Tried the command you gave me, the output is cut off and I have tried to provide what I could get:
grub-install: info: adding a relocation entry for 0x972c.
grub-install: info: adding a relocation entry for 0x974a.
grub-install: info: adding a relocation entry for 0x9757.
grub-install: info: adding a relocation entry for 0x976c.
grub-install: info: adding a relocation entry for 0x977d.
grub-install: info: adding a relocation entry for 0x978e.
grub-install: info: adding a relocation entry for 0x9798.
grub-install: info: adding a relocation entry for 0x97af.
grub-install: info: adding a relocation entry for 0x97bf.
grub-install: info: adding a relocation entry for 0x97cf.
grub-install: info: adding a relocation entry for 0x97df.
grub-install: info: adding a relocation entry for 0x97ef.
grub-install: info: adding a relocation entry for 0x97fc.
grub-install: info: adding a relocation entry for 0x981e.
grub-install: info: adding a relocation entry for 0x9828.
grub-install: info: adding a relocation entry for 0x983b.
grub-install: info: adding a relocation entry for 0x984d.
grub-install: info: adding a relocation entry for 0x985c.
grub-install: info: adding a relocation entry for 0x9866.
grub-install: info: adding a relocation entry for 0x9872.
grub-install: info: adding a relocation entry for 0x987c.
grub-install: info: adding a relocation entry for 0x988d.
grub-install: info: adding a relocation entry for 0x9899.
grub-install: info: adding a relocation entry for 0x98a9.
grub-install: info: adding a relocation entry for 0x98b8.
grub-install: info: adding a relocation entry for 0x98c4.
grub-install: info: adding a relocation entry for 0x98d2.
grub-install: info: adding a relocation entry for 0x98f1.
grub-install: info: adding a relocation entry for 0x9911.
grub-install: info: adding a relocation entry for 0x991b.
grub-install: info: adding a relocation entry for 0x9931.
grub-install: info: adding a relocation entry for 0x993b.
grub-install: info: adding a relocation entry for 0x9962.
grub-install: info: adding a relocation entry for 0x9992.
grub-install: info: adding a relocation entry for 0x99a3.
grub-install: info: adding a relocation entry for 0x99e4.
grub-install: info: adding a relocation entry for 0x9a39.
grub-install: info: adding a relocation entry for 0x9a45.
grub-install: info: adding a relocation entry for 0x9a57.
grub-install: info: adding a relocation entry for 0x9a74.
grub-install: info: adding a relocation entry for 0x9a81.
grub-install: info: adding a relocation entry for 0x9a91.
grub-install: info: adding a relocation entry for 0x9aae.
grub-install: info: adding a relocation entry for 0x9abd.
grub-install: info: adding a relocation entry for 0x9ae3.
grub-install: info: adding a relocation entry for 0x9af8.
grub-install: info: adding a relocation entry for 0x9b0f.
grub-install: info: adding a relocation entry for 0x9b32.
grub-install: info: adding a relocation entry for 0x9b3c.
grub-install: info: adding a relocation entry for 0x9b65.
grub-install: info: adding a relocation entry for 0x9b75.
grub-install: info: adding a relocation entry for 0x9baf.
grub-install: info: adding a relocation entry for 0x9bb9.
grub-install: info: adding a relocation entry for 0x9bcd.
grub-install: info: adding a relocation entry for 0x9c03.
grub-install: info: adding a relocation entry for 0x9c2e.
grub-install: info: adding a relocation entry for 0x9c48.
grub-install: info: adding a relocation entry for 0x9c58.
grub-install: info: adding a relocation entry for 0x9c6f.
grub-install: info: adding a relocation entry for 0x9c86.
grub-install: info: adding a relocation entry for 0x9cab.
grub-install: info: adding a relocation entry for 0x9cbd.
grub-install: info: adding a relocation entry for 0x9ce8.
grub-install: info: adding a relocation entry for 0x9dd6.
grub-install: info: adding a relocation entry for 0x9e22.
grub-install: info: adding a relocation entry for 0x9e2c.
grub-install: info: adding a relocation entry for 0x9e59.
grub-install: info: adding a relocation entry for 0x9ec1.
grub-install: info: adding a relocation entry for 0x9ee2.
grub-install: info: adding a relocation entry for 0x9eec.
grub-install: info: adding a relocation entry for 0x9f30.
grub-install: info: adding a relocation entry for 0x9f61.
grub-install: info: adding a relocation entry for 0x9f8c.
grub-install: info: adding a relocation entry for 0x9f9d.
grub-install: info: adding a relocation entry for 0x9fb4.
grub-install: info: adding a relocation entry for 0x9fc6.
grub-install: info: adding a relocation entry for 0x9ffd.
grub-install: info: adding a relocation entry for 0xa013.
grub-install: info: adding a padding fixup entry.
grub-install: info: writing 288 bytes of a fixup block starting at 0x9000.
grub-install: info: adding a relocation entry for 0xa028.
grub-install: info: adding a relocation entry for 0xa035.
grub-install: info: adding a relocation entry for 0xa03f.
grub-install: info: adding a relocation entry for 0xa049.
grub-install: info: adding a relocation entry for 0xa05a.
grub-install: info: adding a relocation entry for 0xa064.
grub-install: info: adding a relocation entry for 0xa07d.
grub-install: info: adding a relocation entry for 0xa089.
grub-install: info: adding a relocation entry for 0xa093.
grub-install: info: adding a relocation entry for 0xa0a7.
grub-install: info: adding a relocation entry for 0xa0b1.
grub-install: info: adding a relocation entry for 0xa0ce.
grub-install: info: adding a relocation entry for 0xa0da.
grub-install: info: adding a relocation entry for 0xa0e6.
grub-install: info: adding a relocation entry for 0xa10c.
grub-install: info: adding a relocation entry for 0xa121.
grub-install: info: adding a relocation entry for 0xa138.
grub-install: info: adding a relocation entry for 0xa154.
grub-install: info: adding a relocation entry for 0xa175.
grub-install: info: adding a relocation entry for 0xa182.
grub-install: info: adding a relocation entry for 0xa1ac.
grub-install: info: adding a relocation entry for 0xa1bd.
grub-install: info: adding a relocation entry for 0xa1dc.
grub-install: info: adding a relocation entry for 0xa24a.
grub-install: info: adding a relocation entry for 0xa272.
grub-install: info: adding a relocation entry for 0xa27e.
grub-install: info: adding a relocation entry for 0xa28e.
grub-install: info: adding a relocation entry for 0xa2aa.
grub-install: info: adding a relocation entry for 0xa2b6.
grub-install: info: adding a relocation entry for 0xa2c6.
grub-install: info: adding a relocation entry for 0xa2df.
grub-install: info: adding a relocation entry for 0xa2e9.
grub-install: info: adding a relocation entry for 0xa313.
grub-install: info: adding a relocation entry for 0xa31d.
grub-install: info: adding a relocation entry for 0xa36f.
grub-install: info: adding a relocation entry for 0xa382.
grub-install: info: adding a relocation entry for 0xa38c.
grub-install: info: adding a relocation entry for 0xa3a4.
grub-install: info: adding a relocation entry for 0xa3b9.
grub-install: info: adding a relocation entry for 0xa3d5.
grub-install: info: adding a relocation entry for 0xa3e6.
grub-install: info: adding a relocation entry for 0xa3f3.
grub-install: info: adding a relocation entry for 0xa417.
grub-install: info: adding a relocation entry for 0xa457.
grub-install: info: adding a relocation entry for 0xa461.
grub-install: info: adding a relocation entry for 0xa46b.
