Hi all,
I have a strange problem since a few months. The problem is that most times when I run an update or installation of a package, Firefox crashes. It mostly happens after the system was suspended, I can’t see a reproducible pattern. It doesn’t need the suspend to crash but it makes it more likely.
I don’t remember if it started at some point or if it was already the case for this new laptop that I have, so it could be from kernel 6.1 up until 6.8, and any mesa updates that happened in between (both official and nonfree). I’m on the unstable branch.
Typically, I have two Firefox sessions running (one work profile, one private profile) and at least one of them crashes with Firefox telling me that it crashed, sometimes both. The about:crashes page is full with sent reports.
There is nothing in the journal or dmesg.
However, I guess it’s a Firefox problem, not a Manjaro problem ![]()
inxi -Fazy
Kernel: 6.7.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc avail: hpet,acpi_pm parameters: amd_pstate=active
vt.default_red=30,243,166,249,137,245,148,186,88,243,166,249,137,245,148,166
vt.default_grn=30,139,227,226,180,194,226,194,91,139,227,226,180,194,226,173
vt.default_blu=46,168,161,175,250,231,213,222,112,168,161,175,250,231,213,200
nowatchdog quiet loglevel=3 systemd.show_status=0 rd.udev.log_level=3
bgrt_disable root=/dev/mapper/root
rd.luks.name=0de0c664-9e72-4586-8cb9-5d277a20f167=root
rootflags=subvol=@,x-systemd.device-timeout=0 rw
rd.luks.options=discard,no-read-workqueue,no-write-workqueue,timeout=0
lsm=landlock,lockdown,yama,integrity,apparmor,bpf apparmor=1 audit=0
resume=/dev/mapper/root resume_offset=691710
Desktop: i3 v: 4.23 with: i3bar tools: xss-lock avail: i3lock vt: 7
dm: LightDM v: 1.32.0 Distro: Manjaro base: Arch Linux
Type: Laptop System: HP product: HP EliteBook 845 14 inch G10 Notebook PC
v: SBKPF serial: <superuser required> Chassis: type: 10
Mobo: HP model: 8B6E v: KBC Version 60.28.00 serial: <superuser required>
part-nu: 818N0EA#ABD uuid: <superuser required> UEFI: HP v: 82 Ver. 01.03.09
date: 12/11/2023
ID-1: BAT0 charge: 47.0 Wh (100.0%) condition: 47.0/51.3 Wh (91.6%)
volts: 12.9 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: full cycles: 53
Info: model: AMD Ryzen 9 PRO 7940HS w/ Radeon 780M Graphics bits: 64
type: MT MCP arch: Zen 4 gen: 5 level: v4 note: check built: 2022+
process: TSMC n5 (5nm) family: 0x19 (25) model-id: 0x74 (116) stepping: 1
microcode: 0xA704104
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB desc: 8x1024 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 571 high: 2154
min/max: 400/5583:5263:5743:6228:6067:5903:5423 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 400 3: 400
4: 2154 5: 400 6: 400 7: 400 8: 400 9: 1397 10: 400 11: 400 12: 400 13: 400
14: 400 15: 400 16: 400 bogomips: 127818
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Phoenix1 vendor: Hewlett-Packard driver: amdgpu v: kernel
arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm) built: 2023+ pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: DP-6,HDMI-A-1,eDP-1 empty: DP-1,
DP-2, DP-3, DP-4, DP-5, DP-7 bus-ID: c3:00.0 chip-ID: 1002:15bf
class-ID: 0300 temp: 48.0 C
Device-2: Luxvisions Innotech HP 5MP Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 30c9:0096
Device-3: Logitech HD Webcam C525 driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 9-1:2 chip-ID: 046d:0826
Display: x11 server: X.Org v: 21.1.11 compositor: Picom v: git-89c2c
driver: X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 7040x1600 s-dpi: 96 s-size: 1861x423mm (73.27x16.65")
s-diag: 1908mm (75.14")
Monitor-1: DP-6 mapped: DisplayPort-5 pos: primary,center
model: Acer EB321HQU serial: <filter> built: 2016 res: 2560x1440 hz: 60
