Hello,
I just recently installed Manjaro KDE and have two issues.
When I switch to a darker theme on firefox, I can barely see the minimise, maximise, close button in the top right corner (see image)
When I try to play a stream via streamlink twitch and want to use vlc, it does not play the video (see image). If I use the mpv player, it works as intended. However, I would like to use vlc here.
Kernel: 5.10.34-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=5e254acd-9b7d-4b09-8a47-5c10fe0df1cb rw quiet apparmor=1
security=apparmor resume=UUID=d7090368-3e15-4428-969b-1ae0f41039eb
udev.log_priority=3
Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Schenker product: SCHENKER VIA 15 Pro v: Standard
serial: <filter>
Mobo: Schenker model: PF5NU1G v: Standard serial: <filter>
UEFI: American Megatrends v: N.1.06.A00 date: 09/18/2020
ID-1: BAT0 charge: 77.7 Wh (87.0%) condition: 89.3/91.6 Wh (97.5%)
volts: 12.2 min: 11.6 model: standard type: Li-ion serial: <filter>
status: Discharging
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse B330/M330/M331
status: Discharging
RAM: total: 15.12 GiB used: 3.09 GiB (20.4%)
Info: 6-Core model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64
type: MT MCP arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1
microcode: 8600103 cache: L2: 3 MiB bogomips: 71868
Speed: 1397 MHz min/max: 1400/3000 MHz boost: enabled Core speeds (MHz):
1: 1397 2: 1397 3: 1397 4: 1397 5: 1397 6: 1397 7: 1397 8: 1397 9: 1397
10: 1396 11: 1397 12: 1397
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs irperf lahf_lm
lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload vgif
vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
Device-1: AMD Renoir vendor: Tongfang Hongkong Limited driver: amdgpu
v: kernel bus-ID: 04:00.0 chip-ID: 1002:1636 class-ID: 0300
Device-2: Chicony HD Webcam type: USB driver: uvcvideo bus-ID: 1-3:3
chip-ID: 04f2:b68b class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.10.34-1-MANJARO LLVM 11.1.0)
v: 4.6 Mesa 21.0.3 direct render: Yes
Device-1: AMD vendor: Tongfang Hongkong Limited driver: snd_hda_intel
v: kernel bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Tongfang Hongkong Limited driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 04:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Tongfang Hongkong Limited
driver: snd_hda_intel v: kernel bus-ID: 04:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound Server-1: ALSA v: k5.10.34-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.26 running: yes
Device-1: Intel Wi-Fi 6 AX200 vendor: Rivet Networks driver: iwlwifi
v: kernel bus-ID: 01:00.0 chip-ID: 8086:2723 class-ID: 0280
vendor: Tongfang Hongkong Limited driver: r8169 v: kernel port: f000
bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-4.4:6 chip-ID: 8087:0029 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 4 state: down bt-service: enabled,running
Local Storage: total: 232.89 GiB used: 10.17 GiB (4.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M8250G
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: S5Z42105 temp: 26.9 C
scheme: GPT
ID-1: / raw-size: 215.95 GiB size: 211.5 GiB (97.94%) used: 10.17 GiB (4.8%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 5e254acd-9b7d-4b09-8a47-5c10fe0df1cb
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: F332-F5DD
ID-1: swap-1 type: partition size: 16.64 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: d7090368-3e15-4428-969b-1ae0f41039eb
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 1-2:2 info: Logitech Unifying Receiver type: Mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c52f class-ID: 0300
Device-2: 1-3:3 info: Chicony HD Webcam type: Video driver: uvcvideo
interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b68b
Hub-2: 1-4:4 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-4.3:5 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Device-2: 1-4.4:6 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 36.2 C mobo: 35.0 C gpu: amdgpu temp: 35.0 C
Processes: 267 Uptime: 3h 31m wakeups: 23 Init: systemd v: 247
tool: systemctl Compilers: gcc: 10.2.0 Packages: pacman: 1274 lib: 355
flatpak: 0 Shell: Bash v: 5.1.4 running-in: konsole inxi: 3.3.04
I guess the solution is quite simple, but my knowledge is limited
e// ok, sth with the images didn’t work and links are also not possible…
