Errors Every Time After Update System
Every time i update system because required by manjaro, few stuff not working, and the last example its with OBS, before minutes i write this issue i update manjaro then restart then OBS not working any more
i reinstall (ofc i lose all my configs) but still not working
uname -a
Linux 5.18.19-3-MANJARO #1 SMP PREEMPT_DYNAMIC Tue Aug 23 15:56:13 UTC 2022 x86_64 GNU/Linux
any idea to fixe plz ?? hop to avoid issues after every update
Do you reboot after updating?
of course and neovim too not working
Error detected while processing /home/kamal/.config/nvim/init.lua:
E5113: Error while calling lua chunk: ...e/pack/packer/start/gitsigns.nvim/lua/gitsigns/async.lua:67: The coroutine failed with this message: Vim:E5248: Invalid character
 in group name
Please help us help you. See:
Cannot understand you ??
i post second comment just to show many stuff crashed after, but it s ok,i hop to found how can i fixe obs issue, thank u for help
What don’t you understand?
If you want anyone to understand you, please refer to the links I posted above. Using proper spelling, grammar and punctuation shows respect for those you ask help from.
If English is not your first language, you may post in our Languages section in your native language if that’s easier for you.
Even a long time user may forget what can cause a system update to cause issues.
That kernel is EOL and updating might cause problems down the road. Switch to a supported stable or possibly LTS kernel, see:
