I have a weird issue with Manjaro that may take a bit of explaining, so bear with me.
I’m running (or want to run), Manjaro with Gnome on my EVE Pixelbook (Google Pixelbook)
I currently have Fedora 39 on this using some hacks and tweaks from GitHub - jmontleon/pixelbook-fedora: How to install Fedora on a Pixelbook with reasonable results and GitHub - lyncolnmd/PixelbookLinux.
Most notably, it requires switching from PipeWire to PulseAudio.
So I tested this on vanilla archlinux installing with pulseaudio from scratch, and once I copied the firmware files, it worked.
Next I tried Endeavour OS, and switched from pipewire to pulse using
sudo pacman -S pulseaudio pulseaudio-alsa pulseaudio-bluetooth pulseaudio-equalizer pulseaudio-jack pulseaudio-lirc pulseaudio-rtp pulseaudio-zeroconf
Then copied the firmware files and it all worked.
I tried Manjaro doing the same thing, but also adding
sudo pacman -S manjaro-pulse
As that should switchover corresponding files.
And here’s the crunch. These steps (installing manjaro-pulse and all the other pulse packages) USED TO WORK on Manjaro (I’m talking maybe several weeks to a few months back), but now when I try to do this again on a fresh, clean Manjaro installation, doing the same steps as on a vanilla arch or Endeavour OS installation, (with the addition of installing manjaro-pulse), it doesn’t take – by which I mean audio doesn’t work (Gnome’s audio settings don’t see the device)
I’m reimaged back to Fedora for now, so I can write this message.
Does anyone have any thoughts on what might be going on here? I suspect something else might need to be installed/uninstalled, but it seems Manjaro-specific.
