This is alsa-info.sh file reply
I couldnât put specific info because i didnât know what output you may have wanted. Also I couldnât include like so putting whole info. If there is any specific output your looking for please let me know.
00:1f.3 Audio device [0403]: Intel Corporation Sunrise Point-LP HD Audio [8086:9d71] (rev 21)
	Subsystem: Hewlett-Packard Company Device [103c:83f9]
!!Modprobe options (Sound related)
snd_hda_intel: model=headpset-mic
snd_hda_intel: patch=hda-jack-retask.fw,hda-jack-retask.fw,hda-jack-retask.fw,hda-jack-retask.fw
!!Loaded sound module options
!!Module: snd_hda_intel
	align_buffer_size : -1
	bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	beep_mode : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
	dmic_detect : Y
	enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
	enable_msi : -1
	id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	model : headpset-mic,(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	patch : hda-jack-retask.fw,hda-jack-retask.fw,hda-jack-retask.fw,hda-jack-retask.fw,(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	pm_blacklist : Y
	position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	power_save : 0
	power_save_controller : N
	probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	single_cmd : -1
	snoop : -1
!!HDA-Intel Codec information
--startcollapse--
Codec: Realtek ALC295
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x10ec0295
Subsystem Id: 0x103c83f9
Revision Id: 0x100002
No Modem Function Group found
Default PCM:
    rates [0x560]: 44100 48000 96000 192000
    bits [0xe]: 16 20 24
    formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
  Power states:  D0 D1 D2 D3 D3cold CLKSTOP EPSS
  Power: setting=D0, actual=D0
GPIO: io=3, o=0, i=0, unsolicited=1, wake=0
  IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
  IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
  IO[2]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  Control: name="Speaker Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=Out, idx=0, ofs=0
  Amp-Out caps: ofs=0x57, nsteps=0x57, stepsize=0x02, mute=0
  Amp-Out vals:  [0x00 0x00]
  Converter: stream=1, channel=0
  PCM:
    rates [0x60]: 44100 48000
    formats [0x1]: PCM
  Power states:  D0 D1 D2 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  Control: name="Headphone Playback Volume", index=0, device=0
  Device: name="ALC295 Analog", type="Audio", device=0
  Amp-Out vals:  [0x54 0x54]
  PCM:
    formats [0x1]: PCM
Node 0x04 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x05 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x06 [Audio Output] wcaps 0x411: Stereo
  Converter: stream=0, channel=0
  PCM:
    rates [0x40]: 48000
    formats [0x1]: PCM
Node 0x07 [Audio Input] wcaps 0x10051b: Stereo Amp-In
  Amp-In caps: ofs=0x17, nsteps=0x3f, stepsize=0x02, mute=1
  Amp-In vals:  [0x97 0x97]
  SDI-Select: 0
  PCM:
    rates [0x40]: 48000
    formats [0x1]: PCM
  Connection: 1
     0x24
Node 0x08 [Audio Input] wcaps 0x10051b: Stereo Amp-In
  Control: name="Capture Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=0, ofs=0
  Control: name="Capture Switch", index=0, device=0
  Amp-In vals:  [0x17 0x17]
  SDI-Select: 0
  PCM:
    formats [0x1]: PCM
  Connection: 1
     0x23
Node 0x09 [Audio Input] wcaps 0x10051b: Stereo Amp-In
  SDI-Select: 0
  PCM:
    formats [0x1]: PCM
  Connection: 1
     0x22
Node 0x0a [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0b [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0c [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0d [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0e [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0f [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x10 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x11 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x12 [Pin Complex] wcaps 0x40040b: Stereo Amp-In
