Inxi and other possibly relevant info is at the end.
Notes:
- I am not a professional in any way. Almost entirely self taught with Linux, networking and computers in general. I am not a good teacher.
- This is a relatively new computer. It’s overkill for my use case. Don’t let the hardware fool you, I’m actually incredibly poor. I cannot ‘throw money’ at the problem.
- I am disabled. I have minor physical and major developmental disorders. Part of it is something called dyscalculia or simply put: dyslexia for numbers.
- I also have a memory leak. In my brain, not my silicon. Like the movie Memento but not that bad.
(Not asking for special treatment or a psychologist, these simply might be reasons I’m having issues.)
My ethernet intermittently slows drastically, roughly every 20 minutes. When it happens, download speed stays below 20 kb/s and upload speed will run at around 500 b/s. The latter is bytes, it’s not a typo.
In Firefox, webpages show a ‘loading circle’ animated graphic for ~90 seconds then timeout. Some sites don’t have problems, noticeably google, which usually loads instantly, even after doing a search so it’s not a cached page. Google is not my default or preferred search engine. No other search engines will work when this happens.
My ISP (Spectrum/Charter/TWC) recently replaced my modem after I complained about these low speeds. I also stopped using an obsolete wifi router. There’s no useful instructions on the ISP support site for the new modem. They did not provide any paperwork or instructions. The technician hooked it up, tested the coaxial line at the wall, tested the line at the apartment building cable box, then left.
I don’t know how to log into the modem and not sure if I can or should. Note: I do not want to make any changes to the modem. I want to see if there are error messages that might help me diagnose the problem. I believe there are better things to troubleshoot anyways.
My setup currently is very simple. A coaxial cable goes from the wall to the modem. A cat 5a cable goes from the modem to the ethernet port on my computer. I have other cables I’ve used, including a cat6 crossover and tons of cat 5/5a cables and have switched them around a bunch. They all seem to work fine except maybe the cat6 which I’m not using right now.
I have a new router (Asus RT-AX3000) but have not set it up yet. I want to solve this issue before doing that. It’s highly unlikely but i’m a little worried the issue might be from malware and don’t want to risk infecting the router. Like I said, highly unlikely but I can’t rule it out because I don’t know how.
I expect to move somewhere else soon, but this is the best internet available to me in my price range. I cannot get fiber where I live, so my hardware is probably under-utilized. I live next to an airport and a large air force base and mobile data does weird stuff. I can’t explain it.
My ISP is supposedly giving 35mb/5mb down/up and that’s what normal speedtests show (via speedtest.net and librespeed.org) When i click on the network icon in my system tray, once the down/up speed monitoring graph starts, it looks like something is transmitting/receiving constantly. Even if Firefox and all programs that use the internet (that i know of) are closed, there’s still a steady amount of download and upload activity, always at the reduced speeds mentioned earlier. I have no idea what is doing it.
If I do ctrl+esc and bring up the KDE system activity screen, all known internet-using applications closed, with ‘all processes’ selected, it shows nothing is using the internet. Nothing appears in download or upload at all. Using the tools dropdown, if I open the system monitor, it’s the same. Nothing shows any upload or download activity. While those two are showing no activity, the system tray widget for the network, always shows the same steady, low speed mystery usage. This is why I worry it is malware.
Sometimes I will open http://gfblip.appspot.com/ to see errors. It’s a good indicator for me, for when the slowdown/timeouts happen. To explain the site, in case it goes down in the future, I think it uses java(script?) to send hundreds of pings per second to test for latency. I have no idea how it works. When the issue starts and blip is running, every 2 seconds there’s a red blip. The instructions for the site only really say that consistent red blips means something has gone horribly wrong. That’s pretty much it. I have no idea what is going wrong every two seconds.
My current best theory is that it is either NetworkManager or DNS or systemd related. Maybe a combination of those? It might be a configuration change after removing the wifi router. I also will sometimes tether my mobile data to the desktop with a USB cable. My previous computer didn’t have blutooth or wifi builtin so i’m used to doing that with USB and my horrible phone. (Galaxy A20e via Verizon)
if i run the command:
sudo systemctl restart NetworkManager #netreset
the internet works again as intended.
I’ve aliased that command to netreset to make it easier on myself and will use that alias later in this post.
Running it every 20 minutes is not a solution. That’s currently what I’m doing though. I don’t know how I would automate that if it was a viable workaround, not that I think it could be.
When the issue happens, in the terminal I’ve tried
ping -c 3 8.8.4.4
and get 100% packet loss. If I go to www.google.com in Firefox, it loads fine. Searches work too. Other search engines do not work. I’ve tried half a dozen. I tried 8.8.8.8 and 9.9.9.9 too. If I ping 127.0.0.0 it works. I have no idea if that’s useful or pointless. I don’t know if I can try other things to ping or if that matters. This makes me think maybe DNS? I do not know enough though.
I used nmcli to turn wifi off after removing the obselete router. I can’t find the exact command I used. I was messing with my bash history and did something wrong that cleared it entirely. That might be something for another post someday. Typing my password for the netreset alias every 20 minutes led to a mistake and even though I live alone, have no visitors ever and am the only one who will use this computer, I don’t think it is wise to leave a password in plaintext in my bash history.
I went to my ISP’s website and ran their speedtest while the network system tray widget was open. The ISP speedtest results were much higher than what the widget showed at the same time. I reset the modem with their automated support instructions, then did that again with a live chat technician but it did not fix the problem. I still get slow speeds every 20 minutes or so. They offered to send a technician but I don’t think their techs are allowed to mess with my actual system and probably only do Win/Mac stuff if they did.
Wild theories:
I notice in system activity there’s a process “at-spi-registryd” running and the actual command has an argument " --use-gnome-session" which seems odd since I’m using KDE. The internet says it is an accessibility toolkit, which I don’t use despite my many disabilities. Might be suspicious, probably nothing but still weird. I do not use gnome and have not installed any gnome applications that I know of. Learning more is frustrating because the internet keeps slowing down and timing out.
I had the AUR enabled with 2 items installed. One was Clementine and I removed it. It had stopped working anyways. It’s old but I really liked it. The other I didn’t recognize, “libsidplay” showing installed as a dependency of another package. I removed it too and have disabled the AUR. It would be nice if that line in the pamac GUI showed what package. I can never remember how to find out what the dependee? is, and with my internet being so spotty, I end up trying to figure it out using man pages. I don’t mind reading through man pages but it is time consuming and some larger ones or more technical ones get confusing for me. BTW pactree -r [packagename].
I had installed Windows in a dual boot. I didn’t want to and it stopped worked but I needed it to redeem a code for a videogame I’ll probably never play and didn’t have the time or knowledge to setup a virtual machine for it.
My firmware has an update I have not installed yet. I know how, it’s my paranoia of that minimal chance of malware is holding me back. Silly, I know. There’s no reason for anyone to target me, I’m a poor and crazy hermit. Some people just want to see the world burn though.
Some things I’ve tried.
I tried checking the journal but it looks like my journal is not rotating. I’ve never changed anything the conf file, it should be using the default settings. I try to avoid doing anything related to systemd. I always do something wrong which ends up taking me weeks to remedy. Without args, journalctl entries start from last May, when I first built this computer. There are millions of entries. I use -r or -b which help. With just -p4 there’s half a million warnings so trying to use journalctl is very time consuming. Also it doesn’t wrap for me, so i can’t easily copy and paste long errors. I’m digressing and ranting, moving on.
While the issue is occuring:
[lattrommi@taichi ~]$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: enp74s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 9c:6b:00:00:ac:89 brd ff:ff:ff:ff:ff:ff
inet 107.11.230.54/20 brd 107.11.239.255 scope global dynamic noprefixroute enp74s0
valid_lft 69023sec preferred_lft 69023sec
3: wlp73s0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether aa:7b:a5:27:40:69 brd ff:ff:ff:ff:ff:ff permaddr a4:6b:b6:2f:be:0d
4: enp84s0u1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UNKNOWN group default qlen 1000
link/ether 02:2f:77:00:08:6e brd ff:ff:ff:ff:ff:ff
I run my alias netreset to restart the NetworkManager.
Internet appears to be running smoothly again. Speeds at ISP advertised levels.
I run again:
valid_lft 68978sec preferred_lft 68978sec
link/ether 2e:c0:a6:d2:03:42 brd ff:ff:ff:ff:ff:ff permaddr a4:6b:b6:2f:be:0d
I share these but they mean very little to me. I kinda understand what they represent but have no idea what i’m doing here.
Later I do this. The issue is happening. I try to visit a link in Firefox, then I run:
[lattrommi@taichi ~]$ ip -r monitor
_gateway dev enp74s0 lladdr 00:01:5c:78:42:46 PROBE
_gateway dev enp74s0 FAILED
_gateway dev enp74s0 lladdr 00:01:5c:78:42:46 DELAY
_gateway dev enp74s0 lladdr 00:01:5c:78:42:46 STALE
At this point in another terminal, I do my netreset and this shows from the above command:
link/ether a4:6b:b6:2f:be:0d brd ff:ff:ff:ff:ff:ff
Deleted multicast ff00::/8 dev enp84s0u1 table local proto kernel metric 256 pref medium
Deleted fe80::8891:b5ff:fe10:39d8 dev enp84s0u1 lladdr 8a:91:b5:10:39:d8 router STALE
default via _gateway dev enp74s0 proto dhcp src 107.11.230.54 metric 100
Deleted default via _gateway dev enp74s0 proto dhcp src 107.11.230.54 metric 20100
_gateway dev enp74s0 lladdr 00:01:5c:78:42:46 REACHABLE
^C
Internet has resumed working properly. No new lines show for the ip monitor.
here’s some info:
[lattrommi@taichi ~]$ cat /etc/resolv.conf
# Generated by NetworkManager
search woh.rr.com
nameserver 209.18.47.62
nameserver 209.18.47.63
[lattrommi@taichi ~]$ cat /etc/hosts
# Standard host addresses
127.0.0.1 localhost
::1 localhost ip6-localhost ip6-loopback
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
# This host address
127.0.1.1 taichi
[lattrommi@taichi ~]$ inxi -Fazy
Kernel: 6.1.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=35f92074-9c31-464e-b7d5-e75abd70ee8d rw splash
resume=UUID=c0e7051a-efdd-4e71-8f6c-e35b57ff86ac
Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
Type: Desktop Mobo: ASRock model: X670E Taichi serial: <superuser required>
UEFI: American Megatrends LLC. v: 1.21 date: 04/26/2023
Info: model: AMD Ryzen 9 7950X bits: 64 type: MT MCP arch: Zen 4 gen: 5
level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
model-id: 0x61 (97) stepping: 2 microcode: 0xA601203
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 16 MiB desc: 16x1024 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3260 high: 5062 min/max: 3000/5880 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3110 2: 3000
3: 3000 4: 3000 5: 3000 6: 2860 7: 5062 8: 3000 9: 3599 10: 2752 11: 2879
12: 2705 13: 3000 14: 3000 15: 3000 16: 4500 17: 3000 18: 3000 19: 2868
20: 3000 21: 2842 22: 3000 23: 3000 24: 4500 25: 3837 26: 3000 27: 3000
28: 3000 29: 3000 30: 3000 31: 4500 32: 4323 bogomips: 288123
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 21 [Radeon RX 6950 XT] vendor: ASRock driver: amdgpu
v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-3,HDMI-A-1
empty: DP-1,DP-2 bus-ID: 03:00.0 chip-ID: 1002:73a5 class-ID: 0300
Device-2: AMD Raphael driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: HDMI-A-2 empty: DP-4,DP-5,DP-6 bus-ID: 59:00.0
chip-ID: 1002:164e class-ID: 0300 temp: 63.0 C
Device-3: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:3
chip-ID: 046d:082d class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 4480x2160 s-dpi: 96 s-size: 1182x570mm (46.54x22.44")
s-diag: 1312mm (51.66")
Monitor-1: DP-3 mapped: DisplayPort-2 pos: primary,bottom-l
model: LG (GoldStar) ULTRAWIDE serial: <filter> built: 2022 res: 2560x1080
dpi: 81 gamma: 1.2 size: 800x335mm (31.5x13.19") diag: 867mm (34.1") modes:
max: 2560x1080 min: 640x480
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: top-center model: Samsung
serial: <filter> built: 2008 res: 1920x1080 hz: 60 dpi: 305 gamma: 1.2
size: 160x90mm (6.3x3.54") diag: 184mm (7.2") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-3: HDMI-A-2 mapped: HDMI-A-1-1 pos: bottom-r model: AOC 2060W3
serial: <filter> built: 2015 res: 1920x1080 hz: 60 dpi: 112 gamma: 1.2
size: 435x239mm (17.13x9.41") diag: 496mm (19.5") ratio: 16:9 modes:
API: OpenGL v: 4.6 Mesa 23.0.4 renderer: AMD Radeon RX 6950 XT (navi21
LLVM 15.0.7 DRM 3.49 6.1.38-1-MANJARO) direct-render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 59:00.1
chip-ID: 1002:1640 class-ID: 0403
Device-3: AMD Family 17h/19h HD Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 59:00.6 chip-ID: 1022:15e3
class-ID: 0403
Device-4: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
Device-5: Generic USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-8:3
chip-ID: 26ce:0a06 class-ID: 0300
API: ALSA v: k6.1.38-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 0.3.74 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-4: PulseAudio v: 16.1 status: active with: pulseaudio-alsa
Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz vendor: Rivet Networks
driver: iwlwifi v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 49:00.0
chip-ID: 8086:2725 class-ID: 0280
IF: wlp73s0 state: down mac: <filter>
Device-2: Realtek Killer E3000 2.5GbE vendor: ASRock driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: a000 bus-ID: 4a:00.0
chip-ID: 10ec:3000 class-ID: 0200
IF: enp74s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: enp84s0u1 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: Samsung GT-I9070 (network tethering USB debugging enabled)
driver: rndis_host,usbfs type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 3-1:7 chip-ID: 04e8:6864 class-ID: 0a00 serial: <filter>
Device-2: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-7:2 chip-ID: 8087:0032
class-ID: e001
Report: ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: N/A
Local Storage: total: 1.75 TiB used: 344.97 GiB (19.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: PNY model: CS1311 240GB SSD
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 1122 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD5002ABYS-02B1B0 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
fw-rev: 3B03 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WDS120G2G0A-00JH30 size: 111.8 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 0000
scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WD1002FBYS-02A6B0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 0C06 scheme: MBR
ID-5: /dev/sde maj-min: 8:64 vendor: A-Data model: USB Flash Drive
size: 28.91 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.0
spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
fw-rev: 1100 scheme: MBR
ID-6: /dev/sdf maj-min: 8:80 vendor: A-Data model: USB Flash Drive
ID-1: / raw-size: 102.7 GiB size: 100.53 GiB (97.89%) used: 40.97 GiB (40.8%)
fs: ext4 dev: /dev/sdc2 maj-min: 8:34
used: 25.6 MiB (8.6%) fs: vfat dev: /dev/sdc1 maj-min: 8:33
dev: /dev/sdc3 maj-min: 8:35
System Temperatures: cpu: 70.0 C mobo: N/A
GPU: device: amdgpu temp: 63.0 C device: amdgpu temp: 55.0 C mem: 56.0 C
fan: 856 watts: 48.00
Processes: 517 Uptime: 12h 32m wakeups: 431 Memory: total: 128 GiB
available: 124.93 GiB used: 4.08 GiB (3.3%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1375 libs: 377 tools: pamac pm: flatpak pkgs: 0
Shell: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.28
There’s likely to be things I’ve forgotten. I keep a lot of notes using Zim. They are very disorganized and sometimes incorrect. Any advice is appreciated. Thank you for reading this far regardless.
