It appeared the update in the programs app, but finished with error, here i share the image of the error in the update app…and also the final part of the log:
9551 verbose type range
9552 verbose stack minimist: No matching version found for minimist@^1.2.6.
9552 verbose stack at module.exports (/usr/lib/node_modules/npm/node_modules/npm-pick-manifest/lib/index.js:209:23)
9552 verbose stack at /usr/lib/node_modules/npm/node_modules/pacote/lib/registry.js:126:26
9552 verbose stack at async Arborist.[nodeFromEdge] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:1081:19)
9552 verbose stack at async Arborist.[buildDepStep] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:950:11)
9552 verbose stack at async Arborist.buildIdealTree (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:216:7)
9552 verbose stack at async Promise.all (index 1)
9552 verbose stack at async Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:153:5)
9552 verbose stack at async Install.exec (/usr/lib/node_modules/npm/lib/commands/install.js:156:5)
9552 verbose stack at async module.exports (/usr/lib/node_modules/npm/lib/cli.js:66:5)
9553 verbose cwd /var/tmp/pamac-build-solidcapo/ferdi/src/ferdi-5.8.1/build
9554 verbose Linux 5.10.105-1-MANJARO
9555 verbose argv “/usr/bin/node” “/usr/bin/npm” “install” “–production” “–prefer-offline”
9556 verbose node v16.13.2
9557 verbose npm v8.5.4
9558 error code ETARGET
9559 error notarget No matching version found for minimist@^1.2.6.
9560 error notarget In most cases you or one of your dependencies are requesting
9560 error notarget a package version that doesn’t exist.
9561 verbose exit 1
9562 timing npm Completed in 13231ms
9563 verbose unfinished npm timer reify 1648611245444
9564 verbose unfinished npm timer reify:loadTrees 1648611245450
9565 verbose code 1
9566 error A complete log of this run can be found in:
9566 error /home/solidcapo/.npm/_logs/2022-03-30T03_34_05_278Z-debug-0.log
Awesome! it took a while, don’t know exactly what that did, but solved the problem! thankyou
And thanks to @andreas85 and @Mirdarthos , but the solution of using the manjaron app updater it’s easier for me cause i’m a newbie and not a programer, what i saw is that all of you knew the problem was Ferdi, cause i updated first and only chrome and it worked fine, an with the solution of @ishaanbhimwal was solved, thanks again to all i’m happy to be able to ask for help and get solutions this fast!
Download it and mark it as executeable. Right-click on it, go to Properties, go to the Permissions tab, and select the Is executeable checkbox. Apply and/or OK Everything and then run it as usual.
Select to integrate it and everything should be automagic from then.
