Hello guys,
I got a error message when i restart/shutdown my PC, that my SDD (Samsung Portable SSD T5)
are busy and won’t unmount for shutdown. I have a screenshot with the error message:
I have this error after the third reboot since i first time installed manjaro on my External SSD,
after 2-3minutes blackscreen this message showed up… now this error comes everytime but without any delay.
If you guys need any logs please let me know, but please explain me how to create this, because im still not into this linux stuff.
I hope you guys can help me out, thanks in advanced.
EDIT: Okay, here are my logs:
- Mod-edit: Formatting
Please don’t combine output of different commands, it makes them unnoticed.
> inxi -Fazy
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = "",
LC_ALL = (unset),
LC_ADDRESS = "de_DE.UTF-8",
LC_NAME = "de_DE.UTF-8",
LC_MONETARY = "de_DE.UTF-8",
LC_PAPER = "de_DE.UTF-8",
LC_IDENTIFICATION = "de_DE.UTF-8",
LC_TELEPHONE = "de_DE.UTF-8",
LC_MEASUREMENT = "de_DE.UTF-8",
LC_TIME = "de_DE.UTF-8",
LC_NUMERIC = "de_DE.UTF-8",
LANG = "en_DE.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/vmlinuz-5.9-x86_64
root=UUID=eb235aa7-d461-413d-800e-ea57385703fb rw quiet apparmor=1
security=apparmor resume=UUID=a44dd3c4-f5f1-4587-8934-6f7413d28d4f
udev.log_priority=3
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Desktop System: Gigabyte product: Z170X-UD3 v: N/A serial: <filter>
Mobo: Gigabyte model: Z170X-UD3-CF v: x.x serial: <filter>
UEFI [Legacy]: American Megatrends v: F23d date: 12/01/2017
Info: Quad Core model: Intel Core i7-6700K bits: 64 type: MT MCP
arch: Skylake-S family: 6 model-id: 5E (94) stepping: 3 microcode: E2
L2 cache: 8192 KiB
bogomips: 64026
Speed: 800 MHz min/max: 800/4700 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 801 8: 800
Type: l1tf
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: NVIDIA TU102 [GeForce RTX 2080 Ti Rev. A] vendor: Micro-Star MSI driver: nvidia v: 455.45.01 alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1e07
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: nvidia display ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 122 s-size: 533x302mm (21.0x11.9") s-diag: 613mm (24.1")
Monitor-1: DP-4 res: 2560x1440 dpi: 123 size: 527x296mm (20.7x11.7") diag: 604mm (23.8")
OpenGL: renderer: GeForce RTX 2080 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01 direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a170
Device-2: NVIDIA TU102 High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:10f7
Device-3: Creative Labs Sound Core3D [Sound Blaster Recon3D / Z-Series] driver: snd_hda_intel v: kernel bus ID: 0b:00.0 chip ID: 1102:0012
Sound Server: ALSA v: k5.9.11-3-MANJARO
Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel port: f000 bus ID: 00:1f.6 chip ID: 8086:15b8
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 3.87 TiB used: 348.60 GiB (8.8%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 960 EVO 500GB size: 465.76 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 2B7QCXE7 scheme: GPT
ID-2: /dev/sda vendor: Samsung model: SSD 830 Series size: 238.47 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 3B1Q scheme: MBR
ID-3: /dev/sdb vendor: HGST (Hitachi) model: HDN724030ALE640 size: 2.73 TiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: A5E0 scheme: GPT
ID-4: /dev/sdc type: USB vendor: Samsung model: Portable SSD T5 size: 465.76 GiB block size: physical: 512 B logical: 512 B serial: <filter> scheme: MBR
ID-1: / raw size: 88.61 GiB size: 86.72 GiB (97.87%) used: 14.50 GiB (16.7%) fs: ext4 dev: /dev/sdc1
ID-2: /boot raw size: 200.0 MiB size: 189.7 MiB (94.84%) used: 150.8 MiB (79.5%) fs: ext3 dev: /dev/sdc3
ID-3: /home raw size: 332.03 GiB size: 325.82 GiB (98.13%) used: 3.01 GiB (0.9%) fs: ext4 dev: /dev/sdc4
Kernel: swappiness: 10 (default 60) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 2.93 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sdc2
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 36 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 25%
Processes: 207 Uptime: 42m Memory: 15.59 GiB used: 1.34 GiB (8.6%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1235 lib: 339
flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.08
> journalctl -x -p3 -b1
-- Logs begin at Thu 2020-08-06 04:21:30 CEST, end at Tue 2020-12-29 10:49:52 CET. --
Aug 06 04:37:24 koboldx-z170 kernel: watchdog: watchdog0: watchdog did not stop!