grub-install: info: adding a relocation entry for 0xa477.
grub-install: info: adding a relocation entry for 0xa486.
grub-install: info: adding a relocation entry for 0xa4ab.
grub-install: info: adding a relocation entry for 0xa4b5.
grub-install: info: adding a relocation entry for 0xa50c.
grub-install: info: adding a relocation entry for 0xa518.
grub-install: info: adding a relocation entry for 0xa522.
grub-install: info: adding a relocation entry for 0xa538.
grub-install: info: adding a relocation entry for 0xa558.
grub-install: info: adding a relocation entry for 0xa562.
grub-install: info: adding a relocation entry for 0xa56e.
grub-install: info: adding a relocation entry for 0xa582.
grub-install: info: adding a relocation entry for 0xa58f.
grub-install: info: adding a relocation entry for 0xa5a1.
grub-install: info: adding a relocation entry for 0xa5b5.
grub-install: info: adding a relocation entry for 0xa5bf.
grub-install: info: adding a relocation entry for 0xa608.
grub-install: info: adding a relocation entry for 0xa63e.
grub-install: info: adding a relocation entry for 0xa65b.
grub-install: info: adding a relocation entry for 0xa677.
grub-install: info: adding a relocation entry for 0xa6df.
grub-install: info: adding a relocation entry for 0xa6e9.
grub-install: info: adding a relocation entry for 0xa708.
grub-install: info: adding a relocation entry for 0xa74a.
grub-install: info: adding a relocation entry for 0xa754.
grub-install: info: adding a relocation entry for 0xa783.
grub-install: info: adding a relocation entry for 0xa78d.
grub-install: info: adding a relocation entry for 0xa7aa.
grub-install: info: adding a relocation entry for 0xa7b4.
grub-install: info: adding a relocation entry for 0xa7c9.
grub-install: info: adding a relocation entry for 0xa7d3.
grub-install: info: adding a relocation entry for 0xa7e8.
grub-install: info: adding a relocation entry for 0xa7f2.
grub-install: info: adding a relocation entry for 0xa812.
grub-install: info: adding a relocation entry for 0xa824.
grub-install: info: adding a relocation entry for 0xa82e.
grub-install: info: adding a relocation entry for 0xa83a.
grub-install: info: adding a relocation entry for 0xa84c.
grub-install: info: adding a relocation entry for 0xa863.
grub-install: info: adding a relocation entry for 0xa86d.
grub-install: info: adding a relocation entry for 0xa879.
grub-install: info: adding a relocation entry for 0xa883.
grub-install: info: adding a relocation entry for 0xa89d.
grub-install: info: adding a relocation entry for 0xa8a7.
grub-install: info: adding a relocation entry for 0xa8bb.
grub-install: info: adding a relocation entry for 0xa8c5.
grub-install: info: adding a relocation entry for 0xa8d1.
grub-install: info: adding a relocation entry for 0xa8dd.
grub-install: info: adding a relocation entry for 0xa8e9.
grub-install: info: adding a relocation entry for 0xa8fe.
grub-install: info: adding a relocation entry for 0xa90d.
grub-install: info: adding a relocation entry for 0xa91e.
grub-install: info: adding a relocation entry for 0xa92b.
grub-install: info: adding a relocation entry for 0xa93e.
grub-install: info: adding a relocation entry for 0xa948.
grub-install: info: adding a relocation entry for 0xa955.
grub-install: info: adding a relocation entry for 0xa967.
grub-install: info: adding a relocation entry for 0xa973.
grub-install: info: adding a relocation entry for 0xa984.
grub-install: info: adding a relocation entry for 0xa98e.
grub-install: info: adding a relocation entry for 0xa99e.
grub-install: info: adding a relocation entry for 0xa9b1.
grub-install: info: adding a relocation entry for 0xa9bd.
grub-install: info: adding a relocation entry for 0xa9ca.
grub-install: info: adding a relocation entry for 0xaa05.
grub-install: info: adding a relocation entry for 0xaa11.
grub-install: info: adding a relocation entry for 0xaa23.
grub-install: info: adding a relocation entry for 0xaa2d.
grub-install: info: adding a relocation entry for 0xaa4d.
grub-install: info: adding a relocation entry for 0xaa5a.
grub-install: info: adding a relocation entry for 0xaa70.
grub-install: info: adding a relocation entry for 0xaa7a.
grub-install: info: adding a relocation entry for 0xaa91.
grub-install: info: adding a relocation entry for 0xaa9b.
grub-install: info: adding a relocation entry for 0xaab4.
grub-install: info: adding a relocation entry for 0xaabe.
grub-install: info: adding a relocation entry for 0xaadf.
grub-install: info: adding a relocation entry for 0xaaee.
grub-install: info: adding a relocation entry for 0xab4b.
grub-install: info: adding a relocation entry for 0xab59.
grub-install: info: adding a relocation entry for 0xac3b.
grub-install: info: adding a relocation entry for 0xac76.
grub-install: info: adding a relocation entry for 0xad92.
grub-install: info: adding a relocation entry for 0xada2.
grub-install: info: adding a relocation entry for 0xadba.
grub-install: info: adding a relocation entry for 0xadca.
grub-install: info: adding a relocation entry for 0xadf2.
grub-install: info: adding a relocation entry for 0xadfc.
grub-install: info: adding a relocation entry for 0xaec3.
grub-install: info: adding a relocation entry for 0xaeda.
grub-install: info: adding a relocation entry for 0xaee8.
grub-install: info: adding a relocation entry for 0xaf06.
grub-install: info: adding a relocation entry for 0xaf1a.
grub-install: info: adding a relocation entry for 0xaf2f.
grub-install: info: adding a relocation entry for 0xaf45.
grub-install: info: adding a relocation entry for 0xaf66.
grub-install: info: adding a relocation entry for 0xafdb.
grub-install: info: adding a relocation entry for 0xb086.
grub-install: info: writing 296 bytes of a fixup block starting at 0xa000.
grub-install: info: adding a relocation entry for 0xb0a6.
grub-install: info: adding a relocation entry for 0xb0b0.
grub-install: info: adding a relocation entry for 0xb0e1.
grub-install: info: adding a relocation entry for 0xb0eb.
grub-install: info: adding a relocation entry for 0xb17f.
grub-install: info: adding a relocation entry for 0xb20f.
grub-install: info: adding a relocation entry for 0xb22c.
grub-install: info: adding a relocation entry for 0xb240.
grub-install: info: adding a relocation entry for 0xb26a.
grub-install: info: adding a relocation entry for 0xb274.
grub-install: info: adding a relocation entry for 0xb28b.
grub-install: info: adding a relocation entry for 0xb29e.
grub-install: info: adding a relocation entry for 0xb2d9.
grub-install: info: adding a relocation entry for 0xb32f.
grub-install: info: adding a relocation entry for 0xb42d.
grub-install: info: adding a relocation entry for 0xb44f.
grub-install: info: adding a relocation entry for 0xb4e9.
grub-install: info: adding a relocation entry for 0xb594.
grub-install: info: adding a relocation entry for 0xb5ee.
grub-install: info: adding a relocation entry for 0xb752.
grub-install: info: adding a relocation entry for 0xb789.
grub-install: info: adding a relocation entry for 0xb8bb.
grub-install: info: adding a relocation entry for 0xb97d.
grub-install: info: adding a relocation entry for 0xb98c.
grub-install: info: adding a relocation entry for 0xb998.
grub-install: info: adding a relocation entry for 0xb9db.
grub-install: info: adding a relocation entry for 0xb9e5.
grub-install: info: adding a relocation entry for 0xb9f9.
