Failed to build python-pynput 1.7.2-1
Log:
# pamac upgrade
Warning: Building packages as root
Warning: Setting build directory to /var/cache/pamac
Preparing...
Cloning python-pynput build files...
Running as unit: run-u335.service
Finished with result: success
Main processes terminated with: code=exited/status=0
Service runtime: 912ms
Checking python-pynput dependencies...
bsdtar: Failed to set default locale
Resolving dependencies...
Checking inter-conflicts...
To build (1):
  python-pynput  1.7.2-1  (1.7.1-1)  AUR
Edit build files : [e]
Apply transaction ? [e/y/N] y
Building python-pynput...
Running as unit: run-u336.service
Press ^] three times within 1s to disconnect TTY.
==> Making package: python-pynput 1.7.2-1 (Fri 29 Jan 2021 09:02:34 AM CET)
==> Retrieving sources...
  -> Downloading pynput-1.7.2.tar.gz...
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   272  100   272    0     0   1283      0 --:--:-- --:--:-- --:--:--  1283
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
100 75193  100 75193    0     0   179k      0 --:--:-- --:--:-- --:--:--  179k
  -> Found python-pynput.patch
    pynput-1.7.2.tar.gz ... Passed
    python-pynput.patch ... Passed
==> Extracting sources...
  -> Extracting pynput-1.7.2.tar.gz with bsdtar
==> Starting prepare()...
patching file setup.py
==> Starting build()...
WARNING: The wheel package is not available.
WARNING: The directory '/.cache/pip' or its parent directory is not owned or is not writable by the current user. The cache has been disabled. Check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
  ERROR: Command errored out with exit status 1:
   command: /usr/bin/python -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-wheel-3m503_ol/setuptools-lint/setup.py'"'"'; __file__='"'"'/tmp/pip-wheel-3m503_ol/setuptools-lint/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-5ba75jkp
       cwd: /tmp/pip-wheel-3m503_ol/setuptools-lint/
  Complete output (6 lines):
  usage: setup.py [global_opts] cmd1 [cmd1_opts] [cmd2 [cmd2_opts] ...]
     or: setup.py --help [cmd1 cmd2 ...]
     or: setup.py --help-commands
     or: setup.py cmd --help
  error: invalid command 'bdist_wheel'
  ERROR: Failed building wheel for setuptools-lint
ERROR: Failed to build one or more wheels
  File "/usr/lib/python3.9/site-packages/setuptools/installer.py", line 126, in fetch_build_egg
    subprocess.check_call(cmd)
  File "/usr/lib/python3.9/subprocess.py", line 373, in check_call
    raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['/usr/bin/python', '-m', 'pip', '--disable-pip-version-check', 'wheel', '--no-deps', '-w', '/tmp/tmpllrpimn2', '--quiet', 'setuptools-lint>=0.5']' returned non-zero exit status 1.
The above exception was the direct cause of the following exception:
  File "/var/cache/private/pamac/python-pynput/src/pynput-1.7.2/setup.py", line 85, in <module>
    setuptools.setup(
  File "/usr/lib/python3.9/site-packages/setuptools/__init__.py", line 152, in setup
    _install_setup_requires(attrs)
  File "/usr/lib/python3.9/site-packages/setuptools/__init__.py", line 147, in _install_setup_requires
    dist.fetch_build_eggs(dist.setup_requires)
  File "/usr/lib/python3.9/site-packages/setuptools/dist.py", line 673, in fetch_build_eggs
    resolved_dists = pkg_resources.working_set.resolve(
  File "/usr/lib/python3.9/site-packages/pkg_resources/__init__.py", line 764, in resolve
    dist = best[req.key] = env.best_match(
  File "/usr/lib/python3.9/site-packages/pkg_resources/__init__.py", line 1049, in best_match
    return self.obtain(req, installer)
  File "/usr/lib/python3.9/site-packages/pkg_resources/__init__.py", line 1061, in obtain
    return installer(requirement)
  File "/usr/lib/python3.9/site-packages/setuptools/dist.py", line 732, in fetch_build_egg
    return fetch_build_egg(self, req)
  File "/usr/lib/python3.9/site-packages/setuptools/installer.py", line 128, in fetch_build_egg
    raise DistutilsError(str(e)) from e
distutils.errors.DistutilsError: Command '['/usr/bin/python', '-m', 'pip', '--disable-pip-version-check', 'wheel', '--no-deps', '-w', '/tmp/tmpllrpimn2', '--quiet', 'setuptools-lint>=0.5']' returned non-zero exit status 1.