> sudo fdisk -x
Disk /dev/nvme0n1: 465.76 GiB, 500107862016 bytes, 976773168 sectors
Disk model: Samsung SSD 960 EVO 500GB
Disklabel type: gpt
Disk identifier: F6C31B20-AEE8-03A6-C8C6-B03DBAABE900
First LBA: 34
Last LBA: 976773134
Alternative LBA: 976773167
Partition entries LBA: 2
Allocated partition entries: 128
Device Start End Sectors Type-UUID UUID Name Attrs
/dev/nvme0n1p1 2048 927928319 927926272 EBD0A0A2-B9E5-4433-87C0-68B6B72699C7 7B64E8F0-5774-01D3-7874-B23DBAABE900 Basic data partition
Disk /dev/sda: 238.47 GiB, 256060514304 bytes, 500118192 sectors
Disk model: SAMSUNG SSD 830
Disklabel type: dos
Disk identifier: 0xe9182337
Device Boot Start End Sectors Id Type Start-C/H/S End-C/H/S Attrs
/dev/sda1 * 2048 442370047 442368000 7 HPFS/NTFS/exFAT 0/32/33 1023/254/63 80
Disk /dev/sdb: 2.73 TiB, 3000592982016 bytes, 5860533168 sectors
Disk model: HGST HDN724030AL
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 1A6D9890-4635-4233-8C71-89052C9C1DC7
First LBA: 34
Last LBA: 5860533134
Alternative LBA: 5860533167
/dev/sdb1 34 262177 262144 E3C9E316-0B5C-4DB8-817D-F92DF00215AE E633B49C-B3E5-444F-A4CA-F449990F028D Microsoft reserved partition
/dev/sdb2 264192 1229064191 1228800000 EBD0A0A2-B9E5-4433-87C0-68B6B72699C7 185BB421-937B-4EB9-AA63-F3414F53962F Basic data partition
/dev/sdb3 1229064192 3543304191 2314240000 EBD0A0A2-B9E5-4433-87C0-68B6B72699C7 648502F4-0F0D-415D-A33F-7CE22DF69496 Basic data partition
GUID:63
/dev/sdb4 3543304192 5860530175 2317225984 EBD0A0A2-B9E5-4433-87C0-68B6B72699C7 8BAE0754-2B94-47ED-BC81-8CC64C661848 Basic data partition
GUID:63
Partition 1 does not start on physical sector boundary.
Disk /dev/sdc: 465.76 GiB, 500107862016 bytes, 976773168 sectors
Disk model: Portable SSD T5
I/O size (minimum/optimal): 512 bytes / 33553920 bytes
Disklabel type: dos
Disk identifier: 0xa08ac34c
/dev/sdc1 411648 186238975 185827328 83 Linux 25/159/7 328/214/14
/dev/sdc2 186238976 192382975 6144000 82 Linux swap / Solaris 433/89/1 426/131/2
/dev/sdc3 2048 411647 409600 83 Linux 0/32/33 25/159/6
/dev/sdc4 192382976 888702975 696320000 83 Linux 711/73/3 23/51/28
Partition table entries are not in disk order.
