Hi everyone,
So I recently started encountering a problem with my setup. When I disconnect and reconnect the display to my dock (through a KVM switch) it starts displaying image as it should and then 3-4secs later it just turns off. When I check the display settings the external monitor is explicitly disabled:
In an attempt to solve this I tried adding
display-setup-script=xrandr --output DP1-2 --primary
to my lightdm config, but it did not seem to help
Does anyone have any ideas on how to debug this? Of course, when I manually enable the display it works, but it is very inconvenient to open my laptop (which is in a stand) and enable the display in the settings every time.
Here is my xrandr:
xrandr Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767 eDP1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 310mm x 170mm 1920x1080 60.05*+ 59.93 1680x1050 59.88 1400x1050 59.98 1600x900 60.00 59.95 59.82 1280x1024 60.02 1400x900 59.96 59.88 1280x960 60.00 1368x768 60.00 59.88 59.85 1280x800 59.81 59.91 1280x720 59.86 60.00 59.74 1024x768 60.00 1024x576 60.00 59.90 59.82 960x540 60.00 59.63 59.82 800x600 60.32 56.25 864x486 60.00 59.92 59.57 640x480 59.94 720x405 59.51 60.00 58.99 640x360 59.84 59.32 60.00 DP1 disconnected (normal left inverted right x axis y axis) DP1-1 disconnected (normal left inverted right x axis y axis) DP1-2 connected (normal left inverted right x axis y axis) 1920x1080 60.00 + 144.00 120.00 119.88 119.98 99.93 74.97 50.00 59.94 1280x1024 75.02 60.02 1280x720 60.00 50.00 59.94 1024x768 119.99 75.03 70.07 60.00 832x624 74.55 800x600 119.97 72.19 75.00 60.32 56.25 720x576 50.00 720x480 60.00 59.94 640x480 75.00 72.81 66.67 60.00 59.94 720x400 70.08 DP1-3 disconnected (normal left inverted right x axis y axis) DP2 disconnected (normal left inverted right x axis y axis) HDMI1 disconnected (normal left inverted right x axis y axis) HDMI2 disconnected (normal left inverted right x axis y axis) VIRTUAL1 disconnected (normal left inverted right x axis y axis)
And here is my inxi:
System: Host: NC6366 Kernel: 5.13.4-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 parameters: BOOT_IMAGE=/boot/vmlinuz-5.13-x86_64 root=UUID=35b12521-756c-43a1-aa8c-930873c832d1 rw nopti spectre_v2=off ipv6.disable=0 scsi_mod.use_blk_mq=1 quiet cryptdevice=UUID=3e132614-3230-4a7e-9cf3-b4714e806947:luks-3e132614-3230-4a7e-9cf3-b4714e806947 root=/dev/mapper/luks-3e132614-3230-4a7e-9cf3-b4714e806947 resume=/dev/mapper/luks-3e132614-3230-4a7e-9cf3-b4714e806947 Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux Machine: Type: Laptop System: LENOVO product: 20KGSAJX00 v: ThinkPad X1 Carbon 6th serial: <superuser required> Chassis: type: 10 serial: <superuser required> Mobo: LENOVO model: 20KGSAJX00 serial: <superuser required> UEFI: LENOVO v: N23ET76W (1.51 ) date: 04/21/2021 Battery: ID-1: BAT0 charge: 37.0 Wh (79.6%) condition: 46.5/57.0 Wh (81.6%) volts: 12.3 min: 11.6 model: LGC 01AV494 type: Li-poly serial: 2387 status: Unknown cycles: 265 Memory: RAM: total: 15.53 GiB used: 6.31 GiB (40.7%) RAM Report: permissions: Unable to run dmidecode. Root privileges required. PCI Slots: Permissions: Unable to run dmidecode. Root privileges required. CPU: Info: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10) microcode: EA cache: L2: 8 MiB bogomips: 32012 Speed: 700 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 700 2: 700 3: 700 4: 700 5: 700 6: 700 7: 700 8: 700 Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr Vulnerabilities: Type: itlb_multihit status: KVM: VMX disabled Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable Type: mds mitigation: Clear CPU buffers; SMT vulnerable Type: meltdown status: Vulnerable Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl and seccomp Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled Type: srbds mitigation: Microcode Type: tsx_async_abort status: Not affected Graphics: Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300 Device-2: Microdia USB 2.0 Camera type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-3.3:6 chip-ID: 0c45:636d class-ID: 0102 serial: SN0001 Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo bus-ID: 1-8:5 chip-ID: 13d3:56b2 class-ID: 0e02 Display: x11 server: X.Org 1.20.11 compositor: xfwm4 v: 4.16.1 driver: loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1 Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9") Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 157 size: 310x170mm (12.2x6.7") diag: 354mm (13.9") Monitor-2: DP1-2 res: 1920x1080 hz: 60 dpi: 92 size: 530x300mm (20.9x11.8") diag: 609mm (24") OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.1.5 direct render: Yes Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403 Device-2: Microdia USB 2.0 Camera type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-3.3:6 chip-ID: 0c45:636d class-ID: 0102 serial: SN0001 Device-3: Lenovo ThinkPad Dock Audio type: USB driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-3.4.2.3:11 chip-ID: 17ef:3063 class-ID: 0300 serial: 000000000000 Device-4: C-Media TONOR TC30 Audio Device type: USB driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-3.4.3.2:21 chip-ID: 0d8c:0134 class-ID: 0300 serial: 20200707 Sound Server-1: ALSA v: k5.13.4-1-MANJARO running: yes Sound Server-2: JACK v: 0.125.0 running: no Sound Server-3: PulseAudio v: 14.2 running: yes Sound Server-4: PipeWire v: 0.3.32 running: no Network: Device-1: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel port: efa0 bus-ID: 00:1f.6 chip-ID: 8086:15d8 class-ID: 0200 IF: enp0s31f6 state: down mac: e8:6a:64:93:83:01 Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: efa0 bus-ID: 02:00.0 chip-ID: 8086:24fd class-ID: 0280 IF: wlp2s0 state: down mac: f6:61:b8:68:02:37 Device-3: Lenovo ThinkPad Dock Ethernet [Realtek RTL8153B] type: USB driver: r8152 bus-ID: 1-3.1:24 chip-ID: 17ef:3062 class-ID: 0000 serial: 1014570F9 IF: enp0s20f0u3u1 state: up speed: 100 Mbps duplex: full mac: 3c:e1:a1:45:70:f9 IP v4: 192.168.88.247/24 type: dynamic noprefixroute scope: global broadcast: 192.168.88.255 IP v6: fe80::8426:f39e:9622:5b25/64 type: noprefixroute scope: link IF-ID-1: ppp0 state: unknown speed: N/A duplex: N/A mac: N/A IP v4: 10.5.251.35 scope: global WAN IP: 185.97.224.201 Bluetooth: Message: No bluetooth data found. Logical: Message: No logical block device data found. Device-1: luks-3e132614-3230-4a7e-9cf3-b4714e806947 maj-min: 254:0 type: LUKS dm: dm-0 size: 238.22 GiB Components: p-1: nvme0n1p5 maj-min: 259:2 size: 238.22 GiB RAID: Message: No RAID data found. Drives: Local Storage: total: 704.24 GiB used: 171.67 GiB (24.4%) SMART Message: Unable to run smartctl. Root privileges required. ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lenovo model: LENSE30256GMSP34MEAT3TA size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: FBFB18110Y10005764 rev: 2.5.0412 temp: 44.9 C scheme: GPT ID-2: /dev/sdc maj-min: 8:32 type: USB vendor: SanDisk model: SD9SN8W512G size: 465.76 GiB block-size: physical: 4096 B logical: 512 B type: SSD serial: 191112476214 rev: 1012 scheme: GPT SMART Message: Unknown USB bridge. Flash drive/Unsupported enclosure? Message: No optical or floppy data found. Partition: ID-1: / raw-size: 238.22 GiB size: 233.48 GiB (98.01%) used: 149.2 GiB (63.9%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0 mapped: luks-3e132614-3230-4a7e-9cf3-b4714e806947 label: N/A uuid: 35b12521-756c-43a1-aa8c-930873c832d1 ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 2.4 MiB (1.