A week has gone by¹⁾ since I first tried to add an update to this topic. (And I fear it will be a few additional hours before I can klick the Reply button under this editing window.)
¹) That was when I was forced to reboot the desktop after ~7 weeks due to considerable performance degradation. (That typically happens when firefox has eaten too much memory and a major update is pending. The latter is not shown by the “Pamac Updates Indictor” (it turns red only after the reboot and pamac itself says that the system is up-to-date.))
News that showed up after the reboot and 2GB-update:
The GitLab page @linux-aarhus referred to shows a new design with accessible source download options. Maybe I accessed that page some time before during its update process and got an intermediate stage which firefox had cached.
Both systems (desktop and laptop) showed the same Gnome version (48.1), so the topic’s title contains a misconception on my side in that it’s not the Gnome version that causes the different behavior of these systems but something I have not yet been able to identify.
Meanwhile I’ve once more been forced to endure a 2nd reboot of the desktop and both systems run now Gnome 48.2 but behave even more differently.
The laptop has forfeited its usability by the last update due to display problems: ~ 1½ secs after opening a sub-window (e.g. a dialog) this receives a checkered overlay(?), making e.g. any text unreadable and increases with every move of that window and damaging the parent window likewise subsequently.
The original idea was to get an absolutely fresh install on the laptop - without any garbage that might have accrued on the desktop over 4-5 years (its current age + that of the installation on predecessor of the laptop from which I cloned its install ~ 2 years ago.²⁾ … and, of course, without the two dysfunctionalities ³⁾ …
… and to configure the UI like it works on the desktop up to the point that I have a second usable system. ⁴⁾
Then to complete that with all the applications and their data and finally to clone this back to the desktop.
³) indeed not seen on the new install
⁴) I’m apparently not able to configure the install of the currently available iso-download accordingly (and I don’t find an older one as a starting point for a more configurable version)
²) Unfortunately I’ve forgotten how I achieved that cloning exactly. The procedure started with dd-ing it to an external drive, looking whether that would boot (and it did) and dd-ing that to the internal “drive” of the desktop. Now it resides @ the 1 TB NVME and so I cannot clone it completely to the ½ TB NVME of the laptop.
As for the inability to configure the fresh install (which has been damaged during last Tuesday’s update, anyway, I have first and foremost been looking for differences that might cause the different behavior. So I again include a (more recent) inxi output of the two systems:
Desktop (working):
~ sudo inxi -zv8 ✔
Kernel: 6.6.94-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=d25d1a9b-c6a7-48d7-a710-98f6ca1bb234 rw quiet splash
udev.log_priority=3
Desktop: GNOME v: 48.2 tk: GTK v: 3.24.49 wm: gnome-shell
base: Arch Linux
Type: Desktop System: FUJITSU product: ESPRIMO D538 v: N/A serial: <filter>
Chassis: type: 3 serial: <filter>
Mobo: FUJITSU model: D3600-A1 v: S26361-D3600-A1 serial: <filter>
uuid: 6f8988e7-b758-11e9-93e8-4c5262a25182 UEFI: FUJITSU // American
