Fan runs on high as soon as boot up?
Hello,
Today, my fan started running as high as I think it can go. The machine was on (not connected to the internet) and sitting idle while I stepped away for about an hour. It now sounds like a hair dryer constantly. I’m running KDE Plasma and have had it on an HP Elite Desktop 800 since August of this year. I’m not implying that it is definitely related but I updated the system a day or two ago.
As soon as I press the switch to boot up, the fan starts running full blast and stops for maybe one or two seconds, literally, and then starts again. Nothing is running, the RAM is 1.3 GiB of 15.4 and the CPU 1% ; and it runs. I have never heard the fan run before except, perhaps, very faintly when running an extended script in Tcl that writes a large amount of data to SQLite.
The basic system information is below. Thank you for any guidanace you may be able to provide.
inxi -v7azy         ✔
  Kernel: 5.15.81-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    root=UUID=b51565af-f8e8-472a-8187-e7c51806ba49 rw quiet
    resume=UUID=01613b5b-71f6-4021-a856-6f7b2be197d8 udev.log_priority=3
  Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop System: HP product: HP EliteDesk 800 G3 SFF v: N/A
    serial: <superuser required> Chassis: type: 3 serial: <superuser required>
  Mobo: HP model: 8299 v: KBC Version 06.29 serial: <superuser required>
    UEFI: HP v: P01 Ver. 02.43 date: 07/28/2022
  Device-1: hidpp_battery_0 model: Logitech K520 serial: <filter>
    charge: 70% (should be ignored) rechargeable: yes status: discharging
  Device-2: hidpp_battery_1 model: Logitech Marathon Mouse/Performance Plus
    M705 serial: <filter> charge: 55% (should be ignored) rechargeable: yes
    status: discharging
  RAM: total: 15.41 GiB used: 2.41 GiB (15.6%)
  Info: model: Intel Core i7-7700 bits: 64 type: MT MCP arch: Kaby Lake
    gen: core 7 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 9 microcode: 0xF0
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 3102 high: 4035 min/max: 800/4200 scaling:
    driver: intel_pstate governor: powersave cores: 1: 3156 2: 4035 3: 3129
    4: 1995 5: 2650 6: 2496 7: 3464 8: 3891 bogomips: 57616
    dtherm dts epb erms est f16c flush_l1d fma fpu fsgsbase fxsr ht hwp
    hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
    invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
    nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
    pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
    smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc
    tsc_adjust tsc_deadline_timer vme x2apic xgetbv1 xsave xsavec xsaveopt
    xsaves xtopology xtpr
  Type: itlb_multihit status: KVM: VMX unsupported
    prctl and seccomp
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
    PBRSB-eIBRS: Not affected
  Device-1: Intel HD Graphics 630 vendor: Hewlett-Packard driver: i915
    v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
    active: HDMI-A-2 empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-3
    bus-ID: 00:02.0 chip-ID: 8086:5912 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
    loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
    screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: HDMI-A-2 mapped: HDMI-2 model: Samsung S27F350 serial: <filter>
    built: 2016 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
    size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9 modes:
    max: 1920x1080 min: 720x400
  API: OpenGL v: 4.6 Mesa 22.2.4 renderer: Mesa Intel HD Graphics 630 (KBL
    GT2) direct render: Yes
  Device-1: Intel 200 Series PCH HD Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
    class-ID: 0403
  Sound API: ALSA v: k5.15.81-1-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.61 running: yes
  Device-1: Intel Ethernet I219-LM vendor: Hewlett-Packard driver: e1000e
    v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15e3 class-ID: 0200
  Device-2: NetGear Nighthawk A7000 802.11ac Wireless Adapter AC1900
    [Realtek 8814AU] type: USB driver: rtl8814au bus-ID: 1-2:2
    chip-ID: 0846:9054 class-ID: 0000 serial: <filter>
  IF: wlp0s20f0u2 state: up mac: <filter>
  Local Storage: total: 476.94 GiB used: 89.94 GiB (18.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Kingfast model: N/A size: 476.94 GiB
    block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD
    serial: <filter> rev: 0A0 scheme: GPT
  Optical-1: /dev/sr0 vendor: hp HLDS model: DVDROM DUD1N rev: MDM1
    dev-links: cdrom
  Features: speed: 24 multisession: yes audio: yes dvd: yes rw: none
    state: running
  ID-1: / raw-size: 459.69 GiB size: 451.4 GiB (98.20%) used: 89.93 GiB (19.9%)
    fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: b51565af-f8e8-472a-8187-e7c51806ba49
    used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
    uuid: 20B6-5A29
  Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
  ID-1: swap-1 type: partition size: 16.95 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sda3 maj-min: 8:3 label: swap
    uuid: 01613b5b-71f6-4021-a856-6f7b2be197d8
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
  Device-1: 1-2:2 info: NetGear Nighthawk A7000 802.11ac Wireless Adapter
    AC1900 [Realtek 8814AU] type: Network driver: rtl8814au interfaces: 1
    rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0846:9054 class-ID: 0000
    serial: <filter>
  Device-2: 1-3:3 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
    power: 98mA chip-ID: 046d:c52b class-ID: 0300
  Hub-2: 2-0:1 info: Super-speed hub ports: 10 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 33.0 C mobo: N/A
  Processes: 226 Uptime: 13m wakeups: 4 Init: systemd v: 251 default: graphical
  tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
  pkgs: 1491 libs: 381 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
  default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.23
The HP Elite Desktop 800 G3 came out in 2017. Have you taken it apart and cleaned the cpu cooler out along with the old thermal compound and replaced it lately?
Thanks. Good thought. Just bought it refurbished August 22nd and took cover off today and looks clean. Doesn’t feel warm, starts running as soon as press the on button, and the results above for temperature sensor don’t appear to be high. I’m going to check the logs described here but that’ll be new to me and don’t want to burn out the fan while searching through them.
Don’t know if this is useful or not and don’t yet understand it. Thank you.
journalctl --boot=-3 --priority=3 --catalog --no-pager         ✔
Dec 07 21:25:44 gary-hpelitedesk800g3sff kernel: x86/cpu: VMX (outside TXT) disabled by BIOS
Dec 07 21:25:44 gary-hpelitedesk800g3sff kernel: x86/cpu: SGX disabled by BIOS.
Dec 07 21:25:44 gary-hpelitedesk800g3sff kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_PR.PR00._CPC], AE_NOT_FOUND (20210730/psargs-330)
Dec 07 21:25:44 gary-hpelitedesk800g3sff kernel: ACPI Error: Aborting method \_PR.PR01._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Dec 07 21:25:44 gary-hpelitedesk800g3sff kernel: ACPI Error: Aborting method \_PR.PR02._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Dec 07 21:25:44 gary-hpelitedesk800g3sff kernel: ACPI Error: Aborting method \_PR.PR03._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Dec 07 21:25:44 gary-hpelitedesk800g3sff kernel: ACPI Error: Aborting method \_PR.PR04._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Dec 07 21:25:44 gary-hpelitedesk800g3sff kernel: ACPI Error: Aborting method \_PR.PR05._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Dec 07 21:25:44 gary-hpelitedesk800g3sff kernel: ACPI Error: Aborting method \_PR.PR06._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Dec 07 21:25:44 gary-hpelitedesk800g3sff kernel: ACPI Error: Aborting method \_PR.PR07._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Dec 07 21:25:50 gary-hpelitedesk800g3sff systemd[592]: Failed to start Update XDG user dir configuration.
░░ Subject: A start job for unit UNIT has failed
░░ Defined-By: systemd
░░ A start job for unit UNIT has finished with a failure.
░░ The job identifier is 20 and the job result is failed.
Dec 07 21:26:34 gary-hpelitedesk800g3sff pulseaudio[1079]: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
Dec 07 21:26:46 gary-hpelitedesk800g3sff wpa_supplicant[566]: bgscan simple: Failed to enable signal strength monitoring
Dec 08 00:00:00 gary-hpelitedesk800g3sff systemd[1]: Failed to start pkgfile database update.
░░ Subject: A start job for unit pkgfile-update.service has failed
░░ A start job for unit pkgfile-update.service has finished with a failure.
░░ The job identifier is 1716 and the job result is failed.
Dec 08 00:02:55 gary-hpelitedesk800g3sff wpa_supplicant[566]: bgscan simple: Failed to enable signal strength monitoring
Dec 08 13:31:02 gary-hpelitedesk800g3sff wpa_supplicant[566]: bgscan simple: Failed to enable signal strength monitoring
Dec 08 13:48:27 gary-hpelitedesk800g3sff wpa_supplicant[566]: bgscan simple: Failed to enable signal strength monitoring
Dec 08 14:21:59 gary-hpelitedesk800g3sff wpa_supplicant[566]: bgscan simple: Failed to enable signal strength monitoring
Dec 08 14:26:38 gary-hpelitedesk800g3sff wpa_supplicant[566]: bgscan simple: Failed to enable signal strength monitoring
Dec 08 18:43:39 gary-hpelitedesk800g3sff wpa_supplicant[566]: bgscan simple: Failed to enable signal strength monitoring
Dec 08 19:13:03 gary-hpelitedesk800g3sff wpa_supplicant[566]: bgscan simple: Failed to enable signal strength monitoring
Dec 09 08:53:04 gary-hpelitedesk800g3sff wpa_supplicant[566]: bgscan simple: Failed to enable signal strength monitoring
Dec 09 11:22:35 gary-hpelitedesk800g3sff wpa_supplicant[566]: bgscan simple: Failed to enable signal strength monitoring
Dec 09 14:38:30 gary-hpelitedesk800g3sff systemd-coredump[756677]: Failed to connect to coredump service: Connection refused
Dec 09 14:38:30 gary-hpelitedesk800g3sff pulseaudio[1079]: Error opening PCM device front:0: No such file or directory
Some errors from sudo dmesg
0.115236] x86/cpu: VMX (outside TXT) disabled by BIOS
[    0.115237] x86/cpu: SGX disabled by BIOS.
0.137344] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[    0.137344] MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
[    0.137344]  #5 #6 #7
 0.321803] ACPI: button: Power Button [PWRF]
[    0.321935] ACPI BIOS Error (bug): Could not resolve symbol [\_PR.PR00._CPC], AE_NOT_FOUND (20210730/psargs-330)
[    0.321942] ACPI Error: Aborting method \_PR.PR01._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
[    0.322033] ACPI BIOS Error (bug): Could not resolve symbol [\_PR.PR00._CPC], AE_NOT_FOUND (20210730/psargs-330)
[    0.322039] ACPI Error: Aborting method \_PR.PR02._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
[    0.322184] ACPI BIOS Error (bug): Could not resolve symbol [\_PR.PR00._CPC], AE_NOT_FOUND (20210730/psargs-330)
[    0.322190] ACPI Error: Aborting method \_PR.PR03._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
[    0.322283] ACPI BIOS Error (bug): Could not resolve symbol [\_PR.PR00._CPC], AE_NOT_FOUND (20210730/psargs-330)
[    0.322287] ACPI Error: Aborting method \_PR.PR04._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
[    0.322398] ACPI BIOS Error (bug): Could not resolve symbol [\_PR.PR00._CPC], AE_NOT_FOUND (20210730/psargs-330)
[    0.322402] ACPI Error: Aborting method \_PR.PR05._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
[    0.322524] ACPI BIOS Error (bug): Could not resolve symbol [\_PR.PR00._CPC], AE_NOT_FOUND (20210730/psargs-330)
[    0.322529] ACPI Error: Aborting method \_PR.PR06._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
[    0.322696] ACPI BIOS Error (bug): Could not resolve symbol [\_PR.PR00._CPC], AE_NOT_FOUND (20210730/psargs-330)
[    0.322700] ACPI Error: Aborting method \_PR.PR07._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
did you tried with different kernel? try the kernel 6:
sudo mhwd-kernel -i linux60
also provide logs from this:
journalctl -b0 -p4 --no-pager
and disable baloo: system settings/file search and uncheck all options, click apply
Thank you. Here is the log. I will try Kernel linux60 right. I tried going down to 5.10 recommended from 5.15 but that had no effect yesterday. I aso disabled Baloo when I first installed Manajro on this machine. I followed instructions from, I think, this forum.
journalctl -b0 -p4 --no-pager         ✔
Dec 10 12:07:54 gary-hpelitedesk800g3sff kernel: x86/cpu: VMX (outside TXT) disabled by BIOS
Dec 10 12:07:54 gary-hpelitedesk800g3sff kernel: x86/cpu: SGX disabled by BIOS.
Dec 10 12:07:54 gary-hpelitedesk800g3sff kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Dec 10 12:07:54 gary-hpelitedesk800g3sff kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
Dec 10 12:07:54 gary-hpelitedesk800g3sff kernel:  #5 #6 #7
Dec 10 12:07:54 gary-hpelitedesk800g3sff kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Dec 10 12:07:54 gary-hpelitedesk800g3sff kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_PR.PR00._CPC], AE_NOT_FOUND (20210730/psargs-330)
Dec 10 12:07:54 gary-hpelitedesk800g3sff kernel: ACPI Error: Aborting method \_PR.PR01._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Dec 10 12:07:54 gary-hpelitedesk800g3sff kernel: ACPI Error: Aborting method \_PR.PR02._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Dec 10 12:07:54 gary-hpelitedesk800g3sff kernel: ACPI Error: Aborting method \_PR.PR03._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Dec 10 12:07:54 gary-hpelitedesk800g3sff kernel: ACPI Error: Aborting method \_PR.PR04._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Dec 10 12:07:54 gary-hpelitedesk800g3sff kernel: ACPI Error: Aborting method \_PR.PR05._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Dec 10 12:07:54 gary-hpelitedesk800g3sff kernel: ACPI Error: Aborting method \_PR.PR06._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Dec 10 12:07:54 gary-hpelitedesk800g3sff kernel: ACPI Error: Aborting method \_PR.PR07._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Dec 10 12:07:54 gary-hpelitedesk800g3sff kernel: usb: port power management may be unreliable
Dec 10 12:07:54 gary-hpelitedesk800g3sff kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Dec 10 12:07:54 gary-hpelitedesk800g3sff kernel: acpi PNP0C14:02: duplicate WMI GUID 2B814318-4BE8-4707-9D84-A190A859B5D0 (first instance was on PNP0C14:00)
Dec 10 12:07:54 gary-hpelitedesk800g3sff kernel: acpi PNP0C14:02: duplicate WMI GUID 41227C2D-80E1-423F-8B8E-87E32755A0EB (first instance was on PNP0C14:00)
Dec 10 12:07:54 gary-hpelitedesk800g3sff kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Dec 10 12:07:55 gary-hpelitedesk800g3sff kernel: 8814au: loading out-of-tree module taints kernel.
Dec 10 12:07:55 gary-hpelitedesk800g3sff kernel: hp_wmi: query 0x4 returned error 0x5
Dec 10 12:07:55 gary-hpelitedesk800g3sff kernel: hp_wmi: query 0xd returned error 0x5
Dec 10 12:07:56 gary-hpelitedesk800g3sff kernel: kauditd_printk_skb: 29 callbacks suppressed
Dec 10 12:08:01 gary-hpelitedesk800g3sff systemd[581]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
Dec 10 12:08:01 gary-hpelitedesk800g3sff systemd[581]: Failed to start Update XDG user dir configuration.
Dec 10 12:08:02 gary-hpelitedesk800g3sff sddm-greeter[590]: QFont::fromString: Invalid description '(empty)'
Dec 10 12:08:02 gary-hpelitedesk800g3sff sddm-greeter[590]: QObject: Cannot create children for a parent that is in a different thread.
                                                            (Parent is QGuiApplication(0x7ffe0e4d9330), parent's thread is QThread(0x557db5428490), current thread is QThread(0x557db5549bf0)
Dec 10 12:08:02 gary-hpelitedesk800g3sff sddm-greeter[590]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Dec 10 12:08:04 gary-hpelitedesk800g3sff sddm-greeter[590]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Dec 10 12:08:04 gary-hpelitedesk800g3sff sddm-greeter[590]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
Dec 10 12:08:04 gary-hpelitedesk800g3sff sddm-greeter[590]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Dec 10 12:08:05 gary-hpelitedesk800g3sff sddm-greeter[590]: libpng warning: iCCP: known incorrect sRGB profile
Dec 10 12:08:05 gary-hpelitedesk800g3sff sddm-greeter[590]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Dec 10 12:08:05 gary-hpelitedesk800g3sff sddm-greeter[590]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.20'
Dec 10 12:08:06 gary-hpelitedesk800g3sff kernel: kauditd_printk_skb: 7 callbacks suppressed
Dec 10 12:08:06 gary-hpelitedesk800g3sff systemd[1]: pkgfile-update.service: Failed with result 'exit-code'.
