Hi guys, I had this issue for quite some time now. If I restart pc, sometimes even by itself, the network would simply stop working. Now I reinstalled Manjaro, but the problem still persists. Sometimes its enough to restart NetworkManager service, but sometimes I have to boot into windows and then back to manjaro to get it to work. Here is my system info:
System: Kernel: 5.9.1-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UUID=7d35020e-4b06-4944-a2b8-f5a879360b76 rw quiet apparmor=1
security=apparmor resume=UUID=52fe86da-52a7-42df-99ff-7c1a797da17e udev.log_priority=3
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Desktop System: Gigabyte product: B450M DS3H v: N/A serial: <filter>
Mobo: Gigabyte model: B450M DS3H-CF v: x.x serial: <filter> UEFI: American Megatrends v: F51 date: 07/29/2020
CPU: Topology: 8-Core model: AMD Ryzen 7 1700 bits: 64 type: MT MCP arch: Zen family: 17 (23) model-id: 1 stepping: 1
microcode: 8001138 L2 cache: 4096 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 95847
Speed: 2015 MHz min/max: 1550/3000 MHz boost: enabled Core speeds (MHz): 1: 2015 2: 1336 3: 1682 4: 1351 5: 1666
6: 1970 7: 1445 8: 1404 9: 1879 10: 1457 11: 1725 12: 1853 13: 1476 14: 1385 15: 2047 16: 1363
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling
Graphics: Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti] vendor: eVga.com. driver: nouveau v: kernel bus ID: 07:00.0
chip ID: 10de:1b06
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: nouveau unloaded: modesetting
alternate: fbdev,nv,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.9x11.2") s-diag: 1052mm (41.4")
Monitor-1: DP-2 res: 1920x1080 hz: 60 dpi: 102 size: 476x267mm (18.7x10.5") diag: 546mm (21.5")
Monitor-2: HDMI-1 res: 1920x1080 hz: 60 dpi: 102 size: 476x267mm (18.7x10.5") diag: 546mm (21.5")
OpenGL: renderer: NV132 v: 4.3 Mesa 20.1.8 direct render: Yes
Audio: Device-1: NVIDIA GP102 HDMI Audio vendor: eVga.com. driver: snd_hda_intel v: kernel bus ID: 07:00.1
chip ID: 10de:10ef
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
bus ID: 09:00.3 chip ID: 1022:1457
Sound Server: ALSA v: k5.9.1-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169 v: kernel
port: f000 bus ID: 05:00.0 chip ID: 10ec:8168
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Ralink MT7601U Wireless Adapter type: USB driver: mt7601u bus ID: 1-4:5 chip ID: 148f:7601
serial: <filter>
IF: wlp2s0f0u4 state: up mac: <filter>
Drives: Local Storage: total: 2.88 TiB used: 25.05 GiB (0.9%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO 250GB size: 232.89 GiB block size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 1B2QEXE7 scheme: GPT
ID-2: /dev/sda vendor: Seagate model: ST1000DM003-1CH162 size: 931.51 GiB block size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: CC47 scheme: MBR
ID-3: /dev/sdb vendor: Kingston model: SKC600512G size: 476.94 GiB block size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s serial: <filter> rev: 0104 scheme: GPT
ID-4: /dev/sdc vendor: Seagate model: ST1000DM010-2EP102 size: 931.51 GiB block size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: CC43 scheme: GPT
ID-5: /dev/sdd vendor: Kingston model: SUV500240G size: 223.57 GiB block size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s serial: <filter> rev: 56RI scheme: GPT
ID-6: /dev/sde type: USB vendor: Western Digital model: WD1600BEVS-60RST0 size: 149.05 GiB block size:
physical: 512 B logical: 512 B serial: <filter> scheme: MBR
Partition: ID-1: / raw size: 223.79 GiB size: 219.28 GiB (97.98%) used: 13.08 GiB (6.0%) fs: ext4 dev: /dev/nvme0n1p2
Swap: Kernel: swappiness: 10 (default 60) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 8.80 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3
Sensors: System Temperatures: cpu: 37.0 C mobo: N/A gpu: nouveau temp: 47 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 0
Info: Processes: 334 Uptime: 31m Memory: 31.37 GiB used: 1.87 GiB (6.0%) Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: pacman: 1216 lib: 345 flatpak: 0 Shell: Zsh v: 5.8 default: Bash v: 5.0.18 running in: yakuake
inxi: 3.1.05
i get this error:
IP configuration was unavailable
