I am having problems when I try to install packages from the AUR (ex: Brave Browser and audacium). I already tried installing with yay, pamac and without helpers (with git). In all cases, I receive an output: => ERROR: A failure ocurred in build(). I have base-devel installed and up to date.
Kernel: 5.16.11-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
root=UUID=0ca152f5-ae47-461f-88f0-22daf76c6792 rw quiet splash apparmor=1
Desktop: GNOME 41.4 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
Type: Laptop System: SAMSUNG product: 760XBE v: P04REZ serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: SAMSUNG model: NP760XBE-XW1BR
v: SGLA409A0C-C01-G002-S0001+10.0.18363 serial: <filter>
UEFI: American Megatrends v: P04REZ.042.210817.FL date: 08/17/2021
ID-1: BAT1 charge: 30.8 Wh (100.0%) condition: 30.8/43.1 Wh (71.4%)
volts: 12.5 min: 11.4 model: SAMSUNG Electronics SR Real Battery
type: Li-ion serial: <filter> status: Full cycles: 691
Info: model: Intel Core i7-8565U socket: BGA1528 (U3E1) note: check bits: 64
type: MT MCP arch: Comet/Whiskey Lake note: check family: 6
model-id: 0x8E (142) stepping: 0xC (12) microcode: 0xEC
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 680 high: 739 min/max: 400/4600 base/boost: 1683/8300
scaling: driver: intel_pstate governor: powersave volts: 0.7 V
ext-clock: 100 MHz cores: 1: 739 2: 700 3: 700 4: 700 5: 623 6: 700 7: 685
8: 600 bogomips: 32012
Type: srbds mitigation: TSX disabled
Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Samsung Co
driver: i915 v: kernel ports: active: eDP-1 empty: DP-1,HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:3ea0 class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Samsung Co driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm
pcie: gen: 1 speed: 2.5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f91 class-ID: 0300
Device-3: Generic 720p HD Camera type: USB driver: uvcvideo bus-ID: 1-6:4
chip-ID: 2b7e:0134 class-ID: 0e02 serial: <filter>
Display: server: X.org v: 1.21.1.3 compositor: gnome-shell driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa gpu: i915
display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 built: 2018 res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2
size: 344x194mm (13.5x7.6") diag: 395mm (15.5") ratio: 16:9 modes: 1920x1080
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Samsung Co
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
Device-2: NVIDIA vendor: Samsung Co driver: snd_hda_intel v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
Sound Server-1: ALSA v: k5.16.11-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.47 running: yes
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280
vendor: Samsung Co driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-10:5 chip-ID: 8087:0aaa class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 476.97 GiB used: 261.92 GiB (54.9%)
ID-1: /dev/mmcblk0 maj-min: 179:0 type: USB vendor: Samsung model: EE8QT
size: 238.5 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> scheme: MBR
SMART Message: Unknown smartctl error. Unable to generate data.
ID-2: /dev/sda maj-min: 8:0 vendor: LITE-ON model: CV8-8E256
size: 238.47 GiB block-size: physical: 512 B logical: 512 B sata: 3.1
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 002 temp: 25 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 43d 5h cycles: 5001
read: 208.2 MiB written: 170.8 MiB
ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%)
used: 109.24 GiB (46.8%) fs: ext4 block-size: 4096 B dev: /dev/sda2
maj-min: 8:2
used: 288 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 43.0 C pch: 41.0 C mobo: 43.0 C
Processes: 328 Uptime: 5h 16m wakeups: 1 Memory: 15.52 GiB
used: 3.38 GiB (21.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: 1560 pacman: 1525 lib: 331 flatpak: 26
snap: 9 Shell: Zsh (sudo) v: 5.8.1 default: Bash v: 5.1.16 running-in: kitty
inxi: 3.3.13`
AUR is not packages but build scripts for custom packages.
If a software doesnât compile or a script fails - there is a couple of steps
- Check the source
- get in touch with the maintainer
- get in touch with the dev(s)
There is a lot of output above this âoutputâ also which is usually the most helpful. Share that. It is very unlikely that there is something wrong with so many packages at the same time.
make[2]: Leaving directory '/home/felipeqp/.cache/yay/audacium/src/audacium-1.0.0-rel/build'
make[1]: *** [CMakeFiles/Makefile2:1259: src/CMakeFiles/Audacium.dir/all] Error 2
make[1]: Leaving directory '/home/felipeqp/.cache/yay/audacium/src/audacium-1.0.0-rel/build'
make: *** [Makefile:156: all] Error 2
make: Leaving directory '/home/felipeqp/.cache/yay/audacium/src/audacium-1.0.0-rel/build'
==> ERROR: A failure occurred in build().
Aborting...
-> error making: audacium```
Please fix the preformatting: [HowTo] Use preformatting in a forum post
This is a patched version of audacity
Remember - the script is assuming an Arch system not Manjaro.
