I have deleted the boot options shown, regenerated the grub folder and grub.cfg too.
Here’s the output for grub-mkconfig -o /boot/grub/grub.cfg
[manjaro /]# grub-mkconfig -o /boot/grub/grub.cfg
Found linux image: /boot/vmlinuz-6.2-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.2-x86_64.img
Found initrd fallback image: /boot/initramfs-6.2-x86_64-fallback.img
Found linux image: /boot/vmlinuz-6.1-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.1-x86_64.img
Found initrd fallback image: /boot/initramfs-6.1-x86_64-fallback.img
ERROR: mkdir /var/lock/dmraid
grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