==> ERROR: A failure occurred in build().
    Aborting...
Finished with result: exit-code
Main processes terminated with: code=exited/status=4
Service runtime: 2.988s
When first happened:
Preparing...
Download of manjaro-system (20210121-1) started
Download of manjaro-system (20210121-1) finished
Checking keyring...
Checking integrity...
Loading packages files...
Checking file conflicts...
Checking available disk space...
Upgrading manjaro-system (20210101-3 -> 20210121-1)...
Download of firefox (85.0-0.1) started
Download of firefox-i18n-en-us (85.0-0.1) started
Download of firefox-i18n-en-us (85.0-0.1) finished
Download of sudo (1.9.5.p2-0.1) started
Download of sudo (1.9.5.p2-0.1) finished
Download of thunderbird-i18n-en-us (78.7.0-0.1) started
Download of thunderbird-i18n-en-us (78.7.0-0.1) finished
Download of thunderbird (78.7.0-0.1) started
Download of thunderbird (78.7.0-0.1) finished
Download of firefox (85.0-0.1) finished
Checking keyring...
Running pre-transaction hooks...
Remove Firefox Distribution Settings
Remove Thunderbird Distribution Settings
Upgrading firefox (84.0.2-1 -> 85.0-0.1)...
Upgrading firefox-i18n-en-us (84.0.2-1 -> 85.0-0.1)...
Upgrading sudo (1.9.4.p2-2 -> 1.9.5.p2-0.1)...
Upgrading thunderbird (78.6.1-1 -> 78.7.0-0.1)...
Upgrading thunderbird-i18n-en-us (78.6.1-1 -> 78.7.0-0.1)...
Reloading system manager configuration...
Creating temporary files...
Arming ConditionNeedsUpdate...
Copy Firefox Distribution Settings
Updating icon theme caches...
Copy Thunderbird Distribution Settings
Updating the desktop file MIME type cache...
==> Making package: python-pynput 1.7.2-1 (Fri Jan 29 10:58:38 2021)
100   272  100   272    0     0   1307      0 --:--:-- --:--:-- --:--:--  1307
100 75193  100 75193    0     0   206k      0 --:--:-- --:--:-- --:--:--  206k
   command: /usr/bin/python -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-wheel-65be2lbn/setuptools-lint/setup.py'"'"'; __file__='"'"'/tmp/pip-wheel-65be2lbn/setuptools-lint/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-_b_qx798
       cwd: /tmp/pip-wheel-65be2lbn/setuptools-lint/
subprocess.CalledProcessError: Command '['/usr/bin/python', '-m', 'pip', '--disable-pip-version-check', 'wheel', '--no-deps', '-w', '/tmp/tmprb5ud16w', '--quiet', 'setuptools-lint>=0.5']' returned non-zero exit status 1.
  File "/var/tmp/pamac-build-mee/python-pynput/src/pynput-1.7.2/setup.py", line 85, in <module>
    setuptools.setup(
distutils.errors.DistutilsError: Command '['/usr/bin/python', '-m', 'pip', '--disable-pip-version-check', 'wheel', '--no-deps', '-w', '/tmp/tmprb5ud16w', '--quiet', 'setuptools-lint>=0.5']' returned non-zero exit status 1.
    Aborting...
You need to install this package from the AUR first.
Dependencies on packages in the AUR are not automatically installed.
Also, you shouldn’t use sudo with pamac. It will ask for authentication when required.
❯ pamac build python-pynput
Preparing...
Cloning python-setuptools-lint build files...
Not working:
Preparing...