Step 3 from above - contact the developer - create an issue on the github page
Please use git and makepkg - you will get a lot more info - on missing dependencies - satisfy the dependencies and try again.
â audacium git:(master) makepkg -s
==> Making package: audacium 1.0.0-2 (2022-03-04T16:54:31 CET)
==> Installing missing dependencies...
error: target not found: conan
==> ERROR: 'pacman' failed to install missing dependencies.
==> Missing dependencies:
-> nasm
-> conan
==> ERROR: Could not resolve all dependencies.
> Making package: audacium 1.0.0-2 (sex 04 mar 2022 13:19:17)
==> Retrieving sources...
-> Found audacium-1.0.0-rel.tar.gz
audacium-1.0.0-rel.tar.gz ... Passed
==> Extracting sources...
-> Extracting audacium-1.0.0-rel.tar.gz with bsdtar
==> Removing existing $pkgdir/ directory...
==> Starting build()...
-- Conan: Adding audacity remote repository (https://artifactory.audacityteam.org/artifactory/api/conan/conan-local) verify ssl (True)
-- The ASM_NASM compiler identification is NASM
-- Found assembler: /usr/bin/nasm
-- Build Info:
-- Host System: Linux-5.16.11-2-MANJARO
-- Host System Name: Linux
-- Host System Processor: x86_64
-- Host System Version: 5.16.11-2-MANJARO
-- Host System Architecture: 64-bit
-- Compiler: /usr/bin/c++
-- Compiler Version: 11.2.0
-- Compiler Standard: 17
-- Compiler Standard Required: ON
-- Compiler Extensions:
-- Current Commit: c30186a
-- Adding Conan dependency ZLIB
-- Adding Conan dependency expat
-- Adding Conan dependency wxWidgets
-- Adding Conan dependency libmp3lame
-- Adding Conan dependency libid3tag
-- Adding Conan dependency libmad
-- Adding Conan dependency ThreadPool
-- Adding Conan dependency libuuid
-- Adding Conan dependency RapidJSON
-- ========== Configuring sndfile ==========
-- Using 'sndfile' local library
-- ========== Configuring soxr ==========
-- Using 'soxr' local library
-- ========== Configuring portaudio ==========
-- Using 'portaudio' local library
-- ========== Configuring sqlite ==========
-- Using 'sqlite' local library
-- ========== Configuring ffmpeg ==========
-- Will dynamically load 'ffmpeg' library at runtime
-- Using 'ffmpeg' system includes
-- ========== Configuring nyquist ==========
-- Using 'nyquist' local library
-- ========== Configuring vamp ==========
-- Using 'vamp' local library
-- ========== Configuring ogg ==========
-- Using 'ogg' local library
-- ========== Configuring vorbis ==========
-- Using 'vorbis' local library
-- ========== Configuring flac ==========
-- Using 'flac' local library
-- ========== Configuring lv2 ==========
-- Using 'lv2' local library
-- Checking for module 'QtGui >= 4.4.0'
-- Package 'QtGui', required by 'virtual:world', not found
-- ========== Configuring midi ==========
-- Using 'midi' local library
-- ========== Configuring portmixer ==========
-- Using 'portmixer' local library
-- ========== Configuring portsmf ==========
-- Using 'portsmf' local library
-- ========== Configuring sbsms ==========
-- Using 'sbsms' local library
-- ========== Configuring twolame ==========
-- Using 'twolame' local library
-- Executing Conan: REQUIRES zlib/1.2.11;expat/2.2.9@audacity/stable;wxwidgets/3.1.3.1-audacity;libmp3lame/3.100;libid3tag/0.15.2b@audacity/stable;libmad/0.15.2b@audacity/stable;threadpool/20140926;libuuid/1.0.3;rapidjson/1.1.0
GENERATORS cmake_find_package_multi
BUILD_REQUIRES
OPTIONS zlib:shared=True;expat:shared=True;wxwidgets:shared=True;wxwidgets:zlib=zlib;wxwidgets:expat=expat;wxwidgets:compatibility=3.0;wxwidgets:png=libpng;wxwidgets:jpeg=libjpeg-turbo;wxwidgets:tiff=off;wxwidgets:secretstore=False;wxwidgets:opengl=False;wxwidgets:propgrid=False;wxwidgets:ribbon=False;wxwidgets:richtext=False;wxwidgets:stc=False;wxwidgets:webview=False;wxwidgets:help=False;wxwidgets:html_help=False;wxwidgets:fs_inet=False;wxwidgets:protocol=False;libjpeg-turbo:SIMD=False;libid3tag:zlib=conan