Megatrends v: 5.0.0.13 R1.21.0 for D3600-A1x date: 07/04/2019
System RAM: total: 32 GiB available: 30.2 GiB used: 14.41 GiB (47.7%)
igpu: 1024 MiB
Array-1: capacity: 64 GiB slots: 4 modules: 2 EC: None
Device-1: DIMM CHA1 type: DDR4 detail: synchronous size: 16 GiB speed:
spec: 3200 MT/s actual: 2400 MT/s volts: curr: 1.2 width (bits): data: 64
total: 64 manufacturer: Crucial part-no: CP16G4DFRA32A.C8FF
serial: <filter>
Device-2: DIMM CHB2 type: DDR4 detail: synchronous size: 16 GiB speed:
spec: 3200 MT/s actual: 2400 MT/s volts: curr: 1.2 min: 1.2 max: 1.2
width (bits): data: 64 total: 64 manufacturer: Crucial
part-no: CP16G4DFRA32A.C8FF serial: <filter>
Slot: 0 type: PCIe status: available length: short volts: 3.3
bus-ID: 00:1c.6
Slot: 1 type: PCIe status: unknown length: long volts: 3.3 bus-ID: ff:1c.5
Slot: 2 type: PCIe status: unknown length: long volts: 3.3 bus-ID: ff:01.0
Info: model: Intel Pentium Gold G5600 socket: LGA1151 bits: 64 type: MT MCP
arch: Coffee Lake level: v2 built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xB (11) microcode: 0xF6
Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
desc: 2x256 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1300 min/max: 800/3900 base/boost: 3861/8300 scaling:
driver: intel_pstate governor: powersave volts: 1.0 V ext-clock: 100 MHz
cores: 1: 1300 2: 1300 3: 1300 4: 1300 bogomips: 31211
Flags: 3dnowprefetch abm acpi aes aperfmperf apic arat arch_capabilities
arch_perfmon art bts clflush clflushopt cmov constant_tsc cpuid
flexpriority flush_l1d fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp
hwp_notify ibpb ibrs intel_pt invpcid lahf_lm lm mca mce md_clear mmx
monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed
rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
Type: spectre_v2 mitigation: IBRS; IBPB: disabled; STIBP: disabled; RSB
filling; PBRSB-eIBRS: Not affected; BHI: Not affected
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630]
vendor: Fujitsu Solutions driver: i915 v: kernel arch: Gen-9.5
process: Intel 14nm built: 2016-20 ports: active: HDMI-A-1,HDMI-A-2
empty: DP-1, DP-2, DP-3, HDMI-A-3 bus-ID: 00:02.0 chip-ID: 8086:3e91
class-ID: 0300
Display: unspecified server: X.org v: 1.21.1.18 with: Xwayland v: 24.1.8
compositor: gnome-shell driver: gpu: i915 display-ID: :0
note: <missing: xdpyinfo/xrandr>
Monitor-1: HDMI-A-1 model: Samsung S27D390 serial: <filter> built: 2015
res: 1920x1080 dpi: 82 gamma: 1.2 chroma: red: x: 0.647 y: 0.337 green:
x: 0.329 y: 0.616 blue: x: 0.145 y: 0.055 white: x: 0.314 y: 0.329
size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9
modes: 1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800,
1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576, 720x480,
640x480, 720x400
Monitor-2: HDMI-A-2 model: HS156PC built: 2021 res: 1920x1080 dpi: 163
gamma: 1.2 chroma: red: x: 0.639 y: 0.329 green: x: 0.298 y: 0.600 blue:
x: 0.149 y: 0.059 white: x: 0.314 y: 0.329 size: 345x194mm (13.58x7.64")
diag: 397mm (15.6") ratio: 5:4 modes: 1920x1080, 1600x900, 1280x1024,
1152x864, 1280x720, 1024x768, 800x600, 640x480
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.1.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) device-ID: 8086:3e91 memory: 29.5 GiB unified: yes
Info: Tools: api: eglinfo,glxinfo x11: xprop
Device-1: Intel Cannon Lake PCH cAVS vendor: Fujitsu Solutions
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
