==> Verifying source file signatures with gpg…
gcc-11.3.0.tar.xz … cat: write error: Broken pipe
FAILED
==> ERROR: One or more PGP signatures could not be verified!
Finished with result: exit-code
Main processes terminated with: code=exited/status=1
Service runtime: 7min 12.884s
CPU time consumed: 5.888s
Error: Failed to build gcc11
[INFO] Removing package cache
Cache directory: /var/cache/pacman/pkg/
:: Do you want to remove ALL files from cache? [y/N]
Database directory: /var/lib/pacman/
:: Do you want to remove unused repositories? [Y/n]
removing unused sync repositories…
/dev/fd/63: line 38: TMPDIR: unbound variable
[jo@joshitha-pc ~]$ sudo pamac update
[sudo] password for jo:
Warning: Building packages as dynamic user
Warning: Setting build directory to /var/cache/pamac
Preparing...
Refreshing AUR...
Cloning gcc11 build files...
Running as unit: run-u323.service
fatal: not a git repository (or any parent up to mount point /var/cache/private)
Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).
Main processes terminated with: code=exited/status=128
Service runtime: 11ms
CPU time consumed: 11ms
Running as unit: run-u324.service
Finished with result: success
Main processes terminated with: code=exited/status=0
Service runtime: 38ms
CPU time consumed: 38ms
Running as unit: run-u325.service
Service runtime: 1.615s
CPU time consumed: 122ms
Generating gcc11 information...
Running as unit: run-u326.service
Service runtime: 4.133s
CPU time consumed: 4.701s
Checking gcc11 dependencies...
Cloning gnome-shell-extension-unite build files...
Running as unit: run-u327.service
Service runtime: 16ms
CPU time consumed: 15ms
Running as unit: run-u328.service
Service runtime: 10ms
CPU time consumed: 9ms
Running as unit: run-u329.service
Service runtime: 1.658s
CPU time consumed: 113ms
Generating gnome-shell-extension-unite information...
Running as unit: run-u330.service
Service runtime: 1.181s
CPU time consumed: 1.328s
Checking gnome-shell-extension-unite dependencies...
Cloning python-progress build files...
Running as unit: run-u331.service
Service runtime: 18ms
CPU time consumed: 18ms
Running as unit: run-u332.service
Service runtime: 12ms
CPU time consumed: 12ms
Running as unit: run-u333.service
Service runtime: 1.641s
CPU time consumed: 128ms
Generating python-progress information...
Running as unit: run-u334.service
Service runtime: 1.177s
CPU time consumed: 1.321s
Checking python-progress dependencies...
Cloning libsepol build files...
Running as unit: run-u335.service
Service runtime: 14ms
CPU time consumed: 13ms
Running as unit: run-u336.service
Service runtime: 8ms
CPU time consumed: 8ms
Running as unit: run-u337.service
Service runtime: 1.577s
CPU time consumed: 131ms
Generating libsepol information...
Running as unit: run-u338.service
Service runtime: 3.470s
CPU time consumed: 3.928s
Checking libsepol dependencies...
Cloning libselinux build files...
Running as unit: run-u340.service
Service runtime: 17ms
Running as unit: run-u341.service
Running as unit: run-u342.service
Service runtime: 1.629s
CPU time consumed: 120ms
Generating libselinux information...
Running as unit: run-u343.service
Service runtime: 3.495s
CPU time consumed: 3.983s
Checking libselinux dependencies...
Cloning libuvc build files...
Running as unit: run-u344.service
Running as unit: run-u345.service
CPU time consumed: 10ms
Running as unit: run-u346.service
Service runtime: 1.620s
Generating libuvc information...
Running as unit: run-u347.service
Service runtime: 2.829s
CPU time consumed: 3.200s
Checking libuvc dependencies...
Resolving dependencies...
Checking inter-conflicts...
To build (7):
gcc11-libs 11.3.0-6 (11.3.0-5) AUR
gcc11 11.3.0-6 (11.3.0-5) AUR
gnome-shell-extension-unite 71-1 (70-1) AUR
libsepol 3.5-1 (3.4-1) AUR
libselinux 3.5-1 (3.4-1) AUR
libuvc 0.0.7-1 (0.0.6-2) AUR
python-progress 1.6-7 (1.6-5) AUR
Edit build files : [e]
Apply transaction ? [e/y/N] y
Building gcc11...
Running as unit: run-u348.service
Press ^] three times within 1s to disconnect TTY.
==> Making package: gcc11 11.3.0-6 (Saturday 13 May 2023 08:29:11 PM)
==> Retrieving sources...
-> Downloading gcc-11.3.0.tar.xz...
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 77.3M 100 77.3M 0 0 3103k 0 0:00:25 0:00:25 --:--:-- 5723k
-> Downloading gcc-11.3.0.tar.xz.sig...
100 310 100 310 0 0 379 0 --:--:-- --:--:-- --:--:-- 379
-> Downloading isl-0.24.tar.bz2...
100 2208k 100 2208k 0 0 554k 0 0:00:03 0:00:03 --:--:-- 554k
-> Found c89
-> Found c99
==> Validating source files with b2sums...
gcc-11.3.0.tar.xz ... Passed
gcc-11.3.0.tar.xz.sig ... Skipped
isl-0.24.tar.bz2 ... Passed
c89 ... Passed
c99 ... Passed
==> Verifying source file signatures with gpg...
gcc-11.3.0.tar.xz ... cat: write error: Broken pipe
FAILED
Service runtime: 34.237s
CPU time consumed: 5.398s
Oh wait… but your issue is not related and this script cannot fix it. There is something wrong with the gcc archive and these GPG keys which are used for the AUR, are not part of pacman’s gnupg database, but your user gnupg database:
It looks like I do need this package, can you verify based on this:
[jo@joshitha-pc ~]$ pacman -Qi gcc11
Version : 11.3.0-5
Description : The GNU Compiler Collection - C and C++ frontends (11.x.x)
Architecture : x86_64
URL : https://gcc.gnu.org
Licenses : GPL LGPL FDL custom
Groups : None
Provides : None
Depends On : gcc11-libs=11.3.0-5 binutils>=2.28 libmpc zstd libisl.so=23-64
Optional Deps : None
Required By : None
Optional For : None
Conflicts With : None
Replaces : None
Installed Size : 112.51 MiB
Packager : T.J. Townsend <blakkheim@archlinux.org>
Build Date : Tuesday 06 December 2022 04:05:46 AM
Install Date : Friday 30 December 2022 06:30:49 PM
Install Reason : Installed as a dependency for another package
Install Script : No
Validated By : Signature