To build (1):
==> Making package: python-pynput 1.7.2-1 (Fri Jan 29 12:11:26 2021)
100   272  100   272    0     0   1502      0 --:--:-- --:--:-- --:--:--  1502
100 75193  100 75193    0     0   219k      0 --:--:-- --:--:-- --:--:--  219k
  command: /usr/bin/python -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-wheel-f8sxeeor/setuptools-lint/setup.py'"'"'; __file__='"'"'/tmp/pip-wheel-
f8sxeeor/setuptools-lint/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code,
__file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-u6ctw3n2
      cwd: /tmp/pip-wheel-f8sxeeor/setuptools-lint/
subprocess.CalledProcessError: Command '['/usr/bin/python', '-m', 'pip', '--disable-pip-version-check', 'wheel', '--no-deps', '-w', '/tmp/tmpeqvsiuks', '--quiet', 'setuptoo
File "/var/tmp/pamac-build-meee/python-pynput/src/pynput-1.7.2/setup.py", line 85, in <module>
setuptools.setup(
distutils.errors.DistutilsError: Command '['/usr/bin/python', '-m', 'pip', '--disable-pip-version-check', 'wheel', '--no-deps', '-w', '/tmp/tmpeqvsiuks', '--quiet', 'setupt
   Aborting...
Now worked:
pamac build python-setuptools-lint
Preparing...
Checking python-setuptools-lint dependencies...
Warning: python-setuptools-lint-0.6.0-1 is up to date -- reinstalling
To build (1):
  python-setuptools-lint  0.6.0-1             AUR
Building python-setuptools-lint...
==> Making package: python-setuptools-lint 0.6.0-1 (Fri Jan 29 12:13:05 2021)
  -> Downloading python-setuptools-lint-0.6.0.tar.gz...
100  3948  100  3948    0     0  16180      0 --:--:-- --:--:-- --:--:-- 16180
==> Validating source files with sha512sums...
    python-setuptools-lint-0.6.0.tar.gz ... Passed
  -> Extracting python-setuptools-lint-0.6.0.tar.gz with bsdtar
running build
running build_py
creating build
creating build/lib
creating build/lib/setuptools_lint
copying src/setuptools_lint/__init__.py -> build/lib/setuptools_lint
copying src/setuptools_lint/setuptools_command.py -> build/lib/setuptools_lint
running egg_info
writing src/setuptools_lint.egg-info/PKG-INFO
writing dependency_links to src/setuptools_lint.egg-info/dependency_links.txt
writing entry points to src/setuptools_lint.egg-info/entry_points.txt
writing requirements to src/setuptools_lint.egg-info/requires.txt
writing top-level names to src/setuptools_lint.egg-info/top_level.txt
reading manifest file 'src/setuptools_lint.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
writing manifest file 'src/setuptools_lint.egg-info/SOURCES.txt'
==> Entering fakeroot environment...
==> Starting package()...
running install
running install_lib
creating /var/tmp/pamac-build-meee/python-setuptools-lint/pkg/python-setuptools-lint/usr
creating /var/tmp/pamac-build-meee/python-setuptools-lint/pkg/python-setuptools-lint/usr/lib
creating /var/tmp/pamac-build-meee/python-setuptools-lint/pkg/python-setuptools-lint/usr/lib/python3.9
creating /var/tmp/pamac-build-meee/python-setuptools-lint/pkg/python-setuptools-lint/usr/lib/python3.9/site-packages
creating /var/tmp/pamac-build-meee/python-setuptools-lint/pkg/python-setuptools-lint/usr/lib/python3.9/site-packages/setuptools_lint
copying build/lib/setuptools_lint/__init__.py -> /var/tmp/pamac-build-meee/python-setuptools-lint/pkg/python-setuptools-lint/usr/lib/python3.9/site-packages/setuptools_lint
copying build/lib/setuptools_lint/setuptools_command.py -> /var/tmp/pamac-build-meee/python-setuptools-lint/pkg/python-setuptools-lint/usr/lib/python3.9/site-packages/setuptools_lint
byte-compiling /var/tmp/pamac-build-meee/python-setuptools-lint/pkg/python-setuptools-lint/usr/lib/python3.9/site-packages/setuptools_lint/__init__.py to __init__.cpython-39.pyc
byte-compiling /var/tmp/pamac-build-meee/python-setuptools-lint/pkg/python-setuptools-lint/usr/lib/python3.9/site-packages/setuptools_lint/setuptools_command.py to setuptools_command.cpython-39.pyc
writing byte-compilation script '/tmp/tmpixqmnnsn.py'
/usr/bin/python /tmp/tmpixqmnnsn.py
removing /tmp/tmpixqmnnsn.py
running install_egg_info
running egg_info
Copying src/setuptools_lint.egg-info to /var/tmp/pamac-build-meee/python-setuptools-lint/pkg/python-setuptools-lint/usr/lib/python3.9/site-packages/setuptools_lint-0.6.0-py3.9.egg-info
running install_scripts
==> Tidying install...
