I recently installed Fedora Linux on my PC. The bootloader provided by Fedora’s got the entries for all the OS’s that I’ve got installed on my PC: Linux Mint, Manjaro Linux, and Fedora itself, of course. But I wanted to use Manjaro’s bootloader instead of Fedora’s.
When I ran sudo update-grub
on the Terminal on Manjaro, I got the following output:
[sudo] password for arch:
Found linux image: /boot/vmlinuz-6.1-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.1-x86_64.img
Found initrd fallback image: /boot/initramfs-6.1-x86_64-fallback.img
Found Linux Mint 21.1 Vera (21.1) on /dev/nvme0n1p2
Found Fedora Linux 37 (Workstation Edition) on /dev/nvme0n1p5
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
I see that it recognizes I’ve installed Fedora, but it doesn’t add the boot menu entry for the operating system. I don’t understand the reason. Is it because Fedora’s filesystem is btrfs
or is there any other reason? How do I fix this?
Thank you in advance.
