My Ethernet connection stopped working. When I try to run an update from the terminal, I get a string of “Could not resolve host” errors and my browser can’t find server ip address.
In a failed attempt to fix the problem, I went into the network manager and told it to reset/forget the Wired connection settings. That didn’t help. I tried restarting systemd-networkd and dhcpcd. That didn’t help either. Please help.
I’m just trying to figure this out.
Kernel: 6.1.41-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=d974853f-a67d-4d15-b53e-6af12eba8914 rw quiet apparmor=1
security=apparmor resume=UUID=aae190ea-f986-4336-83c6-a97542e0a237
udev.log_priority=3
Desktop: Cinnamon v: 5.8.4 tk: GTK v: 3.24.38 vt: 7 dm: LightDM v: 1.32.0
Type: Desktop System: Hewlett-Packard product: HP Z230 SFF Workstation v: N/A
serial: <superuser required> Chassis: type: 4 serial: <superuser required>
Mobo: Hewlett-Packard model: 1906 serial: <superuser required>
UEFI: Hewlett-Packard v: L51 v01.54 date: 05/05/2016
Info: model: Intel Xeon E3-1225 v3 bits: 64 type: MCP arch: Haswell level: v3
note: check built: 2013-15 process: Intel 22nm family: 6 model-id: 0x3C (60)
stepping: 3 microcode: 0x28
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 2514 high: 3193 min/max: 800/3600 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 3193 2: 2872 3: 3193
4: 798 bogomips: 25555
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Type: itlb_multihit status: KVM: VMX unsupported
STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GM107GL [Quadro K620] vendor: Hewlett-Packard
driver: nouveau v: kernel non-free: 535.xx+ status: current (as of 2023-07)
arch: Maxwell code: GMxxx process: TSMC 28nm built: 2014-19 pcie: gen: 2
speed: 5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: DVI-I-1 empty: DP-1 bus-ID: 01:00.0 chip-ID: 10de:13bb
class-ID: 0300 temp: 55.0 C
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: nouveau gpu: nouveau
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1280x1024 s-dpi: 96 s-size: 338x270mm (13.31x10.63")
s-diag: 433mm (17.03")
Monitor-1: DVI-I-1 model: HP vs17 serial: <filter> built: 2006
res: 1280x1024 hz: 60 dpi: 96 gamma: 1.4 size: 337x270mm (13.27x10.63")
diag: 426mm (16.8") ratio: 5:4 modes: max: 1280x1024 min: 720x400
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel 8 Series/C220 Series High Definition Audio
vendor: Hewlett-Packard 8 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:8c20 class-ID: 0403
Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX]
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1
chip-ID: 10de:0fbc class-ID: 0403
API: ALSA v: k6.1.41-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.75 status: off tools: pw-cli
type: plugin tools: pacat,pactl,pavucontrol
Device-1: Intel Ethernet I217-LM vendor: Hewlett-Packard driver: e1000e
v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:153a class-ID: 0200
IF-ID-1: br-ae72ad30c8cc state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A mac: <filter>
Local Storage: total: 1.82 TiB used: 1.57 TiB (86.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD2003FZEX-00Z4SA0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
fw-rev: 1A01 scheme: GPT
ID-1: / raw-size: 1.79 TiB size: 1.76 TiB (98.37%) used: 1.57 TiB (89.6%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 34.22 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 44.0 C mobo: N/A gpu: nouveau temp: 55.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 3660
Processes: 203 Uptime: 45m wakeups: 0 Memory: total: 32 GiB
available: 31.11 GiB used: 1.8 GiB (5.8%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
Packages: 1317 pm: pacman pkgs: 1302 libs: 380 tools: pamac,yay pm: flatpak
pkgs: 6 pm: snap pkgs: 9 Shell: Bash v: 5.1.16 running-in: kitty inxi: 3.3.28
Hope that helps.
This means your ethernet driver has correctly initialzed your device, so no problem there…
This indicates that you somehow have created a bridge config, maybe due to Docker, which are not working…
So check those…
This ipv6leak interface looks weird. Did you use some kind of VPN which maybe broke everything?
Look at the forum, the e1000e driver has some problems.
Also, I thinks it’s weird to use dhcpd and systemd-networkd in combination.
Indeed its either one or the other not both…
But i seem to have missed that, where did you notice him using those?
I had ProtonVPN installed. I uninstalled it, but the problem still exists.
Lets check a few places to see where things are configured…
networkctl status -a
Should give you info of what is configured where if it’s done using systemd.
Otherwise someone else might know how to query the NetworkManager configs, im not good with nmcli as i use systemd-networked…
TriMoon:
WARNING: systemd-networkd is not running, output will be incomplete.
Failed to query link bit rates: Unit dbus-org.freedesktop.network1.service not found.
Failed to query link DHCP leases: Unit dbus-org.freedesktop.network1.service not found.
● 1: lo
Link File: n/a
Network File: n/a
State: n/a (unmanaged)
Online state: unknown
Type: loopback
Hardware Address: 00:00:00:00:00:00
MTU: 65536
QDisc: noqueue
IPv6 Address Generation Mode: eui64
Number of Queues (Tx/Rx): 1/1
Address: 127.0.0.1
::1
● 2: eno1
Link File: /usr/lib/systemd/network/99-default.link
Network File: n/a
Type: ether
Path: pci-0000:00:19.0
Driver: e1000e
Vendor: Intel Corporation
Model: Ethernet Connection I217-LM
Alternative Names: enp0s25
Hardware Address: ec:b1:d7:44:58:e0 (Hewlett Packard)
MTU: 1500 (min: 68, max: 9000)
QDisc: fq_codel
IPv6 Address Generation Mode: none
Auto negotiation: yes
Speed: 100Mbps
Duplex: full
Port: tp
Address: 10.10.10.2
2603:3015:2003:7a80:5665:97ac:3912:cf4b
fe80::ae70:39c5:6443:72f3
Gateway: 10.10.10.1
fe80::ce40:d0ff:fe62:47fd
● 3: ipv6leakintrf0
Network File: n/a
Type: ether
Kind: dummy
Driver: dummy
Hardware Address: 76:62:2a:59:44:d5
MTU: 1500
QDisc: noqueue
Address: fdeb:446c:912d:8da::
fe80::ac82:d1e5:592a:67fa
Gateway: fdeb:446c:912d:8da::1
● 4: br-ae72ad30c8cc
Network File: n/a
Type: bridge
Kind: bridge
Driver: bridge
Hardware Address: 02:42:46:82:36:0a
MTU: 1500 (min: 68, max: 65535)
QDisc: noqueue
Forward Delay: 14.990s
Hello Time: 1.990s
Max Age: 19.990s
Ageing Time: 4min 59.990s
Priority: 32768
STP: no
Multicast IGMP Version: 2
Cost: 1999
Port State: disabled
Auto negotiation: no
Address: 172.18.0.1
● 5: docker0
Network File: n/a
Type: bridge
Kind: bridge
Driver: bridge
Hardware Address: 02:42:32:31:8c:c4
QDisc: noqueue
Hello Time: 1.990s
Max Age: 19.990s
Priority: 32768
STP: no
Cost: 1999
Address: 172.17.0.1
Ok so we can conclude that your interface are NOT configured using systemd-network,
Most likely either NetworkManager or manual configs via some script using ip etc…
Your eno1
johnblood:
Address: 10.10.10.2
johnblood:
Gateway: 10.10.10.1
Shows that your ethernet port is actually configured, although uses a non-public IP, mostly used by VM’s or example code…
No idea where it gets those…
Your ipv6leakintrf0 interface is only configured with IPv6 and has Gateway fdeb:446c:912d:8da::1
That in combination with:
Led to dig a bit on the internet: https://duckduckgo.com/?t=ffab&q=fdeb%3A446c%3A912d%3A8da%3A%3A1&ia=web
You might also want to try disable Docker also, so you will be left with a bare system with respect to networking…
Well, that fixed the problem. pvpn-ipv6leak-protection was the problem. After I deleted it, the internet worked again.
Thanks
system
Closed
6 August 2023 12:02
13
