Just installed Manjaro, I’m not totally new to Linux but I’m not used to this happening and I could probably fix it myself except for some reason the OS isn’t allowing me to change most of my graphics settings, specifically the rendering backend is the biggest pain not to be able to change.
Any time there is any animation on screen, even something as simple as a mouse hover over animation, dips my framerate into the 20s. I AM pretty new to the Linux community so I’m not certain what information I need to provide in this post but I’m willing to provide any info needed to solve this issue.
First thing to mention is that baloo (indexing) will have to take some time early in a new KDE install.
Second … a good start is system info;
Hey! Thanks for letting me know.
Kernel: 6.1.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=6a481ecd-2178-463a-a908-31ccc17454cd rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Hewlett-Packard product: HP Z210 Workstation v: N/A
serial: <superuser required> Chassis: type: 6 serial: <superuser required>
Mobo: Hewlett-Packard model: 1587h serial: <superuser required>
UEFI: Hewlett-Packard v: J51 v01.52 date: 02/13/2015
Info: model: Intel Core i7-2600 bits: 64 type: MT MCP arch: Sandy Bridge
gen: core 2 level: v2 built: 2010-12 process: Intel 32nm family: 6
model-id: 0x2A (42) stepping: 7 microcode: 0x2F
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 2067 high: 2754 min/max: 1600/3800 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2754 2: 1977 3: 1634
4: 1610 5: 1803 6: 2611 7: 2256 8: 1896 bogomips: 54299
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Type: itlb_multihit status: KVM: VMX unsupported
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GF114 [GeForce GTX 560 Ti] vendor: PNY driver: nouveau
v: kernel alternate: nvidia_drm,nvidia non-free: series: 390.xx+
status: legacy-active (EOL~late 2022) arch: Fermi code: GF1xx
process: 40/28nm built: 2010-16 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
ports: active: DVI-I-2 empty: DVI-I-1,HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:1200 class-ID: 0300 temp: 38.0 C
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: nouveau gpu: nouveau
display-ID: :0 screens: 1
s-diag: 582mm (22.93") monitors: <missing: xrandr>
Monitor-1: DVI-I-2 model: Dell P2212H serial: <filter> built: 2013
res: 1920x1080 dpi: 102 gamma: 1.2 size: 531x299mm (20.91x11.77")
diag: 551mm (21.7") ratio: 16:9 modes: max: 1920x1080 min: 720x400
API: OpenGL v: 4.3 Mesa 23.0.2 renderer: NVCE direct-render: Yes
vendor: Hewlett-Packard driver: snd_hda_intel bus-ID: 1-1.6:5 v: kernel
chip-ID: a014:b014 bus-ID: 00:1b.0 chip-ID: 8086:1c20 class-ID: 0300
class-ID: 0403 serial: <filter>
Device-2: NVIDIA GF114 HDMI Audio vendor: PNY driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:0e0c class-ID: 0403
Device-3: Insignia (Best Buy) Desktop Microphone NS-PAUM50 type: USB
driver: hid-generic,snd-usb-audio,usbhid
API: ALSA v: k6.1.25-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.70 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-3: PulseAudio v: 16.1 status: active tools: pacat,pactl
Device-1: Intel 82579LM Gigabit Network vendor: Hewlett-Packard
driver: e1000e v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1502
class-ID: 0200
Device-1: ASUSTek ASUS USB-BT500 type: USB driver: btusb v: 0.8
bus-ID: 2-1.6:3 chip-ID: 0b05:190e class-ID: e001 serial: <filter>
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: f020
bus-ID: 00:1f.2 chip-ID: 8086:2822 rev: N/A class-ID: 0104
Local Storage: total: 480.41 GiB used: 8.75 GiB (1.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WDBNCE5000PNC
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: 00RL scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB model: General size: 14.65 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: <filter>
rev: 5.00 scheme: MBR
ID-1: / raw-size: 26.68 GiB size: 26.09 GiB (97.80%) used: 8.72 GiB (33.4%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5
ID-2: /boot/efi raw-size: 513 MiB size: 509 MiB (99.22%)
used: 30.8 MiB (6.1%) fs: vfat dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 55.0 C mobo: N/A gpu: nouveau temp: 38.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 1710
Processes: 258 Uptime: 37m wakeups: 0 Memory: 15.58 GiB
used: 3.9 GiB (25.0%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1132 libs: 329 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.26
By the way I am aware of how little storage I gave this partition, it’s only temporary. I would have given it a bit more but windows being windows it only wanted to free up a little less than 30GB of my 150GB free space for a new partition.
A rather old model … You might have BIOS updates.
This doesnt provide iGPU ?
Of course its up to you … but the proprietary 390 does exist in the repos/mhwd.
Configure Graphics Cards - Manjaro
You also have no swap. Again up to you … but generally having some swap is a good idea.
Forgive me, what is that?
Yeah I plan on giving it swap. Just wanting to ensure I can get Manjaro stable before committing to wiping the drive that windows is on.
And yeah don’t worry I am painfully aware that this PC is old. Would you happen to have any idea why most of my compositor settings seem to be missing or how I can stop the framerate from dipping so drastically? Or at all preferably? lol
And if it boils down to getting that driver you mentioned installed, could you walk me through installing it?
I only ask because when I tried, this was the output.
sudo mhwd -a pci nonfree 0300 ✔
[sudo] password for beau:
> Skipping already installed config 'video-nvidia-390xx' for device: 0000:01:00.0 (0300:10de:1200) Display controller nVidia Corporation GF114 [GeForce GTX 560 Ti]
And then I’m pretty sure nothing changed. Forgive me I just really don’t know what I’m doing for the most part.
thats intel graphics, which is probably disabled in bios…
its probably the nouvea driver causing the issue, so you either install the proprietary one, or you can switch to the older kernels: 5.4/ 5.10/ 5.15, and test with them, nouveau works better with them…
post output from:
mhwd -l -li
since it looks it is already installed…
also disable baloo, go to system settings/ search/ file search and uncheck all options, click apply
I’d love to try installing the proprietary one but I simply don’t know how. I thought I had already done it but I suppose not?
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia-390xx 2023.03.23 false PCI
> 0000:01:00.0 (0300:10de:1200) Display controller nVidia Corporation:
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
Disabled baloo.
you already have it installed… the driver is not being loaded …
post output from:
ls /etc/modprobe.d
find /etc/X11/ -name "*.conf"
pacman -Qs 'nvidia|bbswitch|optimus'
/etc/X11/mhwd.d/nvidia.conf
/etc/X11/xorg.conf.d/30-touchpad.conf
/etc/X11/xorg.conf.d/90-mhwd.conf
/etc/X11/xorg.conf.d/00-keyboard.conf
local/egl-wayland 2:1.1.11-4
EGLStream-based Wayland external platform
local/lib32-libvdpau 1.5-1
Nvidia VDPAU library
local/lib32-nvidia-390xx-utils 390.157-4
NVIDIA drivers utilities (32-bit)
local/libvdpau 1.5-1
local/libxnvctrl-390xx 390.157-4
NVIDIA NV-CONTROL X extension
local/linux419-nvidia-390xx 390.157-21 (linux419-extramodules)
NVIDIA drivers for linux
local/linux61-nvidia-390xx 390.157-30 (linux61-extramodules)
local/mhwd-nvidia 530.41.03-4
MHWD module-ids for nvidia 530.41.03
local/mhwd-nvidia-390xx 390.157-5
MHWD module-ids for nvidia 390.157
local/mhwd-nvidia-470xx 470.182.03-1
MHWD module-ids for nvidia 470.182.03
local/nvidia-390xx-settings 390.157-4
Tool for configuring the NVIDIA graphics driver
local/nvidia-390xx-utils 390.157-5
local/xf86-video-nouveau 1.0.17-2 (xorg-drivers)
Open Source 3D acceleration driver for nVidia cards
looks ok…
so reinstall the drivers… first make sure you are up to date:
sudo pacman-mirrors --fasttrack 5 && sudo pacman -Syyu
then remove them:
sudo mhwd -r pci video-linux
sudo mhwd -r pci video-nvidia-390xx
install them:
if there were no errors, enable early loading:
kate /etc/mkinitcpio.conf
and edit the modules section to look like this:
MODULES=(nvidia nvidia_drm nvidia_uvm nvidia_modeset)
save it and update it:
sudo mkinitcpio -P
reboot… and hopefully you will not end up with a black screen … if you do, in the black screen enter into TTY: alt+ctrl+f2 or f1-f6 keys, enter your username and password, and remove them:
and install again the video linux:
sudo mhwd -i pci video-linux
reboot:
systemctl reboot
Sorry for the late reply. I was trying to see if that fixed it, and it didn’t, then I got busy.
I did all the above and it didn’t work. Though the proprietary drivers are installed and are running now to the best of my knowledge.
post output from:
mhwd -li && inxi -G
