I have dual-boot Manjaro and Windows 11. Everything worked fine until recently; sometimes it failed to boot up, and during that, I could not even open tty.
Neofetch output:
Mod edit: Removed picture of text.
Here is the output of journalctl -b-1 -p4 --no-pager:
Thg 12 19 16:07:27 lanhf-rogstrixg513rc kernel: Speculative Return Stack Overflow: IBPB-extending microcode not applied!
Thg 12 19 16:07:27 lanhf-rogstrixg513rc kernel: Speculative Return Stack Overflow: WARNING: See https://kernel.org/doc/html/latest/admin-guide/hw-vuln/srso.html for mitigation options.
Thg 12 19 16:07:27 lanhf-rogstrixg513rc kernel: ACPI BIOS Error (bug): Failure creating named object [\_TZ.TZ01], AE_ALREADY_EXISTS (20230331/dswload2-326)
Thg 12 19 16:07:27 lanhf-rogstrixg513rc kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230331/psobject-220)
Thg 12 19 16:07:27 lanhf-rogstrixg513rc kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GPP2], AE_NOT_FOUND (20230331/dswload2-162)
Thg 12 19 16:07:27 lanhf-rogstrixg513rc kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20230331/psobject-220)
Thg 12 19 16:07:27 lanhf-rogstrixg513rc kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GPP2.WWAN], AE_NOT_FOUND (20230331/dswload2-162)
Thg 12 19 16:07:27 lanhf-rogstrixg513rc kernel: ACPI: \_SB_.PCI0.GP11: Overriding _PRW sleep state (S4) by S0 from power resources
Thg 12 19 16:07:27 lanhf-rogstrixg513rc kernel: ACPI: \_SB_.PCI0.GP12: Overriding _PRW sleep state (S4) by S0 from power resources
Thg 12 19 16:07:27 lanhf-rogstrixg513rc kernel: ACPI: \_SB_.PCI0.GP19.NHI0: Overriding _PRW sleep state (S4) by S0 from power resources
Thg 12 19 16:07:27 lanhf-rogstrixg513rc kernel: ACPI: \_SB_.PCI0.GP19.NHI1: Overriding _PRW sleep state (S4) by S0 from power resources
Thg 12 19 16:07:27 lanhf-rogstrixg513rc kernel: ACPI: IRQ 1 override to edge, low(!)
Thg 12 19 16:07:27 lanhf-rogstrixg513rc kernel: pci 0000:00:08.1: can't derive routing for PCI INT A
Thg 12 19 16:07:27 lanhf-rogstrixg513rc kernel: pci 0000:00:08.1: PCI INT A: not connected
Thg 12 19 16:07:27 lanhf-rogstrixg513rc kernel: pci 0000:00:08.3: can't derive routing for PCI INT A
Thg 12 19 16:07:27 lanhf-rogstrixg513rc kernel: pci 0000:00:08.3: PCI INT A: not connected
Thg 12 19 16:07:27 lanhf-rogstrixg513rc kernel: pci 0000:00:00.2: can't derive routing for PCI INT A
Thg 12 19 16:07:27 lanhf-rogstrixg513rc kernel: pci 0000:00:00.2: PCI INT A: not connected
Thg 12 19 16:07:27 lanhf-rogstrixg513rc kernel: hpet_acpi_add: no address or irqs in _CRS
Thg 12 19 16:07:27 lanhf-rogstrixg513rc kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Thg 12 19 16:07:27 lanhf-rogstrixg513rc kernel: hub 6-0:1.0: config failed, hub doesn't have any ports! (err -19)
Thg 12 19 16:07:27 lanhf-rogstrixg513rc lvm[482]: PV /dev/nvme0n1p7 online, VG LVMGroup is complete.
Thg 12 19 16:07:27 lanhf-rogstrixg513rc lvm[482]: VG LVMGroup finished
Thg 12 19 16:07:27 lanhf-rogstrixg513rc kernel: nvidia: loading out-of-tree module taints kernel.
Thg 12 19 16:07:27 lanhf-rogstrixg513rc kernel: nvidia: module license 'NVIDIA' taints kernel.
Thg 12 19 16:07:27 lanhf-rogstrixg513rc kernel: Disabling lock debugging due to kernel taint
Thg 12 19 16:07:27 lanhf-rogstrixg513rc kernel: nvidia: module license taints kernel.
