mike1
30 May 2024 00:45
1
Im on
x86_64
Manjaro Linux
DISTRIB_ID=“ManjaroLinux”
DISTRIB_RELEASE=“24.0.0”
When I do
sudo pacman -Syu ✔ UK
:: installing icu (75.1-1) breaks dependency 'libicui18n.so=74-64' required by electron25
How do I fix?
what depends on electron25?
Why is it installed?
… can you temporarily remove them? electron25 is from the AUR and would need to be rebuilt
electron25 is an unsupported third party package.
mike1:
How do I fix?
sudo pacman -Rns electron25
Nothing in the repos anymore.
derk:
Because something previously required it.
FYI, older, insecure Electron packages are dropped from the repos to the AUR once nothing requires them.
is there a command line tool to determine dependency chains?
a search of the wiki does not reveal it…
For simple direct depends you can look at the package info;
pacman -Qi electron25
To see a tree you could use
pactree -r electron25
pactree is provided by the pacman-contrib package.
thanks that will prove useful
However, if you happen to have an appication that absolutely must use electron25 (as is the case with one app I use) you could likely use electron25-bin from the AUR until that application is updated.
mike1
31 May 2024 19:58
9
No electron 25 anymore problem solved. Thanks guys.
Got the same error and solved this way.
Also we can use this moment to delete the orphaned packages and prevent future similar problems
$ pacman -Qdt
$ sudo pacman -Rs $(pacman -Qdtq)
system
Closed
5 June 2024 21:42
11
