Greetings. I am new to Manjaro, and before it I only have vague experience with Windows 7 and Linux Mint. Since I installed Manjaro KDE Minimal Stable, my WiFi connection has been on the scale of XX~XXX Kb/s, while before that it was in the range of 200 Mb/s. I had no connectivity issues while booted from the Live USB, and no issues on Mint before that. While I never used the pre-installed Windows 11 on this device, I assume everything was fine OOTB as well.
The network monitor in my system tray indicates that my connection speed is normal (100~200 Mb/s), and that my signal strength is fine (80~90%), but both Firefox and Pacman download at a rate of no more than 200 Kb/s. Settings > Manjaro Settings > Hardware Configuration > Network controller calls my WiFi card, which is an Intel Alder Lake - P Unknown device name (Intel Corporation). My connection (as indicated by the network monitor in the system tray) is 2.4 GHz, MTU is set to Automatic, WiFi Mode is Infrastructure, and if I try to change or configure anything at all, my laptop just refuses to connect. speedtest-cli bizarrely claims that my bitrate is in the range of 1 ~ 2 Mb/s, which is starkly different from both my expected (read desired), and my perceived connection speed.
I am currently using the linux515 kernel, but originally had the linux61 one (I downgraded because I read about people fixing similar issues this way). As far as I’m aware, all my drivers and headers are up to date for both kernels, and my WiFi card has official support via the iwlwifi open-source driver since linux512 (apparently). The problem is exactly the same on both, and has even persisted when booting from Live USB since I installed Manjaro.
I am not sure what info I need to provide so here’s random stuff I saw being asked about on similar threads:
inxi -Fxxxrazy
Kernel: 5.15.91-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=baf403df-5aea-4b1e-ab99-68b29dc2fc1c rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Acer product: Aspire A315-59 v: V1.16
serial: <superuser required>
Mobo: ADL model: Callisto_ADU v: V1.16 serial: <superuser required>
UEFI: Insyde v: 1.16 date: 08/16/2022
ID-1: BAT1 charge: 40.8 Wh (100.0%) condition: 40.8/42.2 Wh (96.8%)
volts: 13.0 min: 11.6 model: SMP AP18C7K type: Li-ion serial: <filter>
status: full
Device-1: hidpp_battery_0 model: Logitech M350 Wireless Mouse
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
Info: model: 12th Gen Intel Core i5-1235U bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 4
microcode: 0x424
Topology: cpus: 1x cores: 10 mt: 2 tpc: 2 st: 8 threads: 12 smt: enabled
cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32 KiB, 8x64 KiB
L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 770 high: 982 min/max: 400/4400:3300 scaling:
driver: intel_pstate governor: powersave cores: 1: 818 2: 732 3: 890 4: 871
5: 709 6: 759 7: 758 8: 982 9: 757 10: 557 11: 769 12: 641 bogomips: 59916
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel Alder Lake-UP3 GT2 [Iris Xe Graphics]
vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen-12.2
process: Intel 10nm built: 2021-22+ ports: active: eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 0000:00:02.0 chip-ID: 8086:46a8
class-ID: 0300
Device-2: Quanta ACER HD User Facing type: USB driver: N/A bus-ID: 3-7:3
chip-ID: 0408:4033 class-ID: fe01 serial: <filter>
Display: x11 server: X.Org v: 21.1.6 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15e7 built: 2016 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.3.4 renderer: Mesa Intel Graphics (ADL GT2)
direct render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio
vendor: Acer Incorporated ALI driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:51c8 class-ID: 0401
Sound API: ALSA v: k5.15.91-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.65 running: yes
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:51f0 class-ID: 0280
vendor: Acer Incorporated ALI driver: r8169 v: kernel modules: r8168
port: 3000 bus-ID: 0000:2a:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp42s0 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 3-10:4 chip-ID: 8087:0aaa class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 21.36 GiB (4.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLQ512HBLU-00B00
lanes: 4 type: SSD serial: <filter> rev: FXM7301Q temp: 33.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%) used: 21.36 GiB (4.6%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 39.0 C mobo: N/A
Packages: pm: pacman pkgs: 1348 libs: 450 tools: pamac
1: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
2: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
3: http://mirrors.colocall.net/manjaro/stable/$repo/$arch
4: https://mirror.init7.net/manjaro/stable/$repo/$arch
5: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
6: https://mirror.23m.com/manjaro/stable/$repo/$arch
7: https://manjaro.ynh.ovh/stable/$repo/$arch
8: https://manjaro.kyberorg.fi/stable/$repo/$arch
9: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
10: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
11: https://mirror.zetup.net/manjaro/stable/$repo/$arch
12: https://mirror.easyname.at/manjaro/stable/$repo/$arch
13: https://mirror.cyberhost.uk/sites/manjaro/stable/$repo/$arch
14: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
15: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
16: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
17: https://repo.skni.umcs.pl/manjaro/stable/$repo/$arch
18: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
19: https://mirror.moson.org/manjaro/stable/$repo/$arch
20: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
21: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
22: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
23: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
24: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
25: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
26: https://mirror.tarnkappe.info/manjaro/stable/$repo/$arch
Processes: 281 Uptime: 1h 20m wakeups: 2001 Memory: 11.4 GiB
used: 3.21 GiB (28.2%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.24
mhwd -l -d
> PCI Device: /devices/pci0000:00/0000:00:02.0 (0300:8086:46a8)
Display controller Intel Corporation
> INSTALLED:
ATTACHED: PCI
VERSION: 2018.05.04
INFO: Standard open source drivers.
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300 0380 0302
VENDORIDS: 1002 8086 10de
> AVAILABLE:
ATTACHED: PCI
VERSION: 2018.05.04
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
ATTACHED: PCI
VERSION: 2020.01.13
INFO: X.org modesetting video driver.
PRIORITY: 1
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
ATTACHED: PCI
VERSION: 2017.03.12
INFO: X.org vesa video driver.
PRIORITY: 0
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
> PCI Device: /devices/pci0000:00/0000:00:1d.0/0000:2a:00.0 (0200:10ec:8168)
Network controller Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
> AVAILABLE:
ATTACHED: PCI
VERSION: 2016.04.20
INFO: RealTek RTL-8168 Gigabit Ethernet driver
PRIORITY: 0
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0200
VENDORIDS: 1186 10ec
Warning: no configs for USB devices found!
speedtest-cli
Retrieving speedtest.net configuration...
Testing from [ REDACTED ] (**.**.**.**)...
Retrieving speedtest.net server list...
Selecting best server based on ping...
Hosted by [ REDACTED ] ([ REDACTED ]) [ca. 400km / 250 mi]: 4083.371 ms
Testing download speed.........................................................
Download: 1.41 Mbit/s
Testing upload speed...........................................................
Upload: 2.00 Mbit/s
EDIT:
I found the issue. MTU - Automatic does not mean the system determines the best MTU for a given connection (TIL), but that it just reads the default value, which for me was 1500 bytes and resulted in ~99% packet loss. I’ve set it to 996 bytes and everything’s in order now.
EDIT 2:
I didn’t fix anything, turns out I only have this problem on one specific network, and I cannot fathom why. All other devices with all kinds of OS’s work fine on that network, and my device works fine on every other network. The MTU change did result in a notable improvement, though.