Thg 12 19 16:07:28 lanhf-rogstrixg513rc kernel:
Thg 12 19 16:07:28 lanhf-rogstrixg513rc kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 545.29.06 Thu Nov 16 01:59:08 UTC 2023
Thg 12 19 16:07:28 lanhf-rogstrixg513rc kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
Thg 12 19 16:07:29 lanhf-rogstrixg513rc kernel: ATPX version 1, functions 0x00000001
Thg 12 19 16:07:29 lanhf-rogstrixg513rc kernel: ATPX Hybrid Graphics
Thg 12 19 16:07:29 lanhf-rogstrixg513rc kernel: Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
Thg 12 19 16:07:30 lanhf-rogstrixg513rc bluetoothd[1165]: src/plugin.c:plugin_init() System does not support csip plugin
Thg 12 19 16:07:30 lanhf-rogstrixg513rc bluetoothd[1165]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
Thg 12 19 16:07:30 lanhf-rogstrixg513rc bluetoothd[1165]: src/plugin.c:plugin_init() System does not support micp plugin
Thg 12 19 16:07:30 lanhf-rogstrixg513rc bluetoothd[1165]: src/plugin.c:plugin_init() System does not support vcp plugin
Thg 12 19 16:07:30 lanhf-rogstrixg513rc bluetoothd[1165]: src/plugin.c:plugin_init() System does not support mcp plugin
Thg 12 19 16:07:30 lanhf-rogstrixg513rc bluetoothd[1165]: src/plugin.c:plugin_init() System does not support bass plugin
Thg 12 19 16:07:30 lanhf-rogstrixg513rc bluetoothd[1165]: src/plugin.c:plugin_init() System does not support bap plugin
Thg 12 19 16:07:30 lanhf-rogstrixg513rc systemd[1]: Cannot find unit for notify message of PID 1192, ignoring.
Thg 12 19 16:07:30 lanhf-rogstrixg513rc systemd[1]: Cannot find unit for notify message of PID 1200, ignoring.
Thg 12 19 16:07:30 lanhf-rogstrixg513rc kernel: kauditd_printk_skb: 55 callbacks suppressed
Thg 12 19 16:07:30 lanhf-rogstrixg513rc systemd[1]: snapd.service: Got notification message from PID 1271, but reception only permitted for main PID 1168
Thg 12 19 16:07:31 lanhf-rogstrixg513rc kernel: ACPI Warning: \_SB.NPCF._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20230331/nsarguments-61)
Thg 12 19 16:07:31 lanhf-rogstrixg513rc kernel: ACPI Warning: \_SB.PCI0.GPP0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20230331/nsarguments-61)
Thg 12 19 16:07:32 lanhf-rogstrixg513rc kernel: Xorg[1294]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
Thg 12 19 16:07:45 lanhf-rogstrixg513rc lightdm[1519]: gkr-pam: unable to locate daemon control file
Thg 12 19 16:07:45 lanhf-rogstrixg513rc systemd-xdg-autostart-generator[1546]: Configuration file /home/lanhf/.config/autostart/xfce-pbw.sh is marked executable. Please remove executable permission bits. Proceeding anyway.
Thg 12 19 16:07:46 lanhf-rogstrixg513rc tumblerd[1716]: Failed to load plugin "tumbler-gepub-thumbnailer.so": libgepub-0.7.so.0: cannot open shared object file: No such file or directory
Thg 12 19 16:07:47 lanhf-rogstrixg513rc xdg-desktop-por[1816]: Choosing gtk.portal for org.freedesktop.impl.portal.Lockdown as a last-resort fallback
Thg 12 19 16:07:47 lanhf-rogstrixg513rc xdg-desktop-por[1816]: The preferred method to match portal implementations to desktop environments is to use the portals.conf(5) configuration file
Thg 12 19 16:07:47 lanhf-rogstrixg513rc xdg-desktop-por[1816]: No skeleton to export
Thg 12 19 16:07:47 lanhf-rogstrixg513rc xdg-desktop-por[1816]: Choosing gtk.portal for org.freedesktop.impl.portal.FileChooser as a last-resort fallback
Thg 12 19 16:07:47 lanhf-rogstrixg513rc xdg-desktop-por[1816]: Choosing gtk.portal for org.freedesktop.impl.portal.AppChooser as a last-resort fallback
Thg 12 19 16:07:47 lanhf-rogstrixg513rc xdg-desktop-por[1816]: Choosing gtk.portal for org.freedesktop.impl.portal.Print as a last-resort fallback
Thg 12 19 16:07:47 lanhf-rogstrixg513rc xdg-desktop-por[1816]: Choosing gtk.portal for org.freedesktop.impl.portal.Notification as a last-resort fallback
