Hi team,
After this update im unable to login to system.
System specs hp 15-dk2096tx, i7 11th gen, rtx 3050 gpu
My system got black screen , showing failed to load kernel modules at start after seeing logs.
Unfortunately i removed 5.17, after installing 5.18.
What to do next… Please help
Moderator edit: Removed useless attached photo
can you boot on USB iso manjaro
open a terminal and browser on this topic
and return
inxi -Fza
Welcome to Manjaro!
Please read the information behind this link. It will help you to post necessary information. [HowTo] Provide System Information
Please press the three dots … below your post and then press the
If you give us information about your system, we can see what we’re talking about and make better suggestions.
You can do this by using inxi in a terminal or in console.
Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
Copy the output from inxi (including the command) and paste it into your post.
To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
Hi team, I’m facing the same problem for a while now. I tried searching for it a bit, but couldn’t find any solution to the issue. Hence I reverted back to the Kernel 5.17 which is working for me.
As asked, here is the output of the command inxi --admin --verbosity=7 --filter --no-host --width in my terminal.
I figure it might also be beneficial to give you the entry in GRUB for 5.18 kernel.
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod btrfs
search --no-floppy --fs-uuid --set=root 32fe2019-db43-4af7-9a17-5fe8f3002e9c
linux /@/boot/vmlinuz-5.18-x86_64 root=UUID=32fe2019-db43-4af7-9a17-5fe8f3002e9c rw rootflags=subvol=@ apparmor=1 security=apparmor udev.log_priority=3 i915.enable_guc=2 resume=UUID=9a029e11-a1f8-4a75-8068-4e2997f34e58 image_size=8000000000
initrd /@/boot/intel-ucode.img /@/boot/initramfs-5.18-x86_64.img
In the same entry, if I edit and replace 5.18 with 5.17, it works properly. Also, I have tried purging the packages linux518, linux518-nvidia and linux518-headers and reinstalling them once again.
All I see is this screen if I use kernel 5.18.
Please do let me know if you need any more details. Until then, I’ll be using 5.17 kernel for work since it is working perfectly with all my hardware.
I found this issue via searching, and temporarily adding the ibt=off parameter to the kernel got the system booting up.
opened 07:12AM - 25 May 22 UTC
bug
NV-Triaged
### NVIDIA Open GPU Kernel Modules Version
515.43.04
### Does this happen with… the proprietary driver (of the same version) as well?
Yes
### Operating System and Version
Arch Linux
### Kernel Release
5.18.0-arch1-1
### Hardware: GPU
RTX 3070 laptop (System 76 Oryx 8)
### Describe the bug
Since upgrading to Kernel 5.18, loading the nvidia driver (Or proprietary one) fails with the same kernel log:
[ 5.429675] nvidia-nvlink: Nvlink Core is being initialized, major device number 510
[ 5.429718] traps: Missing ENDBR: _portMemAllocatorAllocNonPagedWrapper+0x0/0x10 [nvidia]
[ 5.429816] ------------[ cut here ]------------
[ 5.429817] kernel BUG at arch/x86/kernel/traps.c:252!