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A uuid: 6523-3C8F ID-3: /run/timeshift/backup raw-size: N/A size: 162.35 GiB used: 22.47 GiB (13.8%) fs: ext4 dev: /dev/sda4 label: N/A uuid: N/A Swap: Kernel: swappiness: 60 (default) cache-pressure: 100 (default) ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2 file: /swapfile Unmounted: ID-1: /dev/sdc1 maj-min: 8:33 size: 100 MiB fs: vfat label: N/A uuid: CCAE-0329 ID-2: /dev/sdc2 maj-min: 8:34 size: 148.97 GiB fs: ntfs label: N/A uuid: 00E35FC5472F21EC ID-3: /dev/sdc4 maj-min: 8:36 size: 166.02 GiB fs: ext4 label: N/A uuid: b01f950e-2fc8-4880-bd91-ad0ccb2c6553 USB: Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900 Hub-2: 1-3:2 info: Lenovo ports: 4 rev: 2.1 speed: 480 Mb/s chip-ID: 17ef:1025 class-ID: 0900 Device-1: 1-3.1:24 info: Lenovo ThinkPad Dock Ethernet [Realtek RTL8153B] type: Network driver: r8152 interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 350mA chip-ID: 17ef:3062 class-ID: 0000 serial: 1014570F9 Device-2: 1-3.2:4 info: Lenovo ThinkPad Dock type: Billboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 17ef:3060 class-ID: 0300 serial: 0001 Device-3: 1-3.3:6 info: Microdia USB 2.0 Camera type: Video,Audio driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0c45:636d class-ID: 0102 serial: SN0001 Hub-3: 1-3.4:8 info: Lenovo ports: 4 rev: 2.1 speed: 480 Mb/s chip-ID: 17ef:1026 class-ID: 0900 Hub-4: 1-3.4.2:9 info: Lenovo ThinkPad Dock Hub [Cypress HX2VL] ports: 3 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 17ef:1021 class-ID: 0900 Device-1: 1-3.4.2.3:11 info: Lenovo ThinkPad Dock Audio type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 17ef:3063 class-ID: 0300 serial: 000000000000 Hub-5: 1-3.4.3:19 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s power: 100mA chip-ID: 1a40:0101 class-ID: 0900 Device-1: 1-3.4.3.1:20 info: Logitech G3 (MX518) Optical Mouse type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s power: 98mA chip-ID: 046d:c051 class-ID: 0301 Device-2: 1-3.4.3.2:21 info: C-Media TONOR TC30 Audio Device type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 0d8c:0134 class-ID: 0300 serial: 20200707 Device-3: 1-3.4.3.3:22 info: Logitech DeLuxe 250 Keyboard type: Keyboard driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s power: 70mA chip-ID: 046d:c312 class-ID: 0301 Device-4: 1-3.4.4:23 info: SanDisk Extreme Portable SSD type: Mass Storage driver: uas interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 500mA chip-ID: 0781:558c class-ID: 0806 serial: 313931323130343031323638 Device-5: 1-8:5 info: IMC Networks Integrated Camera type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 13d3:56b2 class-ID: 0e02 Device-6: 1-9:7 info: Synaptics Metallica MIS Touch Fingerprint Reader type: <vendor specific> driver: usbfs interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 06cb:009a class-ID: ff00 serial: 0344b4866610 Hub-6: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s chip-ID: 1d6b:0003 class-ID: 0900 Device-1: 2-3:2 info: Realtek USB3.0-CRW type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 800mA chip-ID: 0bda:0328 class-ID: 0806 serial: 28203008282014000 Hub-7: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900 Hub-8: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900 Sensors: System Temperatures: cpu: 56.0 C mobo: N/A Fan Speeds (RPM): fan-1: 0 Repos: Packages: pacman: 1581 lib: 416 pkg: 0 flatpak: 0 Active pacman repo servers in: /etc/pacman.d/mirrorlist 1: https://manjaro.moson.eu/stable/$repo/$arch 2: https://manjaro.moson.org/stable/$repo/$arch 3: https://mirror.alpix.eu/manjaro/stable/$repo/$arch 4: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch 5: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch 6: https://manjaro.re/stable/$repo/$arch Processes: CPU top: 5 of 284 1: cpu: 37.7% command: firefox pid: 8297 mem: 76.2 MiB (0.4%) 2: cpu: 26.6% command: slack pid: 6826 mem: 319.0 MiB (2.0%) 3: cpu: 14.0% command: firefox pid: 3312 mem: 543.0 MiB (3.4%) 4: cpu: 12.9% command: java pid: 3823 mem: 1346.7 MiB (8.4%) 5: cpu: 7.8% command: firefox pid: 3465 mem: 769.2 MiB (4.8%) Memory top: 5 of 284 1: mem: 1346.7 MiB (8.4%) command: java pid: 3823 cpu: 12.9% 2: mem: 769.2 MiB (4.8%) command: firefox pid: 3465 cpu: 7.8% 3: mem: 543.0 MiB (3.4%) command: firefox pid: 3312 cpu: 14.0% 4: mem: 449.9 MiB (2.8%) command: albert pid: 2029 cpu: 1.7% 5: mem: 347.0 MiB (2.1%) command: teams pid: 2445 cpu: 1.0% Info: Processes: 284 Uptime: 1h 16m wakeups: 15 Init: systemd v: 248 tool: systemctl Compilers: gcc: 11.1.0 Shell: Zsh v: 5.8 running-in: kitty inxi: 3.3.06 elmir@NC6366 ~ inxi -v 7 System: Host: NC6366 Kernel: 5.13.4-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux Machine: Type: Laptop System: LENOVO product: 20KGSAJX00 v: ThinkPad X1 Carbon 6th serial: <superuser required> Chassis: type: 10 serial: <superuser required> Mobo: LENOVO model: 20KGSAJX00 serial: <superuser required> UEFI: LENOVO v: N23ET76W (1.51 ) date: 04/21/2021 Battery: ID-1: BAT0 charge: 37.0 Wh (79.6%) condition: 46.5/57.0 Wh (81.6%) volts: 12.3 min: 11.6 model: LGC 01AV494 type: Li-poly serial: 2387 status: Unknown cycles: 265 Memory: RAM: total: 15.53 GiB used: 6.31 GiB (40.6%) RAM Report: permissions: Unable to run dmidecode. Root privileges required. CPU: Info: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Kaby Lake note: check rev: A cache: L2: 8 MiB bogomips: 32012 Speed: 700 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 700 2: 738 3: 800 4: 753 5: 800 6: 760 7: 700 8: 700 Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr Graphics: Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300 Device-2: Microdia USB 2.0 Camera type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-3.3:6 chip-ID: 0c45:636d class-ID: 0102 serial: SN0001 Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo bus-ID: 1-8:5 chip-ID: 13d3:56b2 class-ID: 0e02 Display: x11 server: X.Org 1.20.11 compositor: xfwm4 v: 4.16.1 driver: loaded: intel unloaded: modesetting alternate: fbdev,vesa resolution: 1: 1920x1080~60Hz 2: 1920x1080~60Hz s-dpi: 96 OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.1.5 direct render: Yes Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403 Device-2: Microdia USB 2.0 Camera type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-3.3:6 chip-ID: 0c45:636d class-ID: 0102 serial: SN0001 Device-3: Lenovo ThinkPad Dock Audio type: USB driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-3.4.2.3:11 chip-ID: 17ef:3063 class-ID: 0300 serial: 000000000000 Device-4: C-Media TONOR TC30 Audio Device type: USB driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-3.4.3.2:21 chip-ID: 0d8c:0134 class-ID: 0300 serial: 20200707 Sound Server-1: ALSA v: k5.13.4-1-MANJARO running: yes Sound Server-2: JACK v: 0.125.0 running: no Sound Server-3: PulseAudio v: 14.2 running: yes Sound Server-4: PipeWire v: 0.3.32 running: no Network: Device-1: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel port: efa0 bus-ID: 00:1f.6 chip-ID: 8086:15d8 class-ID: 0200 IF: enp0s31f6 state: down mac: e8:6a:64:93:83:01 Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: efa0 bus-ID: 02:00.0 chip-ID: 8086:24fd class-ID: 0280 IF: wlp2s0 state: down mac: f6:61:b8:68:02:37 Device-3: Lenovo ThinkPad Dock Ethernet [Realtek RTL8153B] type: USB driver: r8152 bus-ID: 1-3.1:24 chip-ID: 17ef:3062 class-ID: 0000 serial: 1014570F9 IF: enp0s20f0u3u1 state: up speed: 100 Mbps duplex: full mac: 3c:e1:a1:45:70:f9 IP v4: 192.168.88.247/24 type: dynamic noprefixroute scope: global broadcast: 192.168.88.255 IP v6: fe80::8426:f39e:9622:5b25/64 type: noprefixroute scope: link IF-ID-1: ppp0 state: unknown speed: N/A duplex: N/A mac: N/A IP v4: 10.5.251.35 scope: global WAN IP: 185.97.224.201 Bluetooth: Message: No bluetooth data found. Logical: Message: No logical block device data found. Device-1: luks-3e132614-3230-4a7e-9cf3-b4714e806947 type: LUKS dm: dm-0 size: 238.22 GiB Components: p-1: nvme0n1p5 RAID: Message: No RAID data found. Drives: Local Storage: total: 704.24 GiB used: 171.67 GiB (24.4%) ID-1: /dev/nvme0n1 vendor: Lenovo model: LENSE30256GMSP34MEAT3TA size: 238.47 GiB speed: 31.6 Gb/s lanes: 4 type: SSD serial: FBFB18110Y10005764 rev: 2.5.0412 temp: 43.9 C scheme: GPT ID-2: /dev/sdc type: USB vendor: SanDisk model: SD9SN8W512G size: 465.76 GiB type: SSD serial: 191112476214 rev: 1012 scheme: GPT Message: No optical or floppy data found. Partition: ID-1: / size: 233.48 GiB used: 149.2 GiB (63.9%) fs: ext4 dev: /dev/dm-0 mapped: luks-3e132614-3230-4a7e-9cf3-b4714e806947 label: N/A uuid: 35b12521-756c-43a1-aa8c-930873c832d1 ID-2: /boot/efi size: 256 MiB used: 2.4 MiB (1.0%) fs: vfat dev: /dev/nvme0n1p1 label: N/A uuid: 6523-3C8F ID-3: /run/timeshift/backup size: 162.35 GiB used: 22.47 GiB (13.8%) fs: ext4 dev: /dev/sda4 label: N/A uuid: N/A Swap: ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2 file: /swapfile Unmounted: ID-1: /dev/sdc1 size: 100 MiB fs: vfat label: N/A uuid: CCAE-0329 ID-2: /dev/sdc2 size: 148.97 GiB fs: ntfs label: N/A uuid: 00E35FC5472F21EC ID-3: /dev/sdc4 size: 166.02 GiB fs: ext4 label: N/A uuid: b01f950e-2fc8-4880-bd91-ad0ccb2c6553 USB: Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900 Hub-2: 1-3:2 info: Lenovo ports: 4 rev: 2.1 speed: 480 Mb/s chip-ID: 17ef:1025 class-ID: 0900 Device-1: 1-3.1:24 info: Lenovo ThinkPad Dock Ethernet [Realtek RTL8153B] type: Network driver: r8152 interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 350mA chip-ID: 17ef:3062 class-ID: 0000 serial: 1014570F9 Device-2: 1-3.2:4 info: Lenovo ThinkPad Dock type: Billboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 17ef:3060 class-ID: 0300 serial: 0001 Device-3: 1-3.3:6 info: Microdia USB 2.0 Camera type: Video,Audio driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0c45:636d class-ID: 0102 serial: SN0001 Hub-3: 1-3.4:8 info: Lenovo ports: 4 rev: 2.1 speed: 480 Mb/s chip-ID: 17ef:1026 class-ID: 0900 Hub-4: 1-3.4.2:9 info: Lenovo ThinkPad Dock Hub [Cypress HX2VL] ports: 3 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 17ef:1021 class-ID: 0900 Device-1: 1-3.4.2.3:11 info: Lenovo ThinkPad Dock Audio type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 17ef:3063 class-ID: 0300 serial: 000000000000 Hub-5: 1-3.4.3:19 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s power: 100mA chip-ID: 1a40:0101 class-ID: 0900 Device-1: 1-3.4.3.1:20 info: Logitech G3 (MX518) Optical Mouse type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s power: 98mA chip-ID: 046d:c051 class-ID: 0301 Device-2: 1-3.4.3.2:21 info: C-Media TONOR TC30 Audio Device type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 0d8c:0134 class-ID: 0300 serial: 20200707 Device-3: 1-3.4.3.3:22 info: Logitech DeLuxe 250 Keyboard type: Keyboard driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s power: 70mA chip-ID: 046d:c312 class-ID: 0301 Device-4: 1-3.4.4:23 info: SanDisk Extreme Portable SSD type: Mass Storage driver: uas interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 500mA chip-ID: 0781:558c class-ID: 0806 serial: 313931323130343031323638 Device-5: 1-8:5 info: IMC Networks Integrated Camera type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 13d3:56b2 class-ID: 0e02 Device-6: 1-9:7 info: Synaptics Metallica MIS Touch Fingerprint Reader type: <vendor specific> driver: usbfs interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 06cb:009a class-ID: ff00 serial: 0344b4866610 Hub-6: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s chip-ID: 1d6b:0003 class-ID: 0900 Device-1: 2-3:2 info: Realtek USB3.0-CRW type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 800mA chip-ID: 0bda:0328 class-ID: 0806 serial: 28203008282014000 Hub-7: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900 Hub-8: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900 Sensors: System Temperatures: cpu: 55.0 C mobo: N/A Fan Speeds (RPM): fan-1: 0 Info: Processes: 281 Uptime: 1h 17m wakeups: 15 Init: systemd v: 248 Compilers: gcc: 11.1.0 Packages: pacman: 1581 Shell: Zsh v: 5.8 running-in: kitty inxi: 3.3.06 elmir@NC6366 ~ inxi -v 8 System: Host: NC6366 Kernel: 5.13.4-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 parameters: BOOT_IMAGE=/boot/vmlinuz-5.13-x86_64 root=UUID=35b12521-756c-43a1-aa8c-930873c832d1 rw nopti spectre_v2=off ipv6.disable=0 scsi_mod.use_blk_mq=1 quiet cryptdevice=UUID=3e132614-3230-4a7e-9cf3-b4714e806947:luks-3e132614-3230-4a7e-9cf3-b4714e806947 root=/dev/mapper/luks-3e132614-3230-4a7e-9cf3-b4714e806947 resume=/dev/mapper/luks-3e132614-3230-4a7e-9cf3-b4714e806947 Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux Machine: Type: Laptop System: LENOVO product: 20KGSAJX00 v: ThinkPad X1 Carbon 6th serial: <superuser required> Chassis: type: 10 serial: <superuser required> Mobo: LENOVO model: 20KGSAJX00 serial: <superuser required> UEFI: LENOVO v: N23ET76W (1.51 ) date: 04/21/2021 Battery: ID-1: BAT0 charge: 37.0 Wh (79.6%) condition: 46.5/57.0 Wh (81.6%) volts: 12.3 min: 11.6 model: LGC 01AV494 type: Li-poly serial: 2387 status: Unknown cycles: 265 Memory: RAM: total: 15.53 GiB used: 6.21 GiB (40.0%) RAM Report: permissions: Unable to run dmidecode. Root privileges required. PCI Slots: Permissions: Unable to run dmidecode. Root privileges required. CPU: Info: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10) microcode: EA cache: L2: 8 MiB bogomips: 32012 Speed: 740 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 740 2: 800 3: 777 4: 725 5: 764 6: 800 7: 800 8: 800 Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr Vulnerabilities: Type: itlb_multihit status: KVM: VMX disabled Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable Type: mds mitigation: Clear CPU buffers; SMT vulnerable Type: meltdown status: Vulnerable Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl and seccomp Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled Type: srbds mitigation: Microcode Type: tsx_async_abort status: Not affected Graphics: Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300 Device-2: Microdia USB 2.0 Camera type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-3.3:6 chip-ID: 0c45:636d class-ID: 0102 serial: SN0001 Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo bus-ID: 1-8:5 chip-ID: 13d3:56b2 class-ID: 0e02 Display: x11 server: X.Org 1.20.11 compositor: xfwm4 v: 4.16.1 driver: loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1 Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9") Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 157 size: 310x170mm (12.2x6.7") diag: 354mm (13.9") Monitor-2: DP1-2 res: 1920x1080 hz: 60 dpi: 92 size: 530x300mm (20.9x11.8") diag: 609mm (24") OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.1.5 direct render: Yes Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403 Device-2: Microdia USB 2.0 Camera type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-3.3:6 chip-ID: 0c45:636d class-ID: 0102 serial: SN0001 Device-3: Lenovo ThinkPad Dock Audio type: USB driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-3.4.2.3:11 chip-ID: 17ef:3063 class-ID: 0300 serial: 000000000000 Device-4: C-Media TONOR TC30 Audio Device type: USB driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-3.4.3.2:21 chip-ID: 0d8c:0134 class-ID: 0300 serial: 20200707 Sound Server-1: ALSA v: k5.13.4-1-MANJARO running: yes Sound Server-2: JACK v: 0.125.0 running: no Sound Server-3: PulseAudio v: 14.2 running: yes Sound Server-4: PipeWire v: 0.3.32 running: no Network: Device-1: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel port: efa0 bus-ID: 00:1f.6 chip-ID: 8086:15d8 class-ID: 0200 IF: enp0s31f6 state: down mac: e8:6a:64:93:83:01 Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: efa0 bus-ID: 02:00.0 chip-ID: 8086:24fd class-ID: 0280 IF: wlp2s0 state: down mac: f6:61:b8:68:02:37 Device-3: Lenovo ThinkPad Dock Ethernet [Realtek RTL8153B] type: USB driver: r8152 bus-ID: 1-3.1:24 chip-ID: 17ef:3062 class-ID: 0000 serial: 1014570F9 IF: enp0s20f0u3u1 state: up speed: 100 Mbps duplex: full mac: 3c:e1:a1:45:70:f9 IP v4: 192.168.88.247/24 type: dynamic noprefixroute scope: global broadcast: 192.168.88.255 IP v6: fe80::8426:f39e:9622:5b25/64 type: noprefixroute scope: link IF-ID-1: ppp0 state: unknown speed: N/A duplex: N/A mac: N/A IP v4: 10.5.251.35 scope: global WAN IP: 185.97.224.201 Bluetooth: Message: No bluetooth data found. Logical: Message: No logical block device data found. Device-1: luks-3e132614-3230-4a7e-9cf3-b4714e806947 maj-min: 254:0 type: LUKS dm: dm-0 size: 238.22 GiB Components: p-1: nvme0n1p5 maj-min: 259:2 size: 238.22 GiB RAID: Message: No RAID data found. Drives: Local Storage: total: 704.24 GiB used: 171.67 GiB (24.4%) SMART Message: Unable to run smartctl. Root privileges required. ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lenovo model: LENSE30256GMSP34MEAT3TA size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: FBFB18110Y10005764 rev: 2.5.0412 temp: 43.9 C scheme: GPT ID-2: /dev/sdc maj-min: 8:32 type: USB vendor: SanDisk model: SD9SN8W512G size: 465.76 GiB block-size: physical: 4096 B logical: 512 B type: SSD serial: 191112476214 rev: 1012 scheme: GPT SMART Message: Unknown USB bridge. Flash drive/Unsupported enclosure? Message: No optical or floppy data found. Partition: ID-1: / raw-size: 238.22 GiB size: 233.48 GiB (98.01%) used: 149.2 GiB (63.9%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0 mapped: luks-3e132614-3230-4a7e-9cf3-b4714e806947 label: N/A uuid: 35b12521-756c-43a1-aa8c-930873c832d1 ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 2.4 MiB (1.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A uuid: 6523-3C8F ID-3: /run/timeshift/backup raw-size: N/A size: 162.35 GiB used: 22.47 GiB (13.8%) fs: ext4 dev: /dev/sda4 label: N/A uuid: N/A Swap: Kernel: swappiness: 60 (default) cache-pressure: 100 (default) ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2 file: /swapfile Unmounted: ID-1: /dev/sdc1 maj-min: 8:33 size: 100 MiB fs: vfat label: N/A uuid: CCAE-0329 ID-2: /dev/sdc2 maj-min: 8:34 size: 148.97 GiB fs: ntfs label: N/A uuid: 00E35FC5472F21EC ID-3: /dev/sdc4 maj-min: 8:36 size: 166.02 GiB fs: ext4 label: N/A uuid: b01f950e-2fc8-4880-bd91-ad0ccb2c6553 USB: Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900 Hub-2: 1-3:2 info: Lenovo ports: 4 rev: 2.1 speed: 480 Mb/s chip-ID: 17ef:1025 class-ID: 0900 Device-1: 1-3.1:24 info: Lenovo ThinkPad Dock Ethernet [Realtek RTL8153B] type: Network driver: r8152 interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 350mA chip-ID: 17ef:3062 class-ID: 0000 serial: 1014570F9 Device-2: 1-3.2:4 info: Lenovo ThinkPad Dock type: Billboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 17ef:3060 class-ID: 0300 serial: 0001 Device-3: 1-3.3:6 info: Microdia USB 2.0 Camera type: Video,Audio driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0c45:636d class-ID: 0102 serial: SN0001 Hub-3: 1-3.4:8 info: Lenovo ports: 4 rev: 2.1 speed: 480 Mb/s chip-ID: 17ef:1026 class-ID: 0900 Hub-4: 1-3.4.2:9 info: Lenovo ThinkPad Dock Hub [Cypress HX2VL] ports: 3 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 17ef:1021 class-ID: 0900 Device-1: 1-3.4.2.3:11 info: Lenovo ThinkPad Dock Audio type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 17ef:3063 class-ID: 0300 serial: 000000000000 Hub-5: 1-3.4.3:19 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s power: 100mA chip-ID: 1a40:0101 class-ID: 0900 Device-1: 1-3.4.3.1:20 info: Logitech G3 (MX518) Optical Mouse type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s power: 98mA chip-ID: 046d:c051 class-ID: 0301 Device-2: 1-3.4.3.2:21 info: C-Media TONOR TC30 Audio Device type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 0d8c:0134 class-ID: 0300 serial: 20200707 Device-3: 1-3.4.3.3:22 info: Logitech DeLuxe 250 Keyboard type: Keyboard driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s power: 70mA chip-ID: 046d:c312 class-ID: 0301 Device-4: 1-3.4.4:23 info: SanDisk Extreme Portable SSD type: Mass Storage driver: uas interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 500mA chip-ID: 0781:558c class-ID: 0806 serial: 313931323130343031323638 Device-5: 1-8:5 info: IMC Networks Integrated Camera type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 13d3:56b2 class-ID: 0e02 Device-6: 1-9:7 info: Synaptics Metallica MIS Touch Fingerprint Reader type: <vendor specific> driver: usbfs interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 06cb:009a class-ID: ff00 serial: 0344b4866610 Hub-6: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s chip-ID: 1d6b:0003 class-ID: 0900 Device-1: 2-3:2 info: Realtek USB3.0-CRW type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 800mA chip-ID: 0bda:0328 class-ID: 0806 serial: 28203008282014000 Hub-7: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900 Hub-8: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900 Sensors: System Temperatures: cpu: 53.0 C mobo: N/A Fan Speeds (RPM): fan-1: 0 Repos: Packages: pacman: 1581 lib: 416 pkg: 0 flatpak: 0 Active pacman repo servers in: /etc/pacman.d/mirrorlist 1: https://manjaro.moson.eu/stable/$repo/$arch 2: https://manjaro.moson.org/stable/$repo/$arch 3: https://mirror.alpix.eu/manjaro/stable/$repo/$arch 4: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch 5: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch 6: https://manjaro.re/stable/$repo/$arch Processes: CPU top: 5 of 278 1: cpu: 34.8% command: firefox pid: 8297 mem: 76.2 MiB (0.4%) 2: cpu: 25.6% command: slack pid: 6826 mem: 315.4 MiB (1.9%) 3: cpu: 13.7% command: firefox pid: 3312 mem: 549.9 MiB (3.4%) 4: cpu: 12.8% command: java pid: 3823 mem: 1346.7 MiB (8.4%) 5: cpu: 7.7% command: firefox pid: 3465 mem: 699.2 MiB (4.3%) Memory top: 5 of 278 1: mem: 1346.7 MiB (8.4%) command: java pid: 3823 cpu: 12.8% 2: mem: 699.2 MiB (4.3%) command: firefox pid: 3465 cpu: 7.7% 3: mem: 549.9 MiB (3.4%) command: firefox pid: 3312 cpu: 13.7% 4: mem: 449.9 MiB (2.8%) command: albert pid: 2029 cpu: 1.6% 5: mem: 348.2 MiB (2.1%) command: teams pid: 2445 cpu: 1.0% Info: Processes: 278 Uptime: 1h 17m wakeups: 15 Init: systemd v: 248 tool: systemctl Compilers: gcc: 11.1.0 Shell: Zsh v: 5.8 running-in: kitty inxi: 3.3.06