Dec 10 12:08:06 gary-hpelitedesk800g3sff systemd[1]: Failed to start pkgfile database update.
Dec 10 12:08:10 gary-hpelitedesk800g3sff ksplashqml[670]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
Dec 10 12:08:10 gary-hpelitedesk800g3sff ksplashqml[670]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:81:29: Unable to assign int to QEasingCurve
Dec 10 12:08:11 gary-hpelitedesk800g3sff ksmserver[727]: Qt: Session management error: networkIdsList argument is NULL
Dec 10 12:08:11 gary-hpelitedesk800g3sff ksmserver[727]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.12'
Dec 10 12:08:11 gary-hpelitedesk800g3sff kwin_x11[730]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Dec 10 12:08:11 gary-hpelitedesk800g3sff kwin_x11[730]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Dec 10 12:08:12 gary-hpelitedesk800g3sff backlighthelper[888]: org.kde.powerdevil: no kernel backlight interface found
Dec 10 12:08:12 gary-hpelitedesk800g3sff org_kde_powerdevil[815]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Dec 10 12:08:12 gary-hpelitedesk800g3sff org_kde_powerdevil[815]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Dec 10 12:08:12 gary-hpelitedesk800g3sff pipewire[905]: mod.rt: Can't find xdg-portal: (null)
Dec 10 12:08:12 gary-hpelitedesk800g3sff pipewire[905]: mod.rt: found session bus but no portal
Dec 10 12:08:12 gary-hpelitedesk800g3sff pipewire-media-session[906]: mod.rt: Can't find xdg-portal: (null)
Dec 10 12:08:12 gary-hpelitedesk800g3sff pipewire-media-session[906]: mod.rt: found session bus but no portal
Dec 10 12:08:12 gary-hpelitedesk800g3sff org_kde_powerdevil[815]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Dec 10 12:08:12 gary-hpelitedesk800g3sff org_kde_powerdevil[815]: org.kde.powerdevil: The profile  "AC" tried to activate "DimDisplay" a non-existent action. This is usually due to an installation problem, a configuration problem, or because the action is not supported
Dec 10 12:08:13 gary-hpelitedesk800g3sff plasmashell[777]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Dec 10 12:08:13 gary-hpelitedesk800g3sff plasmashell[777]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Dec 10 12:08:13 gary-hpelitedesk800g3sff plasmashell[777]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Dec 10 12:08:14 gary-hpelitedesk800g3sff kwin_x11[730]: kwin_core: XCB error: 3 (BadWindow), sequence: 1769, resource id: 4194337, major code: 129 (SHAPE), minor code: 6 (Input)
Dec 10 12:08:14 gary-hpelitedesk800g3sff kwin_x11[730]: kwin_core: XCB error: 152 (BadDamage), sequence: 1780, resource id: 23068715, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 10 12:08:14 gary-hpelitedesk800g3sff plasmashell[777]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:534:9: QML Label: Binding loop detected for property "height"
Dec 10 12:08:14 gary-hpelitedesk800g3sff plasmashell[777]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:499:13: QML Label: Binding loop detected for property "height"
Dec 10 12:08:14 gary-hpelitedesk800g3sff plasmashell[777]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Dec 10 12:08:14 gary-hpelitedesk800g3sff plasmashell[777]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:556:5: QML Label: Binding loop detected for property "height"
Dec 10 12:08:14 gary-hpelitedesk800g3sff plasmashell[777]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Dec 10 12:08:14 gary-hpelitedesk800g3sff plasmashell[777]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
Dec 10 12:08:15 gary-hpelitedesk800g3sff plasmashell[777]: libpng warning: iCCP: known incorrect sRGB profile
Dec 10 12:08:15 gary-hpelitedesk800g3sff plasmashell[777]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Dec 10 12:08:15 gary-hpelitedesk800g3sff pulseaudio[1065]: stat('/etc/pulse/default.pa.d'): No such file or directory