[ 5.429828] invalid opcode: 0000 [#1] PREEMPT SMP NOPTI
[ 5.429830] CPU: 9 PID: 948 Comm: modprobe Tainted: G OE 5.18.0-arch1-1 #1 b71a70fe104889aac2f32556bc52f649da2881d2
[ 5.429832] Hardware name: System76 Oryx Pro/Oryx Pro, BIOS 2021-09-23_b9b0e89 09/23/2021
[ 5.429833] RIP: 0010:exc_control_protection+0xc2/0xd0
[ 5.429837] Code: 8b 93 80 00 00 00 be f9 00 00 00 48 c7 c7 d3 ab 66 b5 e8 d1 01 50 ff e9 72 ff ff ff 48 c7 c7 ba ab 66 b5 e8 c7 31 fb ff 0f 0b <0f> 0b 66 66 2e 0f 1f 84 00 00 00 00 00 90 66 0f 1f 00 55 53 48 89
[ 5.429838] RSP: 0018:ffffa9c3413b3bb8 EFLAGS: 00010002
[ 5.429839] RAX: 000000000000004d RBX: ffffa9c3413b3bd8 RCX: 0000000000000027
[ 5.429840] RDX: 0000000000000000 RSI: 0000000000000001 RDI: ffff9d195fa616a0
[ 5.429841] RBP: 0000000000000003 R08: 0000000000000000 R09: ffffa9c3413b39d8
[ 5.429842] R10: 0000000000000003 R11: ffffffffb5ecaa08 R12: 0000000000000000
[ 5.429842] R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
[ 5.429843] FS: 00007f0aa9bbe740(0000) GS:ffff9d195fa40000(0000) knlGS:0000000000000000
[ 5.429844] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 5.429845] CR2: 00007f0aa8382000 CR3: 00000001063ce002 CR4: 0000000000f70ee0
[ 5.429846] PKRU: 55555554
[ 5.429847] Call Trace:
[ 5.429848] <TASK>
[ 5.429849] asm_exc_control_protection+0x22/0x30
[ 5.429852] RIP: 0010:_portMemAllocatorAllocNonPagedWrapper+0x0/0x10 [nvidia]
[ 5.429920] Code: 08 48 89 d0 48 89 0f 48 c1 e0 17 48 31 c2 48 89 c8 48 c1 e8 05 48 31 c8 48 31 d0 48 c1 ea 12 48 31 d0 48 89 47 08 01 c8 c3 90 <48> 89 f7 e9 38 0f 00 00 0f 1f 84 00 00 00 00 00 48 89 f7 e9 88 0f
[ 5.429921] RSP: 0018:ffffa9c3413b3c80 EFLAGS: 00010202
[ 5.429922] RAX: ffffffffc1eae5f0 RBX: 0000000000000010 RCX: 0000000000000000
[ 5.429923] RDX: 0000000000000000 RSI: 000000000000002c RDI: ffffffffc20f7b70
[ 5.429923] RBP: ffffa9c3413b3c98 R08: 0000000000000020 R09: ffffffffc20f7bf0
[ 5.429924] R10: ffffffffc20f55d0 R11: 0000000000000000 R12: ffffffffc20f7b70
[ 5.429925] R13: 00007f0aa8382dc0 R14: 000055916224ef30 R15: ffffa9c3413b3e20
[ 5.429926] ? portCryptoPseudoRandomGeneratorGetU32+0x30/0x30 [nvidia 5737a4bc014c2c47af46ebdec30e9ee078e09f14]
[ 5.429991] _portMemAllocatorAlloc+0x2e/0x170 [nvidia 5737a4bc014c2c47af46ebdec30e9ee078e09f14]
[ 5.430054] portCryptoPseudoRandomGeneratorCreate+0x16/0xb0 [nvidia 5737a4bc014c2c47af46ebdec30e9ee078e09f14]
[ 5.430117] portCryptoInitialize+0x2a/0x40 [nvidia 5737a4bc014c2c47af46ebdec30e9ee078e09f14]
[ 5.430182] portInitialize+0x2b/0x40 [nvidia 5737a4bc014c2c47af46ebdec30e9ee078e09f14]
[ 5.430246] coreInitializeRm+0x24/0x90 [nvidia 5737a4bc014c2c47af46ebdec30e9ee078e09f14]
[ 5.430324] RmInitRm+0x9/0x20 [nvidia 5737a4bc014c2c47af46ebdec30e9ee078e09f14]
[ 5.430399] rm_init_rm+0x9/0x10 [nvidia 5737a4bc014c2c47af46ebdec30e9ee078e09f14]
[ 5.430472] nvidia_init_module+0x22e/0x5b0 [nvidia 5737a4bc014c2c47af46ebdec30e9ee078e09f14]
[ 5.430517] ? nvidia_init_module+0x5b0/0x5b0 [nvidia 5737a4bc014c2c47af46ebdec30e9ee078e09f14]
[ 5.430565] nvidia_frontend_init_module+0x50/0x91 [nvidia 5737a4bc014c2c47af46ebdec30e9ee078e09f14]
[ 5.430616] ? nvidia_init_module+0x5b0/0x5b0 [nvidia 5737a4bc014c2c47af46ebdec30e9ee078e09f14]
[ 5.430663] do_one_initcall+0x5a/0x220
[ 5.430667] do_init_module+0x4a/0x240
[ 5.430670] __do_sys_init_module+0x138/0x1b0
[ 5.430672] do_syscall_64+0x5c/0x90
[ 5.430674] ? exc_page_fault+0x74/0x170