-- Configuring packages for Release
-- Conan: checking conan executable
-- Conan: Found program /usr/bin/conan
-- Conan: Version found Conan version 1.45.0
-- Conan executing: /usr/bin/conan install . --build missing --settings build_type=Release --settings compiler=gcc --settings compiler.version=11 --settings compiler.libcxx=libstdc++11
Configuration:
[settings]
arch=x86_64
arch_build=x86_64
build_type=Release
compiler=gcc
compiler.version=11
os=Linux
os_build=Linux
[options]
[build_requires]
[env]
WARN: wxwidgets/3.1.3.1-audacity: requirement expat/2.2.9 overridden by your conanfile to expat/2.2.9@audacity/stable
conanfile.txt: Installing package
Requirements
expat/2.2.9@audacity/stable from 'audacity' - Cache
libid3tag/0.15.2b@audacity/stable from 'audacity' - Cache
libjpeg-turbo/2.0.5 from 'conancenter' - Cache
libmad/0.15.2b@audacity/stable from 'audacity' - Cache
libmp3lame/3.100 from 'conancenter' - Cache
libpng/1.6.37 from 'conancenter' - Cache
libuuid/1.0.3 from 'conancenter' - Cache
rapidjson/1.1.0 from 'conancenter' - Cache
threadpool/20140926 from 'conancenter' - Cache
wxwidgets/3.1.3.1-audacity from 'audacity' - Cache
zlib/1.2.11 from 'conancenter' - Cache
Packages
expat/2.2.9@audacity/stable:1748639999ed79b998e4fe4a6d292ed8e874736a - Cache
libid3tag/0.15.2b@audacity/stable:7af82130a9eb00f4f6546ad1d5cbd5b25f702e54 - Cache
libjpeg-turbo/2.0.5:cbe6b6cdfb1a21cfa81fd2d17e0f266bccd8adc0 - Cache
libmad/0.15.2b@audacity/stable:401564b5078c9994c1f21715e2e92c18315e8230 - Cache
libmp3lame/3.100:dfbe50feef7f3c6223a476cd5aeadb687084a646 - Cache
libpng/1.6.37:025ffc7158b5e62f5f3ed9af91d48958d216f972 - Cache
libuuid/1.0.3:dfbe50feef7f3c6223a476cd5aeadb687084a646 - Cache
rapidjson/1.1.0:5ab84d6acfe1f23c4fae0ab88f26e3a396351ac9 - Cache
threadpool/20140926:5ab84d6acfe1f23c4fae0ab88f26e3a396351ac9 - Cache
wxwidgets/3.1.3.1-audacity:16b6333f64afa8c5345b25bebdaf714898bf3f9c - Cache
zlib/1.2.11:1748639999ed79b998e4fe4a6d292ed8e874736a - Cache
Installing (downloading, building) binaries...
expat/2.2.9@audacity/stable: Already installed!
libjpeg-turbo/2.0.5: Already installed!
libmad/0.15.2b@audacity/stable: Already installed!
libmp3lame/3.100: Already installed!
libuuid/1.0.3: Already installed!
rapidjson/1.1.0: Already installed!
threadpool/20140926: Already installed!
zlib/1.2.11: Already installed!
libid3tag/0.15.2b@audacity/stable: Already installed!
libpng/1.6.37: Already installed!
wxwidgets/3.1.3.1-audacity: Already installed!
conanfile.txt: Generator txt created conanbuildinfo.txt
conanfile.txt: Generator cmake_find_package_multi created wxWidgetsConfigVersion.cmake
conanfile.txt: Generator cmake_find_package_multi created wxWidgetsTarget-release.cmake
conanfile.txt: Generator cmake_find_package_multi created wxWidgetsTargets.cmake
conanfile.txt: Generator cmake_find_package_multi created wxWidgetsConfig.cmake
conanfile.txt: Generator cmake_find_package_multi created libmp3lame-config-version.cmake
conanfile.txt: Generator cmake_find_package_multi created libmp3lame-config.cmake
conanfile.txt: Generator cmake_find_package_multi created libmp3lameTargets.cmake
conanfile.txt: Generator cmake_find_package_multi created libmp3lameTarget-release.cmake
conanfile.txt: Generator cmake_find_package_multi created libid3tag-config-version.cmake
conanfile.txt: Generator cmake_find_package_multi created libid3tag-config.cmake
conanfile.txt: Generator cmake_find_package_multi created libid3tagTargets.cmake
conanfile.txt: Generator cmake_find_package_multi created libid3tagTarget-release.cmake
conanfile.txt: Generator cmake_find_package_multi created libmad-config-version.cmake
