My Firefox and any forks I use (Waterfox) constantly crashes randomly when I use the browser. Sometimes it does so immediately, other moments it works for a good hour before crashing. Once it does crash, though, it tends to constantly do so a couple of times before working again.
I attempted following the EndeavourOS Firefox Troubleshooting Guide to no avail; considering this issue happens with all versions of the browser (Waterfox, Firefox), I’m starting to wonder whether it’s a system issue. That or Youtube has something to do with it, as it seems to crash whenever I have a Youtube video playing; I doubt this is the case, but you never know.
As for extensions, I have used the same three for at least a year with no issues on both linux and Windows 10 (tampermonkey, ublock origin, image search options); I have removed tampermonkey and replaced ublock origin for testing purposes, though it doesn’t seem have worked.
While running in terminal, all it ever gives me, in terms of errors, is a message about exiting due to channel error
; this repeats about four times.
What log files is needed for troubleshooting?
Edit: Here’s my system log
Kernel: 5.10.84-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=df133989-f97d-4f2d-9c57-94c7e99fe388 rw quiet
udev.log_priority=3
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: Micro-Star model: B450 GAMING PRO CARBON AC (MS-7B85)
v: 1.0 serial: <superuser required> UEFI: American Megatrends v: 1.C0
date: 06/11/2020
RAM: total: 15.64 GiB used: 2.54 GiB (16.2%)
RAM Report:
Info: model: AMD Ryzen 7 1700X bits: 64 type: MT MCP arch: Zen
family: 0x17 (23) model-id: 1 stepping: 1 microcode: 0x8001138
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 768 KiB desc: d-8x32 KiB; i-8x64 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 1866 high: 2047 min/max: 2200/3400 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1879 2: 1878
3: 1796 4: 1714 5: 1885 6: 1884 7: 1884 8: 1894 9: 2047 10: 1791 11: 1808
12: 1755 13: 1882 14: 1922 15: 1927 16: 1918 bogomips: 108823
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm
mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdrand rdseed rdtscp rep_good sep sev sha_ni skinit smap smca sme
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall
tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
disabled, RSB filling
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Sapphire Limited Nitro+ driver: amdgpu v: kernel bus-ID: 26:00.0
chip-ID: 1002:67df class-ID: 0300
Device-2: Logitech Webcam C110 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-2.4:6 chip-ID: 046d:0829 class-ID: 0102
Display: x11 server: X.Org 1.21.1.2 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 5760x1080 s-dpi: 96 s-size: 1524x285mm (60.0x11.2")
s-diag: 1550mm (61")
Monitor-1: DisplayPort-0 res: 1920x1080 dpi: 92
size: 531x299mm (20.9x11.8") diag: 609mm (24")
Monitor-2: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 92
Monitor-3: HDMI-A-1 res: 1920x1080 hz: 60 dpi: 142
size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: AMD Radeon RX 580 Series (POLARIS10 DRM 3.40.0
5.10.84-1-MANJARO LLVM 13.0.0)
v: 4.6 Mesa 21.2.5 direct render: Yes
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Sapphire Limited driver: snd_hda_intel v: kernel bus-ID: 26:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 28:00.3 chip-ID: 1022:1457
class-ID: 0403
Device-3: Arturia MiniLab mkII type: USB driver: snd-usb-audio
bus-ID: 1-2.3:4 chip-ID: 1c75:0289 class-ID: 0103
Device-4: Logitech Webcam C110 type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.10.84-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.19 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.40 running: yes
Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel bus-ID: 21:00.0
chip-ID: 8086:2526 class-ID: 0280
IF: wlo1 state: down mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: Micro-Star MSI driver: igb
v: kernel port: f000 bus-ID: 22:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
v: 0.8 bus-ID: 3-4:4 chip-ID: 8087:0025 class-ID: e001
Local Storage: total: 11.61 TiB used: 387.19 GiB (3.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3250823AS
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 1.5 Gb/s
type: N/A serial: <filter> rev: 4.24 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 500GB
type: SSD serial: <filter> rev: 3B6Q scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Seagate
model: ST4000LM016-1N2170 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B type: HDD rpm: 5400 serial: <filter> rev: 1153 scheme: GPT
ID-4: /dev/sde maj-min: 8:64 type: USB vendor: SanDisk model: Cruzer Blade
size: 14.53 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00
ID-5: /dev/sdf maj-min: 8:80 type: USB vendor: Western Digital
model: WD Elements 25A3 size: 7.28 TiB block-size: physical: 4096 B
logical: 512 B type: N/A serial: <filter> rev: 1030 scheme: GPT
ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%)
used: 387.19 GiB (84.7%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: df133989-f97d-4f2d-9c57-94c7e99fe388
used: 288 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: NO_LABEL
uuid: 727E-DB89
ID-1: /dev/sda1 maj-min: 8:1 size: 232.88 GiB fs: ntfs label: VM
uuid: 3CD63115044E458B
ID-2: /dev/sdc1 maj-min: 8:33 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sdc2 maj-min: 8:34 size: 3.64 TiB fs: ntfs label: LaCie
uuid: A80EA8770EA84064
ID-4: /dev/sdf1 maj-min: 8:81 size: 7.28 TiB fs: ntfs label: Elements
uuid: 1454C45554C43AEE
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-2.3:4 info: Arturia MiniLab mkII type: Audio
driver: snd-usb-audio interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA
Device-2: 1-2.4:6 info: Logitech Webcam C110 type: Video,Audio
power: 500mA chip-ID: 046d:0829 class-ID: 0102
Device-3: 1-3:3 info: Super Top microSD card reader (SY-T18)
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 14cd:1212 class-ID: 0806
serial: <filter>
Device-4: 1-4:5 info: SanDisk Cruzer Blade type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 224mA
chip-ID: 0781:5567 class-ID: 0806 serial: <filter>
Device-5: 1-8:7 info: Micro Star MSI GK50 LOW PROFILE Gaming Keyboard
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 0db0:0b5a class-ID: 0300
Device-6: 1-9:8 info: Logitech G502 SE HERO Gaming Mouse type: Mouse,HID
power: 300mA chip-ID: 046d:c08b class-ID: 0300 serial: <filter>
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Device-1: 2-1:2 info: LaCie P9227 Mobile type: Mass Storage driver: uas
interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 896mA chip-ID: 059f:1091
Hub-4: 2-2:3 info: Genesys Logic Hub ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 05e3:0612 class-ID: 0900
Device-1: 2-2.2:4 info: Western Digital Elements Desktop (WDBWLG)
type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s
power: 8mA chip-ID: 1058:25a3 class-ID: 0806 serial: <filter>
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-2:2 info: XP-Pen 15.6 inch PenDisplay type: Mouse,HID
driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s power: 70mA
chip-ID: 28bd:090d class-ID: 0300
Device-2: 3-3:3 info: Micro Star PRO CARBON type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 1462:7b85 class-ID: 0300 serial: <filter>
Device-3: 3-4:4 info: Intel Wireless-AC 9260 Bluetooth Adapter
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0025 class-ID: e001
Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 36.8 C mobo: N/A gpu: amdgpu temp: 40.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 827
Processes: 370 Uptime: 5m wakeups: 0 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1462 lib: 436
Shell: Zsh v: 5.8 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.11
