Expired certificate for ISO download on download.manjaro.org
You can test it with curl:
  • TLSv1.3 (OUT), TLS alert, certificate expired (557):
  • SSL certificate problem: certificate has expired
  • Closing connection 0
    curl: (60) SSL certificate problem: certificate has expired
I am getting this on the browser:
This server could not prove that it is download.manjaro.org; its security certificate expired in the last day. This may be caused by a misconfiguration or an attacker intercepting your connection. Your computer’s clock is currently set to Monday, 27 December 2021. Does that look right? If not, you should correct your system’s clock and then refresh this page.
Have you been made aware of this, @philm?
Should be now renewed.