conanfile.txt: Generator cmake_find_package_multi created libmad-config.cmake
conanfile.txt: Generator cmake_find_package_multi created libmadTargets.cmake
conanfile.txt: Generator cmake_find_package_multi created libmadTarget-release.cmake
conanfile.txt: Generator cmake_find_package_multi created ThreadPoolConfigVersion.cmake
conanfile.txt: Generator cmake_find_package_multi created ThreadPoolConfig.cmake
conanfile.txt: Generator cmake_find_package_multi created ThreadPoolTargets.cmake
conanfile.txt: Generator cmake_find_package_multi created ThreadPoolTarget-release.cmake
conanfile.txt: Generator cmake_find_package_multi created libuuid-config-version.cmake
conanfile.txt: Generator cmake_find_package_multi created libuuid-config.cmake
conanfile.txt: Generator cmake_find_package_multi created libuuidTargets.cmake
conanfile.txt: Generator cmake_find_package_multi created libuuidTarget-release.cmake
conanfile.txt: Generator cmake_find_package_multi created RapidJSONConfigVersion.cmake
conanfile.txt: Generator cmake_find_package_multi created RapidJSONConfig.cmake
conanfile.txt: Generator cmake_find_package_multi created RapidJSONTargets.cmake
conanfile.txt: Generator cmake_find_package_multi created RapidJSONTarget-release.cmake
conanfile.txt: Generator cmake_find_package_multi created expat-config-version.cmake
conanfile.txt: Generator cmake_find_package_multi created expat-config.cmake
conanfile.txt: Generator cmake_find_package_multi created expatTargets.cmake
conanfile.txt: Generator cmake_find_package_multi created expatTarget-release.cmake
conanfile.txt: Generator cmake_find_package_multi created PNGConfigVersion.cmake
conanfile.txt: Generator cmake_find_package_multi created PNGConfig.cmake
conanfile.txt: Generator cmake_find_package_multi created PNGTargets.cmake
conanfile.txt: Generator cmake_find_package_multi created PNGTarget-release.cmake
conanfile.txt: Generator cmake_find_package_multi created libjpeg-turbo-config-version.cmake
conanfile.txt: Generator cmake_find_package_multi created libjpeg-turboTarget-release.cmake
conanfile.txt: Generator cmake_find_package_multi created libjpeg-turboTargets.cmake
conanfile.txt: Generator cmake_find_package_multi created libjpeg-turbo-config.cmake
conanfile.txt: Generator cmake_find_package_multi created ZLIBConfigVersion.cmake
conanfile.txt: Generator cmake_find_package_multi created ZLIBConfig.cmake
conanfile.txt: Generator cmake_find_package_multi created ZLIBTargets.cmake
conanfile.txt: Generator cmake_find_package_multi created ZLIBTarget-release.cmake
conanfile.txt: Aggregating env generators
conanfile.txt: Generated conaninfo.txt
conanfile.txt: Generated graphinfo
conanfile.txt imports(): Copied 11 '.so' files
conanfile.txt imports(): Copied 2 '.11' files: libz.so.1.2.11, libexpat.so.1.6.11
conanfile.txt imports(): Copied 2 '.1' files: libexpat.so.1, libz.so.1
-- Resolving Conan library ZLIB
-- Library z found /home/felipeqp/.conan/data/zlib/1.2.11/_/_/package/1748639999ed79b998e4fe4a6d292ed8e874736a/lib/libz.so
-- Found: /home/felipeqp/.conan/data/zlib/1.2.11/_/_/package/1748639999ed79b998e4fe4a6d292ed8e874736a/lib/libz.so
-- Resolving Conan library expat
-- Library expat found /home/felipeqp/.conan/data/expat/2.2.9/audacity/stable/package/1748639999ed79b998e4fe4a6d292ed8e874736a/lib/libexpat.so
-- Found: /home/felipeqp/.conan/data/expat/2.2.9/audacity/stable/package/1748639999ed79b998e4fe4a6d292ed8e874736a/lib/libexpat.so
-- Resolving Conan library wxWidgets
-- Library wx_gtk2u_adv-3.1 found /home/felipeqp/.conan/data/wxwidgets/3.1.3.1-audacity/_/_/package/16b6333f64afa8c5345b25bebdaf714898bf3f9c/lib/libwx_gtk2u_adv-3.1.so
-- Found: /home/felipeqp/.conan/data/wxwidgets/3.1.3.1-audacity/_/_/package/16b6333f64afa8c5345b25bebdaf714898bf3f9c/lib/libwx_gtk2u_adv-3.1.so