Thg 12 19 16:07:47 lanhf-rogstrixg513rc xdg-desktop-por[1816]: Choosing gtk.portal for org.freedesktop.impl.portal.Inhibit as a last-resort fallback
Thg 12 19 16:07:47 lanhf-rogstrixg513rc xdg-desktop-por[1816]: Choosing gtk.portal for org.freedesktop.impl.portal.Access as a last-resort fallback
Thg 12 19 16:07:47 lanhf-rogstrixg513rc xdg-desktop-por[1816]: Choosing gtk.portal for org.freedesktop.impl.portal.Account as a last-resort fallback
Thg 12 19 16:07:47 lanhf-rogstrixg513rc xdg-desktop-por[1816]: Choosing gtk.portal for org.freedesktop.impl.portal.Email as a last-resort fallback
Thg 12 19 16:07:47 lanhf-rogstrixg513rc xdg-desktop-por[1816]: Choosing gtk.portal for org.freedesktop.impl.portal.DynamicLauncher as a last-resort fallback
Thg 12 19 16:07:47 lanhf-rogstrixg513rc gvfsd-trash[2014]: GFileInfo created without standard::name
Thg 12 19 16:07:47 lanhf-rogstrixg513rc gvfsd-trash[2014]: file ../glib/gio/gfileinfo.c: line 1699 (g_file_info_get_name): should not be reached
Thg 12 19 16:07:50 lanhf-rogstrixg513rc gnome-keyring-daemon[1554]: asked to register item /org/freedesktop/secrets/collection/login/1, but it's already registered
Thg 12 19 16:07:50 lanhf-rogstrixg513rc gnome-keyring-d[1554]: asked to register item /org/freedesktop/secrets/collection/login/1, but it's already registered
Thg 12 19 17:00:45 lanhf-rogstrixg513rc kernel: nvidia 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
Thg 12 19 17:00:45 lanhf-rogstrixg513rc kernel: nvidia 0000:01:00.0: device [10de:25a2] error status/mask=00000001/0000a000
Thg 12 19 17:00:45 lanhf-rogstrixg513rc kernel: nvidia 0000:01:00.0: [ 0] RxErr (First)
Thg 12 19 17:00:45 lanhf-rogstrixg513rc kernel: nvidia 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID)
Thg 12 19 17:00:45 lanhf-rogstrixg513rc kernel: nvidia 0000:01:00.0: device [10de:25a2] error status/mask=00000040/0000a000
Thg 12 19 17:00:45 lanhf-rogstrixg513rc kernel: nvidia 0000:01:00.0: [ 6] BadTLP
Thg 12 19 17:00:52 lanhf-rogstrixg513rc lightdm[3694]: gkr-pam: unable to locate daemon control file
Thg 12 19 17:36:22 lanhf-rogstrixg513rc kernel: warning: `flameshot' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
Thg 12 19 17:36:22 lanhf-rogstrixg513rc org.flameshot.Flameshot[7869]: flameshot: info: Capture saved to clipboard.
Thg 12 19 17:43:56 lanhf-rogstrixg513rc org.flameshot.Flameshot[7869]: flameshot: info: Capture saved to clipboard.
Thg 12 19 18:01:37 lanhf-rogstrixg513rc tumblerd[9157]: Failed to load plugin "tumbler-gepub-thumbnailer.so": libgepub-0.7.so.0: cannot open shared object file: No such file or directory
Thg 12 19 18:11:01 lanhf-rogstrixg513rc pulseaudio[1648]: X11 I/O error handler called
Thg 12 19 18:11:01 lanhf-rogstrixg513rc pulseaudio[1648]: X11 I/O error exit handler called, preparing to tear down X11 modules
Thg 12 19 18:11:01 lanhf-rogstrixg513rc flameshot[7869]: The X11 connection broke (error 1). Did the X11 server die?
Thg 12 19 18:11:01 lanhf-rogstrixg513rc systemd[1540]: xfce4-notifyd.service: Failed with result 'exit-code'.
Thg 12 19 18:11:01 lanhf-rogstrixg513rc systemd[1540]: xdg-desktop-portal-gtk.service: Failed with result 'exit-code'.
Thg 12 19 18:11:02 lanhf-rogstrixg513rc systemd[1540]: xdg-document-portal.service: Failed with result 'exit-code'.
Thg 12 19 18:11:02 lanhf-rogstrixg513rc systemd[1540]: xdg-permission-store.service: Failed with result 'exit-code'.
Thg 12 19 18:11:02 lanhf-rogstrixg513rc systemd[1540]: obex.service: Failed with result 'exit-code'.
Thg 12 19 18:11:02 lanhf-rogstrixg513rc pulseaudio[1648]: Error opening PCM device front:1: No such file or directory
Thg 12 19 18:11:04 lanhf-rogstrixg513rc kernel: watchdog: watchdog0: watchdog did not stop!