Dec 10 12:08:15 gary-hpelitedesk800g3sff plasmashell[777]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Dec 10 12:08:15 gary-hpelitedesk800g3sff plasmashell[777]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x564a59716750) QQmlContext(0x564a58cb3d70) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Dec 10 12:08:15 gary-hpelitedesk800g3sff plasmashell[777]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Dec 10 12:08:15 gary-hpelitedesk800g3sff plasmashell[777]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Dec 10 12:08:15 gary-hpelitedesk800g3sff plasmashell[777]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1f.3.analog-stereo.monitor"
Dec 10 12:08:17 gary-hpelitedesk800g3sff plasmashell[777]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Dec 10 12:08:19 gary-hpelitedesk800g3sff plasmashell[777]: qt.svg: <input>:662:9: Could not resolve property: #radialGradient3118
Dec 10 12:08:19 gary-hpelitedesk800g3sff plasmashell[777]: qt.svg: <input>:662:9: Could not resolve property: #radialGradient3112
Dec 10 12:08:19 gary-hpelitedesk800g3sff plasmashell[777]: qt.svg: <input>:662:9: Could not resolve property: #radialGradient3321
Dec 10 12:08:19 gary-hpelitedesk800g3sff plasmashell[777]: qt.svg: <input>:662:9: Could not resolve property: #radialGradient3327
Dec 10 12:08:19 gary-hpelitedesk800g3sff plasmashell[777]: qt.svg: <input>:662:9: Could not resolve property: #radialGradient3085
Dec 10 12:08:19 gary-hpelitedesk800g3sff plasmashell[777]: qt.svg: <input>:662:9: Could not resolve property: #radialGradient3101
Dec 10 12:08:19 gary-hpelitedesk800g3sff plasmashell[777]: qt.svg: <input>:662:9: Could not resolve property: #radialGradient3139
Dec 10 12:08:19 gary-hpelitedesk800g3sff plasmashell[777]: qt.svg: <input>:662:9: Could not resolve property: #radialGradient3133
Dec 10 12:08:19 gary-hpelitedesk800g3sff plasmashell[777]: qt.svg: <input>:662:9: Could not resolve property: #radialGradient3499
Dec 10 12:08:19 gary-hpelitedesk800g3sff plasmashell[777]: qt.svg: <input>:662:9: Could not resolve property: #radialGradient3505
Dec 10 12:08:19 gary-hpelitedesk800g3sff plasmashell[777]: qt.svg: <input>:662:9: Could not resolve property: #radialGradient3047
Dec 10 12:08:19 gary-hpelitedesk800g3sff plasmashell[777]: qt.svg: <input>:662:9: Could not resolve property: #radialGradient3041
Dec 10 12:08:19 gary-hpelitedesk800g3sff plasmashell[777]: qt.svg: <input>:662:9: Could not resolve property: #radialGradient3079
Dec 10 12:08:19 gary-hpelitedesk800g3sff plasmashell[777]: qt.svg: <input>:662:9: Could not resolve property: #radialGradient3073
Dec 10 12:08:19 gary-hpelitedesk800g3sff kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 10 12:08:22 gary-hpelitedesk800g3sff plasmashell[777]: file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/ConnectionItem.qml:45:32: QML Action: Accessible must be attached to an Item
Dec 10 12:08:22 gary-hpelitedesk800g3sff plasmashell[777]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:162: TypeError: Cannot read property 'text' of null
Dec 10 12:08:22 gary-hpelitedesk800g3sff plasmashell[777]: trying to show an empty dialog
Dec 10 12:08:23 gary-hpelitedesk800g3sff ModemManager[451]: <warn>  [plugin/generic] could not grab port ttyS4: Cannot add port 'tty/ttyS4', unhandled port type
Dec 10 12:08:23 gary-hpelitedesk800g3sff ModemManager[451]: <warn>  [base-manager] couldn't create modem for device '/sys/devices/pci0000:00/0000:00:16.3': Failed to find primary AT port
Dec 10 12:08:24 gary-hpelitedesk800g3sff kwalletd5[654]: Application ' "kded5" ' using kwallet without parent window!
