Before starting my session I get four [FAILED] messages.
[FAILED] Failed to mount Mount unit for core18, revision 1880.
[FAILED] Failed to mount Mount unit for gnome-3-28-1804, revision 128.
[FAILED] Failed to mount Mount unit for gtk-common-themes, revision 1506.
[FAILED] Failed to mount Mount unit for snapd, revision 8542.
The session does start though and works perfectly fine afterwards. I don’t use snaps so I have uninstalled snapd. I am using Operating System: Manjaro 21.0.2 Ornara, KDE Plasma Version: 5.21.4, KDE Frameworks Version: 5.81.0, Qt Version: 5.15.2 with Kernel Version: 5.10.30-1-MANJARO.
The output of systemctl --failed is
UNIT LOAD ACTIVE SUB DESCRIPTION
● var-lib-snapd-snap-core18-1880.mount loaded failed failed Mount unit for core18, revision 1880
● var-lib-snapd-snap-gnome\x2d3\x2d28\x2d1804-128.mount loaded failed failed Mount unit for gnome-3-28-1804, revision 128
● var-lib-snapd-snap-gtk\x2dcommon\x2dthemes-1506.mount loaded failed failed Mount unit for gtk-common-themes, revision 1506
● var-lib-snapd-snap-snapd-8542.mount loaded failed failed Mount unit for snapd, revision 8542
LOAD = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB = The low-level unit activation state, values depend on unit type.
4 loaded units listed.