-- Library wx_baseu_net-3.1 found /home/felipeqp/.conan/data/wxwidgets/3.1.3.1-audacity/_/_/package/16b6333f64afa8c5345b25bebdaf714898bf3f9c/lib/libwx_baseu_net-3.1.so
-- Found: /home/felipeqp/.conan/data/wxwidgets/3.1.3.1-audacity/_/_/package/16b6333f64afa8c5345b25bebdaf714898bf3f9c/lib/libwx_baseu_net-3.1.so
-- Library wx_gtk2u_aui-3.1 found /home/felipeqp/.conan/data/wxwidgets/3.1.3.1-audacity/_/_/package/16b6333f64afa8c5345b25bebdaf714898bf3f9c/lib/libwx_gtk2u_aui-3.1.so
-- Found: /home/felipeqp/.conan/data/wxwidgets/3.1.3.1-audacity/_/_/package/16b6333f64afa8c5345b25bebdaf714898bf3f9c/lib/libwx_gtk2u_aui-3.1.so
-- Library wx_gtk2u_qa-3.1 found /home/felipeqp/.conan/data/wxwidgets/3.1.3.1-audacity/_/_/package/16b6333f64afa8c5345b25bebdaf714898bf3f9c/lib/libwx_gtk2u_qa-3.1.so
-- Found: /home/felipeqp/.conan/data/wxwidgets/3.1.3.1-audacity/_/_/package/16b6333f64afa8c5345b25bebdaf714898bf3f9c/lib/libwx_gtk2u_qa-3.1.so
-- Library wx_gtk2u_xrc-3.1 found /home/felipeqp/.conan/data/wxwidgets/3.1.3.1-audacity/_/_/package/16b6333f64afa8c5345b25bebdaf714898bf3f9c/lib/libwx_gtk2u_xrc-3.1.so
-- Found: /home/felipeqp/.conan/data/wxwidgets/3.1.3.1-audacity/_/_/package/16b6333f64afa8c5345b25bebdaf714898bf3f9c/lib/libwx_gtk2u_xrc-3.1.so
-- Library wx_baseu_xml-3.1 found /home/felipeqp/.conan/data/wxwidgets/3.1.3.1-audacity/_/_/package/16b6333f64afa8c5345b25bebdaf714898bf3f9c/lib/libwx_baseu_xml-3.1.so
-- Found: /home/felipeqp/.conan/data/wxwidgets/3.1.3.1-audacity/_/_/package/16b6333f64afa8c5345b25bebdaf714898bf3f9c/lib/libwx_baseu_xml-3.1.so
-- Library wx_gtk2u_html-3.1 found /home/felipeqp/.conan/data/wxwidgets/3.1.3.1-audacity/_/_/package/16b6333f64afa8c5345b25bebdaf714898bf3f9c/lib/libwx_gtk2u_html-3.1.so
-- Found: /home/felipeqp/.conan/data/wxwidgets/3.1.3.1-audacity/_/_/package/16b6333f64afa8c5345b25bebdaf714898bf3f9c/lib/libwx_gtk2u_html-3.1.so
-- Library wx_gtk2u_core-3.1 found /home/felipeqp/.conan/data/wxwidgets/3.1.3.1-audacity/_/_/package/16b6333f64afa8c5345b25bebdaf714898bf3f9c/lib/libwx_gtk2u_core-3.1.so
-- Found: /home/felipeqp/.conan/data/wxwidgets/3.1.3.1-audacity/_/_/package/16b6333f64afa8c5345b25bebdaf714898bf3f9c/lib/libwx_gtk2u_core-3.1.so
-- Library wx_baseu-3.1 found /home/felipeqp/.conan/data/wxwidgets/3.1.3.1-audacity/_/_/package/16b6333f64afa8c5345b25bebdaf714898bf3f9c/lib/libwx_baseu-3.1.so
-- Found: /home/felipeqp/.conan/data/wxwidgets/3.1.3.1-audacity/_/_/package/16b6333f64afa8c5345b25bebdaf714898bf3f9c/lib/libwx_baseu-3.1.so
-- Library gtk-x11-2.0 found /usr/lib/libgtk-x11-2.0.so
-- Found: /usr/lib/libgtk-x11-2.0.so
-- Library gdk-x11-2.0 found /usr/lib/libgdk-x11-2.0.so
-- Found: /usr/lib/libgdk-x11-2.0.so
-- Library pangocairo-1.0 found /usr/lib/libpangocairo-1.0.so
-- Found: /usr/lib/libpangocairo-1.0.so
-- Library atk-1.0 found /usr/lib/libatk-1.0.so
-- Found: /usr/lib/libatk-1.0.so
-- Library cairo found /usr/lib/libcairo.so
-- Found: /usr/lib/libcairo.so
-- Library gdk_pixbuf-2.0 found /usr/lib/libgdk_pixbuf-2.0.so
-- Found: /usr/lib/libgdk_pixbuf-2.0.so
-- Library gio-2.0 found /usr/lib/libgio-2.0.so
-- Found: /usr/lib/libgio-2.0.so
-- Library pangoft2-1.0 found /usr/lib/libpangoft2-1.0.so
-- Found: /usr/lib/libpangoft2-1.0.so
-- Library pango-1.0 found /usr/lib/libpango-1.0.so
-- Found: /usr/lib/libpango-1.0.so
-- Library gobject-2.0 found /usr/lib/libgobject-2.0.so
-- Found: /usr/lib/libgobject-2.0.so
-- Library glib-2.0 found /usr/lib/libglib-2.0.so
-- Found: /usr/lib/libglib-2.0.so
-- Library harfbuzz found /usr/lib/libharfbuzz.so
-- Found: /usr/lib/libharfbuzz.so
-- Library fontconfig found /usr/lib/libfontconfig.so
-- Found: /usr/lib/libfontconfig.so
-- Library freetype found /usr/lib/libfreetype.so
-- Found: /usr/lib/libfreetype.so
