@linux-aarhus It’s a UEFI based system running in UEFI mode.
@papajoke Thank you for pointing that out. I shall remove it.
@stephane:
[manjaro@manjaro ~]$ inxi -Fza
Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_GB keytable=gb
tz=Europe/London driver=nonfree nouveau.modeset=0 i915.modeset=1
radeon.modeset=1 misobasedir=manjaro misolabel=MANJARO_KDE_201 quiet
systemd.show_status=1 apparmor=1 security=apparmor
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Desktop System: Gigabyte product: N/A v: N/A serial: <filter>
Chassis: type: 3 serial: <filter>
Mobo: Gigabyte model: 990FXA-UD5 serial: <filter>
UEFI: American Megatrends v: FC date: 06/24/2015
Topology: 8-Core model: AMD FX-8350 bits: 64 type: MCP arch: Bulldozer
family: 15 (21) model-id: 2 stepping: N/A microcode: 6000852
L2 cache: 2048 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 64322
Speed: 1403 MHz min/max: 1400/4000 MHz boost: enabled
Core speeds (MHz): 1: 1404 2: 1403 3: 1405 4: 1402 5: 1403 6: 1405
7: 1405 8: 1407
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
STIBP: disabled, RSB filling
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: Micro-Star MSI
driver: nvidia v: 450.66 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1b81
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: nvidia
display ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 94 s-size: 1038x292mm (40.9x11.5")
s-diag: 1078mm (42.5")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 69
size: 708x398mm (27.9x15.7") diag: 812mm (32")
Monitor-2: DP-3 res: 1920x1080 hz: 60 dpi: 102
size: 478x269mm (18.8x10.6") diag: 548mm (21.6")
Monitor-3: DP-4 res: 1920x1080 hz: 60 dpi: 96
size: 509x286mm (20.0x11.3") diag: 584mm (23")
OpenGL: renderer: GeForce GTX 1070/PCIe/SSE2 v: 4.6.0 NVIDIA 450.66
direct render: Yes
Device-1: AMD SBx00 Azalia vendor: Gigabyte driver: snd_hda_intel
v: kernel bus ID: 00:14.2 chip ID: 1002:4383
Device-2: NVIDIA GP104 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:10f0
Sound Server: ALSA v: k5.8.6-1-MANJARO
vendor: Gigabyte driver: r8169 v: kernel port: b000 bus ID: 05:00.0
chip ID: 10ec:8168
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 5.47 TiB used: 677.1 MiB (0.0%)
ID-1: /dev/sda vendor: Seagate model: ST3750640AS size: 698.63 GiB
block size: physical: 512 B logical: 512 B speed: 1.5 Gb/s
serial: <filter> rev: E scheme: MBR
ID-2: /dev/sdb vendor: Samsung model: SSD 860 EVO 250GB
size: 232.89 GiB block size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s serial: <filter> rev: 4B6Q scheme: GPT
ID-3: /dev/sdc vendor: Samsung model: HD642JJ size: 596.17 GiB
block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
serial: <filter> rev: 1113 scheme: MBR
ID-4: /dev/sdd vendor: Samsung model: SSD 860 EVO 250GB
speed: <unknown> serial: <filter> rev: 4B6Q scheme: GPT
ID-5: /dev/sde vendor: Western Digital model: WD40EZRX-00SPEB0
size: 3.64 TiB block size: physical: 4096 B logical: 512 B
speed: <unknown> rotation: 5400 rpm serial: <filter> rev: 0A80
scheme: GPT
ID-6: /dev/sdf type: USB vendor: SanDisk model: Ultra size: 114.61 GiB
block size: physical: 512 B logical: 512 B serial: <filter> rev: 1.00
scheme: MBR
ID-1: / raw size: N/A size: 17.63 GiB used: 677.1 MiB (3.8%)
fs: overlay source: ERR-102
System Temperatures: cpu: 18.8 C mobo: N/A gpu: nvidia temp: 56 C
Processes: 248 Uptime: 1h 45m Memory: 23.51 GiB used: 2.03 GiB (8.6%)
Init: systemd v: 246 Compilers: gcc: N/A Packages: pacman: 1188
lib: 313 flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole
inxi: 3.1.05
[manjaro@manjaro ~]$ sudo parted -l
Model: ATA ST3750640AS (scsi)
Disk /dev/sda: 750GB
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 1049kB 742GB 742GB primary ntfs boot
2 742GB 750GB 8590MB primary ntfs
Model: ATA Samsung SSD 860 (scsi)
Disk /dev/sdb: 250GB
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 538MB 537MB fat32 msftdata
2 538MB 250GB 250GB ext4
Model: ATA SAMSUNG HD642JJ (scsi)
Disk /dev/sdc: 640GB
Disk Flags:
Disk /dev/sdd: 250GB
Disk Flags:
1 1049kB 106MB 105MB fat32 EFI system partition boot, esp
2 106MB 123MB 16.8MB Microsoft reserved partition msftres
3 123MB 250GB 249GB ntfs Basic data partition msftdata
4 250GB 250GB 538MB ntfs hidden, diag
Model: ATA WDC WD40EZRX-00S (scsi)
Disk /dev/sde: 4001GB
Sector size (logical/physical): 512B/4096B
Disk Flags:
1 17.4kB 134MB 134MB Microsoft reserved partition msftres
2 135MB 4001GB 4001GB ntfs Basic data partition msftdata
Model: SanDisk Ultra (scsi)
Disk /dev/sdf: 123GB
Disk Flags:
2 3100MB 3105MB 4194kB primary esp
[manjaro@manjaro ~]$ sudo efibootmgr -v
BootCurrent: 0005
Timeout: 3 seconds
BootOrder: 0000,0005,0002,0004,0003
Boot0000* Windows Boot Manager HD(1,GPT,c40fa206-7f46-4559-9727-859af5275c52,0x800,0x32000)/File(\EFI\Microsoft\Boot\bootmgfw.efi)WINDOWS.........x...B.C.D.O.B.J.E.C.T.=.{.9.d.e.a.8.6.2.c.-.5.c.d.d.-.4.e.7.0.-.a.c.c.1.-.f.3.2.b.3.4.4.d.4.7.9.5.}....................
Boot0002* CD/DVD Drive BBS(CDROM,,0x0)AMGOAMNO........I.P.I.O.N.E.E.R. .B.D.-.R.W. . . .B.D.R.-.2.0.9.D....................A..............................Gd-.;.A..MQ..L.N......AMBO
Boot0003* USB2.0 Mass Storage BBS(255,,0x0)AMBO
Boot0004* Hard Drive BBS(HD,,0x0)AMGOAMNO........o.S.T.3.7.5.0.6.4.0.A.S....................A...........................>..Gd-.;.A..MQ..L. . . . . . . . . . . . .Q.3.1.D.8.8.Z.J......AMBOAMNO........o.S.A.M.S.U.N.G. .H.D.6.4.2.J.J....................A...........................>..Gd-.;.A..MQ..L.1.S.F.A.9.J.Q.A.0.A.7.2.2.7. . . . . . ......AMBOAMNO........m.S.a.m.s.u.n.g. .S.S.D. .8.6.0. .E.V.O. .2.5.0.G.B....................A.........................>..Gd-.;.A..MQ..L.4.S.J.C.J.N.N.0.1.3.9.5.7.6. .E. . . . ......AMBOAMNO........m.S.a.m.s.u.n.g. .S.S.D. .8.6.0. .E.V.O. .2.5.0.G.B....................A.........................>..Gd-.;.A..MQ..L.4.S.J.C.J.N.N.0.1.3.9.5.7.6. .E. . . . ......AMBOAMNO........o.S.a.m.s.u.n.g. .S.S.D. .8.6.0. .E.V.O. .2.5.0.G.B....................A...........................>..Gd-.;.A..MQ..L.4.S.J.C.J.N.N.0.1.3.9.5.9.4. .P. . . . ......AMBOAMNO[.......9.S.a.n.D.i.s.k....................A................................Gd-.;.A..MQ..L.0.1.0.1.4.6.e.9.f.f.6.c.2.4.d.4.3.a.a.f.b.5.3.1.d.9.1.9.4.9.4.9.1.c.f.3.1.c.d.b.7.7.8.f.e.4.0.e.4.e.9.1.a.2.7.a.1.2.c.6.9.1.d.a.8.0.6.2.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.5.a.8.2.7.6.d.3.f.f.9.d.7.1.0.0.8.1.5.5.8.1.0.7.3.7.2.9.7.8.c.d......AMBO
Boot0005* UEFI: SanDisk PciRoot(0x0)/Pci(0x15,0x1)/Pci(0x0,0x0)/USB(3,0)/HD(1,MBR,0x0,0x5c6664,0x2000)AMBO
[manjaro@manjaro ~]$ test -d /sys/firmware/efi && echo efi || echo bios
efi
