I presume it’s stremio 4.4.168-1 from the AUR that you’re trying to install. I noticed a comment that seems related, however their resolution is less than ideal. I’d suggest you contact the maintainer directly.
Further to this; a comment from the maintainer [dbermond]: “Sorry, but Manjaro is not supported. Please seek help in your distribution support channels.”
So, it would seem they are not being overly helpful, in this instance.
Edit:- It seems one of the sources listed doesn’t exist. - The AUR page lists Stremio-Shell v4.4.168 whereas the latest version available on GitHub is v4.4.107.
What version are you trying to update from? If it is a pre-4.4.168 version, then you might want to try building the stremio-beta package, which I just successfully built on my Stable system. The beta package is v4.4.168-0, not the v4.4.168-1 that failed to build for you. It has been flagged as out-of-date on the AUR though.
If you were trying to update from v4.4.168-0 to v4.4.168-1, then you can ignore what I have just written.
Don’t you see anything inherently wrong with skipping the validity check?
A better approach might be to find which file is failing, obtain its checksum value from the source, and update the PKGBUILD if everything seems in order.
My point is that if whatever file is somehow damaged, and if that’s the reason for the validity check failing, the package might still continue to build by skipping the check, but might also cause you grief later.
This is just something for consideration.
In fairness, it might also be that the checksum simply hasn’t been updated in the PKGBUILD file and that the source is actually fine; in which case, see the the post from @cscs .
Provided all the dependencies are there (installed from normal repo, nothing from AUR).
My procedure: wget https://aur.archlinux.org/cgit/aur.git/snapshot/stremio.tar.gz
(get the snapshot from the AUR website.)
unpack it in its own directory cd into that directory
run updpkgsums
then run makepkg
successful build without errors of: stremio-4.4.168-1-x86_64.pkg.tar.zst
found in the same directory makepkg -i would have installed it after successful build
The package has been updated to generate checksums for the git tag supported by pacman 6.1.0. Either switch to the testing branch or skip the checksums for now.
