location with Nemo just as it is supposed to. But this is not a permanent fix. After restarting Firefox, it reverts right back to Thunar and now Thunar is not even shown in Session and Startup. I have a feeling this has something to do with a daemon running for Thunar but I’m not sure.
Perhaps this can help someone here to come closer to the solution?
When I was using SpaceFM as default file manger, I used to run “killall Thunar” at startup/login to kill the Thunar daemon.
That also didn’t do the trick. The daemon thing was just a thought I had.
I went searching to see how I solved this, and found I had added a line to /home/[user]/.local/share/applications/mimeapps.list
inode/directory=spacefm.desktop;
Change “spacefm.desktop” to whatever file manager launcher you wish and Firefox should use that to open containing folder. I just tried it and it works for me.
Still no luck. According to the Arch Wiki there are multiple location that could be the case. But adding
1 [Default Applications]
2 inode/directory=nemo.desktop;
in any of these location still has no effect. I feel like this option is buried somewhere deeper in the Manjaro defaults
https://wiki.archlinux.org/index.php/XDG_MIME_Applications#mimeapps.list
There’s also inode/directory entries in the mimeinfo.cache files in /usr/share/applications and /home/[user]/.local/share/applications. You could check those and list your preferred file manager first.
I also tried that but it still doesn’t work.
Mozilla has an open bug report about this
1285711 - Firefox does not use default file manager | bugzilla.mozilla.org
Comments suggest that using Open Containing Folder in the right-click context menu for the downloaded file will use the correct File Manager
One person stated that he also experienced that problem with Chrome. Indeed I noticed that I had the same problem with chromium, so I guess this is not Firefox related. Needless to say that using “Open Containing Folder” didn’t solve it.
EDIT: I think I managed to solve it thanks to @nikgnomic link.
I figure out that it is due to the use of the org.freedesktop.FileManager1 d-bus service from nsGIOService.cpp - mozsearch . The solution is to change the implementation of the d-bus service (see /usr/share/dbus-1/services/org.xfce.Thunar.service).
For example, for Thunar we have the following in /usr/share/dbus-1/services/org.freedesktop.FileManager1.service:
[D-BUS Service]
Name=org.freedesktop.FileManager1
Exec=/usr/bin/Thunar --gapplication-service
SystemdService=thunar.service
I changed /usr/share/dbus-1/services/org.xfce.FileManager.service to contain the following content:
[D-BUS Service]
Exec=/usr/bin/nemo --no-default-window
SystemdService=nemo.service
I don’t think this is the cleanest of solutions but it works! So I have to ask: IS THIS SAFE TO DO?
File /usr/share/dbus-1/services/org.xfce.FileManager.service is owned by Thunar
A future update could revert the service back to Thunar
So you should check after an update to see if the service needs to be edited again
grep -A1 Exec /usr/share/dbus-1/services/org.xfce.FileManager.service
On second thought I have to say that this solution in combination with running “killall thunar” at startup WILL break your desktop icons. The desktop will work normal again when I have an instance of Thunar running and stop working again, when it is closed. Trying to click on icons on the desktop will just prompt with the following error:
GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.xfce.FileManager was not provided by any .service files
How can I retain my desktop functionality with this solution?