  Control: name="Internal Mic Boost Volume", index=0, device=0
  Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
  Amp-In vals:  [0x00 0x00]
  Pincap 0x00000020: IN
  Pin Default 0xb7a601c0: [Fixed] Mic at Oth Mobile-In
    Conn = Digital, Color = Unknown
    DefAssociation = 0xc, Sequence = 0x0
    Misc = NO_PRESENCE
  Pin-ctls: 0x20: IN
Node 0x13 [Pin Complex] wcaps 0x40040b: Stereo Amp-In
  Pin Default 0x40000000: [N/A] Line Out at Ext N/A
    Conn = Unknown, Color = Unknown
    DefAssociation = 0x0, Sequence = 0x0
  Pin-ctls: 0x00:
Node 0x14 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
  Control: name="Speaker Playback Switch", index=0, device=0
  Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
  Amp-Out vals:  [0x80 0x80]
  Pincap 0x00010014: OUT EAPD Detect
  EAPD 0x2: EAPD
  Pin Default 0x90170110: [Fixed] Speaker at Int N/A
    Conn = Analog, Color = Unknown
    DefAssociation = 0x1, Sequence = 0x0
    Misc = NO_PRESENCE
  Pin-ctls: 0x00:
  Unsolicited: tag=00, enabled=0
  Connection: 1
     0x02
Node 0x15 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x16 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
  Pincap 0x0000001c: OUT HP Detect
  Pin Default 0x411111f0: [N/A] Speaker at Ext Rear
    Conn = 1/8, Color = Black
    DefAssociation = 0xf, Sequence = 0x0
    Misc = NO_PRESENCE
  Pin-ctls: 0x00:
  Connection: 2
     0x02* 0x03
Node 0x17 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
    Misc = NO_PRESENCE
  Pin-ctls: 0x00:
  Connection: 3
     0x02* 0x03 0x06
Node 0x18 [Pin Complex] wcaps 0x40048b: Stereo Amp-In
  Pincap 0x00000024: IN Detect
    Misc = NO_PRESENCE
  Pin-ctls: 0x00:
Node 0x19 [Pin Complex] wcaps 0x40048b: Stereo Amp-In
  Control: name="Mic Boost Volume", index=0, device=0
  Pincap 0x00003724: IN Detect
    Vref caps: HIZ 50 GRD 80 100
  Pin Default 0x03a11040: [Jack] Mic at Ext Left
    DefAssociation = 0x4, Sequence = 0x0
  Pin-ctls: 0x24: IN VREF_80
  Unsolicited: tag=02, enabled=1
Node 0x1a [Pin Complex] wcaps 0x40048b: Stereo Amp-In
    Misc = NO_PRESENCE
  Pin-ctls: 0x00: VREF_HIZ
Node 0x1b [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
  Pincap 0x00013734: IN OUT EAPD Detect
  EAPD 0x2: EAPD
    Misc = NO_PRESENCE
  Connection: 2
     0x02* 0x03
Node 0x1c [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x1d [Pin Complex] wcaps 0x400400: Mono
  Pin Default 0x40600001: [N/A] Modem Line at Ext N/A
    DefAssociation = 0x0, Sequence = 0x1
  Pin-ctls: 0x20: IN
Node 0x1e [Pin Complex] wcaps 0x400501: Stereo
  Pincap 0x00000010: OUT
    Misc = NO_PRESENCE
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x06
Node 0x1f [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
  Processing caps: benign=0, ncoeff=104
Node 0x21 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
  Control: name="Headphone Playback Switch", index=0, device=0
  Pincap 0x0001001c: OUT HP EAPD Detect
  EAPD 0x2: EAPD
  Pin Default 0x03211020: [Jack] HP Out at Ext Left
    DefAssociation = 0x2, Sequence = 0x0
  Pin-ctls: 0xc0: OUT HP
  Unsolicited: tag=01, enabled=1
  Connection: 2
     0x02 0x03*
Node 0x22 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
  Amp-In vals:  [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
  Connection: 5
     0x19 0x1a 0x1b 0x1d 0x13
Node 0x23 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Amp-In vals:  [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x00 0x00]
  Connection: 5
     0x19 0x1a 0x1b 0x1d 0x12
Node 0x24 [Audio Selector] wcaps 0x300101: Stereo
  Connection: 3
     0x12* 0x13 0x18
Codec: Intel Kabylake HDMI
Address: 2
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x8086280b
Subsystem Id: 0x80860101
Revision Id: 0x100000
Default PCM:
    rates [0x0]:
    bits [0x0]:
    formats [0x0]:
  Power states:  D0 D3 CLKSTOP EPSS
  Power: setting=D0, actual=D0, Clock-stop-OK
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x02 [Audio Output] wcaps 0x6611: 8-Channels Digital
  Digital: Enabled KAE
  Digital category: 0x0
  IEC Coding Type: 0x0
  PCM:
    rates [0x7f0]: 32000 44100 48000 88200 96000 176400 192000
    bits [0x1a]: 16 24 32
    formats [0x5]: PCM AC3
  Power states:  D0 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x6611: 8-Channels Digital
  PCM:
Node 0x04 [Audio Output] wcaps 0x6611: 8-Channels Digital
  PCM:
Node 0x05 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Pincap 0x0b000094: OUT Detect HBR HDMI DP
  Pin Default 0x18560010: [Jack] Digital Out at Int HDMI
  Pin-ctls: 0x00:
  Devices: 0
  Connection: 0
Node 0x06 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Pin-ctls: 0x00:
  Devices: 0
  Connection: 0
Node 0x07 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Pin-ctls: 0x00:
  Devices: 0
  Connection: 0
Node 0x08 [Vendor Defined Widget] wcaps 0xf00000: Mono
--endcollapse--
!!ALSA Device nodes
crw-rw----  1 root audio 116, 11 Oct  3 12:09 /dev/snd/controlC0
crw-rw----  1 root audio 116,  9 Oct  3 12:09 /dev/snd/hwC0D0
crw-rw----  1 root audio 116, 10 Oct  3 12:09 /dev/snd/hwC0D2
crw-rw----  1 root audio 116,  3 Oct  3 12:10 /dev/snd/pcmC0D0c
crw-rw----  1 root audio 116,  2 Oct  3 12:10 /dev/snd/pcmC0D0p
crw-rw----  1 root audio 116,  8 Oct  3 12:11 /dev/snd/pcmC0D10p
crw-rw----  1 root audio 116,  4 Oct  3 12:11 /dev/snd/pcmC0D3p
crw-rw----  1 root audio 116,  5 Oct  3 12:11 /dev/snd/pcmC0D7p
crw-rw----  1 root audio 116,  6 Oct  3 12:11 /dev/snd/pcmC0D8p
crw-rw----  1 root audio 116,  7 Oct  3 12:11 /dev/snd/pcmC0D9p
crw-rw----  1 root audio 116,  1 Oct  3 12:11 /dev/snd/seq
crw-rw----  1 root audio 116, 33 Oct  3 12:09 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root  60 Oct  3 12:09 .
drwxr-xr-x 3 root root 300 Oct  3 12:09 ..
lrwxrwxrwx 1 root root  12 Oct  3 12:09 pci-0000:00:1f.3 -> ../controlC0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC295 Analog [ALC295 Analog]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 10: HDMI 4 [HDMI 4]
  Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
  Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card PCH
Card hw:0 'PCH'/'HDA Intel PCH at 0xb4328000 irq 135'
  Mixer name	: 'Realtek ALC295'
  Components	: 'HDA:10ec0295,103c83f9,00100002 HDA:8086280b,80860101,00100000'
  Controls      : 54
  Simple ctrls  : 14
Simple mixer control 'Master',0
  Capabilities: pvolume pvolume-joined pswitch pswitch-joined
  Playback channels: Mono
  Limits: Playback 0 - 87
  Mono: Playback 84 [97%] [-2.25dB] [on]
Simple mixer control 'Headphone',0
  Capabilities: pvolume pswitch
  Mono:
  Front Left: Playback 87 [100%] [0.00dB] [on]
  Front Right: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'Speaker',0
  Mono:
  Front Left: Playback 0 [0%] [-65.25dB] [off]
  Front Right: Playback 0 [0%] [-65.25dB] [off]
Simple mixer control 'PCM',0
  Limits: Playback 0 - 255
  Mono:
  Front Left: Playback 255 [100%] [0.00dB]
  Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Mic Boost',0
  Capabilities: volume
  Limits: 0 - 3
  Front Left: 0 [0%] [0.00dB]
  Front Right: 0 [0%] [0.00dB]
Simple mixer control 'IEC958',0
  Capabilities: pswitch pswitch-joined
  Mono: Playback [off]
Simple mixer control 'IEC958',1
  Mono: Playback [on]
Simple mixer control 'IEC958',2
  Mono: Playback [on]
Simple mixer control 'IEC958',3
  Mono: Playback [on]
Simple mixer control 'IEC958',4
  Mono: Playback [on]
Simple mixer control 'Capture',0
  Capabilities: cvolume cswitch
  Limits: Capture 0 - 63
  Front Left: Capture 23 [37%] [0.00dB] [on]
  Front Right: Capture 23 [37%] [0.00dB] [on]
Simple mixer control 'Auto-Mute Mode',0
  Capabilities: enum
  Items: 'Disabled' 'Enabled'
  Item0: 'Enabled'
Simple mixer control 'Internal Mic Boost',0
  Limits: 0 - 3
Simple mixer control 'Mute-LED Mode',0
  Capabilities: enum
  Items: 'On' 'Off' 'Follow Master'
  Item0: 'Follow Master'
!!Alsactl output
--startcollapse--
state.PCH {
	control.1 {
		iface MIXER
		name 'Headphone Playback Volume'
		value.0 87
		value.1 87
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 87'
			dbmin -6525
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
	control.2 {
		iface MIXER
		name 'Headphone Playback Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.3 {
		iface MIXER
		name 'Speaker Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 87'
			dbmin -6525
			dbmax 0
			dbvalue.0 -6525
			dbvalue.1 -6525
	control.4 {
		iface MIXER
		name 'Speaker Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.5 {
		iface MIXER
		name 'Auto-Mute Mode'
		value Enabled
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Disabled
			item.1 Enabled
	control.6 {
		iface MIXER
		name 'Capture Volume'
		value.0 23
		value.1 23
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 63'
			dbmin -1725
			dbmax 3000
			dbvalue.0 0
			dbvalue.1 0
	control.7 {
		iface MIXER
		name 'Capture Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.8 {
		iface MIXER
		name 'Mic Boost Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 3'
			dbmin 0
			dbmax 3000
			dbvalue.0 0
			dbvalue.1 0
	control.9 {
		iface MIXER
		name 'Internal Mic Boost Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 3'
			dbmin 0
			dbmax 3000
			dbvalue.0 0
			dbvalue.1 0
	control.10 {
		iface MIXER
		name 'Master Playback Volume'
		value 84
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 87'
			dbmin -6525
			dbmax 0
			dbvalue.0 -225
	control.11 {
		iface MIXER
		name 'Master Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.12 {
		iface MIXER
		name 'Mute-LED Mode'
		value 'Follow Master'
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 On
			item.1 Off
			item.2 'Follow Master'
	control.13 {
		iface CARD
		name 'Mic Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.14 {
		iface CARD
		name 'Internal Mic Phantom Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.15 {
		iface CARD
		name 'Headphone Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.16 {
		iface CARD
		name 'Speaker Phantom Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.17 {
		iface PCM
		name 'Playback Channel Map'
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.18 {
		iface PCM
		name 'Capture Channel Map'
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.19 {
		iface CARD
		name 'HDMI/DP,pcm=3 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.20 {
		iface MIXER
		name 'IEC958 Playback Con Mask'
		value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.21 {
		iface MIXER
		name 'IEC958 Playback Pro Mask'
		value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.22 {
		iface MIXER
		name 'IEC958 Playback Default'
		value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access 'read write'
			type IEC958
			count 1
	control.23 {
		iface MIXER
		name 'IEC958 Playback Switch'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.24 {
		iface PCM
		device 3
		name ELD
		value ''
		comment {
			access 'read volatile'
			type BYTES
			count 0
	control.25 {
		iface CARD
		name 'HDMI/DP,pcm=7 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.26 {
		iface MIXER
		index 1
		comment {
			access read
			type IEC958
			count 1
	control.27 {
		iface MIXER
		index 1
		comment {
			access read
			type IEC958
			count 1
	control.28 {
		iface MIXER
		index 1
		comment {
			access 'read write'
			type IEC958
			count 1
	control.29 {
		iface MIXER
		index 1
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.30 {
		iface PCM
		device 7
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.31 {
		iface CARD
		name 'HDMI/DP,pcm=8 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.32 {
		iface MIXER
		index 2
		comment {
			access read
			type IEC958
			count 1
	control.33 {
		iface MIXER
		index 2
		comment {
			access read
			type IEC958
			count 1
	control.34 {
		iface MIXER
		index 2
		comment {
			access 'read write'
			type IEC958
			count 1
	control.35 {
		iface MIXER
		index 2
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.36 {
		iface PCM
		device 8
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.37 {
		iface CARD
		name 'HDMI/DP,pcm=9 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.38 {
		iface MIXER
		index 3
		comment {
			access read
			type IEC958
			count 1
	control.39 {
		iface MIXER
		index 3
		comment {
			access read
			type IEC958
			count 1
	control.40 {
		iface MIXER
		index 3
		comment {
			access 'read write'
			type IEC958
			count 1
	control.41 {
		iface MIXER
		index 3
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.42 {
		iface PCM
		device 9
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.43 {
		iface CARD
		name 'HDMI/DP,pcm=10 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.44 {
		iface MIXER
		index 4
		comment {
			access read
			type IEC958
			count 1
	control.45 {
		iface MIXER
		index 4
		comment {
			access read
			type IEC958
			count 1
	control.46 {
		iface MIXER
		index 4
		comment {
			access 'read write'
			type IEC958
			count 1
	control.47 {
		iface MIXER
		index 4
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.48 {
		iface PCM
		device 10
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.49 {
		iface PCM
		device 3
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.50 {
		iface PCM
		device 7
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.51 {
		iface PCM
		device 8
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.52 {
		iface PCM
		device 9
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.53 {
		iface PCM
		device 10
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.54 {
		iface MIXER
		name 'PCM Playback Volume'
		value.0 255
		value.1 255
		comment {
			access 'read write user'
			type INTEGER
			count 2
			range '0 - 255'
			tlv '0000000100000008ffffec1400000014'
			dbmin -5100
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
--endcollapse--
!!All Loaded Modules
ac
ac97_bus
acpi_thermal_rel
aesni_intel
af_alg
agpgart
algif_hash
algif_skcipher
atkbd
battery
bluetooth
bnep
btbcm
btintel
btrtl
btusb
ccm
cdrom
cec
cfg80211
cmac
coretemp
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
drm
drm_kms_helper
ecc
ecdh_generic
evdev
ext4
fat
fb_sys_fops
fixed_phy
fuse
ghash_clmulni_intel
glue_helper
hid
hid_generic
hid_logitech_dj
hid_logitech_hidpp
hp_accel
hp_wireless
hp_wmi
i2c_algo_bit
i2c_i801
i2c_smbus
i8042
i915
iTCO_vendor_support
iTCO_wdt
input_leds
int3400_thermal
int3403_thermal
int340x_thermal_zone
intel_cstate
intel_gtt
intel_pch_thermal
intel_pmc_bxt
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_soc_dts_iosf
intel_uncore
intel_xhci_usb_role_switch
ip_tables
iwlmvm
iwlwifi
jbd2
joydev
ledtrig_audio
libarc4
libphy
libps2
lis3lv02d
loop
mac80211
mac_hid
mbcache
mc
mdio_devres
mei
mei_hdcp
mei_me
mmc_core
mousedev
mxm_wmi
nls_cp437
nls_iso8859_1
nouveau
of_mdio
pcspkr
processor_thermal_device
psmouse
r8169
rapl
rc_core
realtek
rfcomm
rfkill
rng_core
roles
rtsx_pci
rtsx_pci_sdmmc
serio
serio_raw
sg
snd
snd_compress
snd_hda_codec
snd_hda_codec_generic
snd_hda_codec_hdmi
snd_hda_codec_realtek
snd_hda_core
snd_hda_ext_core
snd_hda_intel
snd_hrtimer
snd_hwdep
snd_intel_dspcfg
snd_pcm
snd_pcm_dmaengine
snd_seq
snd_seq_device
snd_seq_dummy
snd_soc_acpi
snd_soc_acpi_intel_match
snd_soc_core
snd_soc_skl
snd_soc_sst_dsp
snd_soc_sst_ipc
snd_timer
soundcore
sparse_keymap
squashfs
sr_mod
syscopyarea
sysfillrect
sysimgblt
tpm
tpm_crb
tpm_tis
tpm_tis_core
ttm
uinput
usbhid
uvcvideo
vfat
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
wmi
wmi_bmof
x86_pkg_temp_thermal
x_tables
xhci_hcd
xhci_pci
xhci_pci_renesas
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x12 0xb7a601c0
0x13 0x40000000
0x14 0x90170110
0x16 0x411111f0
0x17 0x411111f0
0x18 0x411111f0
0x19 0x03a11040
0x1a 0x411111f0
0x1b 0x411111f0
0x1d 0x40600001
0x1e 0x411111f0
0x21 0x03211020
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
0x12 0xb7a601c0
0x13 0x40000000
0x14 0x90170110
0x16 0x411111f0
0x17 0x411111f0
0x18 0x411111f0
0x19 0x03a11040
0x1a 0x411111f0
0x1b 0x411111f0
0x1d 0x40600001
0x1e 0x411111f0
0x21 0x03211020
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D0/hints:
/sys/class/sound/hwC0D2/init_pin_configs:
0x05 0x18560010
0x06 0x18560010
0x07 0x18560010
/sys/class/sound/hwC0D2/driver_pin_configs:
/sys/class/sound/hwC0D2/user_pin_configs:
/sys/class/sound/hwC0D2/init_verbs:
/sys/class/sound/hwC0D2/hints:
!!ALSA/HDA dmesg
[    0.139237] ACPI: Added _OSI(Linux-Dell-Video)
[    0.139237] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.139238] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[    0.376787] pci 0000:01:00.0: reg 0x30: [mem 0xfff80000-0xffffffff pref]
[    0.376804] pci 0000:01:00.0: Enabling HDA controller
[    0.377008] pci 0000:00:1c.0: PCI bridge to [bus 01]
[   14.409517] libphy: Fixed MDIO Bus: probed
[   14.419978] snd_hda_intel 0000:00:1f.3: Applying patch firmware 'hda-jack-retask.fw'
[   14.544059] r8169 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
[   14.986754] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:3a/LNXVIDEO:01/input/input26
[   14.987195] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[   14.992155] fbcon: i915drmfb (fb0) is primary device
[   15.100928] nouveau 0000:01:00.0: bus: MMIO read of 00000000 FAULT at 6013d4 [ IBUS ]
[   15.664838] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC295: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[   15.664840] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[   15.664841] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[   15.664842] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[   15.664843] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[   15.664843] snd_hda_codec_realtek hdaudioC0D0:      Mic=0x19
[   15.664844] snd_hda_codec_realtek hdaudioC0D0:      Internal Mic=0x12
[   15.702508] iwlwifi 0000:05:00.0: Detected Intel(R) Dual Band Wireless AC 7265, REV=0x210
[   15.728055] iwlwifi 0000:05:00.0: base HW address: 88:b1:11:f5:87:28
[   15.756472] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input27
[   15.756534] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input28
[   15.756591] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input29
[   15.756649] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input30
[   15.756688] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input31
[   15.756729] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input32
[   15.756781] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input33
[   15.789654] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[   28.728445] audit: type=1130 audit(1601707200.651:52): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   28.922632] nouveau 0000:01:00.0: Enabling HDA controller
[   29.806410] audit: type=1130 audit(1601707201.731:53): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Thank you for your reply.
