Firefoxfails to load, crashes at load time with this error.
INT ✘
ExceptionHandler::GenerateDump cloned child 17127
ExceptionHandler::SendContinueSignalToChild sent continue signal to child
ExceptionHandler::WaitForContinueSignal waiting for continue signal...
~ Failed to open curl lib from binary, use libcurl.so instead
That kind of might be it, although I’m not sure…I’ve never seen the use of more than 1 YouTube instance at a time…and besides, that should affect your Firefox, possibly only your internet speed.
There are only 2 options left I can think of:
Your profile.
Which is easy to test: just remove the .mozilla directory from you home:
mv ~/.mozilla ~/.mozilla.backup
Firefox isn’t installed from the repos, but the AUR and needs to be rebuilt.
Best option: Buy her an old Chromebook, and tell her that if she breaks it, it’s hers to fix.
Second best option: Set her up with her own user account and make sure you’re logged out of your own account before you let her use the machine. Then at least she can’t be messing with your own files and configs.
By the way…
It won’t. Reinstalling the package won’t touch your home directory, which is where your profile is stored.
cert9.db = certificates
key4.db = has to do with passwords, I don’t remember exactly, but worth backing up
logins.json = saved passwords
places.sqlite = bookmarks
prefs.js = self explanatory
search.json.mozlz4 = Search engines, including custom
I would recommend the following to reduce the load when Firefox has lots of YouTube tabs open:
Type “about:config” in Firefox’s address bar to access Advanced Preferences, use the filter bar to search for “browser.sessionstore.restore” & make sure that “browser.sessionstore.restore_tabs_lazily” & “browser.sessionstore.restore_on_demand” are both set to “true”. That way, any tabs that were open when Firefox was closed will be restored but not loaded until clicked on when Firefox is re-opened.
Install the below Firefox add-ons. Auto Tab Discard will unload (not close) unused tabs after a set period of time, freeing up system resources. Tab Session Manager allows multiple sessions to be saved & opened at a later time. It also saves & restores tabs unloaded by Auto Tab Discard. Very useful if your partner has lots of videos open that she won’t be able to watch in one sitting. She can just save the tab session to be opened at a later time. As well as storing sessions locally, it also saves the sessions to Google Drive if signed in & authorised.
Quoting the same portion that did not contain enough information will still not contain enough information.
Maybe I’m confused as to why you are talking about multiple firefoxs etc.
I just care about the one crashing.
I suppose the rest answers the question as to whether you have tried a clean profile though. Maybe ?
If you have tried with a clean profile and/or safe mode … then it should mean the culprit is not found with its configuration or extensions.
So … more information would be good. I see the crash was not very explanatory.
We dont know anything about the system. Maybe share an inxi and we will see you are missing a swap partition on a low memory system.
As to firefox in general … theres manytweaks … but still … I dont see any reason a handful of tabs should crash the browser. Every laptop within spitting distance can open dozens of tabs, including multiple videos, without running off a cliff.
One other thing I am wondering (and this is probably only a remote possibility of being the cause) is whether the recent changes that YouTube implemented to delay video loading if the browser is Firefox (a blatantly transparent attempt to force users to switch to Chrome) could be causing problems if many tabs are trying to load videos at the same time. It apparently uses javascript to identify the browser and enact a 5-second delay if it is Firefox. In that case, a Firefox add-on that prevents preloading &/or auto-playing of videos until the play button is clicked on might be useful. I’ve been using Disable HTML5 Autoplay - Firefox Add-ons for a few years, however I just noticed in its comments that it hasn’t been updated for a while, so there may be other, more recent, choices available on the add-ons site.
I’m not. You asked what the ‘See Above’ refered to I told you by quoting the full context of the post you were referring to.
I’m sorry if that confuses you. But the see above comment was to tell another poster that it’s not my Computer nor my copy of Firefox that is problematic
When the information I sought was about the clean profile, which you said was not a problem, and to ‘see above’… in which you never mention trying a clean profile. I suppose it is intended to mean it isnt ‘your profile’ thats the issue … but that would be beside the point of ‘please try clean profile’ and the lack of information pertaining to it.
Aw well … conversing is hard I guess.