grub-install: info: adding a relocation entry for 0xba12.
grub-install: info: adding a relocation entry for 0xba30.
grub-install: info: adding a relocation entry for 0xba42.
grub-install: info: adding a relocation entry for 0xba5b.
grub-install: info: adding a relocation entry for 0xba65.
grub-install: info: adding a relocation entry for 0xba85.
grub-install: info: adding a relocation entry for 0xbad7.
grub-install: info: adding a relocation entry for 0xbb1d.
grub-install: info: adding a relocation entry for 0xbb39.
grub-install: info: adding a relocation entry for 0xbb4a.
grub-install: info: adding a relocation entry for 0xbb88.
grub-install: info: adding a relocation entry for 0xbb92.
grub-install: info: adding a relocation entry for 0xbbbe.
grub-install: info: adding a relocation entry for 0xbbd2.
grub-install: info: adding a relocation entry for 0xbbe9.
grub-install: info: adding a relocation entry for 0xbc1c.
grub-install: info: adding a relocation entry for 0xbc30.
grub-install: info: adding a relocation entry for 0xbc57.
grub-install: info: adding a relocation entry for 0xbc88.
grub-install: info: adding a relocation entry for 0xbcab.
grub-install: info: adding a relocation entry for 0xbcba.
grub-install: info: adding a relocation entry for 0xbcea.
grub-install: info: adding a relocation entry for 0xbd0a.
grub-install: info: adding a relocation entry for 0xbd1e.
grub-install: info: adding a relocation entry for 0xbd4e.
grub-install: info: adding a relocation entry for 0xbd7e.
grub-install: info: adding a relocation entry for 0xbdd4.
grub-install: info: adding a relocation entry for 0xbdde.
grub-install: info: adding a relocation entry for 0xbdfa.
grub-install: info: adding a relocation entry for 0xbe4e.
grub-install: info: adding a relocation entry for 0xbe6f.
grub-install: info: adding a relocation entry for 0xbe80.
grub-install: info: adding a relocation entry for 0xbe8e.
grub-install: info: adding a relocation entry for 0xbeb5.
grub-install: info: adding a relocation entry for 0xbec2.
grub-install: info: adding a relocation entry for 0xbece.
grub-install: info: adding a relocation entry for 0xbede.
grub-install: info: adding a relocation entry for 0xbeec.
grub-install: info: adding a relocation entry for 0xbef8.
grub-install: info: adding a relocation entry for 0xbf35.
grub-install: info: adding a relocation entry for 0xbf51.
grub-install: info: adding a relocation entry for 0xbf5d.
grub-install: info: adding a relocation entry for 0xbf69.
grub-install: info: adding a relocation entry for 0xbf75.
grub-install: info: adding a relocation entry for 0xbf81.
grub-install: info: adding a relocation entry for 0xbfb9.
grub-install: info: adding a relocation entry for 0xbfc3.
grub-install: info: adding a relocation entry for 0xbfdf.
grub-install: info: adding a relocation entry for 0xc018.
grub-install: info: writing 168 bytes of a fixup block starting at 0xb000.
grub-install: info: adding a relocation entry for 0xc02b.
grub-install: info: adding a relocation entry for 0xc03e.
grub-install: info: adding a relocation entry for 0xc081.
grub-install: info: adding a relocation entry for 0xc08d.
grub-install: info: adding a relocation entry for 0xc09e.
grub-install: info: adding a relocation entry for 0xc0d5.
grub-install: info: adding a relocation entry for 0xc0f3.
grub-install: info: adding a relocation entry for 0xc104.
grub-install: info: adding a relocation entry for 0xc138.
grub-install: info: adding a relocation entry for 0xc154.
grub-install: info: adding a relocation entry for 0xc16e.
grub-install: info: adding a relocation entry for 0xc178.
grub-install: info: adding a relocation entry for 0xc195.
grub-install: info: adding a relocation entry for 0xc1d3.
grub-install: info: adding a relocation entry for 0xc1f8.
grub-install: info: adding a relocation entry for 0xc207.
grub-install: info: adding a relocation entry for 0xc225.
grub-install: info: adding a relocation entry for 0xc261.
grub-install: info: adding a relocation entry for 0xc271.
grub-install: info: adding a relocation entry for 0xc27d.
grub-install: info: adding a relocation entry for 0xc291.
grub-install: info: adding a relocation entry for 0xc2a3.
grub-install: info: adding a relocation entry for 0xc2b4.
grub-install: info: adding a relocation entry for 0xc2fb.
grub-install: info: adding a relocation entry for 0xc33f.
grub-install: info: adding a relocation entry for 0xc395.
grub-install: info: adding a relocation entry for 0xc40a.
grub-install: info: adding a relocation entry for 0xc419.
grub-install: info: adding a relocation entry for 0xc46d.
grub-install: info: adding a relocation entry for 0xc48b.
grub-install: info: adding a relocation entry for 0xc49a.
grub-install: info: adding a relocation entry for 0xc4a9.
grub-install: info: adding a relocation entry for 0xc4ee.
grub-install: info: adding a relocation entry for 0xc509.
grub-install: info: adding a relocation entry for 0xc52d.
grub-install: info: adding a relocation entry for 0xc554.
grub-install: info: adding a relocation entry for 0xc57c.
grub-install: info: adding a relocation entry for 0xc597.
grub-install: info: adding a relocation entry for 0xc5c4.
grub-install: info: adding a relocation entry for 0xc5d1.
grub-install: info: adding a relocation entry for 0xc5db.
grub-install: info: adding a relocation entry for 0xc5fe.
grub-install: info: adding a relocation entry for 0xc635.
grub-install: info: adding a relocation entry for 0xc65c.
grub-install: info: adding a relocation entry for 0xc66c.
grub-install: info: adding a relocation entry for 0xc684.
grub-install: info: adding a relocation entry for 0xc693.
grub-install: info: adding a relocation entry for 0xc69f.
grub-install: info: adding a relocation entry for 0xc6b5.
grub-install: info: adding a relocation entry for 0xc6d7.
grub-install: info: adding a relocation entry for 0xc6e1.
grub-install: info: adding a relocation entry for 0xc6fb.
grub-install: info: adding a relocation entry for 0xc731.
grub-install: info: adding a relocation entry for 0xc748.
grub-install: info: adding a relocation entry for 0xc752.
grub-install: info: adding a relocation entry for 0xc75e.
grub-install: info: adding a relocation entry for 0xc76b.
grub-install: info: adding a relocation entry for 0xc7d9.
grub-install: info: adding a relocation entry for 0xc7eb.
grub-install: info: adding a relocation entry for 0xc81e.
grub-install: info: adding a relocation entry for 0xc835.
grub-install: info: adding a relocation entry for 0xc85a.
grub-install: info: adding a relocation entry for 0xc87a.
grub-install: info: adding a relocation entry for 0xc889.
grub-install: info: adding a relocation entry for 0xc89b.
grub-install: info: adding a relocation entry for 0xc8aa.
grub-install: info: adding a relocation entry for 0xc8d1.
grub-install: info: adding a relocation entry for 0xc8ef.
grub-install: info: adding a relocation entry for 0xc937.
grub-install: info: adding a relocation entry for 0xc945.
grub-install: info: adding a relocation entry for 0xc980.
grub-install: info: adding a relocation entry for 0xc9ac.
grub-install: info: adding a relocation entry for 0xc9b6.
grub-install: info: adding a relocation entry for 0xc9c6.
grub-install: info: adding a relocation entry for 0xca08.
grub-install: info: adding a relocation entry for 0xca12.
