Good morning, evening & afternoon,
I hope you are well.
I’ve recently moved from Express VPN to MozillaVPN. Works great on my phone.
But for the life of me, I cannot get it to work.
I’ve tried building it from AUR repo and compiling the source from Github. Both result in the same errors.
I’ve tried running it as sudo and my normal user.
It appears to install with no errors just like any other package I compile from AUR.
I’ve attempted to install the missing “kvantum” and every time it says its successful? My guess is Kvantum needs to be QT6 and I can only find 5? But that’s my only guess.
I can load up Kvantum Manager fine? It shows the GUI. (no idea what it is except a theme manager) but I can’t start kvantum from the terminal. I just get command not found.
Any ideas?
thank you!
~/Dow/mozillavpn master ?1 mozillavpn ✔ 3m 45s
[26.04.2022 22:11:19.119] Info: (main - Command) MozillaVPN 2.8.0
[26.04.2022 22:11:19.119] Info: (main - Command) User-Agent: MozillaVPN/2.8.0 (sys:manjaro unknown)
[26.04.2022 22:11:19.240] Error: (main - EventListener) Connection failed.
[26.04.2022 22:11:19.268] Info: (networking - NetworkRequest) Imported cert from: ISRG Root X1
[26.04.2022 22:11:19.280] Warning: QQmlApplicationEngine failed to load component
[26.04.2022 22:11:19.280] Warning: qrc:/ui/main.qml: module "kvantum" is not installed (main.qml)
zsh: segmentation fault (core dumped) mozillavpn
Edit 1:
Tried running it with an argument of linuxdaemon and got a different error.
~ sudo mozillavpn linuxdaemon 1 ✘
[26.04.2022 23:20:09.524] Info: (main - Command) MozillaVPN 2.8.0
[26.04.2022 23:20:09.524] Info: (main - Command) User-Agent: MozillaVPN/2.8.0 (sys:manjaro unknown)
[26.04.2022 23:20:09.527] Error: (linux - main) Connection failed - name: message:
Edit 2:
Using the mozillavpn docs, I did manage to figured out how to authenticate myself by using the command
~ mozillavpn login SEGV ✘
[27.04.2022 07:57:53.007] Info: (main - Command) MozillaVPN 2.8.0
[27.04.2022 07:57:53.007] Info: (main - Command) User-Agent: MozillaVPN/2.8.0 (sys:manjaro unknown)
User status: already authenticated
But now I get another error if I try activating:
mozillavpn activate 1 ✘
[27.04.2022 07:58:16.289] Info: (main - Command) MozillaVPN 2.8.0
[27.04.2022 07:58:16.289] Info: (main - Command) User-Agent: MozillaVPN/2.8.0 (sys:manjaro unknown)
[27.04.2022 07:58:16.425] Error: (linux|controller - LinuxController) DBus service says: error.
[27.04.2022 07:58:16.425] Error: (main - MozillaVPN) Alert: MozillaVPN::ControllerErrorAlertState: MozillaVPN::StateInitialize
The VPN tunnel activation failed
Edit 3:
Got some new errors. Tried stopping the service, and starting it in sudo and running mozillavpn in sudo which gives me “not activated”. So I reactivated in sudo, it wouldn’t even open the browser. So I manually did it. But now it gives me:
~ sudo mozillavpn ✔
[27.04.2022 08:08:09.163] Info: (main - Command) MozillaVPN 2.8.0
[27.04.2022 08:08:09.163] Info: (main - Command) User-Agent: MozillaVPN/2.8.0 (sys:manjaro unknown)
[27.04.2022 08:08:09.170] Warning: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
[27.04.2022 08:08:09.185] Error: (main - EventListener) Connection failed.
[27.04.2022 08:08:09.220] Info: (networking - NetworkRequest) Imported cert from: ISRG Root X1
[27.04.2022 08:08:09.221] Error: (main - MozillaVPN) No keys found
[27.04.2022 08:08:09.239] Warning: QQmlApplicationEngine failed to load component
[27.04.2022 08:08:09.239] Warning: qrc:/ui/main.qml: module "kvantum" is not installed (main.qml)
zsh: segmentation fault sudo mozillavpn
And the status turns into:
Apr 27 08:00:57 user-allseries systemd[1]: Started MozillaVPN D-Bus service.
Apr 27 08:05:04 user-allseries mozillavpn[19050]: [27.04.2022 08:05:04.406] Error: (linux - IPUtilsLinux) Failed to set IPv6: XXXXXXXX error: Permission denied
Apr 27 08:05:04 user-allseries mozillavpn[19050]: [27.04.2022 08:05:04.406] Error: (linux - DnsUtilsLinux) Error received from the DBus service
Apr 27 08:05:04 user-allseries mozillavpn[19050]: [27.04.2022 08:05:04.406] Error: (linux - DnsUtilsLinux) Error retrieving the DNS domains from the DBus service