[ 5.430676] entry_SYSCALL_64_after_hwframe+0x44/0xae
[ 5.430677] RIP: 0033:0x7f0aa9512c3e
[ 5.430679] Code: 48 8b 0d 5d b1 0e 00 f7 d8 64 89 01 48 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 90 f3 0f 1e fa 49 89 ca b8 af 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 2a b1 0e 00 f7 d8 64 89 01 48
[ 5.430680] RSP: 002b:00007fff39f3cc58 EFLAGS: 00000246 ORIG_RAX: 00000000000000af
[ 5.430681] RAX: ffffffffffffffda RBX: 000055916224ebd0 RCX: 00007f0aa9512c3e
[ 5.430682] RDX: 000055916224ef30 RSI: 00000000008f1db0 RDI: 00007f0aa7a91010
[ 5.430682] RBP: 00007f0aa7a91010 R08: 000055916224eae0 R09: 0000000000000000
[ 5.430683] R10: 0000000000000005 R11: 0000000000000246 R12: 000055916224ef30
[ 5.430684] R13: 000055916224ed00 R14: 000055916224ebd0 R15: 000055916224ef60
[ 5.430685] </TASK>
[ 5.430685] Modules linked in: pcc_cpufreq(-) nvidia(OE+) acpi_cpufreq(-) bnep bridge stp llc btusb btrtl btbcm btintel uvcvideo btmtk videobuf2_vmalloc bluetooth videobuf2_memops videobuf2_v4l2 videobuf2_common ecdh_generic videodev mc snd_sof_pci_intel_tgl snd_sof_intel_hda_common soundwire_intel soundwire_generic_allocation soundwire_cadence snd_hda_codec_realtek snd_sof_intel_hda snd_hda_codec_generic snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_soc_hdac_hda iwlmvm snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi joydev intel_tcc_cooling soundwire_bus mousedev ledtrig_audio mac80211 x86_pkg_temp_thermal intel_powerclamp snd_soc_core coretemp snd_compress ac97_bus kvm_intel libarc4 hid_multitouch snd_hda_codec_hdmi 8250_dw spi_nor mei_pxp snd_pcm_dmaengine mei_hdcp ee1004 mtd i915 iTCO_wdt snd_hda_intel kvm intel_pmc_bxt snd_intel_dspcfg iTCO_vendor_support intel_rapl_msr iwlwifi irqbypass snd_intel_sdw_acpi snd_hda_codec crct10dif_pclmul crc32_pclmul
[ 5.430709] ghash_clmulni_intel snd_hda_core iwlmei vfat aesni_intel processor_thermal_device_pci_legacy processor_thermal_device pmt_telemetry snd_hwdep crypto_simd pmt_class cryptd fat intel_cstate r8169 drm_buddy cfg80211 intel_uncore snd_pcm processor_thermal_rfim realtek psmouse ttm processor_thermal_mbox mei_me snd_timer rfkill pcspkr i2c_i801 mdio_devres processor_thermal_rapl intel_lpss_pci spi_intel_pci intel_rapl_common snd libphy intel_lpss drm_dp_helper spi_intel i2c_smbus soundcore int340x_thermal_zone thunderbolt mei i2c_hid_acpi idma64 intel_gtt intel_vsec intel_soc_dts_iosf i2c_hid intel_hid video intel_scu_pltdrv sparse_keymap system76_acpi mac_hid coreboot_table dm_multipath dm_mod ipmi_devintf ipmi_msghandler crypto_user acpi_call(OE) fuse bpf_preload ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 serio_raw atkbd uas libps2 usb_storage usbhid vivaldi_fmap nvme xhci_pci nvme_core crc32c_intel i8042 xhci_pci_renesas serio
[ 5.430736] ---[ end trace 0000000000000000 ]---
### To Reproduce
1. Upgrade to kernel 5.18
2. Reboot
3. Observe nvidia module won't load and check kernel logs for the same error
### Bug Incidence
Always
### nvidia-bug-report.log.gz
[nvidia-bug-report.log.gz](https://github.com/NVIDIA/open-gpu-kernel-modules/files/8768756/nvidia-bug-report.log.gz)
### More Info
Originally I thought this issue was to do with optimus-manager (As I am using a hybrid setup I use that utility to switch between intel and nvidia mode), but after uninstalling optimus manager the same issue occurs
However, I don’t think this is a correct solution, so I’m still going back to 5.17 kernel.