grub-install: info: adding a relocation entry for 0xca3b.
grub-install: info: adding a relocation entry for 0xca45.
grub-install: info: adding a relocation entry for 0xca59.
grub-install: info: adding a relocation entry for 0xcb0e.
grub-install: info: adding a relocation entry for 0xcb23.
grub-install: info: adding a relocation entry for 0xcb2d.
grub-install: info: adding a relocation entry for 0xcb3c.
grub-install: info: adding a relocation entry for 0xcb4e.
grub-install: info: adding a relocation entry for 0xcb70.
grub-install: info: adding a relocation entry for 0xcb8b.
grub-install: info: adding a relocation entry for 0xcba8.
grub-install: info: adding a relocation entry for 0xcbbc.
grub-install: info: adding a relocation entry for 0xcbdc.
grub-install: info: adding a relocation entry for 0xcc17.
grub-install: info: adding a relocation entry for 0xcc6f.
grub-install: info: adding a relocation entry for 0xcc80.
grub-install: info: adding a relocation entry for 0xcca1.
grub-install: info: adding a relocation entry for 0xccc6.
grub-install: info: adding a relocation entry for 0xccd6.
grub-install: info: adding a relocation entry for 0xcce1.
grub-install: info: adding a relocation entry for 0xcd37.
grub-install: info: adding a relocation entry for 0xcd5f.
grub-install: info: adding a relocation entry for 0xcd85.
grub-install: info: adding a relocation entry for 0xcd92.
grub-install: info: adding a relocation entry for 0xcdbf.
grub-install: info: adding a relocation entry for 0xcdce.
grub-install: info: adding a relocation entry for 0xcdde.
grub-install: info: adding a relocation entry for 0xcdef.
grub-install: info: adding a relocation entry for 0xcdfb.
grub-install: info: adding a relocation entry for 0xce27.
grub-install: info: adding a relocation entry for 0xce3e.
grub-install: info: adding a relocation entry for 0xce4a.
grub-install: info: adding a relocation entry for 0xce56.
grub-install: info: adding a relocation entry for 0xce67.
grub-install: info: adding a relocation entry for 0xce72.
grub-install: info: adding a relocation entry for 0xce97.
grub-install: info: adding a relocation entry for 0xcea6.
grub-install: info: adding a relocation entry for 0xcee1.
grub-install: info: adding a relocation entry for 0xcf14.
grub-install: info: adding a relocation entry for 0xcf28.
grub-install: info: adding a relocation entry for 0xcf32.
grub-install: info: adding a relocation entry for 0xcf44.
grub-install: info: adding a relocation entry for 0xcf65.
grub-install: info: adding a relocation entry for 0xcf73.
grub-install: info: adding a relocation entry for 0xcf7d.
grub-install: info: adding a relocation entry for 0xcf94.
grub-install: info: adding a relocation entry for 0xcfa9.
grub-install: info: adding a relocation entry for 0xcfcc.
grub-install: info: adding a relocation entry for 0xcfe0.
grub-install: info: adding a relocation entry for 0xcfea.
grub-install: info: adding a relocation entry for 0xd02e.
grub-install: info: writing 264 bytes of a fixup block starting at 0xc000.
grub-install: info: adding a relocation entry for 0xd077.
grub-install: info: adding a relocation entry for 0xd090.
grub-install: info: adding a relocation entry for 0xd0b3.
grub-install: info: adding a relocation entry for 0xd0e2.
grub-install: info: adding a relocation entry for 0xd0f6.
grub-install: info: adding a relocation entry for 0xd107.
grub-install: info: adding a relocation entry for 0xd12f.
grub-install: info: adding a relocation entry for 0xd142.
grub-install: info: adding a relocation entry for 0xd17f.
grub-install: info: adding a relocation entry for 0xd19b.
grub-install: info: adding a relocation entry for 0xd1c3.
grub-install: info: adding a relocation entry for 0xd1ce.
grub-install: info: adding a relocation entry for 0xd1e9.
grub-install: info: adding a relocation entry for 0xd1f4.
grub-install: info: adding a relocation entry for 0xd230.
grub-install: info: adding a relocation entry for 0xd23a.
grub-install: info: adding a relocation entry for 0xd244.
grub-install: info: adding a relocation entry for 0xd25e.
grub-install: info: adding a relocation entry for 0xd2a8.
grub-install: info: adding a relocation entry for 0xd2f6.
grub-install: info: adding a relocation entry for 0xd300.
grub-install: info: adding a relocation entry for 0xd338.
grub-install: info: adding a relocation entry for 0xd342.
grub-install: info: adding a relocation entry for 0xd362.
grub-install: info: adding a relocation entry for 0xd377.
grub-install: info: adding a relocation entry for 0xd388.
grub-install: info: adding a relocation entry for 0xd3a3.
grub-install: info: adding a relocation entry for 0xd3c5.
grub-install: info: adding a relocation entry for 0xd3e9.
grub-install: info: adding a relocation entry for 0xd3fe.
grub-install: info: adding a relocation entry for 0xd41c.
grub-install: info: adding a relocation entry for 0xd426.
grub-install: info: adding a relocation entry for 0xd4e6.
grub-install: info: adding a relocation entry for 0xd4ff.
grub-install: info: adding a relocation entry for 0xd509.
grub-install: info: adding a relocation entry for 0xd539.
grub-install: info: adding a relocation entry for 0xd55b.
grub-install: info: adding a relocation entry for 0xd56e.
grub-install: info: adding a relocation entry for 0xd57b.
grub-install: info: adding a relocation entry for 0xd59e.
grub-install: info: adding a relocation entry for 0xd5af.
grub-install: info: adding a relocation entry for 0xd5bf.
grub-install: info: adding a relocation entry for 0xd5c9.
grub-install: info: adding a relocation entry for 0xd5d6.
grub-install: info: adding a relocation entry for 0xd60b.
grub-install: info: adding a relocation entry for 0xd615.
grub-install: info: adding a relocation entry for 0xd621.
grub-install: info: adding a relocation entry for 0xd62c.
grub-install: info: translating the relocation section .rela.rodata.
grub-install: info: adding a relocation entry for 0xe000.
grub-install: info: writing 112 bytes of a fixup block starting at 0xd000.
grub-install: info: adding a relocation entry for 0xe008.
grub-install: info: adding a relocation entry for 0xe010.
grub-install: info: adding a relocation entry for 0xe018.
grub-install: info: adding a relocation entry for 0xe020.
grub-install: info: adding a relocation entry for 0xe028.
grub-install: info: adding a relocation entry for 0xe030.
grub-install: info: adding a relocation entry for 0xe038.
grub-install: info: adding a relocation entry for 0xe040.
grub-install: info: adding a relocation entry for 0xe048.
grub-install: info: adding a relocation entry for 0xe050.
grub-install: info: adding a relocation entry for 0xe058.
grub-install: info: adding a relocation entry for 0xe060.
grub-install: info: adding a relocation entry for 0xe068.
grub-install: info: adding a relocation entry for 0xe070.
grub-install: info: adding a relocation entry for 0xe078.
grub-install: info: adding a relocation entry for 0xe080.
grub-install: info: adding a relocation entry for 0xe088.
grub-install: info: adding a relocation entry for 0xe090.
grub-install: info: adding a relocation entry for 0xe098.
grub-install: info: adding a relocation entry for 0xe0a0.
grub-install: info: adding a relocation entry for 0xe0a8.
grub-install: info: adding a relocation entry for 0xe0b0.
grub-install: info: adding a relocation entry for 0xe0b8.
grub-install: info: adding a relocation entry for 0xe0c0.
grub-install: info: adding a relocation entry for 0xe0c8.
grub-install: info: adding a relocation entry for 0xe0d0.
grub-install: info: adding a relocation entry for 0xe0d8.
grub-install: info: adding a relocation entry for 0xe0e0.
grub-install: info: adding a relocation entry for 0xe0e8.
grub-install: info: adding a relocation entry for 0xe0f0.
grub-install: info: adding a relocation entry for 0xe0f8.
grub-install: info: adding a relocation entry for 0xe100.
grub-install: info: adding a relocation entry for 0xe108.
grub-install: info: adding a relocation entry for 0xe110.
grub-install: info: adding a relocation entry for 0xe118.
grub-install: info: adding a relocation entry for 0xe120.
grub-install: info: adding a relocation entry for 0xe128.
grub-install: info: adding a relocation entry for 0xe130.
grub-install: info: adding a relocation entry for 0xe138.
grub-install: info: adding a relocation entry for 0xe140.
grub-install: info: adding a relocation entry for 0xe148.
grub-install: info: adding a relocation entry for 0xe150.
grub-install: info: adding a relocation entry for 0xe158.
grub-install: info: adding a relocation entry for 0xe160.
grub-install: info: adding a relocation entry for 0xe1e0.
grub-install: info: adding a relocation entry for 0xe1e8.
grub-install: info: adding a relocation entry for 0xe1f0.
grub-install: info: adding a relocation entry for 0xe1f8.
grub-install: info: adding a relocation entry for 0xe200.
grub-install: info: adding a relocation entry for 0xe208.
grub-install: info: adding a relocation entry for 0xe210.
grub-install: info: translating the relocation section .rela.data.
grub-install: info: adding a relocation entry for 0x10960.
grub-install: info: writing 112 bytes of a fixup block starting at 0xe000.
grub-install: info: adding a relocation entry for 0x10970.
grub-install: info: adding a relocation entry for 0x10978.
grub-install: info: adding a relocation entry for 0x10980.
grub-install: info: adding a relocation entry for 0x10988.
grub-install: info: adding a relocation entry for 0x10990.
grub-install: info: adding a relocation entry for 0x10a10.
grub-install: info: adding a relocation entry for 0x10a20.
grub-install: info: adding a relocation entry for 0x10a28.
grub-install: info: adding a relocation entry for 0x10a38.
grub-install: info: adding a relocation entry for 0x10a40.
grub-install: info: adding a relocation entry for 0x10a48.
grub-install: info: adding a relocation entry for 0x10a50.
grub-install: info: adding a relocation entry for 0x10a58.
grub-install: info: adding a relocation entry for 0x10a60.
grub-install: info: adding a relocation entry for 0x10ab0.
grub-install: info: adding a relocation entry for 0x10ab8.
grub-install: info: adding a relocation entry for 0x10ac8.
grub-install: info: adding a relocation entry for 0x10ad0.
grub-install: info: adding a relocation entry for 0x10b50.
grub-install: info: adding a relocation entry for 0x10b58.
grub-install: info: adding a relocation entry for 0x10b60.
grub-install: info: adding a relocation entry for 0x10bb0.
grub-install: info: adding a relocation entry for 0x10bb8.
grub-install: info: adding a relocation entry for 0x10be0.
grub-install: info: adding a relocation entry for 0x10c10.
grub-install: info: adding a relocation entry for 0x10c20.
grub-install: info: adding a relocation entry for 0x10c28.
grub-install: info: adding a relocation entry for 0x10c50.
grub-install: info: adding a relocation entry for 0x10c58.
grub-install: info: adding a relocation entry for 0x10da0.
grub-install: info: adding a relocation entry for 0x10dd0.
grub-install: info: adding a relocation entry for 0x10de8.
grub-install: info: adding a relocation entry for 0x10df0.
grub-install: info: adding a relocation entry for 0x10e20.
grub-install: info: adding a relocation entry for 0x10e28.
grub-install: info: adding a relocation entry for 0x10e38.
grub-install: info: adding a relocation entry for 0x10e40.
grub-install: info: adding a relocation entry for 0x10e50.
grub-install: info: adding a relocation entry for 0x10e58.
grub-install: info: adding a relocation entry for 0x10e68.
grub-install: info: adding a relocation entry for 0x10e70.
grub-install: info: adding a relocation entry for 0x10e80.
grub-install: info: adding a relocation entry for 0x10e88.
grub-install: info: adding a relocation entry for 0x10e98.
grub-install: info: adding a relocation entry for 0x10ea0.
grub-install: info: adding a relocation entry for 0x10eb0.
grub-install: info: adding a relocation entry for 0x10eb8.
grub-install: info: adding a relocation entry for 0x10ec8.
grub-install: info: adding a relocation entry for 0x10ed0.
grub-install: info: adding a relocation entry for 0x10ee0.
grub-install: info: adding a relocation entry for 0x10ee8.
grub-install: info: adding a relocation entry for 0x10ef8.
grub-install: info: adding a relocation entry for 0x10f00.
grub-install: info: adding a relocation entry for 0x10f10.
grub-install: info: adding a relocation entry for 0x10f18.
grub-install: info: adding a relocation entry for 0x10f28.
grub-install: info: adding a relocation entry for 0x10f30.
grub-install: info: adding a relocation entry for 0x10f40.
grub-install: info: adding a relocation entry for 0x10f48.
grub-install: info: adding a relocation entry for 0x10f58.
grub-install: info: adding a relocation entry for 0x10f60.
grub-install: info: adding a relocation entry for 0x10f70.
grub-install: info: adding a relocation entry for 0x10f78.
grub-install: info: adding a relocation entry for 0x10f88.
grub-install: info: adding a relocation entry for 0x10f90.
grub-install: info: adding a relocation entry for 0x10fa0.
grub-install: info: adding a relocation entry for 0x10fa8.
grub-install: info: adding a relocation entry for 0x10fb8.
grub-install: info: adding a relocation entry for 0x10fc0.
grub-install: info: adding a relocation entry for 0x10fd0.
grub-install: info: adding a relocation entry for 0x10fd8.
grub-install: info: adding a relocation entry for 0x10fe8.
grub-install: info: adding a relocation entry for 0x10ff0.
grub-install: info: adding a relocation entry for 0x11000.
grub-install: info: writing 160 bytes of a fixup block starting at 0x10000.
grub-install: info: adding a relocation entry for 0x11008.
grub-install: info: adding a relocation entry for 0x11018.
grub-install: info: adding a relocation entry for 0x11020.
grub-install: info: adding a relocation entry for 0x11030.
grub-install: info: adding a relocation entry for 0x11038.
grub-install: info: adding a relocation entry for 0x11048.
grub-install: info: adding a relocation entry for 0x11050.
grub-install: info: adding a relocation entry for 0x11060.
grub-install: info: adding a relocation entry for 0x11068.
grub-install: info: adding a relocation entry for 0x11078.
grub-install: info: adding a relocation entry for 0x11080.
grub-install: info: adding a relocation entry for 0x11090.
grub-install: info: adding a relocation entry for 0x11098.
grub-install: info: adding a relocation entry for 0x110a8.
grub-install: info: adding a relocation entry for 0x110b0.
grub-install: info: adding a relocation entry for 0x110c0.
grub-install: info: adding a relocation entry for 0x110c8.
grub-install: info: adding a relocation entry for 0x110d8.
grub-install: info: adding a relocation entry for 0x110e0.
grub-install: info: adding a relocation entry for 0x110f0.
grub-install: info: adding a relocation entry for 0x110f8.
grub-install: info: adding a relocation entry for 0x11108.
grub-install: info: adding a relocation entry for 0x11110.
grub-install: info: adding a relocation entry for 0x11120.
grub-install: info: adding a relocation entry for 0x11128.
grub-install: info: adding a relocation entry for 0x11138.
grub-install: info: adding a relocation entry for 0x11140.
grub-install: info: adding a relocation entry for 0x11150.
grub-install: info: adding a relocation entry for 0x11158.
grub-install: info: adding a relocation entry for 0x11168.
grub-install: info: adding a relocation entry for 0x11170.
grub-install: info: adding a relocation entry for 0x11180.
grub-install: info: adding a relocation entry for 0x11188.
grub-install: info: adding a relocation entry for 0x11198.
grub-install: info: adding a relocation entry for 0x111a0.
grub-install: info: adding a relocation entry for 0x111b0.
grub-install: info: adding a relocation entry for 0x111b8.
grub-install: info: adding a relocation entry for 0x111c8.
grub-install: info: adding a relocation entry for 0x111d0.
grub-install: info: adding a relocation entry for 0x111e0.
grub-install: info: adding a relocation entry for 0x111e8.
grub-install: info: adding a relocation entry for 0x111f8.
grub-install: info: adding a relocation entry for 0x11200.
grub-install: info: adding a relocation entry for 0x11210.
grub-install: info: adding a relocation entry for 0x11218.
grub-install: info: adding a relocation entry for 0x11228.
grub-install: info: adding a relocation entry for 0x11230.
grub-install: info: adding a relocation entry for 0x11240.
grub-install: info: adding a relocation entry for 0x11248.
grub-install: info: adding a relocation entry for 0x11258.
grub-install: info: adding a relocation entry for 0x11260.
grub-install: info: adding a relocation entry for 0x11270.
grub-install: info: adding a relocation entry for 0x11278.
grub-install: info: adding a relocation entry for 0x11288.
grub-install: info: adding a relocation entry for 0x11290.
grub-install: info: adding a relocation entry for 0x112a0.
grub-install: info: adding a relocation entry for 0x112a8.
grub-install: info: adding a relocation entry for 0x112b8.
grub-install: info: adding a relocation entry for 0x112c0.
grub-install: info: adding a relocation entry for 0x112d0.
grub-install: info: adding a relocation entry for 0x112d8.
grub-install: info: adding a relocation entry for 0x112e8.
grub-install: info: adding a relocation entry for 0x112f0.
grub-install: info: adding a relocation entry for 0x11300.
grub-install: info: adding a relocation entry for 0x11308.
grub-install: info: adding a relocation entry for 0x11318.
grub-install: info: adding a relocation entry for 0x11320.
grub-install: info: adding a relocation entry for 0x11330.
grub-install: info: adding a relocation entry for 0x11338.
grub-install: info: adding a relocation entry for 0x11348.
grub-install: info: adding a relocation entry for 0x11350.
grub-install: info: adding a relocation entry for 0x11360.
grub-install: info: adding a relocation entry for 0x11368.
grub-install: info: adding a relocation entry for 0x11378.
grub-install: info: adding a relocation entry for 0x11380.
grub-install: info: adding a relocation entry for 0x11390.
grub-install: info: adding a relocation entry for 0x11398.
grub-install: info: adding a relocation entry for 0x113a8.
grub-install: info: adding a relocation entry for 0x113b0.
grub-install: info: adding a relocation entry for 0x113c0.
grub-install: info: adding a relocation entry for 0x113c8.
grub-install: info: adding a relocation entry for 0x113d8.
grub-install: info: adding a relocation entry for 0x113e0.
grub-install: info: adding a relocation entry for 0x113f0.
grub-install: info: adding a relocation entry for 0x113f8.
grub-install: info: adding a relocation entry for 0x11408.
grub-install: info: adding a relocation entry for 0x11410.
grub-install: info: adding a relocation entry for 0x11420.
grub-install: info: adding a relocation entry for 0x11428.
grub-install: info: adding a relocation entry for 0x11438.
grub-install: info: adding a relocation entry for 0x11440.
grub-install: info: adding a relocation entry for 0x11450.
grub-install: info: adding a relocation entry for 0x11458.
grub-install: info: adding a relocation entry for 0x11468.
grub-install: info: adding a relocation entry for 0x11470.
grub-install: info: adding a relocation entry for 0x11480.
grub-install: info: adding a relocation entry for 0x11488.
grub-install: info: adding a relocation entry for 0x11498.
grub-install: info: adding a relocation entry for 0x114a0.
grub-install: info: adding a relocation entry for 0x114b0.
grub-install: info: adding a relocation entry for 0x114b8.
grub-install: info: adding a relocation entry for 0x114c8.
grub-install: info: adding a relocation entry for 0x114d0.
grub-install: info: adding a relocation entry for 0x114e0.
grub-install: info: adding a relocation entry for 0x114e8.
grub-install: info: adding a relocation entry for 0x114f8.
grub-install: info: adding a relocation entry for 0x11500.
grub-install: info: adding a relocation entry for 0x11510.
grub-install: info: adding a relocation entry for 0x11518.
grub-install: info: adding a relocation entry for 0x11528.
grub-install: info: adding a relocation entry for 0x11530.
grub-install: info: adding a relocation entry for 0x11540.
grub-install: info: adding a relocation entry for 0x11548.
grub-install: info: adding a relocation entry for 0x11558.
grub-install: info: adding a relocation entry for 0x11560.
grub-install: info: adding a relocation entry for 0x11570.
grub-install: info: adding a relocation entry for 0x11578.
grub-install: info: adding a relocation entry for 0x11588.
grub-install: info: adding a relocation entry for 0x11590.
grub-install: info: adding a relocation entry for 0x115a0.
grub-install: info: adding a relocation entry for 0x115a8.
grub-install: info: adding a relocation entry for 0x115b8.
grub-install: info: adding a relocation entry for 0x115c0.
grub-install: info: adding a relocation entry for 0x115d0.
grub-install: info: adding a relocation entry for 0x115d8.
grub-install: info: adding a relocation entry for 0x115e8.
grub-install: info: adding a relocation entry for 0x115f0.
grub-install: info: adding a relocation entry for 0x11600.
grub-install: info: adding a relocation entry for 0x11608.
grub-install: info: adding a relocation entry for 0x11618.
grub-install: info: adding a relocation entry for 0x11620.
grub-install: info: adding a relocation entry for 0x11630.
grub-install: info: adding a relocation entry for 0x11638.
grub-install: info: adding a relocation entry for 0x11648.
grub-install: info: adding a relocation entry for 0x11650.
grub-install: info: adding a relocation entry for 0x11660.
grub-install: info: adding a relocation entry for 0x11668.
grub-install: info: adding a relocation entry for 0x11678.
grub-install: info: adding a relocation entry for 0x11680.
grub-install: info: adding a relocation entry for 0x11690.
grub-install: info: adding a relocation entry for 0x11698.
grub-install: info: adding a relocation entry for 0x116a8.
grub-install: info: adding a relocation entry for 0x116b0.
grub-install: info: adding a relocation entry for 0x116c0.
grub-install: info: adding a relocation entry for 0x116c8.
grub-install: info: adding a relocation entry for 0x116d8.
grub-install: info: adding a relocation entry for 0x116e0.
grub-install: info: adding a relocation entry for 0x116f0.
grub-install: info: adding a relocation entry for 0x116f8.
grub-install: info: adding a relocation entry for 0x11708.
grub-install: info: adding a relocation entry for 0x11710.
grub-install: info: adding a relocation entry for 0x11720.
grub-install: info: adding a relocation entry for 0x11728.
grub-install: info: adding a relocation entry for 0x11738.
grub-install: info: adding a relocation entry for 0x11740.
grub-install: info: adding a relocation entry for 0x11750.
grub-install: info: adding a relocation entry for 0x11758.
grub-install: info: adding a relocation entry for 0x11768.
grub-install: info: adding a relocation entry for 0x11770.
grub-install: info: adding a relocation entry for 0x11780.
grub-install: info: adding a relocation entry for 0x11788.
grub-install: info: adding a relocation entry for 0x11798.
grub-install: info: adding a relocation entry for 0x117a0.
grub-install: info: adding a relocation entry for 0x117b0.
grub-install: info: adding a relocation entry for 0x117b8.
grub-install: info: adding a relocation entry for 0x117c8.
grub-install: info: adding a relocation entry for 0x117d0.
grub-install: info: adding a relocation entry for 0x117e0.
grub-install: info: adding a relocation entry for 0x117e8.
grub-install: info: adding a relocation entry for 0x117f8.
grub-install: info: adding a relocation entry for 0x11800.
grub-install: info: adding a relocation entry for 0x11810.
grub-install: info: adding a relocation entry for 0x11818.
grub-install: info: adding a relocation entry for 0x11828.
grub-install: info: adding a relocation entry for 0x11830.
grub-install: info: adding a relocation entry for 0x11840.
grub-install: info: adding a relocation entry for 0x11848.
grub-install: info: adding a relocation entry for 0x11858.
grub-install: info: adding a relocation entry for 0x11860.
grub-install: info: adding a relocation entry for 0x11870.
grub-install: info: adding a relocation entry for 0x11878.
grub-install: info: adding a relocation entry for 0x11888.
grub-install: info: adding a relocation entry for 0x11890.
grub-install: info: adding a relocation entry for 0x118a0.
grub-install: info: adding a relocation entry for 0x118a8.
grub-install: info: adding a relocation entry for 0x118b8.
grub-install: info: adding a relocation entry for 0x118c0.
grub-install: info: adding a relocation entry for 0x118d0.
grub-install: info: adding a relocation entry for 0x118d8.
grub-install: info: adding a relocation entry for 0x118e8.
grub-install: info: adding a relocation entry for 0x118f0.
grub-install: info: adding a relocation entry for 0x11900.
grub-install: info: adding a relocation entry for 0x11908.
grub-install: info: adding a relocation entry for 0x11918.
grub-install: info: adding a relocation entry for 0x11920.
grub-install: info: adding a relocation entry for 0x11930.
grub-install: info: adding a relocation entry for 0x11938.
grub-install: info: adding a relocation entry for 0x11948.
grub-install: info: adding a relocation entry for 0x11950.
grub-install: info: adding a relocation entry for 0x11960.
grub-install: info: adding a relocation entry for 0x11968.
grub-install: info: adding a relocation entry for 0x11978.
grub-install: info: adding a relocation entry for 0x11980.
grub-install: info: adding a relocation entry for 0x11990.
grub-install: info: adding a relocation entry for 0x11998.
grub-install: info: adding a relocation entry for 0x119a8.
grub-install: info: adding a relocation entry for 0x119b0.
grub-install: info: adding a relocation entry for 0x119c0.
grub-install: info: adding a relocation entry for 0x119c8.
grub-install: info: adding a relocation entry for 0x119d8.
grub-install: info: adding a relocation entry for 0x119e0.
grub-install: info: adding a relocation entry for 0x119f0.
grub-install: info: adding a relocation entry for 0x119f8.
grub-install: info: adding a relocation entry for 0x11a08.
grub-install: info: adding a relocation entry for 0x11a10.
grub-install: info: adding a relocation entry for 0x11a20.
grub-install: info: adding a relocation entry for 0x11a28.
grub-install: info: adding a relocation entry for 0x11a38.
grub-install: info: adding a relocation entry for 0x11a40.
grub-install: info: adding a relocation entry for 0x11a50.
grub-install: info: adding a relocation entry for 0x11a58.
grub-install: info: adding a relocation entry for 0x11a68.
grub-install: info: adding a relocation entry for 0x11a70.
grub-install: info: adding a relocation entry for 0x11a80.
grub-install: info: adding a relocation entry for 0x11a88.
grub-install: info: adding a relocation entry for 0x11a98.
grub-install: info: adding a relocation entry for 0x11aa0.
grub-install: info: adding a relocation entry for 0x11ab0.
grub-install: info: adding a relocation entry for 0x11ab8.
grub-install: info: adding a relocation entry for 0x11ac8.
grub-install: info: adding a relocation entry for 0x11ad0.
grub-install: info: adding a relocation entry for 0x11ae0.
grub-install: info: adding a relocation entry for 0x11ae8.
grub-install: info: adding a relocation entry for 0x11af8.
grub-install: info: adding a relocation entry for 0x11b00.
grub-install: info: adding a relocation entry for 0x11b10.
grub-install: info: adding a relocation entry for 0x11b18.
grub-install: info: adding a relocation entry for 0x11b28.
grub-install: info: adding a relocation entry for 0x11b30.
grub-install: info: adding a relocation entry for 0x11b40.
grub-install: info: adding a relocation entry for 0x11b48.
grub-install: info: adding a relocation entry for 0x11b58.
grub-install: info: adding a relocation entry for 0x11b60.
grub-install: info: adding a relocation entry for 0x11b70.
grub-install: info: adding a relocation entry for 0x11b78.
grub-install: info: adding a relocation entry for 0x11b88.
grub-install: info: adding a relocation entry for 0x11b90.
grub-install: info: adding a relocation entry for 0x11ba0.
grub-install: info: adding a relocation entry for 0x11ba8.
grub-install: info: adding a relocation entry for 0x11bb8.
grub-install: info: adding a relocation entry for 0x11bc0.
grub-install: info: adding a relocation entry for 0x11bd0.
grub-install: info: adding a relocation entry for 0x11bd8.
grub-install: info: adding a relocation entry for 0x11be8.
grub-install: info: adding a relocation entry for 0x11bf0.
grub-install: info: adding a relocation entry for 0x11c00.
grub-install: info: adding a relocation entry for 0x11c08.
grub-install: info: adding a relocation entry for 0x11c18.
grub-install: info: adding a relocation entry for 0x11c20.
grub-install: info: adding a relocation entry for 0x11c30.
grub-install: info: adding a relocation entry for 0x11c38.
grub-install: info: adding a relocation entry for 0x11c48.
grub-install: info: adding a relocation entry for 0x11c50.
grub-install: info: adding a relocation entry for 0x11c60.
grub-install: info: adding a relocation entry for 0x11c68.
grub-install: info: adding a relocation entry for 0x11c78.
grub-install: info: adding a relocation entry for 0x11c80.
grub-install: info: adding a relocation entry for 0x11c90.
grub-install: info: adding a relocation entry for 0x11c98.
grub-install: info: adding a relocation entry for 0x11ca8.
grub-install: info: adding a relocation entry for 0x11cb0.
grub-install: info: adding a relocation entry for 0x11cc0.
grub-install: info: adding a relocation entry for 0x11cc8.
grub-install: info: adding a relocation entry for 0x11cd8.
grub-install: info: adding a relocation entry for 0x11ce0.
grub-install: info: adding a relocation entry for 0x11cf0.
grub-install: info: adding a relocation entry for 0x11cf8.
grub-install: info: adding a relocation entry for 0x11d08.
grub-install: info: adding a relocation entry for 0x11d10.
grub-install: info: adding a relocation entry for 0x11d20.
grub-install: info: adding a relocation entry for 0x11d28.
grub-install: info: adding a relocation entry for 0x11d38.
grub-install: info: adding a relocation entry for 0x11d40.
grub-install: info: adding a relocation entry for 0x11d50.
grub-install: info: adding a relocation entry for 0x11d58.
grub-install: info: adding a relocation entry for 0x11d68.
grub-install: info: adding a relocation entry for 0x11d70.
grub-install: info: adding a relocation entry for 0x11d80.
grub-install: info: adding a relocation entry for 0x11d88.
grub-install: info: adding a relocation entry for 0x11d98.
grub-install: info: adding a relocation entry for 0x11da0.
grub-install: info: adding a relocation entry for 0x11db0.
grub-install: info: adding a relocation entry for 0x11db8.
grub-install: info: adding a relocation entry for 0x11dc8.
grub-install: info: adding a relocation entry for 0x11dd0.
grub-install: info: adding a relocation entry for 0x11de0.
grub-install: info: adding a relocation entry for 0x11de8.
grub-install: info: adding a relocation entry for 0x11df8.
grub-install: info: adding a relocation entry for 0x11e00.
grub-install: info: adding a relocation entry for 0x11e10.
grub-install: info: adding a relocation entry for 0x11e18.
grub-install: info: adding a relocation entry for 0x11e28.
grub-install: info: adding a relocation entry for 0x11e30.
grub-install: info: adding a relocation entry for 0x11e40.
grub-install: info: adding a relocation entry for 0x11e48.
grub-install: info: adding a relocation entry for 0x11e58.
grub-install: info: adding a relocation entry for 0x11e60.
grub-install: info: adding a relocation entry for 0x11e70.
grub-install: info: adding a relocation entry for 0x11e78.
grub-install: info: adding a relocation entry for 0x11e88.
grub-install: info: adding a relocation entry for 0x11e90.
grub-install: info: adding a relocation entry for 0x11ea0.
grub-install: info: adding a relocation entry for 0x11ea8.
grub-install: info: adding a relocation entry for 0x11eb8.
grub-install: info: adding a relocation entry for 0x11ec0.
grub-install: info: adding a relocation entry for 0x11ed0.
grub-install: info: adding a relocation entry for 0x11ed8.
grub-install: info: adding a relocation entry for 0x11ee8.
grub-install: info: adding a relocation entry for 0x11ef0.
grub-install: info: adding a relocation entry for 0x11f00.
grub-install: info: adding a relocation entry for 0x11f08.
grub-install: info: adding a relocation entry for 0x11f18.
grub-install: info: adding a relocation entry for 0x11f20.
grub-install: info: adding a relocation entry for 0x11f30.
grub-install: info: adding a relocation entry for 0x11f38.
grub-install: info: adding a relocation entry for 0x11f48.
grub-install: info: adding a relocation entry for 0x11f50.
grub-install: info: adding a relocation entry for 0x11f60.
grub-install: info: adding a relocation entry for 0x11f68.
grub-install: info: adding a relocation entry for 0x11f78.
grub-install: info: adding a relocation entry for 0x11f80.
grub-install: info: adding a relocation entry for 0x11f90.
grub-install: info: adding a relocation entry for 0x11f98.
grub-install: info: adding a relocation entry for 0x11fa8.
grub-install: info: adding a relocation entry for 0x11fb0.
grub-install: info: adding a relocation entry for 0x11fc0.
grub-install: info: adding a relocation entry for 0x11fc8.
grub-install: info: adding a relocation entry for 0x11fd8.
grub-install: info: adding a relocation entry for 0x11fe0.
grub-install: info: adding a relocation entry for 0x11ff0.
grub-install: info: adding a relocation entry for 0x11ff8.
grub-install: info: adding a relocation entry for 0x12008.
grub-install: info: writing 696 bytes of a fixup block starting at 0x11000.
grub-install: info: adding a relocation entry for 0x12010.
grub-install: info: adding 1938 padding fixup entries.
grub-install: info: writing 3888 bytes of a fixup block starting at 0x12000.
grub-install: info: reading /usr/lib/grub/x86_64-efi/fshelp.mod.
grub-install: info: reading /usr/lib/grub/x86_64-efi/ext2.mod.
grub-install: info: reading /usr/lib/grub/x86_64-efi/part_gpt.mod.
grub-install: info: kernel_img=0x559e6c7d03d0, kernel_size=0x1d000.
grub-install: info: the core size is 0x21320.
grub-install: info: writing 0x25000 bytes.
grub-install: info: copying `/boot/grub/x86_64-efi/core.efi' -> `/boot/efi/EFI/manjaro/grubx64.efi'.
grub-install: info: Registering with EFI: distributor = `manjaro', path = `\EFI\manjaro\grubx64.efi', ESP at hostdisk//dev/sda,gpt1.
grub-install: info: executing efibootmgr --version </dev/null >/dev/null.
grub-install: info: executing modprobe -q efivarfs.
grub-install: info: executing efibootmgr -b 0007 -B.
BootCurrent: 0000
Timeout: 0 seconds
BootOrder: 0001,2001,2002,2003
Boot0000* USB HDD: SanDisk PciRoot(0x0)/Pci(0x14,0x0)/USB(1,0)/HD(1,MBR,0x0,0x7c445c,0x2000)RC
Boot0001* HDD0: WDC WDBNCE5000PNC PciRoot(0x0)/Pci(0x17,0x0)/Sata(0,0,0)/HD(1,GPT,ce657930-38f5-e947-904e-3473ba991e4e,0x800,0x96000)RC
Boot0002* Unknown Device: HD(1,GPT,6efe005d-5144-4766-94e8-0bb139ef551c,0x800,0x12c000)/File(\EFI\fedora\shim.efi) File(.䍒)
Boot0003* Fedora HD(1,GPT,694cfc0c-1091-4d0c-b5f7-9d3703db7482,0x800,0x12c000)/File(\EFI\fedora\shimx64.efi)
Boot0004* ubuntu HD(1,GPT,ac84fd8e-897a-0448-b28f-2f2a17876d75,0x1000,0x96000)/File(\EFI\ubuntu\shimx64.efi)
Boot0005* Fedora HD(1,GPT,bfb87df9-baac-43e4-8026-4a19911f9bf8,0x800,0x12c000)/File(\EFI\fedora\shimx64.efi)
Boot0006* Fedora HD(1,GPT,6efe005d-5144-4766-94e8-0bb139ef551c,0x800,0x12c000)/File(\EFI\fedora\shimx64.efi)
Boot0009* Fedora HD(1,GPT,c0f1fd48-91cb-4586-85aa-ce39d808f5fa,0x800,0x94800)/File(\EFI\fedora\shimx64.efi)
Boot000A* Fedora HD(1,GPT,3afc0557-5eb5-44b4-8b0d-a89fb21133f3,0x800,0x12c000)/File(\EFI\fedora\shimx64.efi)
Boot2001* EFI USB Device RC
Boot2002* EFI DVD/CDROM RC
Boot2003* EFI Network RC
grub-install: info: executing efibootmgr -c -d /dev/sda -p 1 -w -L manjaro -l \EFI\manjaro\grubx64.efi.
BootCurrent: 0000
Timeout: 0 seconds
BootOrder: 0007,0001,2001,2002,2003
Boot0007* manjaro HD(1,GPT,ce657930-38f5-e947-904e-3473ba991e4e,0x800,0x96000)/File(\EFI\manjaro\grubx64.efi)
Installation finished. No error reported.
I’ll go remove /boot/grub
. After I remove it, should I rerun the command you provided to recreate the folder?