dpi: 93 gamma: 1.2 size: 699x393mm (27.52x15.47") diag: 802mm (31.6")
ratio: 16:9 modes: max: 2560x1440 min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: left model: Samsung SyncMaster
serial: <filter> built: 2010 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
size: 477x268mm (18.78x10.55") diag: 547mm (21.5") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
Monitor-3: eDP-1 mapped: eDP pos: right model: AU Optronics 0x6da8
built: 2022 res: 2560x1600 hz: 120 dpi: 216 gamma: 1.2
size: 301x188mm (11.85x7.4") diag: 355mm (14") ratio: 16:10 modes:
max: 2560x1600 min: 640x480
device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.1-arch10.1
gfx1103_r1 LLVM 16.0.6 DRM 3.57 6.7.5-1-MANJARO) device-ID: 1002:15bf
memory: 500 MiB unified: no
Device-1: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: c3:00.1
chip-ID: 1002:1640 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
driver: snd_pci_ps v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
snd_sof_amd_acp63 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: c3:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
bus-ID: c3:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Logitech HD Webcam C525 driver: snd-usb-audio,uvcvideo type: USB
Device-5: Texas Instruments PCM2912A Audio Codec driver: snd-usb-audio
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 9-4:3
chip-ID: 08bb:2912 class-ID: 0102
API: ALSA v: k6.7.5-1-MANJARO status: kernel-api
Server-1: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: Realtek RTL8852CE PCIe 802.11ax Wireless Network
vendor: Hewlett-Packard driver: rtw89_8852ce v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: a000 bus-ID: 01:00.0 chip-ID: 10ec:c852
class-ID: 0280
Device-2: Intel I210 Gigabit Network driver: igb v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 66:00.0 chip-ID: 8086:1533
class-ID: 0200
IF: enp102s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
IF-ID-2: wg-ghoofybox state: down mac: N/A
IF-ID-3: wg-ottobeuren state: down mac: N/A
Info: services: systemd-networkd, systemd-timesyncd, wpa_supplicant
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:2 chip-ID: 0bda:c85c
Report: btmgmt ID: hci0 rfk-id: 5 state: down bt-service: enabled,running
rfk-block: hardware: no software: no address: <filter> bt-v: 5.3 lmp-v: 12
status: discoverable: yes pairing: yes
Local Storage: total: 953.87 GiB used: 375.55 GiB (39.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SanDisk model: SK hynix PC801
HFS001TEJ9X101N size: 953.87 GiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: HPS1
temp: 45.9 C scheme: GPT
ID-1: / raw-size: 953.32 GiB size: 953.32 GiB (100.00%)
used: 373.4 GiB (39.2%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0 mapped: root
ID-2: /boot raw-size: 550 MiB size: 548.9 MiB (99.80%)
used: 97.2 MiB (17.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 953.32 GiB size: 953.32 GiB (100.00%)
Kernel: swappiness: 10 (default 60) cache-pressure: 75 (default 100)
zswap: yes compressor: zstd max-pool: 20%
ID-1: swap-1 type: file size: 32 GiB used: 9.1 MiB (0.0%) priority: -2
file: /swap/swapfile
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 57.0 C
Fan Speeds (rpm): N/A
Memory: total: 32 GiB note: est. available: 30.63 GiB used: 17.44 GiB (56.9%)
Processes: 455 Power: uptime: 1d 1h 51m states: freeze,mem,disk
suspend: s2idle wakeups: 4 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 12.22 GiB services: power-profiles-daemon,
upowerd, xfce4-power-manager Init: systemd v: 255 default: graphical
tool: systemctl
Packages: 1637 pm: pacman pkgs: 1622 libs: 308
tools: pacseek,pamac,paru,yay pm: flatpak pkgs: 15 Compilers: clang: 16.0.6
gcc: 13.2.1 Shell: Zsh v: 5.9 running-in: tmux: inxi: 3.3.33
