Firefox starts only after long delay
For months I have been experiencing performance problems with Firefox. The major problem is an extreme delay when I start Firefox. Sometimes I have the impression that my click was not noticed and I click a second time. Then - after long delay - the system tells me that I should close the 2nd Firefox process.
I have installed all updates (as of 2023-08-19) , nevertheless the problem remains. I have got a friend, who uses Manjaro like me. He does not have that delay problem. Which log files or configuration files should I examine on my PC to find out the problem?
sudo pacman -Rdd xdg-desktop-portal-gnome
sudo pacman -S xdg-desktop-portal-gtk
Start wit posting output of
inxi -Fazy
What firefox version is installed?
Post output of
pacman -Qi firefox
What firefox extensions are you using?
It would appear then that you’ve been bitten by the xdg-desktop-portal-gnome bug.
Your profile does not say what desktop environment you’re using, but you need to remove xdg-desktop-portal-gnome and replace it by one that’s appropriate for your desktop environment. :arrow_down:
Careful, if OP is using KDE then
dg-desktop-portal-kde
is the package to be installed (I see @Aragorn was faster… :laughing:.]
The post is tagged with xfce.
But the post is better :+1:
