Hi,
since some weeks ago moving and resizing windows stutters and my systemmonitor widgets are only showing their nubers but are missing their graphs.
If I open the systemmonitor it says (roughly translated from my language): “Systemmonitor fell back to softwarerendering because hardwareacceleration is not available and visual errors may occour. Please check your graphics driver”
I’ve tried OpenGL 2.0 and OpenGL 3.1 under Settings → Compositor but both behave the same.
Has someone an idea what may cause this?
inxi:
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: initrd=\amd-ucode.img initrd=\intel-ucode.img
initrd=\initramfs-5.13-x86_64.img zfs=pMain/os/root rw
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: X570 AORUS ULTRA v: -CF
serial: <filter>
Mobo: Gigabyte model: X570 AORUS ULTRA v: x.x serial: <filter>
UEFI: American Megatrends v: F31 date: 12/31/2020
ID-1: hidpp_battery_0 charge: N/A condition: N/A volts: 4.2 min: N/A
model: Logitech G502 LIGHTSPEED Wireless Gaming Mouse type: N/A
serial: <filter> status: Discharging
RAM: total: 62.75 GiB used: 17.58 GiB (28.0%)
Info: 12-Core model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701021 cache:
L2: 6 MiB bogomips: 182133
Speed: 3268 MHz min/max: 2200/3800 MHz boost: enabled Core speeds (MHz):
1: 3268 2: 2070 3: 2196 4: 2196 5: 4004 6: 2188 7: 2195 8: 2196 9: 2195
10: 2205 11: 2151 12: 2130 13: 2053 14: 3160 15: 2196 16: 2195 17: 2196
18: 2196 19: 2196 20: 2191 21: 2052 22: 2072 23: 2272 24: 2195
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es sha_ni
skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
conditional, RSB filling
Device-1: NVIDIA GP104 [GeForce GTX 1080] vendor: ZOTAC driver: nvidia
v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 0b:00.0
chip-ID: 10de:1b80 class-ID: 0300
Screen-1: 0 s-res: 6720x2160 s-dpi: 141 s-size: 1207x388mm (47.5x15.3")
s-diag: 1268mm (49.9")
Monitor-1: DVI-D-0 res: 2880x1620 hz: 60 dpi: 140
size: 521x293mm (20.5x11.5") diag: 598mm (23.5")
Monitor-2: DP-0 res: 3840x2160 hz: 60 dpi: 163 size: 598x336mm (23.5x13.2")
diag: 686mm (27")
OpenGL: renderer: NVIDIA GeForce GTX 1080/PCIe/SSE2
v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Device-1: NVIDIA GP104 High Definition Audio vendor: ZOTAC
driver: snd_hda_intel v: kernel bus-ID: 0b:00.1 chip-ID: 10de:10f0
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 0d:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-3: Corsair VOID PRO Wireless Gaming Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-3.4.4:7
chip-ID: 1b1c:0a14 class-ID: 0300
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.37 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 06:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlp6s0 state: down mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
port: f000 bus-ID: 07:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: ASUSTek Broadcom BCM20702A0 Bluetooth type: USB driver: btusb
v: 0.8 bus-ID: 3-3.1.1:8 chip-ID: 0b05:17cb class-ID: fe01 serial: <filter>
Report: rfkill ID: hci1 rfk-id: 2 state: up address: see --recommends
Device-2: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-5:4
Report: ID: hci0 rfk-id: 1 state: up address: N/A
Device-1: pMain type: zfs status: ONLINE level: linear raw: size: 2.63 TiB
free: 1.69 TiB allocated: 966 GiB zfs-fs: size: 2.55 TiB free: 1.61 TiB
Components: Online:
1: nvme0n1p2 maj-min: 259:2 size: 846.51 GiB
2: nvme1n1 maj-min: 259:5 size: 931.51 GiB
3: nvme2n1 maj-min: 259:4 size: 931.51 GiB
Local Storage: total: raw: 13.7 TiB usable: 16.24 TiB used: 2.57 TiB (15.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Gigabyte model: GP-ASM2NE6100TTTD
lanes: 4 type: SSD serial: <filter> rev: EGFM11.2 temp: 48.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Gigabyte model: GP-ASM2NE6100TTTD
lanes: 4 type: SSD serial: <filter> rev: EGFM11.2 temp: 43.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:4 vendor: Gigabyte model: GP-ASM2NE6100TTTD
lanes: 4 type: SSD serial: <filter> rev: EGFM11.2 temp: 50.9 C scheme: GPT
ID-4: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD40EZRX-00SPEB0
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: 0A80 scheme: GPT
ID-5: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000VN008-2DR166
type: HDD rpm: 5980 serial: <filter> rev: SC60 scheme: GPT
ID-6: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST4000VN008-2DR166
ID-7: /dev/sdd maj-min: 8:48 type: USB vendor: SanDisk model: Ultra Trek
size: 57.3 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00
ID-1: / raw-size: N/A size: 1.85 TiB used: 244.1 GiB (12.9%) fs: zfs
logical: pMain/os/root
ID-2: /backup1 raw-size: 3.64 TiB size: 3.64 TiB (100.00%)
used: 1.64 TiB (45.0%) fs: ntfs dev: /dev/sdc2 maj-min: 8:34 label: Backup
uuid: 781E50C11E5079D8
ID-3: /backup2 raw-size: 3.64 TiB size: 3.64 TiB (100.00%)
used: 38.67 GiB (1.0%) fs: ntfs dev: /dev/sdb2 maj-min: 8:18 label: Backup 2
uuid: 3E944F9F944F5913
ID-4: /boot raw-size: 5 GiB size: 4.99 GiB (99.80%) used: 112.3 MiB (2.2%)
fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A uuid: 6461-6E21
ID-5: /home raw-size: N/A size: 1.61 TiB used: 128 KiB (0.0%) fs: zfs
logical: pMain/data/home
ID-6: /home/alexander raw-size: N/A size: 2.21 TiB used: 619.36 GiB (27.3%)
fs: zfs logical: pMain/data/home/alexander
ID-7: /home/<filter>/Downloads raw-size: N/A size: 1.62 TiB
used: 14.95 GiB (0.9%) fs: zfs logical: pMain/data/Downloads
ID-8: /home/<filter>/Programs raw-size: N/A size: 1.64 TiB
used: 36.3 GiB (2.2%) fs: zfs logical: pMain/data/Programs
ID-9: /nfs/webserver raw-size: N/A size: 2.69 TiB used: 615.31 GiB (22.4%)
fs: nfs4 remote: 10.0.0.20:/storage/webserver
ID-10: /root raw-size: N/A size: 1.61 TiB used: 874.2 MiB (0.1%) fs: zfs
logical: pMain/data/home/root
ID-11: /tmp raw-size: N/A size: 1.61 TiB used: 83.9 MiB (0.0%) fs: zfs
logical: pMain/temp/tmp
Kernel: swappiness: 15 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 80 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: Swap
uuid: 5d8f4dda-6290-47a2-8654-4fd214e4f35c
ID-1: /dev/nvme1n1p9 maj-min: 259:9 size: 8 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme2n1p9 maj-min: 259:7 size: 8 MiB fs: <superuser required>
ID-3: /dev/sda1 maj-min: 8:1 size: 128 MiB fs: <superuser required>
ID-4: /dev/sda2 maj-min: 8:2 size: 3.64 TiB fs: ntfs label: Datengrab
uuid: 2C2E4BF52E4BB69C
ID-5: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
ID-6: /dev/sdc1 maj-min: 8:33 size: 16 MiB fs: <superuser required>
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Device-1: 1-1:2 info: Integrated Express IT8297 RGB LED Controller
type: Keyboard driver: hid-generic,usbhid interfaces: 1 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 048d:8297 class-ID: 0301
Hub-2: 1-3:3 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2817 class-ID: 0900
Hub-3: 1-3.4:5 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
Device-1: 1-3.4.4:7 info: Corsair VOID PRO Wireless Gaming Headset
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 1b1c:0a14 class-ID: 0300
Hub-4: 1-6:4 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-6.1:6 info: Atmel WootingTwo type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 7 rev: 2.0 speed: 12 Mb/s
power: 400mA chip-ID: 03eb:ff02 class-ID: 0300 serial: <filter>
Hub-5: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-6: 2-2:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 2109:0817 class-ID: 0900
Hub-7: 2-2.4:3 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.1 speed: 5 Gb/s
Hub-8: 3-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Device-1: 3-2:2 info: Logitech USB Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c539 class-ID: 0300
Hub-9: 3-3:3 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 0bda:5411 class-ID: 0900
Hub-10: 3-3.1:5 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
Device-1: 3-3.1.1:8 info: ASUSTek Broadcom BCM20702A0 Bluetooth
type: Bluetooth driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0b05:17cb class-ID: fe01 serial: <filter>
Device-2: 3-3.1.4:10 info: Valve Watchman Dongle type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 20mA
chip-ID: 28de:2101 class-ID: 0300 serial: <filter>
Hub-11: 3-3.2:7 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
Device-1: 3-3.2.3:11 info: Reiner SCT Kartensysteme cyberJack RFID standard
dual interface smartcard reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 192mA chip-ID: 0c4b:0500 class-ID: 0000 serial: <filter>
Device-2: 3-3.2.4:14 info: Valve Wireless Steam Controller
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 5 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 28de:1142 class-ID: 0300
Hub-12: 3-3.3:9 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
Hub-13: 3-3.4:12 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
Device-1: 3-3.4.2:16 info: Valve Watchman Dongle type: HID
Device-2: 3-5:4 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-14: 3-6:6 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-15: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Device-1: 4-1:2 info: SanDisk Ultra Trek type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s power: 896mA
chip-ID: 0781:559f class-ID: 0806 serial: <filter>
Hub-16: 4-3:3 info: Realtek Hub ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 0bda:0411 class-ID: 0900
Hub-17: 4-3.1:4 info: Realtek Hub ports: 4 rev: 3.1 speed: 5 Gb/s
Hub-18: 4-3.2:5 info: Realtek Hub ports: 4 rev: 3.1 speed: 5 Gb/s
Hub-19: 4-3.3:6 info: Realtek Hub ports: 4 rev: 3.1 speed: 5 Gb/s
Hub-20: 4-3.4:7 info: Realtek Hub ports: 4 rev: 3.1 speed: 5 Gb/s
Hub-21: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-22: 5-4:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Hub-23: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1
Hub-24: 6-4:2 info: Genesys Logic Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 05e3:0612 class-ID: 0900
System Temperatures: cpu: 53.9 C mobo: 16.8 C gpu: nvidia temp: 58 C
Processes: 620 Uptime: 1h 44m wakeups: 8 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1539
lib: 448 Shell: Zsh v: 5.8 default: Bash v: 5.1.8 running-in: konsole
inxi: 3.3.06
glxinfo:
name of display: :0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: NVIDIA Corporation
server glx version string: 1.4
server glx extensions:
GLX_ARB_context_flush_control, GLX_ARB_create_context,
GLX_ARB_create_context_no_error, GLX_ARB_create_context_profile,
GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float,
GLX_ARB_multisample, GLX_EXT_buffer_age,
GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile,
GLX_EXT_framebuffer_sRGB, GLX_EXT_import_context, GLX_EXT_libglvnd,
GLX_EXT_stereo_tree, GLX_EXT_swap_control, GLX_EXT_swap_control_tear,
GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_NV_copy_image, GLX_NV_delay_before_swap, GLX_NV_float_buffer,
GLX_NV_multigpu_context, GLX_NV_robustness_video_memory_purge,
GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGI_swap_control,
GLX_SGI_video_sync
client glx vendor string: NVIDIA Corporation
client glx version string: 1.4
client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_buffer_age,
GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB,
GLX_EXT_import_context, GLX_EXT_stereo_tree, GLX_EXT_swap_control,
GLX_EXT_swap_control_tear, GLX_EXT_texture_from_pixmap,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_NV_copy_buffer,
GLX_NV_multigpu_context, GLX_NV_multisample_coverage,
GLX_NV_robustness_video_memory_purge, GLX_NV_swap_group,
GLX_SGI_video_sync
GLX version: 1.4
GLX extensions:
GLX_EXT_framebuffer_sRGB, GLX_EXT_import_context, GLX_EXT_stereo_tree,
GLX_SGI_video_sync
Memory info (GL_NVX_gpu_memory_info):
Dedicated video memory: 8192 MB
Total available memory: 8192 MB
Currently available dedicated video memory: 5234 MB
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: NVIDIA GeForce GTX 1080/PCIe/SSE2
OpenGL core profile version string: 4.6.0 NVIDIA 470.63.01
OpenGL core profile shading language version string: 4.60 NVIDIA
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
GL_AMD_multi_draw_indirect, GL_AMD_seamless_cubemap_per_texture,
GL_AMD_vertex_shader_layer, GL_AMD_vertex_shader_viewport_index,
GL_ARB_ES2_compatibility, GL_ARB_ES3_1_compatibility,
GL_ARB_ES3_2_compatibility, GL_ARB_ES3_compatibility,
GL_ARB_arrays_of_arrays, GL_ARB_base_instance, GL_ARB_bindless_texture,
GL_ARB_blend_func_extended, GL_ARB_buffer_storage,
GL_ARB_clear_buffer_object, GL_ARB_clear_texture, GL_ARB_clip_control,
GL_ARB_color_buffer_float, GL_ARB_compressed_texture_pixel_storage,
GL_ARB_compute_shader, GL_ARB_compute_variable_group_size,
GL_ARB_conditional_render_inverted, GL_ARB_conservative_depth,
GL_ARB_copy_buffer, GL_ARB_copy_image, GL_ARB_cull_distance,
GL_ARB_debug_output, GL_ARB_depth_buffer_float, GL_ARB_depth_clamp,
GL_ARB_depth_texture, GL_ARB_derivative_control,
GL_ARB_direct_state_access, GL_ARB_draw_buffers,
GL_ARB_draw_buffers_blend, GL_ARB_draw_elements_base_vertex,
GL_ARB_draw_indirect, GL_ARB_draw_instanced, GL_ARB_enhanced_layouts,
GL_ARB_explicit_attrib_location, GL_ARB_explicit_uniform_location,
GL_ARB_fragment_coord_conventions, GL_ARB_fragment_layer_viewport,
GL_ARB_fragment_program, GL_ARB_fragment_program_shadow,
GL_ARB_fragment_shader, GL_ARB_fragment_shader_interlock,
GL_ARB_framebuffer_no_attachments, GL_ARB_framebuffer_object,
GL_ARB_framebuffer_sRGB, GL_ARB_geometry_shader4,
GL_ARB_get_program_binary, GL_ARB_get_texture_sub_image, GL_ARB_gl_spirv,
GL_ARB_gpu_shader5, GL_ARB_gpu_shader_fp64, GL_ARB_gpu_shader_int64,
GL_ARB_half_float_pixel, GL_ARB_half_float_vertex, GL_ARB_imaging,
GL_ARB_indirect_parameters, GL_ARB_instanced_arrays,
GL_ARB_internalformat_query, GL_ARB_internalformat_query2,
GL_ARB_invalidate_subdata, GL_ARB_map_buffer_alignment,
GL_ARB_map_buffer_range, GL_ARB_multi_bind, GL_ARB_multi_draw_indirect,
GL_ARB_multisample, GL_ARB_multitexture, GL_ARB_occlusion_query,
GL_ARB_occlusion_query2, GL_ARB_parallel_shader_compile,
GL_ARB_pipeline_statistics_query, GL_ARB_pixel_buffer_object,
GL_ARB_point_parameters, GL_ARB_point_sprite, GL_ARB_polygon_offset_clamp,
GL_ARB_post_depth_coverage, GL_ARB_program_interface_query,
GL_ARB_provoking_vertex, GL_ARB_query_buffer_object,
GL_ARB_robust_buffer_access_behavior, GL_ARB_robustness,
GL_ARB_sample_locations, GL_ARB_sample_shading, GL_ARB_sampler_objects,
GL_ARB_seamless_cube_map, GL_ARB_seamless_cubemap_per_texture,
GL_ARB_separate_shader_objects, GL_ARB_shader_atomic_counter_ops,
GL_ARB_shader_atomic_counters, GL_ARB_shader_ballot,
GL_ARB_shader_bit_encoding, GL_ARB_shader_clock,
GL_ARB_shader_draw_parameters, GL_ARB_shader_group_vote,
GL_ARB_shader_image_load_store, GL_ARB_shader_image_size,
GL_ARB_shader_objects, GL_ARB_shader_precision,
GL_ARB_shader_storage_buffer_object, GL_ARB_shader_subroutine,
GL_ARB_shader_texture_image_samples, GL_ARB_shader_texture_lod,
GL_ARB_shader_viewport_layer_array, GL_ARB_shading_language_100,
GL_ARB_shading_language_420pack, GL_ARB_shading_language_include,
GL_ARB_shading_language_packing, GL_ARB_shadow, GL_ARB_sparse_buffer,
GL_ARB_sparse_texture, GL_ARB_sparse_texture2,
GL_ARB_sparse_texture_clamp, GL_ARB_spirv_extensions,
GL_ARB_stencil_texturing, GL_ARB_sync, GL_ARB_tessellation_shader,
GL_ARB_texture_barrier, GL_ARB_texture_border_clamp,
GL_ARB_texture_buffer_object, GL_ARB_texture_buffer_object_rgb32,
GL_ARB_texture_buffer_range, GL_ARB_texture_compression,
GL_ARB_texture_compression_bptc, GL_ARB_texture_compression_rgtc,
GL_ARB_texture_cube_map, GL_ARB_texture_cube_map_array,
GL_ARB_texture_env_add, GL_ARB_texture_env_combine,
GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3,
GL_ARB_texture_filter_anisotropic, GL_ARB_texture_filter_minmax,
GL_ARB_texture_float, GL_ARB_texture_gather,
GL_ARB_texture_mirror_clamp_to_edge, GL_ARB_texture_mirrored_repeat,
GL_ARB_texture_multisample, GL_ARB_texture_non_power_of_two,
GL_ARB_texture_query_levels, GL_ARB_texture_query_lod,
GL_ARB_texture_rectangle, GL_ARB_texture_rg, GL_ARB_texture_rgb10_a2ui,
GL_ARB_texture_stencil8, GL_ARB_texture_storage,
GL_ARB_texture_storage_multisample, GL_ARB_texture_swizzle,
GL_ARB_texture_view, GL_ARB_timer_query, GL_ARB_transform_feedback2,
GL_ARB_transform_feedback3, GL_ARB_transform_feedback_instanced,
GL_ARB_transform_feedback_overflow_query, GL_ARB_transpose_matrix,
GL_ARB_uniform_buffer_object, GL_ARB_vertex_array_bgra,
GL_ARB_vertex_array_object, GL_ARB_vertex_attrib_64bit,
GL_ARB_vertex_attrib_binding, GL_ARB_vertex_buffer_object,
GL_ARB_vertex_program, GL_ARB_vertex_shader,
GL_ARB_vertex_type_10f_11f_11f_rev, GL_ARB_vertex_type_2_10_10_10_rev,
GL_ARB_viewport_array, GL_ARB_window_pos, GL_ATI_draw_buffers,
GL_ATI_texture_float, GL_ATI_texture_mirror_once,
GL_EXTX_framebuffer_mixed_formats, GL_EXT_Cg_shader, GL_EXT_abgr,
GL_EXT_bgra, GL_EXT_bindable_uniform, GL_EXT_blend_color,
GL_EXT_blend_equation_separate, GL_EXT_blend_func_separate,
GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_compiled_vertex_array,
GL_EXT_depth_bounds_test, GL_EXT_direct_state_access,
GL_EXT_draw_buffers2, GL_EXT_draw_instanced, GL_EXT_draw_range_elements,
GL_EXT_fog_coord, GL_EXT_framebuffer_blit, GL_EXT_framebuffer_multisample,
GL_EXT_framebuffer_multisample_blit_scaled, GL_EXT_framebuffer_object,
GL_EXT_framebuffer_sRGB, GL_EXT_geometry_shader4,
GL_EXT_gpu_program_parameters, GL_EXT_gpu_shader4,
GL_EXT_import_sync_object, GL_EXT_memory_object, GL_EXT_memory_object_fd,
GL_EXT_multi_draw_arrays, GL_EXT_multiview_texture_multisample,
GL_EXT_multiview_timer_query, GL_EXT_packed_depth_stencil,
GL_EXT_packed_float, GL_EXT_packed_pixels, GL_EXT_pixel_buffer_object,
GL_EXT_point_parameters, GL_EXT_polygon_offset_clamp,
GL_EXT_post_depth_coverage, GL_EXT_provoking_vertex,
GL_EXT_raster_multisample, GL_EXT_rescale_normal, GL_EXT_secondary_color,
GL_EXT_semaphore, GL_EXT_semaphore_fd, GL_EXT_separate_shader_objects,
GL_EXT_separate_specular_color, GL_EXT_shader_image_load_formatted,
GL_EXT_shader_image_load_store, GL_EXT_shader_integer_mix,
GL_EXT_shadow_funcs, GL_EXT_sparse_texture2, GL_EXT_stencil_two_side,
GL_EXT_stencil_wrap, GL_EXT_texture3D, GL_EXT_texture_array,
GL_EXT_texture_buffer_object, GL_EXT_texture_compression_dxt1,
GL_EXT_texture_compression_latc, GL_EXT_texture_compression_rgtc,
GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map,
GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add,
GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
GL_EXT_texture_filter_anisotropic, GL_EXT_texture_filter_minmax,
GL_EXT_texture_integer, GL_EXT_texture_lod, GL_EXT_texture_lod_bias,
GL_EXT_texture_mirror_clamp, GL_EXT_texture_object, GL_EXT_texture_sRGB,
GL_EXT_texture_sRGB_R8, GL_EXT_texture_sRGB_decode,
GL_EXT_texture_shadow_lod, GL_EXT_texture_shared_exponent,
GL_EXT_texture_storage, GL_EXT_texture_swizzle, GL_EXT_timer_query,
GL_EXT_transform_feedback2, GL_EXT_vertex_array, GL_EXT_vertex_array_bgra,
GL_EXT_vertex_attrib_64bit, GL_EXT_window_rectangles,
GL_EXT_x11_sync_object, GL_IBM_rasterpos_clip,
GL_IBM_texture_mirrored_repeat, GL_KHR_blend_equation_advanced,
GL_KHR_blend_equation_advanced_coherent, GL_KHR_context_flush_control,
GL_KHR_debug, GL_KHR_no_error, GL_KHR_parallel_shader_compile,
GL_KHR_robust_buffer_access_behavior, GL_KHR_robustness,
GL_KHR_shader_subgroup, GL_KTX_buffer_region,
GL_NVX_blend_equation_advanced_multi_draw_buffers,
GL_NVX_conditional_render, GL_NVX_gpu_memory_info, GL_NVX_nvenc_interop,
GL_NVX_progress_fence, GL_NV_ES1_1_compatibility,
GL_NV_ES3_1_compatibility, GL_NV_alpha_to_coverage_dither_control,
GL_NV_bindless_multi_draw_indirect,
GL_NV_bindless_multi_draw_indirect_count, GL_NV_bindless_texture,
GL_NV_blend_equation_advanced, GL_NV_blend_equation_advanced_coherent,
GL_NV_blend_minmax_factor, GL_NV_blend_square, GL_NV_clip_space_w_scaling,
GL_NV_command_list, GL_NV_compute_program5, GL_NV_conditional_render,
GL_NV_conservative_raster, GL_NV_conservative_raster_dilate,
GL_NV_conservative_raster_pre_snap_triangles, GL_NV_copy_depth_to_color,
GL_NV_copy_image, GL_NV_depth_buffer_float, GL_NV_depth_clamp,
GL_NV_draw_texture, GL_NV_draw_vulkan_image, GL_NV_explicit_multisample,
GL_NV_feature_query, GL_NV_fence, GL_NV_fill_rectangle,
GL_NV_float_buffer, GL_NV_fog_distance, GL_NV_fragment_coverage_to_color,
GL_NV_fragment_program, GL_NV_fragment_program2,
GL_NV_fragment_program_option, GL_NV_fragment_shader_interlock,
GL_NV_framebuffer_mixed_samples, GL_NV_framebuffer_multisample_coverage,
GL_NV_geometry_shader4, GL_NV_geometry_shader_passthrough,
GL_NV_gpu_multicast, GL_NV_gpu_program4, GL_NV_gpu_program4_1,
GL_NV_gpu_program5, GL_NV_gpu_program5_mem_extended,
GL_NV_gpu_program_fp64, GL_NV_gpu_shader5, GL_NV_half_float,
GL_NV_internalformat_sample_query, GL_NV_light_max_exponent,
GL_NV_memory_attachment, GL_NV_memory_object_sparse,
GL_NV_multisample_coverage, GL_NV_multisample_filter_hint,
GL_NV_occlusion_query, GL_NV_packed_depth_stencil,
GL_NV_parameter_buffer_object, GL_NV_parameter_buffer_object2,
GL_NV_path_rendering, GL_NV_path_rendering_shared_edge,
GL_NV_pixel_data_range, GL_NV_point_sprite, GL_NV_primitive_restart,
GL_NV_query_resource, GL_NV_query_resource_tag, GL_NV_register_combiners,
GL_NV_register_combiners2, GL_NV_robustness_video_memory_purge,
GL_NV_sample_locations, GL_NV_sample_mask_override_coverage,
GL_NV_shader_atomic_counters, GL_NV_shader_atomic_float,
GL_NV_shader_atomic_float64, GL_NV_shader_atomic_fp16_vector,
GL_NV_shader_atomic_int64, GL_NV_shader_buffer_load,
GL_NV_shader_storage_buffer_object, GL_NV_shader_subgroup_partitioned,
GL_NV_shader_thread_group, GL_NV_shader_thread_shuffle,
GL_NV_stereo_view_rendering, GL_NV_texgen_reflection,
GL_NV_texture_barrier, GL_NV_texture_compression_vtc,
GL_NV_texture_env_combine4, GL_NV_texture_multisample,
GL_NV_texture_rectangle, GL_NV_texture_rectangle_compressed,
GL_NV_texture_shader, GL_NV_texture_shader2, GL_NV_texture_shader3,
GL_NV_timeline_semaphore, GL_NV_transform_feedback,
GL_NV_transform_feedback2, GL_NV_uniform_buffer_unified_memory,
GL_NV_vdpau_interop, GL_NV_vdpau_interop2, GL_NV_vertex_array_range,
GL_NV_vertex_array_range2, GL_NV_vertex_attrib_integer_64bit,
GL_NV_vertex_buffer_unified_memory, GL_NV_vertex_program,
GL_NV_vertex_program1_1, GL_NV_vertex_program2,
GL_NV_vertex_program2_option, GL_NV_vertex_program3,
GL_NV_viewport_array2, GL_NV_viewport_swizzle, GL_OVR_multiview,
GL_OVR_multiview2, GL_S3_s3tc, GL_SGIS_generate_mipmap,
GL_SGIS_texture_lod, GL_SGIX_depth_texture, GL_SGIX_shadow,
GL_SUN_slice_accum
OpenGL version string: 4.6.0 NVIDIA 470.63.01
OpenGL shading language version string: 4.60 NVIDIA
OpenGL context flags: (none)
OpenGL profile mask: (none)
OpenGL extensions:
GL_ARB_color_buffer_float, GL_ARB_compatibility,
GL_ARB_compressed_texture_pixel_storage, GL_ARB_compute_shader,
GL_ARB_compute_variable_group_size, GL_ARB_conditional_render_inverted,
GL_ARB_conservative_depth, GL_ARB_copy_buffer, GL_ARB_copy_image,
GL_ARB_cull_distance, GL_ARB_debug_output, GL_ARB_depth_buffer_float,
GL_ARB_depth_clamp, GL_ARB_depth_texture, GL_ARB_derivative_control,
GL_SUN_slice_accum
OpenGL ES profile version string: OpenGL ES 3.2 NVIDIA 470.63.01
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
OpenGL ES profile extensions:
GL_ANDROID_extension_pack_es31a, GL_EXT_EGL_image_external_wrap_modes,
GL_EXT_base_instance, GL_EXT_blend_func_extended, GL_EXT_blend_minmax,
GL_EXT_buffer_storage, GL_EXT_clear_texture, GL_EXT_clip_control,
GL_EXT_clip_cull_distance, GL_EXT_color_buffer_float,
GL_EXT_color_buffer_half_float, GL_EXT_compressed_ETC1_RGB8_sub_texture,
GL_EXT_conservative_depth, GL_EXT_copy_image, GL_EXT_debug_label,
GL_EXT_depth_clamp, GL_EXT_discard_framebuffer,
GL_EXT_disjoint_timer_query, GL_EXT_draw_buffers_indexed,
GL_EXT_draw_elements_base_vertex, GL_EXT_draw_transform_feedback,
GL_EXT_float_blend, GL_EXT_frag_depth, GL_EXT_geometry_point_size,
GL_EXT_geometry_shader, GL_EXT_gpu_shader5, GL_EXT_map_buffer_range,
GL_EXT_memory_object, GL_EXT_memory_object_fd, GL_EXT_multi_draw_indirect,
GL_EXT_multisample_compatibility, GL_EXT_multisampled_render_to_texture,
GL_EXT_multisampled_render_to_texture2,
GL_EXT_multiview_texture_multisample, GL_EXT_multiview_timer_query,
GL_EXT_occlusion_query_boolean, GL_EXT_polygon_offset_clamp,
GL_EXT_post_depth_coverage, GL_EXT_primitive_bounding_box,
GL_EXT_raster_multisample, GL_EXT_render_snorm, GL_EXT_robustness,
GL_EXT_sRGB, GL_EXT_sRGB_write_control, GL_EXT_semaphore,
GL_EXT_shader_group_vote, GL_EXT_shader_implicit_conversions,
GL_EXT_shader_integer_mix, GL_EXT_shader_io_blocks,
GL_EXT_shader_non_constant_global_initializers, GL_EXT_shader_texture_lod,
GL_EXT_shadow_samplers, GL_EXT_sparse_texture, GL_EXT_sparse_texture2,
GL_EXT_tessellation_point_size, GL_EXT_tessellation_shader,
GL_EXT_texture_border_clamp, GL_EXT_texture_buffer,
GL_EXT_texture_compression_bptc, GL_EXT_texture_compression_dxt1,
GL_EXT_texture_compression_rgtc, GL_EXT_texture_compression_s3tc,
GL_EXT_texture_cube_map_array, GL_EXT_texture_filter_anisotropic,
GL_EXT_texture_filter_minmax, GL_EXT_texture_format_BGRA8888,
GL_EXT_texture_mirror_clamp_to_edge, GL_EXT_texture_norm16,
GL_EXT_texture_query_lod, GL_EXT_texture_rg, GL_EXT_texture_sRGB_R8,
GL_EXT_texture_sRGB_decode, GL_EXT_texture_shadow_lod,
GL_EXT_texture_storage, GL_EXT_texture_view, GL_EXT_unpack_subimage,
GL_EXT_window_rectangles, GL_KHR_blend_equation_advanced,
GL_KHR_shader_subgroup, GL_KHR_texture_compression_astc_hdr,
GL_KHR_texture_compression_astc_ldr,
GL_KHR_texture_compression_astc_sliced_3d,
GL_NVX_blend_equation_advanced_multi_draw_buffers, GL_NV_bgr,
GL_NV_bindless_texture, GL_NV_blend_equation_advanced,
GL_NV_blend_equation_advanced_coherent, GL_NV_blend_minmax_factor,
GL_NV_clip_space_w_scaling, GL_NV_conditional_render,
GL_NV_conservative_raster, GL_NV_conservative_raster_pre_snap_triangles,
GL_NV_copy_buffer, GL_NV_copy_image, GL_NV_draw_buffers,
GL_NV_draw_instanced, GL_NV_draw_texture, GL_NV_draw_vulkan_image,
GL_NV_explicit_attrib_location, GL_NV_fbo_color_attachments,
GL_NV_fill_rectangle, GL_NV_fragment_coverage_to_color,
GL_NV_fragment_shader_interlock, GL_NV_framebuffer_blit,
GL_NV_framebuffer_mixed_samples, GL_NV_framebuffer_multisample,
GL_NV_generate_mipmap_sRGB, GL_NV_geometry_shader_passthrough,
GL_NV_gpu_shader5, GL_NV_image_formats, GL_NV_instanced_arrays,
GL_NV_internalformat_sample_query, GL_NV_memory_attachment,
GL_NV_memory_object_sparse, GL_NV_non_square_matrices,
GL_NV_occlusion_query_samples, GL_NV_pack_subimage, GL_NV_packed_float,
GL_NV_packed_float_linear, GL_NV_path_rendering,
GL_NV_path_rendering_shared_edge, GL_NV_pixel_buffer_object,
GL_NV_polygon_mode, GL_NV_read_buffer, GL_NV_read_depth,
GL_NV_read_depth_stencil, GL_NV_read_stencil, GL_NV_sRGB_formats,
GL_NV_shader_atomic_fp16_vector, GL_NV_shader_noperspective_interpolation,
GL_NV_shader_subgroup_partitioned, GL_NV_shadow_samplers_array,
GL_NV_shadow_samplers_cube, GL_NV_stereo_view_rendering,
GL_NV_texture_array, GL_NV_texture_barrier, GL_NV_texture_border_clamp,
GL_NV_texture_compression_latc, GL_NV_texture_compression_s3tc,
GL_NV_texture_compression_s3tc_update, GL_NV_timeline_semaphore,
GL_NV_timer_query, GL_NV_viewport_array, GL_NV_viewport_array2,
GL_NV_viewport_swizzle, GL_OES_compressed_ETC1_RGB8_texture,
GL_OES_copy_image, GL_OES_depth24, GL_OES_depth32, GL_OES_depth_texture,
GL_OES_depth_texture_cube_map, GL_OES_draw_buffers_indexed,
GL_OES_draw_elements_base_vertex, GL_OES_element_index_uint,
GL_OES_fbo_render_mipmap, GL_OES_geometry_point_size,
GL_OES_geometry_shader, GL_OES_get_program_binary, GL_OES_gpu_shader5,
GL_OES_mapbuffer, GL_OES_packed_depth_stencil,
GL_OES_primitive_bounding_box, GL_OES_rgb8_rgba8, GL_OES_sample_shading,
GL_OES_sample_variables, GL_OES_shader_image_atomic,
GL_OES_shader_io_blocks, GL_OES_shader_multisample_interpolation,
GL_OES_standard_derivatives, GL_OES_tessellation_point_size,
GL_OES_tessellation_shader, GL_OES_texture_border_clamp,
GL_OES_texture_buffer, GL_OES_texture_cube_map_array,
GL_OES_texture_float, GL_OES_texture_float_linear,
GL_OES_texture_half_float, GL_OES_texture_half_float_linear,
GL_OES_texture_npot, GL_OES_texture_stencil8,
GL_OES_texture_storage_multisample_2d_array, GL_OES_texture_view,
GL_OES_vertex_array_object, GL_OES_vertex_half_float,
GL_OES_viewport_array, GL_OVR_multiview, GL_OVR_multiview2,
GL_OVR_multiview_multisampled_render_to_texture
132 GLX Visuals
visual x bf lv rg d st colorbuffer sr ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a F gb bf th cl r g b a ns b eat
0x021 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x022 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x024 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
0x025 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x026 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
0x027 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x028 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
0x029 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x02a 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
0x02b 24 tc 0 24 0 r y . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x02c 24 tc 0 32 0 r y . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
0x02d 24 tc 0 24 0 r . . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x02e 24 tc 0 32 0 r . . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
0x02f 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 None
0x030 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 None
0x031 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 None
0x032 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 None
0x033 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 None
0x034 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 None
0x035 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 None
0x036 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 None
0x037 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 None
0x038 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 None
0x039 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 None
0x03a 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 None
0x03b 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 None
0x03c 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 None
0x03d 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 None
0x03e 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 None
0x03f 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 None
0x040 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 None
0x041 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 None
0x042 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 None
0x043 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 None
0x044 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 None
0x045 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 None
0x046 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 None
0x047 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 None
0x048 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 None
0x049 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 None
0x04a 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 None
0x04b 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 None
0x04c 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 None
0x04d 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 None
0x04e 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 None
0x04f 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
0x050 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x051 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
0x052 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x053 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
0x054 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x055 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
0x056 24 dc 0 24 0 r y . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x057 24 dc 0 32 0 r y . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
0x058 24 dc 0 24 0 r . . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x059 24 dc 0 32 0 r . . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
0x05a 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 None
0x05b 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 None
0x05c 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 None
0x05d 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 None
