~ ls -lhR /var/tmp/pamac ✔
drwxr-xr-x diego diego 4.0 KB Sat Jun 15 12:04:30 2024 aur-diego
drwxr-xr-x root root 4.0 KB Sat Jun 15 12:03:06 2024 dbs
/var/tmp/pamac/aur-diego:
drwxr-xr-x diego diego 4.0 KB Sat Jun 15 12:04:25 2024 android-studio-2023.3.1.20-1
drwxr-xr-x diego diego 4.0 KB Sat Jun 15 12:04:19 2024 burpsuite-2024.5.2-1
drwxr-xr-x diego diego 4.0 KB Sat Jun 15 12:04:25 2024 docker-desktop-4.30.0-1
drwxr-xr-x diego diego 4.0 KB Sat Jun 15 12:04:25 2024 electron29-bin-29.4.2-2
drwxr-xr-x diego diego 4.0 KB Sat Jun 15 12:04:28 2024 electron30-bin-30.1.1-1
drwxr-xr-x diego diego 4.0 KB Sat Jun 15 12:04:30 2024 ferdium-bin-6.7.4-1
drwxr-xr-x diego diego 4.0 KB Sat Jun 15 12:04:30 2024 google-chrome-126.0.6478.61-1
drwxr-xr-x diego diego 4.0 KB Sat Jun 15 12:04:21 2024 key-mon-1.20-3
drwxr-xr-x diego diego 4.0 KB Sat Jun 15 12:04:26 2024 krunner5-5.115.0-4
drwxr-xr-x diego diego 4.0 KB Sat Jun 15 12:04:25 2024 logiops-0.3.4-1
drwxr-xr-x diego diego 4.0 KB Sat Jun 15 12:04:26 2024 microsoft-edge-stable-bin-126.0.2592.56-1
drwxr-xr-x diego diego 4.0 KB Sat Jun 15 12:04:30 2024 mongodb-bin-7.0.11-1
drwxr-xr-x diego diego 4.0 KB Sat Jun 15 12:04:21 2024 mongosh-bin-2.2.6-1
drwxr-xr-x diego diego 4.0 KB Sat Jun 15 12:04:25 2024 responsively-1.12.0-1
drwxr-xr-x diego diego 4.0 KB Sat Jun 15 12:04:24 2024 vcpkg-2024.06.10-1
drwxr-xr-x diego diego 4.0 KB Sat Jun 15 12:04:30 2024 visual-studio-code-bin-1.90.1-1
drwxr-xr-x diego diego 4.0 KB Sat Jun 15 12:04:26 2024 vmware-workstation-17.5.2-1
drwxr-xr-x diego diego 4.0 KB Sat Jun 15 12:04:30 2024 zoom-6.0.12-1
/var/tmp/pamac/aur-diego/android-studio-2023.3.1.20-1:
.rw-r--r-- diego diego 243 B Sat Jun 15 12:04:25 2024 desc
/var/tmp/pamac/aur-diego/burpsuite-2024.5.2-1:
.rw-r--r-- diego diego 244 B Sat Jun 15 12:04:19 2024 desc
/var/tmp/pamac/aur-diego/docker-desktop-4.30.0-1:
.rw-r--r-- diego diego 387 B Sat Jun 15 12:04:25 2024 desc
/var/tmp/pamac/aur-diego/electron29-bin-29.4.2-2:
.rw-r--r-- diego diego 328 B Sat Jun 15 12:04:25 2024 desc
/var/tmp/pamac/aur-diego/electron30-bin-30.1.1-1:
.rw-r--r-- diego diego 289 B Sat Jun 15 12:04:28 2024 desc
/var/tmp/pamac/aur-diego/ferdium-bin-6.7.4-1:
.rw-r--r-- diego diego 530 B Sat Jun 15 12:04:30 2024 desc
/var/tmp/pamac/aur-diego/google-chrome-126.0.6478.61-1:
.rw-r--r-- diego diego 276 B Sat Jun 15 12:04:30 2024 desc
/var/tmp/pamac/aur-diego/key-mon-1.20-3:
.rw-r--r-- diego diego 259 B Sat Jun 15 12:04:21 2024 desc
/var/tmp/pamac/aur-diego/krunner5-5.115.0-4:
.rw-r--r-- diego diego 346 B Sat Jun 15 12:04:26 2024 desc
/var/tmp/pamac/aur-diego/logiops-0.3.4-1:
.rw-r--r-- diego diego 292 B Sat Jun 15 12:04:25 2024 desc
/var/tmp/pamac/aur-diego/microsoft-edge-stable-bin-126.0.2592.56-1:
.rw-r--r-- diego diego 468 B Sat Jun 15 12:04:26 2024 desc
/var/tmp/pamac/aur-diego/mongodb-bin-7.0.11-1:
.rw-r--r-- diego diego 313 B Sat Jun 15 12:04:30 2024 desc
/var/tmp/pamac/aur-diego/mongosh-bin-2.2.6-1:
.rw-r--r-- diego diego 304 B Sat Jun 15 12:04:21 2024 desc
/var/tmp/pamac/aur-diego/responsively-1.12.0-1:
.rw-r--r-- diego diego 233 B Sat Jun 15 12:04:25 2024 desc
/var/tmp/pamac/aur-diego/vcpkg-2024.06.10-1:
.rw-r--r-- diego diego 236 B Sat Jun 15 12:04:24 2024 desc
/var/tmp/pamac/aur-diego/visual-studio-code-bin-1.90.1-1:
.rw-r--r-- diego diego 446 B Sat Jun 15 12:04:30 2024 desc
/var/tmp/pamac/aur-diego/vmware-workstation-17.5.2-1:
.rw-r--r-- diego diego 488 B Sat Jun 15 12:04:26 2024 desc
/var/tmp/pamac/aur-diego/zoom-6.0.12-1:
.rw-r--r-- diego diego 435 B Sat Jun 15 12:04:30 2024 desc
/var/tmp/pamac/dbs:
lrwxrwxrwx root root 21 B Sat Jun 15 12:03:03 2024 local ⇒ /var/lib/pacman/local
drwxrwxrwx root root 4.0 KB Fri Jul 5 17:42:38 2024 sync
/var/tmp/pamac/dbs/sync:
.rw-rw-rw- root root 29 B Wed Jul 3 18:27:00 2024 community.db
.rw-rw-rw- diego diego 0 B Fri Jul 5 17:42:38 2024 community.db.part
.rw-rw-rw- root root 29 B Sat Jan 13 02:38:19 2024 community.files
.rw-rw-rw- root root 141 KB Wed Jul 3 18:27:00 2024 core.db
.rw-rw-rw- diego diego 0 B Fri Jul 5 17:42:38 2024 core.db.sig.part
.rw-rw-rw- root root 2.2 MB Sat Jan 13 02:38:19 2024 core.files
.rw-r--r-- root root 8.3 MB Sat Jun 15 04:43:09 2024 extra.db
.rw-rw-rw- diego diego 0 B Fri Jul 5 17:42:38 2024 extra.db.sig.part
.rw-rw-rw- root root 41 MB Sun Jan 14 18:47:58 2024 extra.files
.rw-rw-rw- root root 145 KB Wed Jul 3 18:27:00 2024 multilib.db
.rw-rw-rw- diego diego 0 B Fri Jul 5 17:42:38 2024 multilib.db.part
.rw-rw-rw- root root 215 KB Sat Jan 13 02:38:44 2024 multilib.files
.rw-r--r-- root root 10 MB Sat Jun 15 12:00:04 2024 packages-meta-ext-v1.json.gz
.rw-rw-rw- root root 0 B Sat Jun 15 12:03:08 2024 refresh_timestamp
I executed the command and now is updating a lot of things more that with -Syyu command was not updating before.
I will write again when the command finish.
I did again and after a lot of downloads fail in rustdesk right now:
Downloading vcpkg-glibc...
vcpkg package management program version 2024-06-10-02590c430e4ed9215d27870138c2e579cc338772
See LICENSE.txt for license information.
Telemetry
vcpkg collects usage data in order to help us improve your experience.
The data collected by Microsoft is anonymous.
You can opt-out of telemetry by re-running the bootstrap-vcpkg script with -disableMetrics,
passing --disable-metrics to vcpkg on the command line,
or by setting the VCPKG_DISABLE_METRICS environment variable.
Read more about vcpkg telemetry at docs/about/privacy.md
unable to read $HOME
==> ERROR: A failure occurred in build().
/usr/share/makepkg/util/message.sh: line 51: QUIET: unbound variable
/usr/bin/makepkg: line 131: logpipe: unbound variable
Finished with result: exit-code
Main processes terminated with: code=exited, status=1/FAILURE
Service runtime: 2min 12.587s
Error: Failed to build rustdesk