API: ALSA v: k6.6.94-1-MANJARO status: kernel-api tools: N/A
Server-2: PipeWire v: 1.4.5 status: n/a (root, process) with: wireplumber
status: active tools: pw-cat,pw-cli,wpctl
Server-3: PulseAudio v: 17.0-43-g3e2bb status: active (root, process)
with: pulseaudio-alsa type: plugin tools: pacat,pactl
vendor: Fujitsu Solutions driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8188FTV 802.11b/g/n 1T1R 2.4G WLAN Adapter
driver: rtl8xxxu type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 1-8:4 chip-ID: 0bda:f179 class-ID: 0000 serial: <filter>
IF: wlp0s20f0u8 state: down mac: <filter>
Local Storage: total: 3.7 TiB used: 240.2 GiB (6.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P3SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR30A temp: 32.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD20EFRX-68EUZN0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
fw-rev: 0A82 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: Expansion
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter>
fw-rev: 9300 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: SanDisk model: Ultra Fit
size: 57.84 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 1.00 scheme: MBR
ID-1: / raw-size: 93.13 GiB size: 91.11 GiB (97.83%) used: 27.58 GiB (30.3%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p3 maj-min: 259:3
label: cme1t.manjaro_g uuid: d25d1a9b-c6a7-48d7-a710-98f6ca1bb234
ID-2: /boot/efi raw-size: 954 MiB size: 952.1 MiB (99.80%)
used: 5.5 MiB (0.6%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: CME1T_EFI uuid: 4A16-8340
ID-3: /home raw-size: 93.13 GiB size: 91.11 GiB (97.83%)
used: 1.21 GiB (1.3%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p5
maj-min: 259:5 label: cme1t.mg_home
uuid: 98bd367d-22a4-4028-906e-2f5ae44f1f17
ID-4: /mnt/data raw-size: 372.72 GiB size: 365.81 GiB (98.15%)
used: 162.04 GiB (44.3%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p7
maj-min: 259:7 label: cme1t.data
uuid: 75b32bf9-4850-4499-94d6-cb737cc173d9
ID-5: /run/media/backup raw-size: 1024 KiB size: 984 KiB (96.09%)
used: 14 KiB (1.4%) fs: ext4 block-size: 1024 B dev: /dev/sda3 maj-min: 8:3
label: wd2t.dummy uuid: 1d8df0e9-6028-42e1-8c69-da2e78aba055
ID-6: /run/media/tn/Transporter raw-size: 57.84 GiB
size: 56.63 GiB (97.91%) used: 43.18 GiB (76.2%) fs: ext4 block-size: 4096 B
dev: /dev/sdc1 maj-min: 8:33 label: Transporter
uuid: 6b52de8e-1520-4301-baa8-263317452d48
ID-1: swap-1 type: partition size: 36.32 GiB used: 6.19 GiB (17.0%)
priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 8a3d6405-5b6b-4989-9631-0d94e08239f5
ID-1: /dev/nvme0n1p4 maj-min: 259:4 size: 93.13 GiB fs: ext4
label: cme1t.ubuntu_g uuid: 216e4cc0-56ac-42e4-b551-b3e3e2b2b3f6
ID-2: /dev/nvme0n1p6 maj-min: 259:6 size: 93.13 GiB fs: ext4
label: cme1t.ug_home uuid: eeb3cc1a-506a-4deb-b32c-8a384016e1a5
ID-3: /dev/nvme0n1p8 maj-min: 259:8 size: 18.63 GiB fs: ext4
label: cme1t.mg_test uuid: db10dd45-b09e-4aa9-8e5a-c9169aad751d
ID-4: /dev/nvme0n1p9 maj-min: 259:9 size: 18.63 GiB fs: ext4
label: cme1t.mgt_home uuid: 3f28027a-6fc9-4a3e-9e23-38c4bbdae08c
ID-5: /dev/sda1 maj-min: 8:1 size: 186.26 GiB fs: ext4 label: wd2t.ts4ct3
uuid: 46399e9f-c924-418b-b49e-fd610ab96b4f
ID-6: /dev/sda2 maj-min: 8:2 size: 372.9 GiB fs: ext4 label: wd2t.backup
uuid: d13f645b-d2ee-4af6-9ae7-ed84a4355e2e
ID-7: /dev/sda5 maj-min: 8:5 size: 558.79 GiB fs: ext4 label: wd2t.bkp.old
uuid: 0ccc4358-5553-49be-a2d5-62fcce9e24d9