  -> Removing libtool files...
  -> Purging unwanted files...
  -> Removing static library files...
  -> Stripping unneeded symbols from binaries and libraries...
  -> Compressing man and info pages...
==> Checking for packaging issues...
==> Creating package "python-setuptools-lint"...
  -> Generating .PKGINFO file...
  -> Generating .BUILDINFO file...
  -> Generating .MTREE file...
  -> Compressing package...
==> Leaving fakeroot environment.
==> Finished making: python-setuptools-lint 0.6.0-1 (Fri Jan 29 12:13:07 2021)
==> Cleaning up...
Checking keyring...        [1/1]
Checking integrity...        [1/1]
Loading packages files...        [1/1]
Checking file conflicts...        [1/1]
Checking available disk space...        [1/1]
Reinstalling python-setuptools-lint (0.6.0-1)...        [1/1]
And finally thanks @merlock
@Yochanan for some reason did not work for me had to do it manually.
Preparing...
To build (1):
==> Making package: python-pynput 1.7.2-1 (Fri Jan 29 12:16:18 2021)
  -> Found pynput-1.7.2.tar.gz
==> Removing existing $pkgdir/ directory...
running build
running build_py
creating build
creating build/lib
creating build/lib/pynput
copying lib/pynput/__init__.py -> build/lib/pynput
copying lib/pynput/_info.py -> build/lib/pynput
creating build/lib/pynput/keyboard
copying lib/pynput/keyboard/_dummy.py -> build/lib/pynput/keyboard
copying lib/pynput/keyboard/_uinput.py -> build/lib/pynput/keyboard
copying lib/pynput/keyboard/_darwin.py -> build/lib/pynput/keyboard
copying lib/pynput/keyboard/__init__.py -> build/lib/pynput/keyboard
copying lib/pynput/keyboard/_xorg.py -> build/lib/pynput/keyboard
copying lib/pynput/keyboard/_base.py -> build/lib/pynput/keyboard
copying lib/pynput/keyboard/_win32.py -> build/lib/pynput/keyboard
creating build/lib/pynput/_util
copying lib/pynput/_util/win32_vks.py -> build/lib/pynput/_util
copying lib/pynput/_util/xorg.py -> build/lib/pynput/_util
copying lib/pynput/_util/win32.py -> build/lib/pynput/_util
copying lib/pynput/_util/__init__.py -> build/lib/pynput/_util
copying lib/pynput/_util/uinput.py -> build/lib/pynput/_util
copying lib/pynput/_util/xorg_keysyms.py -> build/lib/pynput/_util
copying lib/pynput/_util/darwin.py -> build/lib/pynput/_util
creating build/lib/pynput/mouse
copying lib/pynput/mouse/_dummy.py -> build/lib/pynput/mouse
copying lib/pynput/mouse/_darwin.py -> build/lib/pynput/mouse
copying lib/pynput/mouse/__init__.py -> build/lib/pynput/mouse
copying lib/pynput/mouse/_xorg.py -> build/lib/pynput/mouse
copying lib/pynput/mouse/_base.py -> build/lib/pynput/mouse
copying lib/pynput/mouse/_win32.py -> build/lib/pynput/mouse
running install
running install_lib
creating /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr
creating /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib
creating /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9
creating /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages
creating /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput
creating /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/keyboard
copying build/lib/pynput/keyboard/_dummy.py -> /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/keyboard
copying build/lib/pynput/keyboard/_uinput.py -> /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/keyboard
copying build/lib/pynput/keyboard/_darwin.py -> /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/keyboard
copying build/lib/pynput/keyboard/__init__.py -> /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/keyboard
copying build/lib/pynput/keyboard/_xorg.py -> /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/keyboard
copying build/lib/pynput/keyboard/_base.py -> /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/keyboard
copying build/lib/pynput/keyboard/_win32.py -> /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/keyboard
creating /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/_util
copying build/lib/pynput/_util/win32_vks.py -> /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/_util
copying build/lib/pynput/_util/xorg.py -> /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/_util
copying build/lib/pynput/_util/win32.py -> /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/_util
copying build/lib/pynput/_util/__init__.py -> /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/_util
copying build/lib/pynput/_util/uinput.py -> /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/_util
