My PC is slow so I removed snap after that I am getting this message during the boot process. Please kindly help me with this problem.
Info of the boot screen image.
[FAILED] Failed to mount Mount unit for core, revision 12834.
[FAILED] Failed to mount Mount unit for core, revision 12941.
[FAILED] Failed to mount Mount unit for snapd, revision 15177.
[FAILED] Failed to mount Mount unit for snapd, revision 15534.
Here is the outcome of systemctl --failed
systemctl --failed ✔ 9m 1s
UNIT LOAD ACTIVE SUB DESCRIPTION
● var-lib-snapd-snap-core-12834.mount loaded failed failed Mount unit for core, revision 12834
● var-lib-snapd-snap-core-12941.mount loaded failed failed Mount unit for core, revision 12941
● var-lib-snapd-snap-snapd-15177.mount loaded failed failed Mount unit for snapd, revision 15177
● var-lib-snapd-snap-snapd-15534.mount loaded failed failed Mount unit for snapd, revision 15534
output of inxi
Kernel: 5.10.114-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=9755c64c-a8ee-42b7-824c-8177b167f952 rw quiet apparmor=1
security=apparmor resume=UUID=da5ee717-ac61-4fd6-abdd-e98739f3f3c5
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 20RAS0SG00 v: ThinkPad E14
Mobo: LENOVO model: 20RAS0SG00 v: SDK0Q55724 WIN
serial: <superuser required> UEFI: LENOVO v: R16ET26W (1.12 )
date: 06/08/2020
ID-1: BAT0 charge: 20.8 Wh (98.6%) condition: 21.1/45.0 Wh (47.0%)
volts: 12.0 min: 11.1 model: LGC 5B10W138 type: Li-poly serial: <filter>
status: discharging cycles: 768
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M185
status: discharging
RAM: total: 7.46 GiB used: 3.79 GiB (50.9%)
RAM Report:
Info: model: Intel Core i3-10110U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xEC
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 900 min/max: 400/4100 scaling: driver: intel_pstate
governor: powersave cores: 1: 900 2: 900 3: 900 4: 900 bogomips: 20810
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Type: srbds mitigation: TSX disabled
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Lenovo driver: i915
v: kernel ports: active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:9b41 class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-8:3 chip-ID: 04f2:b6d9 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: BOE Display 0x07c9 built: 2018 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 345mm (13.6")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.0.3
direct render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Lenovo driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
chip-ID: 8086:02c8 class-ID: 0403
Sound Server-1: ALSA v: k5.10.114-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel pcie: speed: Unknown lanes: 63
link-max: gen: 5 speed: 32 GT/s port: 2000 bus-ID: 04:00.0
IF: enp4s0 state: down mac: <filter>
Local Storage: total: 931.51 GiB used: 673 GiB (72.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-08Z10
type: HDD rpm: 5400 serial: <filter> rev: 1A05 scheme: GPT
ID-1: / raw-size: 922.42 GiB size: 906.86 GiB (98.31%) used: 673 GiB (74.2%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 9755c64c-a8ee-42b7-824c-8177b167f952
used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: FE8B-8CD1
ID-1: swap-1 type: partition size: 8.8 GiB used: 1.3 MiB (0.0%)
priority: -2 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: da5ee717-ac61-4fd6-abdd-e98739f3f3c5
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-5:2 info: Logitech Unifying Receiver type: Mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c52f class-ID: 0300
Device-2: 1-8:3 info: Chicony Integrated Camera type: Video
Device-3: 1-9:4 info: Shenzhen Goodix FingerPrint Device
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 27c6:55a4 class-ID: ef00
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 51.0 C pch: 50.0 C mobo: 0.0 C
Fan Speeds (RPM): cpu: 0
Processes: 235 Uptime: 2h 2m wakeups: 6887 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 2088
pacman: 2052 lib: 428 flatpak: 36 Shell: Zsh v: 5.8.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.15