-- Library X11 found /usr/lib/libX11.so
-- Found: /usr/lib/libX11.so
-- Dependency expat already found
-- Library png16 found /home/felipeqp/.conan/data/libpng/1.6.37/_/_/package/025ffc7158b5e62f5f3ed9af91d48958d216f972/lib/libpng16.a
-- Found: /home/felipeqp/.conan/data/libpng/1.6.37/_/_/package/025ffc7158b5e62f5f3ed9af91d48958d216f972/lib/libpng16.a
-- Dependency ZLIB already found
-- Library jpeg found /home/felipeqp/.conan/data/libjpeg-turbo/2.0.5/_/_/package/cbe6b6cdfb1a21cfa81fd2d17e0f266bccd8adc0/lib/libjpeg.a
-- Found: /home/felipeqp/.conan/data/libjpeg-turbo/2.0.5/_/_/package/cbe6b6cdfb1a21cfa81fd2d17e0f266bccd8adc0/lib/libjpeg.a
-- Library turbojpeg found /home/felipeqp/.conan/data/libjpeg-turbo/2.0.5/_/_/package/cbe6b6cdfb1a21cfa81fd2d17e0f266bccd8adc0/lib/libturbojpeg.a
-- Found: /home/felipeqp/.conan/data/libjpeg-turbo/2.0.5/_/_/package/cbe6b6cdfb1a21cfa81fd2d17e0f266bccd8adc0/lib/libturbojpeg.a
-- Resolving Conan library libmp3lame
-- Library mp3lame found /home/felipeqp/.conan/data/libmp3lame/3.100/_/_/package/dfbe50feef7f3c6223a476cd5aeadb687084a646/lib/libmp3lame.a
-- Found: /home/felipeqp/.conan/data/libmp3lame/3.100/_/_/package/dfbe50feef7f3c6223a476cd5aeadb687084a646/lib/libmp3lame.a
-- Resolving Conan library libid3tag
-- Library libid3tag found /home/felipeqp/.conan/data/libid3tag/0.15.2b/audacity/stable/package/7af82130a9eb00f4f6546ad1d5cbd5b25f702e54/lib/liblibid3tag.a
-- Found: /home/felipeqp/.conan/data/libid3tag/0.15.2b/audacity/stable/package/7af82130a9eb00f4f6546ad1d5cbd5b25f702e54/lib/liblibid3tag.a
-- Resolving Conan library libmad
-- Library libmad found /home/felipeqp/.conan/data/libmad/0.15.2b/audacity/stable/package/401564b5078c9994c1f21715e2e92c18315e8230/lib/liblibmad.a
-- Found: /home/felipeqp/.conan/data/libmad/0.15.2b/audacity/stable/package/401564b5078c9994c1f21715e2e92c18315e8230/lib/liblibmad.a
-- Resolving Conan library ThreadPool
-- Resolving Conan library libuuid
-- Library uuid found /home/felipeqp/.conan/data/libuuid/1.0.3/_/_/package/dfbe50feef7f3c6223a476cd5aeadb687084a646/lib/libuuid.a
-- Found: /home/felipeqp/.conan/data/libuuid/1.0.3/_/_/package/dfbe50feef7f3c6223a476cd5aeadb687084a646/lib/libuuid.a
-- Resolving Conan library RapidJSON
-- ========== Configuring manual ==========
-- ========== Configuring images ==========
-- ========== Configuring lib-strings ==========
-- ========== Configuring lib-utility ==========
-- ========== Configuring locale ==========
-- ========== Configuring Audacium ==========
-- Using precompiled headers
-- ========== Configuring mod-script-pipe ==========
-- ========== Configuring mod-null ==========
-- ========== Configuring mod-nyq-bench ==========
-- ========== Configuring plug-ins ==========
-- ========== Configuring minsrc ==========
-- Configuring done
-- Generating done
-- Build files have been written to: /home/felipeqp/gitpackages/ani-cli/audacium/src/audacium-1.0.0-rel/build
make: Entering directory '/home/felipeqp/gitpackages/ani-cli/audacium/src/audacium-1.0.0-rel/build'
make[1]: Entering directory '/home/felipeqp/gitpackages/ani-cli/audacium/src/audacium-1.0.0-rel/build'
make[2]: Entering directory '/home/felipeqp/gitpackages/ani-cli/audacium/src/audacium-1.0.0-rel/build'
Consolidate compiler generated dependencies of target lib-strings
make[2]: Leaving directory '/home/felipeqp/gitpackages/ani-cli/audacium/src/audacium-1.0.0-rel/build'
[ 1%] Built target lib-strings
Consolidate compiler generated dependencies of target lib-utility
[ 1%] Built target lib-utility
[ 7%] Built target locale
[ 10%] Built target plug-ins
Consolidate compiler generated dependencies of target libsndfile
[ 19%] Built target libsndfile
Consolidate compiler generated dependencies of target libsoxr