copying build/lib/pynput/_util/xorg_keysyms.py -> /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/_util
copying build/lib/pynput/_util/darwin.py -> /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/_util
copying build/lib/pynput/__init__.py -> /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput
copying build/lib/pynput/_info.py -> /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput
creating /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/mouse
copying build/lib/pynput/mouse/_dummy.py -> /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/mouse
copying build/lib/pynput/mouse/_darwin.py -> /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/mouse
copying build/lib/pynput/mouse/__init__.py -> /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/mouse
copying build/lib/pynput/mouse/_xorg.py -> /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/mouse
copying build/lib/pynput/mouse/_base.py -> /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/mouse
copying build/lib/pynput/mouse/_win32.py -> /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/mouse
byte-compiling /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/keyboard/_dummy.py to _dummy.cpython-39.pyc
byte-compiling /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/keyboard/_uinput.py to _uinput.cpython-39.pyc
byte-compiling /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/keyboard/_darwin.py to _darwin.cpython-39.pyc
byte-compiling /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/keyboard/__init__.py to __init__.cpython-39.pyc
byte-compiling /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/keyboard/_xorg.py to _xorg.cpython-39.pyc
byte-compiling /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/keyboard/_base.py to _base.cpython-39.pyc
byte-compiling /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/keyboard/_win32.py to _win32.cpython-39.pyc
byte-compiling /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/_util/win32_vks.py to win32_vks.cpython-39.pyc
byte-compiling /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/_util/xorg.py to xorg.cpython-39.pyc
byte-compiling /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/_util/win32.py to win32.cpython-39.pyc
byte-compiling /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/_util/__init__.py to __init__.cpython-39.pyc
byte-compiling /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/_util/uinput.py to uinput.cpython-39.pyc
byte-compiling /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/_util/xorg_keysyms.py to xorg_keysyms.cpython-39.pyc
byte-compiling /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/_util/darwin.py to darwin.cpython-39.pyc
byte-compiling /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/__init__.py to __init__.cpython-39.pyc
byte-compiling /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/_info.py to _info.cpython-39.pyc
byte-compiling /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/mouse/_dummy.py to _dummy.cpython-39.pyc
byte-compiling /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/mouse/_darwin.py to _darwin.cpython-39.pyc
byte-compiling /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/mouse/__init__.py to __init__.cpython-39.pyc
byte-compiling /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/mouse/_xorg.py to _xorg.cpython-39.pyc
byte-compiling /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/mouse/_base.py to _base.cpython-39.pyc
byte-compiling /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput/mouse/_win32.py to _win32.cpython-39.pyc
writing byte-compilation script '/tmp/tmp5fk5ktxx.py'
/usr/bin/python /tmp/tmp5fk5ktxx.py
removing /tmp/tmp5fk5ktxx.py
running egg_info
writing lib/pynput.egg-info/PKG-INFO
writing dependency_links to lib/pynput.egg-info/dependency_links.txt
writing requirements to lib/pynput.egg-info/requires.txt
writing top-level names to lib/pynput.egg-info/top_level.txt
reading manifest file 'lib/pynput.egg-info/SOURCES.txt'
writing manifest file 'lib/pynput.egg-info/SOURCES.txt'
Copying lib/pynput.egg-info to /var/tmp/pamac-build-meee/python-pynput/pkg/python-pynput/usr/lib/python3.9/site-packages/pynput-1.7.2-py3.9.egg-info
==> Creating package "python-pynput"...
==> Finished making: python-pynput 1.7.2-1 (Fri Jan 29 12:16:19 2021)
==> Cleaning up...
Upgrading python-pynput (1.7.1-1 -> 1.7.2-1)...        [1/1]
Related issue:
