solnce
17 September 2021 17:55
1
Hi guys,
I have done fresh install of manjaro deepin, updated, booted in for first time - everything worked fine. Now on a second boot after full update i got this
And machine freezes here. I don’t think this is related to hardware, I have manjaro kde on other partition and no problems booting.
Kernel 5.13.15
Fallback mode is with the same problem
Any help please?
Thanks
Wollie
17 September 2021 18:38
2
Nvidia driver updates (?) may cause this type of issue with lightdm or xorg.
In your case I would study content of
/var/log/lightdm/lightdm.log
and
/var/log/lightdm/x-0.org
Sometimes it helps to reinstall xorg by
sudo pacman -Syu xorg
from a chroot environment.
solnce
17 September 2021 21:08
3
Thank you for your response.
I’m not very competent in that, but log says, it couldn’t find screen - can that be the case?
That’s the fragment:
I’ll try to reintstall xorg the other day.
Thanks
S
Yes.
There is a “mismatch” between what’s defined in the config files (in /etc/X11/) and what’s currently present.
