Ethernet connection fails after reboot
Since today I have strange issues with my ethernet connection on Manjaro.
To make sure the issue was not on my connection side, I can confirm the network connects instantly and works well under Windows, but when I reboot on Manjaro it just fails and fails and so on… after rebooting a lot and restarting the router and deleting/recreating the connection in Network, in short insisting A LOT, then at some point it connects after a reboot or after failing a lot.
Here is my inxi:
[omano@omano-nvme ~]$ inxi -Fazy
  Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
  root=UUID=6a81f472-9ea9-40f8-85f6-7925c4bbe742 rw quiet splash apparmor=1
  Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM
  Distro: Manjaro Linux
  Type: Desktop System: Gigabyte product: B450M DS3H v: N/A serial: <filter>
  Mobo: Gigabyte model: B450M DS3H-CF v: x.x serial: <filter>
  UEFI: American Megatrends v: F51f date: 07/02/2020
  Topology: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
  family: 17 (23) model-id: 71 (113) stepping: N/A microcode: 8701021
  L2 cache: 3072 KiB
  bogomips: 86269
  Speed: 2053 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
  1: 2053 2: 2053 3: 2191 4: 2194 5: 3593 6: 2197 7: 2196 8: 2195 9: 2049
  10: 2053 11: 3594 12: 2196
  conditional, RSB filling
  Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: eVga.com.
  driver: nvidia v: 450.66 alternate: nouveau,nvidia_drm bus ID: 07:00.0
  chip ID: 10de:1c03
  Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: nvidia
  display ID: :0 screens: 1
  Screen-1: 0 s-res: 1680x1050 s-dpi: 87 s-size: 490x321mm (19.3x12.6")
  s-diag: 586mm (23.1")
  Monitor-1: DVI-D-0 res: 1680x1050 dpi: 87 size: 490x320mm (19.3x12.6")
  diag: 585mm (23")
  OpenGL: renderer: GeForce GTX 1060 6GB/PCIe/SSE2 v: 4.6.0 NVIDIA 450.66
  direct render: Yes
  Device-1: NVIDIA GP106 High Definition Audio vendor: eVga.com.
  driver: snd_hda_intel v: kernel bus ID: 07:00.1 chip ID: 10de:10f1
  Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
  driver: snd_hda_intel v: kernel bus ID: 09:00.4 chip ID: 1022:1487
  Sound Server: ALSA v: k5.8.11-1-MANJARO
  vendor: Gigabyte driver: r8169 v: kernel port: f000 bus ID: 05:00.0
  chip ID: 10ec:8168
  IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 2.03 TiB used: 436.87 GiB (21.0%)
  ID-1: /dev/nvme0n1 vendor: Crucial model: CT1000P1SSD8 size: 931.51 GiB
  block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
  serial: <filter> rev: P3CR020 scheme: GPT
  ID-2: /dev/sda vendor: SanDisk model: SSD PLUS 480GB size: 447.14 GiB
  block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
  rev: 00RL scheme: MBR
  ID-3: /dev/sdb vendor: Western Digital model: WD5001AALS-00E3A0
  size: 465.76 GiB block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
  serial: <filter> rev: 1D05 scheme: MBR
  ID-4: /dev/sdc vendor: SanDisk model: SDSSDHP256G size: 238.47 GiB
  rev: 6RL scheme: GPT
  ID-1: / raw size: 931.22 GiB size: 915.60 GiB (98.32%)
  used: 436.86 GiB (47.7%) fs: ext4 dev: /dev/nvme0n1p2
  System Temperatures: cpu: 54.2 C mobo: N/A gpu: nvidia temp: 49 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 8%
  Processes: 277 Uptime: 5m Memory: 15.65 GiB used: 1.88 GiB (12.0%)
  Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 10.0.1 Packages:
  pacman: 1403 lib: 382 flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole
  inxi: 3.1.05
So the issue is that the NetworkManager fails to connect to my router, with error popup saying (translated) Ethernet connection disabled followed instantly by the IP configuration was unavailable
I tried to disable NetworkManager and switch for DHCPCD but when it fails with NetworkManager, it also doesn’t work with DHCPCD. So I’m back with NetworkManager for now.
So right now I am connected it works good, like before, but for the next time, how would be the proper way to troubleshoot, what info would be relevant to look at, what logs and which specific keywords in these logs would be the best to try to find the issue?
If anyone can give some advices, I’m all ears because I’m lost currently and when it happens I’m just not fixing anything, I think it just works again by itself for unknown reason.
I kinda found a temporary way to fix my issue, but I found a post really similar to my issue here [Stable Update] 2020-08-28 - Kernels, Systemd, PAM, PAMBASE, KDE-git, Deepin, Pamac, Nvidia 450.66, LibreOffice 7.0
His issue mysteriously was there for a moment then it worked at some point after the non sense he tried like me.
I found what changed in the past week on my Manjaro, for a thread I replied to, I changed my DNS server in Network Manager, I had set cloud flare DNS servers, everything was working as expected for days.
The issue was not about the DNS server at all, BUT by manually setting the DNS server as 192.168.1.1 (the router IP address which was automatically set in theory with full AUTO in N.M.) then it connects properly, but here is the issue in log, like the guy above:
[omano@omano-nvme ~]$ journalctl -k -p err -b -1
-- Logs begin at Sun 2020-09-13 02:58:12 CEST, end at Fri 2020-09-25 21:35:51 CEST. --
sept. 25 16:32:56 omano-nvme kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
sept. 25 16:33:25 omano-nvme kernel: r8169 0000:05:00.0 enp5s0: rtl_rxtx_empty_cond == 0 (loop: 42, delay: 100).
sept. 25 16:35:12 omano-nvme kernel: r8169 0000:05:00.0 enp5s0: rtl_rxtx_empty_cond == 0 (loop: 42, delay: 100).
sept. 25 16:35:22 omano-nvme kernel: r8169 0000:05:00.0 enp5s0: rtl_rxtx_empty_cond == 0 (loop: 42, delay: 100).
sept. 25 16:36:28 omano-nvme kernel: r8169 0000:05:00.0 enp5s0: rtl_rxtx_empty_cond == 0 (loop: 42, delay: 100).
sept. 25 16:36:53 omano-nvme kernel: r8169 0000:05:00.0 enp5s0: rtl_rxtx_empty_cond == 0 (loop: 42, delay: 100).
sept. 25 16:37:28 omano-nvme kernel: r8169 0000:05:00.0 enp5s0: rtl_rxtx_empty_cond == 0 (loop: 42, delay: 100).
sept. 25 16:37:53 omano-nvme kernel: r8169 0000:05:00.0 enp5s0: rtl_rxtx_empty_cond == 0 (loop: 42, delay: 100).
sept. 25 16:38:28 omano-nvme kernel: r8169 0000:05:00.0 enp5s0: rtl_rxtx_empty_cond == 0 (loop: 42, delay: 100).
sept. 25 16:38:53 omano-nvme kernel: r8169 0000:05:00.0 enp5s0: rtl_rxtx_empty_cond == 0 (loop: 42, delay: 100).
sept. 25 16:39:22 omano-nvme kernel: r8169 0000:05:00.0 enp5s0: rtl_rxtx_empty_cond == 0 (loop: 42, delay: 100).
sept. 25 16:39:32 omano-nvme kernel: r8169 0000:05:00.0 enp5s0: rtl_rxtx_empty_cond == 0 (loop: 42, delay: 100).
sept. 25 16:40:57 omano-nvme kernel: r8169 0000:05:00.0 enp5s0: rtl_rxtx_empty_cond == 0 (loop: 42, delay: 100).
sept. 25 16:41:32 omano-nvme kernel: r8169 0000:05:00.0 enp5s0: rtl_rxtx_empty_cond == 0 (loop: 42, delay: 100).
sept. 25 16:42:59 omano-nvme kernel: r8169 0000:05:00.0 enp5s0: rtl_rxtx_empty_cond == 0 (loop: 42, delay: 100).
sept. 25 16:43:30 omano-nvme kernel: r8169 0000:05:00.0 enp5s0: rtl_rxtx_empty_cond == 0 (loop: 42, delay: 100).
sept. 25 16:43:55 omano-nvme kernel: r8169 0000:05:00.0 enp5s0: rtl_rxtx_empty_cond == 0 (loop: 42, delay: 100).
sept. 25 16:44:25 omano-nvme kernel: r8169 0000:05:00.0 enp5s0: rtl_rxtx_empty_cond == 0 (loop: 42, delay: 100).
sept. 25 16:45:30 omano-nvme kernel: r8169 0000:05:00.0 enp5s0: rtl_rxtx_empty_cond == 0 (loop: 42, delay: 100).
sept. 25 16:45:35 omano-nvme kernel: r8169 0000:05:00.0 enp5s0: rtl_rxtx_empty_cond == 0 (loop: 42, delay: 100).
sept. 25 16:45:55 omano-nvme kernel: r8169 0000:05:00.0 enp5s0: rtl_rxtx_empty_cond == 0 (loop: 42, delay: 100).
sept. 25 16:46:30 omano-nvme kernel: r8169 0000:05:00.0 enp5s0: rtl_rxtx_empty_cond == 0 (loop: 42, delay: 100).
sept. 25 16:46:55 omano-nvme kernel: r8169 0000:05:00.0 enp5s0: rtl_rxtx_empty_cond == 0 (loop: 42, delay: 100).
sept. 25 16:47:36 omano-nvme kernel: r8169 0000:05:00.0 enp5s0: rtl_rxtx_empty_cond == 0 (loop: 42, delay: 100).
sept. 25 16:47:46 omano-nvme kernel: r8169 0000:05:00.0 enp5s0: rtl_rxtx_empty_cond == 0 (loop: 42, delay: 100).
sept. 25 16:47:56 omano-nvme kernel: r8169 0000:05:00.0 enp5s0: rtl_rxtx_empty_cond == 0 (loop: 42, delay: 100).
sept. 25 16:48:25 omano-nvme kernel: r8169 0000:05:00.0 enp5s0: rtl_rxtx_empty_cond == 0 (loop: 42, delay: 100).
sept. 25 16:48:55 omano-nvme kernel: r8169 0000:05:00.0 enp5s0: rtl_rxtx_empty_cond == 0 (loop: 42, delay: 100).
sept. 25 16:49:29 omano-nvme kernel: r8169 0000:05:00.0 enp5s0: rtl_rxtx_empty_cond == 0 (loop: 42, delay: 100).
sept. 25 16:49:55 omano-nvme kernel: r8169 0000:05:00.0 enp5s0: rtl_rxtx_empty_cond == 0 (loop: 42, delay: 100).
sept. 25 16:50:30 omano-nvme kernel: r8169 0000:05:00.0 enp5s0: rtl_rxtx_empty_cond == 0 (loop: 42, delay: 100).
Here is journalctl:
journalctl -u NetworkManager.service -f
-- Logs begin at Sun 2020-09-13 02:58:12 CEST. --
sept. 25 16:46:07 omano-nvme NetworkManager[552]: <warn>  [1601045167.1097] dhcp4 (enp5s0): request timed out
sept. 25 16:46:07 omano-nvme NetworkManager[552]: <warn>  [1601045167.1111] device (enp5s0): Activation: failed for connection 'Connexion Ethernet'
sept. 25 16:46:52 omano-nvme NetworkManager[552]: <warn>  [1601045212.0987] dhcp4 (enp5s0): request timed out
sept. 25 16:46:52 omano-nvme NetworkManager[552]: <warn>  [1601045212.0999] device (enp5s0): Activation: failed for connection 'Connexion Ethernet'
sept. 25 16:48:09 omano-nvme NetworkManager[552]: <warn>  [1601045289.1080] dhcp4 (enp5s0): request timed out
sept. 25 16:48:09 omano-nvme NetworkManager[552]: <warn>  [1601045289.1092] device (enp5s0): Activation: failed for connection 'Connexion Ethernet'
sept. 25 16:48:57 omano-nvme NetworkManager[552]: <warn>  [1601045337.1083] dhcp4 (enp5s0): request timed out
sept. 25 16:48:57 omano-nvme NetworkManager[552]: <warn>  [1601045337.1094] device (enp5s0): Activation: failed for connection 'Connexion Ethernet'
sept. 25 16:49:42 omano-nvme NetworkManager[552]: <warn>  [1601045382.1064] dhcp4 (enp5s0): request timed out
sept. 25 16:49:42 omano-nvme NetworkManager[552]: <warn>  [1601045382.1079] device (enp5s0): Activation: failed for connection 'Connexion Ethernet'
For now I can have proper connection by forcing the DNS server. That doesn’t make sense to me but OK, problem kinda fixed I guess.
// EDIT: it actually was just pure ‘luck’ or ‘mystery’, in the end nothing was fixed.
new magical fix/band-aid/nothing: I enabled IPV6 in my router (but still disabled in NetworkManager) as a last resort for the sake of trying, and it seems to work… I did that because an old TimeShift backup also has the issue now so it seems to be external to Manjaro now… :man_facepalming: :sweat_smile:
Spoiler from future still not fixed it was just another fluke
I reinstalled the network drivers through System Settings it seems to work so far…
inxi before:
  chip ID: 10ec:8168
inxi now:
  vendor: Gigabyte driver: r8168 v: 8.048.03-NAPI modules: r8169 port: f000
  bus ID: 05:00.0 chip ID: 10ec:8168
  IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
