Error when mounting raid
I recently tried to install manjaro on a raid with architect. I could configure the raid, failed when mounting. I tested it in virtualbox.
Yeah it can’t be found because it has other names:
ls /dev/md*
/dev/md126  /dev/md127
/dev/md:
boot  root
Seems to be an easy bug, but don’t know if it reported already.
Update
Seems to be something wrong on this line:
https://gitlab.manjaro.org/applications/manjaro-architect/-/blob/master/lib/util-disk.sh#L146
Thank you for reporting. @cscs do you want to take a look at this?
I am not super familiar with raid.
Have its functions changed in recent versions ?
That is - is the /dev/md/${i} deprecated in favor of /dev/${i} ?
or do we need to make provisions for both cases ?
To be more precise:
When i setup the raid, then i typed the name boot for the first partition /dev/md127 and root for the second partition /dev/md126. The names don’t get recognized. if i write nothing, same problem also. Not able to mount. But if i write the name md127 for /dev/md127 and md126 for /dev/md126, then it worked.
The script can’t detect the current names.
I would solve it myself but i am not familiar with awk.
