It suggests me to remove qt5-webkit. Is it safe? I’ve seen messages of people, both using Manjaro and other Arch distributions, having bricked systems after this latest update, so I’m not sure if going on or wait for a new update.
People could make better suggestions on how to proceed if you would share the terminal output of the whole session.
The graphical tool (pamac-manager
) also has the option to show this.
But it may be easier to open a terminal and:
sudo pacman-mirrors -f
or, in my case:
sudo pacman-mirrors -c Germany
(refresh mirrors)
and then:
sudo pacman -Syyu
then share the whole output
Hi @viktorbir,
The only qt-webkit
I could fine is in the AUR:
$ pamac search qt5-webkit
python-pyqt5-webkit 5.15.10-1 AUR
A set of Python bindings for the Qt5 toolkit with Qt5WebKit support
mingw-w64-qt5-webkit 5.9.0-1 AUR
Classes for a WebKit2 based implementation and a new QML API (mingw-w64)
qt5-webkit-movableink-git r269464.3cfcdcf38a52-3 AUR
qt5-webkit-git 5.212.0.alpha4.r13.gac8ebc6c3-4 AUR
qt5-webkit 5.212.0alpha4-23 AUR
Therefore, I think it’s safe to remove as long as your mirrors are updated and synced.
You can use pacman -Qi qt5-webkit
to see if the package is required by any other package. If not, you can remove it.
That depends … on what is depending on it - the simplest check
sudo pacman -Rns qt5-webkit -p
If you find there is no problems you repeat the command without the -p option
Im getting something similar, it asks me to remove electron25 though.
My output:
core 139.8 KiB 149 KiB/s 00:01 [------------------------------------------------------] 100%
extra 8.3 MiB 4.09 MiB/s 00:02 [------------------------------------------------------] 100%
multilib 144.9 KiB 134 KiB/s 00:01 [------------------------------------------------------] 100%
:: Replace dbus-python with extra/python-dbus? [Y/n] y
resolving dependencies...
:: installing icu (75.1-1) breaks dependency 'libicui18n.so=74-64' required by electron25
:: installing icu (75.1-1) breaks dependency 'libicuuc.so=74-64' required by electron25
There is at least one other thread about this exact same issue.
and you should.
will it not break anything?
No, it won’t break anything - you would know why had you read the the other thread I linked you to.
(the green part of the text is a link)
