Hi @dragan,
I tried
sudo modprobe -r e1000e
sudo modprobe e1000e
but this not worked. The output it gaves me:
[riccarobi@riccarobi-PC ~]$ journalctl -r
apr 14 19:45:33 riccarobi-PC kernel: audit: type=1106 audit(1681494333.495:103)>
apr 14 19:45:33 riccarobi-PC kernel: e1000e: probe of 0000:00:19.0 failed with >
apr 14 19:45:33 riccarobi-PC sudo[1495]: pam_unix(sudo:session): session closed>
apr 14 19:45:33 riccarobi-PC audit[1495]: CRED_DISP pid=1495 uid=1000 auid=1000>
apr 14 19:45:33 riccarobi-PC audit[1495]: USER_END pid=1495 uid=1000 auid=1000 >
apr 14 19:45:32 riccarobi-PC kernel: e1000e 0000:00:19.0: Interrupt Throttling >
apr 14 19:45:32 riccarobi-PC kernel: e1000e: Copyright(c) 1999 - 2015 Intel Cor>
apr 14 19:45:32 riccarobi-PC kernel: e1000e: Intel(R) PRO/1000 Network Driver
apr 14 19:45:32 riccarobi-PC kernel: audit: type=1105 audit(1681494332.469:102)>
apr 14 19:45:32 riccarobi-PC kernel: audit: type=1110 audit(1681494332.469:101)>
apr 14 19:45:32 riccarobi-PC audit[1495]: USER_START pid=1495 uid=1000 auid=100>
apr 14 19:45:32 riccarobi-PC sudo[1495]: pam_unix(sudo:session): session opened>
apr 14 19:45:32 riccarobi-PC audit[1495]: CRED_REFR pid=1495 uid=1000 auid=1000>
apr 14 19:45:32 riccarobi-PC sudo[1495]: riccarobi : TTY=pts/1 ; PWD=/home/ricc>
apr 14 19:45:32 riccarobi-PC audit[1495]: USER_ACCT pid=1495 uid=1000 auid=1000>
apr 14 19:45:32 riccarobi-PC kernel: audit: type=1101 audit(1681494332.465:100)>
apr 14 19:45:32 riccarobi-PC sudo[1495]: pam_systemd_home(sudo:account): system>
apr 14 19:45:32 riccarobi-PC dbus-daemon[510]: [system] Activation via systemd >
apr 14 19:45:32 riccarobi-PC dbus-daemon[510]: [system] Activating via systemd:>
apr 14 19:45:30 riccarobi-PC kernel: audit: type=1104 audit(1681494330.325:99):>
apr 14 19:45:30 riccarobi-PC kernel: audit: type=1106 audit(1681494330.325:98):>
apr 14 19:45:30 riccarobi-PC audit[1491]: CRED_DISP pid=1491 uid=1000 auid=1000>
apr 14 19:45:30 riccarobi-PC audit[1491]: USER_END pid=1491 uid=1000 auid=1000 >
lines 1-23...skipping...
apr 14 19:45:33 riccarobi-PC kernel: audit: type=1106 audit(1681494333.495:103): pid=1495
uid=1000 auid=1000 ses=2 msg='op=PAM:session_close
grantors=pam_systemd_home,pam_limits,pam_unix,pa>
apr 14 19:45:33 riccarobi-PC kernel: e1000e: probe of 0000:00:19.0 failed with error -3
apr 14 19:45:33 riccarobi-PC sudo[1495]: pam_unix(sudo:session): session closed for user root
apr 14 19:45:33 riccarobi-PC audit[1495]: CRED_DISP pid=1495 uid=1000 auid=1000 ses=2
msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root"
exe="/usr/bin/sud>
apr 14 19:45:33 riccarobi-PC audit[1495]: USER_END pid=1495 uid=1000 auid=1000 ses=2
msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit
acct="root" exe="/usr>
apr 14 19:45:32 riccarobi-PC kernel: e1000e 0000:00:19.0: Interrupt Throttling Rate (ints/sec)
set to dynamic conservative mode
apr 14 19:45:32 riccarobi-PC kernel: e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
apr 14 19:45:32 riccarobi-PC kernel: audit: type=1105 audit(1681494332.469:102): pid=1495
uid=1000 auid=1000 ses=2 msg='op=PAM:session_open
grantors=pam_systemd_home,pam_limits,pam_unix,pam>
apr 14 19:45:32 riccarobi-PC kernel: audit: type=1110 audit(1681494332.469:101): pid=1495
uid=1000 auid=1000 ses=2 msg='op=PAM:setcred
grantors=pam_faillock,pam_permit,pam_env,pam_faillock >
apr 14 19:45:32 riccarobi-PC audit[1495]: USER_START pid=1495 uid=1000 auid=1000 ses=2
msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit
acct="root" exe="/us>
apr 14 19:45:32 riccarobi-PC sudo[1495]: pam_unix(sudo:session): session opened for user
root(uid=0) by (uid=1000)
apr 14 19:45:32 riccarobi-PC audit[1495]: CRED_REFR pid=1495 uid=1000 auid=1000 ses=2
exe="/usr/bin/sud>
apr 14 19:45:32 riccarobi-PC sudo[1495]: riccarobi : TTY=pts/1 ; PWD=/home/riccarobi ;
USER=root ; COMMAND=/usr/bin/modprobe e1000e
apr 14 19:45:32 riccarobi-PC audit[1495]: USER_ACCT pid=1495 uid=1000 auid=1000 ses=2
msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="riccarobi"
exe="/usr/bin/sudo" hostn>
apr 14 19:45:32 riccarobi-PC kernel: audit: type=1101 audit(1681494332.465:100): pid=1495
uid=1000 auid=1000 ses=2 msg='op=PAM:accounting
grantors=pam_unix,pam_permit,pam_time acct="riccaro>
apr 14 19:45:32 riccarobi-PC sudo[1495]: pam_systemd_home(sudo:account): systemd-homed
is not available: Unit dbus-org.freedesktop.home1.service not found.
apr 14 19:45:32 riccarobi-PC dbus-daemon[510]: [system] Activation via systemd failed for unit
'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
apr 14 19:45:32 riccarobi-PC dbus-daemon[510]: [system] Activating via systemd: service
name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.42'
(uid=0 pi>
apr 14 19:45:30 riccarobi-PC kernel: audit: type=1104 audit(1681494330.325:99): pid=1491
grantors=pam_faillock,pam_permit,pam_faillock acct="roo>
apr 14 19:45:30 riccarobi-PC kernel: audit: type=1106 audit(1681494330.325:98): pid=1491
apr 14 19:45:30 riccarobi-PC audit[1491]: CRED_DISP pid=1491 uid=1000 auid=1000 ses=2
msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root"
apr 14 19:45:30 riccarobi-PC audit[1491]: USER_END pid=1491 uid=1000 auid=1000 ses=2
apr 14 19:45:30 riccarobi-PC sudo[1491]: pam_unix(sudo:session): session closed for user root
apr 14 19:45:30 riccarobi-PC kernel: audit: type=1105 audit(1681494330.299:97): pid=1491
grantors=pam_systemd_home,pam_limits,pam_unix,pam_>
apr 14 19:45:30 riccarobi-PC kernel: audit: type=1110 audit(1681494330.299:96): pid=1491
apr 14 19:45:30 riccarobi-PC kernel: audit: type=1101 audit(1681494330.299:95): pid=1491
grantors=pam_unix,pam_permit,pam_time acct="riccarob>
apr 14 19:45:30 riccarobi-PC kernel: audit: type=1100 audit(1681494330.299:94): pid=1491
uid=1000 auid=1000 ses=2 msg='op=PAM:authentication
grantors=pam_faillock,pam_permit,pam_faillock ac>
apr 14 19:45:30 riccarobi-PC sudo[1491]: pam_unix(sudo:session): session opened for user
apr 14 19:45:30 riccarobi-PC audit[1491]: USER_START pid=1491 uid=1000 auid=1000 ses=2
apr 14 19:45:30 riccarobi-PC audit[1491]: CRED_REFR pid=1491 uid=1000 auid=1000 ses=2
apr 14 19:45:30 riccarobi-PC sudo[1491]: riccarobi : TTY=pts/1 ; PWD=/home/riccarobi ;
USER=root ; COMMAND=/usr/bin/modprobe -r e1000e
apr 14 19:45:30 riccarobi-PC audit[1491]: USER_ACCT pid=1491 uid=1000 auid=1000 ses=2
apr 14 19:45:30 riccarobi-PC audit[1491]: USER_AUTH pid=1491 uid=1000 auid=1000 ses=2
msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="riccarobi"
exe="/usr/bin>
apr 14 19:45:26 riccarobi-PC sudo[1491]: pam_systemd_home(sudo:auth): systemd-homed is
apr 14 19:45:26 riccarobi-PC dbus-daemon[510]: [system] Activation via systemd failed for unit
apr 14 19:45:26 riccarobi-PC dbus-daemon[510]: [system] Activating via systemd: service
name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.41'
(uid=0 pi>
apr 14 19:45:07 riccarobi-PC dbus-daemon[958]: [session uid=1000 pid=958] Successfully
activated service 'org.xfce.Xfconf'
apr 14 19:45:07 riccarobi-PC dbus-daemon[958]: [session uid=1000 pid=958] Activating service
name='org.xfce.Xfconf' requested by ':1.14' (uid=1000 pid=1032 comm="xfsettingsd")
@Wollie in the thread you linked the problem is solved disabling “wake on lan” from Windows, but I’haven’t Windows anymore. Bye!