0x05e 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 None
0x05f 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 None
0x060 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 None
0x061 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 None
0x062 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 None
0x063 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 None
0x064 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 None
0x065 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 None
0x066 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 None
0x067 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 None
0x068 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 None
0x069 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 None
0x06a 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 None
0x06b 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 None
0x06c 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 None
0x06d 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 None
0x06e 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 None
0x06f 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 None
0x070 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 None
0x071 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 None
0x072 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 None
0x073 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 None
0x074 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 None
0x075 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 None
0x076 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 None
0x077 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 None
0x078 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 None
0x079 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 None
0x023 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x07a 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
0x07b 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x07c 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
0x07d 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x07e 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
0x07f 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x080 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
0x081 32 tc 0 24 0 r y . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x082 32 tc 0 32 0 r y . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
0x083 32 tc 0 24 0 r . . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x084 32 tc 0 32 0 r . . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
0x085 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 None
0x086 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 None
0x087 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 None
0x088 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 None
0x089 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 None
0x08a 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 None
0x08b 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 None
0x08c 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 None
0x08d 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 None
0x08e 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 None
0x08f 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 None
0x090 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 None
0x091 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 None
0x092 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 None
0x093 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 None
0x094 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 None
0x095 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 None
0x096 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 None
0x097 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 None
0x098 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 None
0x099 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 None
0x09a 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 None
0x09b 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 None
0x09c 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 None
0x09d 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 None
0x09e 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 None
0x09f 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 None
0x0a0 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 None
0x0a1 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 None
0x0a2 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 None
0x0a3 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 None
0x0a4 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 None
215 GLXFBConfigs:
0x0a5 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x0a6 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x0a7 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
0x0a8 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
0x0a9 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x0aa 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x0ab 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
0x0ac 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
0x0ad 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x0ae 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x0af 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
0x0b0 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
0x0b1 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x0b2 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x0b3 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
0x0b4 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
0x0b5 24 tc 0 24 0 r y . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x0b6 24 dc 0 24 0 r y . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x0b7 24 tc 0 32 0 r y . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
0x0b8 24 dc 0 32 0 r y . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
0x0b9 24 tc 0 24 0 r . . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x0ba 24 dc 0 24 0 r . . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x0bb 24 tc 0 32 0 r . . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
0x0bc 24 dc 0 32 0 r . . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
0x0bd 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 None
0x0be 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 None
0x0bf 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 None
0x0c0 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 None
0x0c1 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 None
0x0c2 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 None
0x0c3 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 None
0x0c4 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 None
0x0c5 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 None
0x0c6 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 None
0x0c7 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 None
0x0c8 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 None
0x0c9 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 None
0x0ca 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 None
0x0cb 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 None
0x0cc 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 None
0x0cd 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 None
0x0ce 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 None
0x0cf 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 None
0x0d0 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 None
0x0d1 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 None
0x0d2 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 None
0x0d3 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 None
0x0d4 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 None
0x0d5 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 None
0x0d6 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 None
0x0d7 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 None
0x0d8 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 None
0x0d9 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 None
0x0da 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 None
0x0db 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 None
0x0dc 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 None
0x0dd 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 None
0x0de 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 None
0x0df 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 None
0x0e0 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 None
0x0e1 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 None
0x0e2 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 None
0x0e3 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 None
0x0e4 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 None
0x0e5 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 None
0x0e6 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 None
0x0e7 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 None
0x0e8 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 None
0x0e9 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 None
0x0ea 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 None
0x0eb 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 None
0x0ec 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 None
0x0ed 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 None
0x0ee 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 None
0x0ef 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 None
0x0f0 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 None
0x0f1 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 None
0x0f2 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 None
0x0f3 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 None
0x0f4 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 None
0x0f5 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 None
0x0f6 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 None
0x0f7 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 None
0x0f8 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 None
0x0f9 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 None
0x0fa 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 None
0x0fb 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 None
0x0fc 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 None
0x0fd 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x0fe 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
0x0ff 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x100 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
0x101 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x102 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
0x103 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x104 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
0x105 32 tc 0 24 0 r y . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x106 32 tc 0 32 0 r y . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
0x107 32 tc 0 24 0 r . . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x108 32 tc 0 32 0 r . . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
0x109 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 None
0x10a 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 None
0x10b 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 None
0x10c 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 None
0x10d 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 None
0x10e 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 None
0x10f 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 None
0x110 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 None
0x111 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 None
0x112 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 None
0x113 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 None
0x114 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 None
0x115 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 None
0x116 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 None
0x117 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 None
0x118 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 None
0x119 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 None
0x11a 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 None
0x11b 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 None
0x11c 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 None
0x11d 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 None
0x11e 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 None
0x11f 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 None
0x120 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 None
0x121 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 None
0x122 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 None
0x123 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 None
0x124 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 None
0x125 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 None
0x126 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 None
0x127 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 None
0x128 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 None
0x129 0 sg 0 16 0 r y . 5 6 5 0 . . 4 16 0 16 16 16 16 0 0 None
0x12a 0 sg 0 16 0 r . . 5 6 5 0 . . 4 16 0 16 16 16 16 0 0 None
0x12b 0 sg 0 16 0 r y . 5 6 5 0 . . 4 24 0 16 16 16 16 0 0 None
0x12c 0 sg 0 16 0 r . . 5 6 5 0 . . 4 24 0 16 16 16 16 0 0 None
0x12d 0 sg 0 16 0 r y . 5 6 5 0 . . 4 24 8 16 16 16 16 0 0 None
0x12e 0 sg 0 16 0 r . . 5 6 5 0 . . 4 24 8 16 16 16 16 0 0 None
0x12f 0 sg 0 16 0 r y . 5 6 5 0 . . 4 0 0 16 16 16 16 0 0 None
0x130 0 sg 0 16 0 r . . 5 6 5 0 . . 4 0 0 16 16 16 16 0 0 None
0x131 0 sg 0 0 0 r . . 0 0 0 0 . . 4 16 0 16 16 16 16 0 0 None
0x132 0 sg 0 0 0 r . . 0 0 0 0 . . 4 24 0 16 16 16 16 0 0 None
0x133 0 sg 0 0 0 r . . 0 0 0 0 . . 4 24 8 16 16 16 16 0 0 None
0x134 0 sg 0 32 0 r . . 16 16 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x135 0 sg 0 32 0 . . 16 16 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x136 0 sg 0 32 0 r y . 16 16 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x137 0 sg 0 32 0 y . 16 16 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x138 0 sg 0 32 0 r . . 32 0 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x139 0 sg 0 32 0 . . 32 0 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x13a 0 sg 0 32 0 r y . 32 0 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x13b 0 sg 0 32 0 y . 32 0 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x13c 0 sg 0 64 0 r . . 16 16 16 16 f . 4 0 0 16 16 16 16 0 0 None
0x13d 0 sg 0 64 0 . . 16 16 16 16 f . 4 0 0 16 16 16 16 0 0 None
0x13e 0 sg 0 64 0 r y . 16 16 16 16 f . 4 0 0 16 16 16 16 0 0 None
0x13f 0 sg 0 64 0 y . 16 16 16 16 f . 4 0 0 16 16 16 16 0 0 None
0x140 0 sg 0 128 0 r . . 32 32 32 32 f . 4 0 0 16 16 16 16 0 0 None
0x141 0 sg 0 128 0 . . 32 32 32 32 f . 4 0 0 16 16 16 16 0 0 None
0x142 0 sg 0 128 0 r y . 32 32 32 32 f . 4 0 0 16 16 16 16 0 0 None
0x143 0 sg 0 128 0 y . 32 32 32 32 f . 4 0 0 16 16 16 16 0 0 None
0x144 0 sg 0 32 0 r . . 16 16 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x145 0 sg 0 32 0 . . 16 16 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x146 0 sg 0 32 0 r y . 16 16 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x147 0 sg 0 32 0 y . 16 16 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x148 0 sg 0 32 0 r . . 16 16 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x149 0 sg 0 32 0 . . 16 16 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x14a 0 sg 0 32 0 r y . 16 16 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x14b 0 sg 0 32 0 y . 16 16 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x14c 0 sg 0 32 0 r . . 32 0 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x14d 0 sg 0 32 0 . . 32 0 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x14e 0 sg 0 32 0 r y . 32 0 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x14f 0 sg 0 32 0 y . 32 0 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x150 0 sg 0 32 0 r . . 32 0 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x151 0 sg 0 32 0 . . 32 0 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x152 0 sg 0 32 0 r y . 32 0 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x153 0 sg 0 32 0 y . 32 0 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x154 0 sg 0 64 0 r . . 16 16 16 16 f . 4 24 0 16 16 16 16 0 0 None
0x155 0 sg 0 64 0 . . 16 16 16 16 f . 4 24 0 16 16 16 16 0 0 None
0x156 0 sg 0 64 0 r y . 16 16 16 16 f . 4 24 0 16 16 16 16 0 0 None
0x157 0 sg 0 64 0 y . 16 16 16 16 f . 4 24 0 16 16 16 16 0 0 None
0x158 0 sg 0 64 0 r . . 16 16 16 16 f . 4 24 8 16 16 16 16 0 0 None
0x159 0 sg 0 64 0 . . 16 16 16 16 f . 4 24 8 16 16 16 16 0 0 None
0x15a 0 sg 0 64 0 r y . 16 16 16 16 f . 4 24 8 16 16 16 16 0 0 None
0x15b 0 sg 0 64 0 y . 16 16 16 16 f . 4 24 8 16 16 16 16 0 0 None
0x15c 0 sg 0 128 0 r . . 32 32 32 32 f . 4 24 0 16 16 16 16 0 0 None
0x15d 0 sg 0 128 0 . . 32 32 32 32 f . 4 24 0 16 16 16 16 0 0 None
0x15e 0 sg 0 128 0 r y . 32 32 32 32 f . 4 24 0 16 16 16 16 0 0 None
0x15f 0 sg 0 128 0 y . 32 32 32 32 f . 4 24 0 16 16 16 16 0 0 None
0x160 0 sg 0 128 0 r . . 32 32 32 32 f . 4 24 8 16 16 16 16 0 0 None
0x161 0 sg 0 128 0 . . 32 32 32 32 f . 4 24 8 16 16 16 16 0 0 None
0x162 0 sg 0 128 0 r y . 32 32 32 32 f . 4 24 8 16 16 16 16 0 0 None
0x163 0 sg 0 128 0 y . 32 32 32 32 f . 4 24 8 16 16 16 16 0 0 None
0x164 0 sg 0 16 0 r . . 16 0 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x165 0 sg 0 16 0 . . 16 0 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x166 0 sg 0 16 0 r y . 16 0 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x167 0 sg 0 16 0 y . 16 0 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x168 0 sg 0 64 0 r . . 32 32 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x169 0 sg 0 64 0 . . 32 32 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x16a 0 sg 0 64 0 r y . 32 32 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x16b 0 sg 0 64 0 y . 32 32 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x16c 0 sg 0 16 0 r . . 16 0 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x16d 0 sg 0 16 0 . . 16 0 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x16e 0 sg 0 16 0 r y . 16 0 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x16f 0 sg 0 16 0 y . 16 0 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x170 0 sg 0 16 0 r . . 16 0 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x171 0 sg 0 16 0 . . 16 0 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x172 0 sg 0 16 0 r y . 16 0 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x173 0 sg 0 16 0 y . 16 0 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x174 0 sg 0 64 0 r . . 32 32 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x175 0 sg 0 64 0 . . 32 32 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x176 0 sg 0 64 0 r y . 32 32 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x177 0 sg 0 64 0 y . 32 32 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x178 0 sg 0 64 0 r . . 32 32 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x179 0 sg 0 64 0 . . 32 32 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x17a 0 sg 0 64 0 r y . 32 32 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x17b 0 sg 0 64 0 y . 32 32 0 0 f . 4 24 8 16 16 16 16 0 0 None