Dec 10 12:08:24 gary-hpelitedesk800g3sff plasmashell[777]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Dec 10 12:08:25 gary-hpelitedesk800g3sff plasmashell[777]: file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/ConnectionItem.qml:45:32: QML Action: Accessible must be attached to an Item
Dec 10 12:08:25 gary-hpelitedesk800g3sff plasmashell[777]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:162: TypeError: Cannot read property 'text' of null
Dec 10 12:08:26 gary-hpelitedesk800g3sff kwin_x11[730]: kwin_core: XCB error: 152 (BadDamage), sequence: 9123, resource id: 23069137, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 10 12:08:30 gary-hpelitedesk800g3sff plasmashell[777]: file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/ConnectionItem.qml:45:32: QML Action: Accessible must be attached to an Item
Dec 10 12:08:30 gary-hpelitedesk800g3sff plasmashell[777]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Dec 10 12:08:31 gary-hpelitedesk800g3sff wpa_supplicant[542]: bgscan simple: Failed to enable signal strength monitoring
Dec 10 12:08:31 gary-hpelitedesk800g3sff plasmashell[777]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x564a5bc364b0) QQmlContext(0x564a58cb3d70) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Dec 10 12:08:31 gary-hpelitedesk800g3sff plasmashell[777]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Dec 10 12:08:31 gary-hpelitedesk800g3sff plasmashell[777]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Dec 10 12:08:34 gary-hpelitedesk800g3sff kwin_x11[730]: kwin_core: XCB error: 152 (BadDamage), sequence: 14707, resource id: 23069962, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 10 12:08:38 gary-hpelitedesk800g3sff kded5[729]: kf.bluezqt: PendingCall Error: "Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken."
Dec 10 12:08:38 gary-hpelitedesk800g3sff pulseaudio[1065]: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
Dec 10 12:08:38 gary-hpelitedesk800g3sff plasmashell[777]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:433: Unable to assign [undefined] to QString
Dec 10 12:08:39 gary-hpelitedesk800g3sff plasmashell[777]: trying to show an empty dialog
Dec 10 12:08:42 gary-hpelitedesk800g3sff systemsettings[1192]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ScrollablePage.qml:203:9: QML MouseArea: Binding loop detected for property "width"
Dec 10 12:08:42 gary-hpelitedesk800g3sff systemsettings[1192]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Dec 10 12:08:45 gary-hpelitedesk800g3sff systemsettings[1192]: QLayout::removeWidget: Cannot remove a null widget.
Dec 10 12:09:31 gary-hpelitedesk800g3sff kwin_x11[730]: kwin_core: XCB error: 152 (BadDamage), sequence: 32692, resource id: 23071708, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Unfortunately, the kernel didn’t stop the fan from running as soon as I press the start button. Apparently my internet connection device doesn’t like that kernel because couldn’t find any WIFI networks until switched back to 5.15.
I forgot that I read that should try to update the BIOS information by clicking the “link” in setup. I tried that but, of course, should have realized that an line internet connection is required. Gave up on that about 2 AM but will move equipment to where I can reach a wired connection and see if that helps.
Thanks for the help.
this looks like it could be some bios setting, since it worked normally until now… check if in bios you have som setting regarding fans, like fan always on…
also you could try booting into manjaro live usb, to see if the fan keeps running there too…
Thank you. I don’t understand what happened just now. I had to unplug the CPU to move it where the internet router is located so that it could be connected with a wire to try to update the BIOS. When I turned it on, the fan was running normally again. I thought perhaps the cause was the WIFI device I use, since that was the only other difference, but when I plugged it in the fan still didn’t blow.
I updated the BIOS anyway since it was connected and there was an update from 2.43 to 2.44, rollback to 2.40. It finished successfully and I returned the machine to its original location and it seems to be working fine still.
I thought perhaps the fan blew up or burned out but, after removing the cover, I can see it spinning slowly.
I shut the machine down (not just a restart) several times the past day while trying different kernels and other attempts to identify the cause–and because the fan couldn’t be left running full blast; but I never unplugged it from the wall socket. I don’t know why that would make a difference but it appears to have done so.
Perhaps it is an indication of another underlying hardware issue that will more fully manifest itself in the future but I don’t know enough to speculate.
Is there anything I can monitor to attempt to identify an underlying issue before it fails completely or causes additional damage, if it ccan cause additional damage?
Thanks again for the guidance.
maybe some hardware/electricity bug? … i wouldnt worry about it, if its not happens regularly