[ 20%] Built target libsoxr
Consolidate compiler generated dependencies of target portaudio-v19
[ 21%] Built target portaudio-v19
Consolidate compiler generated dependencies of target sqlite
[ 22%] Built target sqlite
Consolidate compiler generated dependencies of target libnyquist
[ 43%] Built target libnyquist
Consolidate compiler generated dependencies of target libvamp
[ 44%] Built target libvamp
Consolidate compiler generated dependencies of target libogg
[ 44%] Built target libogg
Consolidate compiler generated dependencies of target libvorbis
[ 46%] Built target libvorbis
Consolidate compiler generated dependencies of target libflac
[ 49%] Built target libflac
Consolidate compiler generated dependencies of target libsuil_qt5_in_gtk3
[ 50%] Built target libsuil_qt5_in_gtk3
Consolidate compiler generated dependencies of target libsuil_x11
[ 50%] Built target libsuil_x11
Consolidate compiler generated dependencies of target libsuil_x11_in_gtk2
[ 50%] Built target libsuil_x11_in_gtk2
Consolidate compiler generated dependencies of target libsuil_x11_in_gtk3
[ 50%] Built target libsuil_x11_in_gtk3
Consolidate compiler generated dependencies of target libsuil_qt5_in_gtk2
[ 50%] Built target libsuil_qt5_in_gtk2
Consolidate compiler generated dependencies of target lv2
[ 50%] Building C object cmake-proxies/lv2/CMakeFiles/lv2.dir/__/__/lib-src/lv2/lilv/src/collections.c.o
[ 50%] Building C object cmake-proxies/lv2/CMakeFiles/lv2.dir/__/__/lib-src/lv2/lilv/src/instance.c.o
[ 50%] Building C object cmake-proxies/lv2/CMakeFiles/lv2.dir/__/__/lib-src/lv2/lilv/src/lib.c.o
[ 50%] Building C object cmake-proxies/lv2/CMakeFiles/lv2.dir/__/__/lib-src/lv2/lilv/src/node.c.o
[ 50%] Building C object cmake-proxies/lv2/CMakeFiles/lv2.dir/__/__/lib-src/lv2/lilv/src/plugin.c.o
[ 50%] Building C object cmake-proxies/lv2/CMakeFiles/lv2.dir/__/__/lib-src/lv2/lilv/src/pluginclass.c.o
[ 51%] Building C object cmake-proxies/lv2/CMakeFiles/lv2.dir/__/__/lib-src/lv2/lilv/src/port.c.o
[ 51%] Building C object cmake-proxies/lv2/CMakeFiles/lv2.dir/__/__/lib-src/lv2/lilv/src/query.c.o
[ 51%] Building C object cmake-proxies/lv2/CMakeFiles/lv2.dir/__/__/lib-src/lv2/lilv/src/scalepoint.c.o
[ 51%] Building C object cmake-proxies/lv2/CMakeFiles/lv2.dir/__/__/lib-src/lv2/lilv/src/state.c.o
[ 51%] Building C object cmake-proxies/lv2/CMakeFiles/lv2.dir/__/__/lib-src/lv2/lilv/src/ui.c.o
[ 51%] Building C object cmake-proxies/lv2/CMakeFiles/lv2.dir/__/__/lib-src/lv2/lilv/src/util.c.o
[ 51%] Building C object cmake-proxies/lv2/CMakeFiles/lv2.dir/__/__/lib-src/lv2/lilv/src/world.c.o
[ 51%] Linking C static library liblv2.a
[ 53%] Built target lv2
Consolidate compiler generated dependencies of target portmidi
[ 54%] Built target portmidi
Consolidate compiler generated dependencies of target portmixer
[ 54%] Built target portmixer
Consolidate compiler generated dependencies of target portsmf
[ 55%] Built target portsmf
Consolidate compiler generated dependencies of target libsbsms
[ 56%] Built target libsbsms
Consolidate compiler generated dependencies of target twolame
[ 58%] Built target twolame
[ 58%] Built target version
[ 62%] Built target nyquist
Consolidate compiler generated dependencies of target Audacium
[ 62%] Building CXX object src/CMakeFiles/Audacium.dir/AudacityApp.cpp.o
In file included from /home/felipeqp/gitpackages/ani-cli/audacium/src/audacium-1.0.0-rel/src/AudacityApp.cpp:83:
/home/felipeqp/gitpackages/ani-cli/audacium/src/audacium-1.0.0-rel/src/FFmpeg.h:544:7: error: conflicting declaration of C function âAVCodec* avcodec_find_encoder(AVCodecID)â
544 | avcodec_find_encoder,
/home/felipeqp/gitpackages/ani-cli/audacium/src/audacium-1.0.0-rel/src/FFmpeg.h:451:16: note: in definition of macro âFFMPEG_FUNCTION_WITH_RETURNâ
451 | inline r n a \
In file included from /usr/include/libavcodec/avcodec.h:40,
from /home/felipeqp/gitpackages/ani-cli/audacium/src/audacium-1.0.0-rel/src/FFmpeg.h:48,
/usr/include/libavcodec/codec.h:392:16: note: previous declaration âconst AVCodec* avcodec_find_encoder(AVCodecID)â
392 | const AVCodec *avcodec_find_encoder(enum AVCodecID id);
/home/felipeqp/gitpackages/ani-cli/audacium/src/audacium-1.0.0-rel/src/FFmpeg.h:550:7: error: conflicting declaration of C function âAVCodec* avcodec_find_encoder_by_name(const char*)â
550 | avcodec_find_encoder_by_name,
/usr/include/libavcodec/codec.h:400:16: note: previous declaration âconst AVCodec* avcodec_find_encoder_by_name(const char*)â
400 | const AVCodec *avcodec_find_encoder_by_name(const char *name);
/home/felipeqp/gitpackages/ani-cli/audacium/src/audacium-1.0.0-rel/src/FFmpeg.h:556:7: error: conflicting declaration of C function âAVCodec* avcodec_find_decoder(AVCodecID)â
556 | avcodec_find_decoder,
/usr/include/libavcodec/codec.h:376:16: note: previous declaration âconst AVCodec* avcodec_find_decoder(AVCodecID)â
376 | const AVCodec *avcodec_find_decoder(enum AVCodecID id);
/home/felipeqp/gitpackages/ani-cli/audacium/src/audacium-1.0.0-rel/src/FFmpeg.h:634:7: error: conflicting declaration of C function âint avformat_open_input(AVFormatContext**, const char*, AVInputFormat*, AVDictionary**)â
634 | avformat_open_input,
In file included from /home/felipeqp/gitpackages/ani-cli/audacium/src/audacium-1.0.0-rel/src/FFmpeg.h:49,
/usr/include/libavformat/avformat.h:2097:5: note: previous declaration âint avformat_open_input(AVFormatContext**, const char*, const AVInputFormat*, AVDictionary**)â
2097 | int avformat_open_input(AVFormatContext **ps, const char *url,
/home/felipeqp/gitpackages/ani-cli/audacium/src/audacium-1.0.0-rel/src/FFmpeg.h:716:7: error: conflicting declaration of C function âAVOutputFormat* av_guess_format(const char*, const char*, const char*)â
716 | av_guess_format,
/usr/include/libavformat/avformat.h:2480:23: note: previous declaration âconst AVOutputFormat* av_guess_format(const char*, const char*, const char*)â
2480 | const AVOutputFormat *av_guess_format(const char *short_name,
/home/felipeqp/gitpackages/ani-cli/audacium/src/audacium-1.0.0-rel/src/FFmpeg.h: In constructor âAVPacketEx::AVPacketEx()â:
/home/felipeqp/gitpackages/ani-cli/audacium/src/audacium-1.0.0-rel/src/FFmpeg.h:887:21: warning: âvoid av_init_packet(AVPacket*)â is deprecated [-Wdeprecated-declarations]
887 | av_init_packet(this);
/home/felipeqp/gitpackages/ani-cli/audacium/src/audacium-1.0.0-rel/src/FFmpeg.h:738:7: note: declared here
738 | av_init_packet,
/home/felipeqp/gitpackages/ani-cli/audacium/src/audacium-1.0.0-rel/src/FFmpeg.h:461:19: note: in definition of macro âFFMPEG_FUNCTION_NO_RETURNâ
461 | inline void n a \
/home/felipeqp/gitpackages/ani-cli/audacium/src/audacium-1.0.0-rel/src/FFmpeg.h: In member function âvoid AVPacketEx::steal(AVPacketEx&&)â:
/home/felipeqp/gitpackages/ani-cli/audacium/src/audacium-1.0.0-rel/src/FFmpeg.h:921:21: warning: âvoid av_init_packet(AVPacket*)â is deprecated [-Wdeprecated-declarations]
921 | av_init_packet(&that);
make[2]: *** [src/CMakeFiles/Audacium.dir/build.make:173: src/CMakeFiles/Audacium.dir/AudacityApp.cpp.o] Error 1
make[1]: Leaving directory '/home/felipeqp/gitpackages/ani-cli/audacium/src/audacium-1.0.0-rel/build'
make: Leaving directory '/home/felipeqp/gitpackages/ani-cli/audacium/src/audacium-1.0.0-rel/build'
= ERROR: A failure occurred in build().
Aborting...
I have not found any problem related to the dependencies, because they have been installed correctly.
This is not a forum for debugging random source files
Step 3 mentioned above
Contact the developer
Closing as irrelevant to Manjaro.
