I see those messages while trying to update python-pynput:
Erstelle python-pynput...
==> Erstelle Paket: python-pynput 1.7.2-1 (Mi 27 Jan 2021 14:32:56 CET)
==> Prüfe Laufzeit-Abhängigkeiten...
==> Prüfe Buildtime-Abhängigkeiten...
==> Empfange Quellen...
-> pynput-1.7.2.tar.gz gefunden
-> python-pynput.patch gefunden
==> Überprüfe source Dateien mit sha256sums...
pynput-1.7.2.tar.gz ... Durchgelaufen
python-pynput.patch ... Durchgelaufen
==> Entferne existierendes $srcdir/ Verzeichnis...
==> Entpacke Quellen...
-> Entpacke pynput-1.7.2.tar.gz mit bsdtar
==> Beginne prepare()...
patching file setup.py
==> Entferne existierendes $pkgdir/ Verzeichnis...
==> Beginne build()...
WARNING: The wheel package is not available.
ERROR: Command errored out with exit status 1:
command: /usr/bin/python -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-wheel-caf5ll9x/setuptools-lint_77f800c207fb4f5ebbc7caea66d68faa/setup.py'"'"'; __file__='"'"'/tmp/pip-wheel-caf5ll9x/setuptools-lint_77f800c207fb4f5ebbc7caea66d68faa/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-afqzd4yd
cwd: /tmp/pip-wheel-caf5ll9x/setuptools-lint_77f800c207fb4f5ebbc7caea66d68faa/
Complete output (6 lines):
usage: setup.py [global_opts] cmd1 [cmd1_opts] [cmd2 [cmd2_opts] ...]
or: setup.py --help [cmd1 cmd2 ...]
or: setup.py --help-commands
or: setup.py cmd --help
error: invalid command 'bdist_wheel'
ERROR: Failed building wheel for setuptools-lint
ERROR: Failed to build one or more wheels
File "/usr/lib/python3.9/site-packages/setuptools/installer.py", line 75, in fetch_build_egg
subprocess.check_call(cmd)
File "/usr/lib/python3.9/subprocess.py", line 373, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['/usr/bin/python', '-m', 'pip', '--disable-pip-version-check', 'wheel', '--no-deps', '-w', '/tmp/tmphjxif1_p', '--quiet', 'setuptools-lint>=0.5']' returned non-zero exit status 1.
The above exception was the direct cause of the following exception:
File "/var/tmp/pamac-build-sepp/python-pynput/src/pynput-1.7.2/setup.py", line 85, in <module>
setuptools.setup(
File "/usr/lib/python3.9/site-packages/setuptools/__init__.py", line 152, in setup
_install_setup_requires(attrs)
File "/usr/lib/python3.9/site-packages/setuptools/__init__.py", line 147, in _install_setup_requires
dist.fetch_build_eggs(dist.setup_requires)
File "/usr/lib/python3.9/site-packages/setuptools/dist.py", line 686, in fetch_build_eggs
resolved_dists = pkg_resources.working_set.resolve(
File "/usr/lib/python3.9/site-packages/pkg_resources/__init__.py", line 766, in resolve
dist = best[req.key] = env.best_match(
File "/usr/lib/python3.9/site-packages/pkg_resources/__init__.py", line 1051, in best_match
return self.obtain(req, installer)
File "/usr/lib/python3.9/site-packages/pkg_resources/__init__.py", line 1063, in obtain
return installer(requirement)
File "/usr/lib/python3.9/site-packages/setuptools/dist.py", line 745, in fetch_build_egg
return fetch_build_egg(self, req)
File "/usr/lib/python3.9/site-packages/setuptools/installer.py", line 77, in fetch_build_egg
raise DistutilsError(str(e)) from e
distutils.errors.DistutilsError: Command '['/usr/bin/python', '-m', 'pip', '--disable-pip-version-check', 'wheel', '--no-deps', '-w', '/tmp/tmphjxif1_p', '--quiet', 'setuptools-lint>=0.5']' returned non-zero exit status 1.
==> FEHLER: Ein Fehler geschah in build().
Breche ab...
I’m a novice, but isn’t it strange that the package is located in AUR than a “normal” repo?!