ID-8: /dev/sdb1 maj-min: 8:17 size: 954 MiB fs: vfat label: ST1T_EFI
uuid: 471A-2489
ID-9: /dev/sdb2 maj-min: 8:18 size: 93.13 GiB fs: ext4
label: st1t.Manjaro_Kde uuid: 4f75c403-57c4-47f4-bb0d-381143b805ee
ID-10: /dev/sdb3 maj-min: 8:19 size: 93.13 GiB fs: ext4
label: st1t.MK_home uuid: e84290bd-f4e9-46a5-9cc0-6b5054e992b1
ID-11: /dev/sdb4 maj-min: 8:20 size: 93.13 GiB fs: ext4
label: st1t.Manjaro_Gnm uuid: 4a7ab03a-dd23-4ba6-80f5-c491e68a10c0
ID-12: /dev/sdb5 maj-min: 8:21 size: 93.13 GiB fs: ext4
label: st1t.MG_home uuid: 3ed7641d-0a80-4baa-8967-86a3435cbe4d
ID-13: /dev/sdb6 maj-min: 8:22 size: 279.4 GiB fs: ext4 label: st1t.data
uuid: cba80c7b-7a8c-4b98-bd2b-8f895a4c2ed2
ID-14: /dev/sdb7 maj-min: 8:23 size: 278.66 GiB fs: ext4 label: st1t.bkp
uuid: 811bccd1-86eb-45b0-b2be-4cfbcb1fff96
Device-1: 1-5:6 info: YICHIP Wireless Device type: keyboard,mouse
lanes: 1 mode: 1.1 power: 100mA chip-ID: 3151:1001 class-ID: 0301
Hub-2: 1-7:3 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 1-7.1:7 info: SHARKOON GmbH [Mediatrack Edge Mini Keyboard]
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
chip-ID: 1ea7:0066 class-ID: 0301
Device-2: 1-7.2:8 info: Seagate RSS LLC SRD0NF1 Expansion Portable (STEA)
type: mass storage driver: uas interfaces: 1 rev: 2.1
chip-ID: 0bc2:2322 class-ID: 0806 serial: <filter>
Device-3: 1-8:4 info: Realtek RTL8188FTV 802.11b/g/n 1T1R 2.4G WLAN
Adapter type: Network driver: rtl8xxxu interfaces: 1 rev: 2.0
Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
Device-1: 2-4:2 info: SanDisk Ultra Fit type: mass storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 0781:5583 class-ID: 0806
serial: <filter>
System Temperatures: cpu: 49.0 C pch: 52.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 1474 libs: 399
tools: gnome-software,pamac
1: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
2: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
3: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
4: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
5: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
6: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
7: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
8: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 288
1: cpu: 100% command: ps pid: 177906 mem: 4.15 MiB (0.0%)
2: cpu: 13.8% command: firefox pid: 3558 mem: 1568.4 MiB (5.0%)
3: cpu: 13.5% command: gnome-shell pid: 1220 mem: 733.6 MiB (2.3%)
4: cpu: 7.4% command: firefox pid: 4146 mem: 262.8 MiB (0.8%)
5: cpu: 4.9% command: firefox pid: 3948 mem: 958.6 MiB (3.0%)
Memory top: 5 of 288
1: mem: 1568.4 MiB (5.0%) command: firefox pid: 3558 cpu: 13.8%
2: mem: 958.6 MiB (3.0%) command: firefox pid: 3948 cpu: 4.9%
3: mem: 733.6 MiB (2.3%) command: gnome-shell pid: 1220 cpu: 13.5%
4: mem: 548.4 MiB (1.7%) command: thunderbird pid: 16839 cpu: 0.4%
5: mem: 442.5 MiB (1.4%) command: Telegram pid: 3305 cpu: 0.1%
Processes: 288 Power: uptime: 1d 26m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 12.07 GiB services: gsd-power,upowerd
Compilers: clang: 20.1.6 gcc: 15.1.1 Shell: Sudo (sudo) v: 1.9.16p2
default: Bash v: 5.2.37 running-in: gnome-terminal inxi: 3.3.38
~ ✔ 18s
Laptop (damaged on Tuesday, no dysfunctionality before, see post #3 for corresponding inxi output):
~ sudo inxi -zv8 ✔
Kernel: 6.12.34-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=d8f4af35-596a-4d92-a4be-d75c3c8de81f rw quiet splash apparmor=1
base: Arch Linux
Type: Laptop System: FUJITSU product: CELSIUS H780 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: FUJITSU model: FJNBB5D v: 757383-01R9500225 serial: <filter>
part-nu: SK00 uuid: a41a3b37-7475-e911-8b14-a06610a7488b
UEFI: FUJITSU // Insyde v: Version 1.22 date: 11/16/2023
ID-1: BAT1 charge: 84.1 Wh (100.0%) condition: 84.1/96.5 Wh (87.2%)
volts: 16.6 min: 14.4 model: PAC CP722160-01 type: Li-ion serial: <filter>
status: full cycles: 20
System RAM: total: 32 GiB available: 31 GiB used: 1.82 GiB (5.9%)
igpu: 64 MiB
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 16 GiB
speed: 2400 MT/s volts: curr: 1.2 min: 1.35 max: 1.35 width (bits): data: 64
total: 64 manufacturer: SK Hynix part-no: HMA82GS6AFR8N-UH
serial: <filter>
Device-2: ChannelA-DIMM1 type: no module installed
Device-3: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 16 GiB
serial: <filter>
Device-4: ChannelB-DIMM1 type: no module installed
Message: No PCI Slot data found.
Info: model: Intel Core i7-8750H socket: BGA1440 bits: 64 type: MT MCP
arch: Coffee Lake gen: core 8 level: v3 note: check built: 2018
process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 0xA (10)
microcode: 0xFA
Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
desc: 6x256 KiB L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 800 min/max: 800/4100 scaling: driver: intel_pstate
governor: powersave volts: 0.8 V ext-clock: 100 MHz cores: 1: 800 2: 800
3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
bogomips: 52815
smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
vulnerable
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Fujitsu
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
class-ID: 0300
Device-2: NVIDIA GP107GLM [Quadro P600 Mobile] vendor: Fujitsu
driver: nouveau v: kernel non-free: 550-570.xx+ status: current (as of
2025-04; EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s ports: active: none empty: DP-1, DP-2, DP-3, DP-4, DP-5
bus-ID: 01:00.0 chip-ID: 10de:1cbc class-ID: 0300 temp: 40.0 C
Device-3: Chicony FJ Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:4 chip-ID: 04f2:b3b4
Monitor-1: eDP-1 model: BOE Display 0x0630 built: 2016 res: 1920x1080
dpi: 142 gamma: 1.2 chroma: red: x: 0.584 y: 0.365 green: x: 0.349 y: 0.580
blue: x: 0.161 y: 0.141 white: x: 0.314 y: 0.329
size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
modes: 1920x1080
API: EGL v: 1.5 hw: drv: intel iris drv: nvidia nouveau platforms:
device: 0 drv: nouveau device: 1 drv: iris device: 2 drv: swrast gbm:
drv: nouveau surfaceless: drv: nouveau x11: drv: iris inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.3 vendor: intel mesa v: 25.1.4-arch1.1
GT2) device-ID: 8086:3e9b memory: 30.27 GiB unified: yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Fujitsu driver: snd_hda_intel
v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
Device-2: NVIDIA GP107GL High Definition Audio vendor: Fujitsu
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fb9
class-ID: 0403
API: ALSA v: k6.12.34-1-MANJARO status: kernel-api with: aoss
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
Device-2: Intel Ethernet I219-LM vendor: Fujitsu driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bb class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: wwp0s20f0u4i12 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5
Local Storage: total: 476.94 GiB used: 23.42 GiB (4.9%)
model: MZVLB512HAJQ-00007 size: 476.94 GiB block-size: physical: 512 B
fw-rev: EXA7302Q temp: 31.9 C scheme: GPT
ID-1: / raw-size: 46.57 GiB size: 45.53 GiB (97.78%) used: 15.38 GiB (33.8%)
label: sme_5.ManjaroGnm uuid: d8f4af35-596a-4d92-a4be-d75c3c8de81f
ID-2: /bkp raw-size: 149.01 GiB size: 145.61 GiB (97.72%)
used: 2 MiB (0.0%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p7
maj-min: 259:7 label: sme_5.bkp uuid: c36ae656-eb75-4218-8828-26090d9b1dec
ID-3: /boot/efi raw-size: 477 MiB size: 476 MiB (99.80%)
used: 432 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: SME_5_EFI uuid: 407C-EF8F
ID-4: /data raw-size: 149.01 GiB size: 145.61 GiB (97.72%)
used: 6.02 GiB (4.1%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p6
maj-min: 259:6 label: sme_5.data
uuid: fae9353f-dda4-4b69-9f6e-5179fa11200c
ID-5: /home raw-size: 9.31 GiB size: 9.08 GiB (97.54%)
used: 2.02 GiB (22.2%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p5
maj-min: 259:5 label: sme_5.MG_home
uuid: 712c9ed3-f03d-4a27-8dec-1d3cbaa0c0da
ID-1: swap-1 type: partition size: 20.12 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p8 maj-min: 259:8 label: sme_5.swap
uuid: 136dda25-3200-4c4d-8cd7-dce0de17bdd8
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 46.57 GiB fs: ext4
label: sme_5.ManjaroKDE uuid: 25f5f5ad-49fe-495c-861f-513c2bb77042
ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 9.31 GiB fs: ext4
label: sme_5.MK_home uuid: 2f771f65-7d0a-4dc7-9b37-decd655d959f
Device-1: 1-3:2 info: Areson Corp Elecom MR-K013 Multicard Reader
chip-ID: 25a7:fa61 class-ID: 0301
Device-2: 1-4:3 info: Sierra Wireless EM7455 type: communication,CDC-data
driver: cdc_mbim interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 1199:9075 class-ID: 0a00
serial: <filter>
Device-3: 1-7:4 info: Chicony FJ Camera type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 04f2:b3b4 class-ID: 0e02 serial: <filter>
Device-4: 1-14:5 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 10 rev: 3.1
System Temperatures: cpu: 42.0 C pch: 50.0 C mobo: N/A gpu: nouveau
temp: 40.0 C
Packages: pm: pacman pkgs: 1322 libs: 341 tools: gnome-software,pamac
pm: flatpak pkgs: 0
1: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
2: https://mirror.easyname.at/manjaro/stable/$repo/$arch
3: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
4: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
5: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
6: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
8: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 305
1: cpu: 600% command: ps pid: 4456 mem: 3.95 MiB (0.0%)
2: cpu: 137% command: mutter-x11-frames pid: 4437 mem: 117.5 MiB (0.3%)
3: cpu: 74.5% command: gsd-xsettings pid: 4425 mem: 135.5 MiB (0.4%)
4: cpu: 45.4% command: ibus-x11 pid: 4447 mem: 12.0 MiB (0.0%)
5: cpu: 18.2% command: Xwayland pid: 4417 mem: 136.5 MiB (0.4%)
Memory top: 5 of 305
1: mem: 339.5 MiB (1.0%) command: gnome-shell pid: 1563 cpu: 11.5%
2: mem: 136.5 MiB (0.4%) command: Xwayland pid: 4417 cpu: 18.2%
3: mem: 135.5 MiB (0.4%) command: gsd-xsettings pid: 4425 cpu: 74.5%
4: mem: 117.5 MiB (0.3%) command: mutter-x11-frames pid: 4437 cpu: 137%
5: mem: 97.3 MiB (0.3%) command: gjs pid: 2153 cpu: 0.4%
Processes: 305 Power: uptime: 19m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.37 GiB services: gsd-power,
tool: systemctl
Compilers: gcc: 15.1.1 Shell: Sudo (sudo) v: 1.9.16p2 default: Bash
~ ✔ 19s
