Error on booting Live USB
After the first part of the booting, in the graphical it put the error:
“Unable to contact settings server
Could not connect: No such file or directory
Close”
After close it, the LightDM asks for user / password (manjaro / manjaro) but the error its shown again.
The ISO is not corrupted, already checked and used on another equipment with not problems.
I already try the following and it didn’t work
https://forum.manjaro.org/t/unable-to-boot-xfce-live-usb/184851/49
I also try the minimal ISO, but again the same error
Running the terminal I’m able to get:
System Info
  Kernel: 6.18.18-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1 clocksource: tsc
    avail: hpet,acpi_pm parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
    misobasedir=manjaro misolabel=MANJARO_XFCE_2604 quiet systemd.show_status=1 splash apparmor=1
    security=apparmor driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
    rdinit=/vtoy/vtoy
  Console: tty 2 DM: LightDM v: 1.32.0 Distro: Manjaro base: Arch Linux
  Type: Laptop System: Acer product: Aspire V5-122 v: V2.10 serial: <superuser required>
  Mobo: Acer model: Aspire V5-122 v: V2.10 serial: <superuser required>
    part-nu: Aspire V5-122_080D_2.10 uuid: <superuser required> Firmware: UEFI vendor: Insyde
    v: 2.10 date: 10/14/2013
  ID-1: BAT0 charge: 27.7 Wh (100%) condition: 27.7/30 Wh (92.3%) volts: 12.86 min: 11.25
    model: SANYO AC13C34 type: Li-ion serial: <filter> charging: status: full cycles: N/A
  System RAM: total: 4 GiB available: 3.27 GiB used: 927.1 MiB (27.7%)
  Array-1: capacity: 4 GiB slots: 2 modules: 2 EC: None max-module-size: 2 GiB note: est.
  Device-1: Channel-A DIMM 0 type: DDR3 detail: synchronous unbuffered (unregistered)
    size: 2 GiB speed: spec: 800 MT/s actual: 667 MT/s volts: N/A width (bits): data: 64 total: 64
    manufacturer: SK-Hynix part-no: HMT425S6AFR6A-PB serial: <filter>
  Device-2: Channel-A DIMM 1 type: DDR3 detail: synchronous unbuffered (unregistered)
    size: 2 GiB speed: 667 MT/s volts: N/A width (bits): data: 64 total: 64 manufacturer: Elpida
    part-no: N/A serial: N/A
  Info: model: AMD A4-1250 APU with Radeon HD Graphics bits: 64 type: MCP arch: Jaguar level: v2
    built: 2013-14 process: GF 28nm family: 0x16 (22) model-id: 0 stepping: 1 microcode: 0x700010F
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 2 smt: <unsupported> cache: L1: 128 KiB
    desc: d-2x32 KiB; i-2x32 KiB L2: 1024 KiB desc: 1x1024 KiB
  Speed (MHz): avg: 800 min/max: 800/1000 boost: disabled scaling: driver: acpi-cpufreq
    governor: schedutil cores: 1: 800 2: 800 bogomips: 3992
  Flags: 3dnowprefetch abm aes aperfmperf apic arat avx bmi1 bpext clflush cmov cmp_legacy
    constant_tsc cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c flushbyasid
    fpu fxsr fxsr_opt ht hw_pstate ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor
    movbe msr mtrr nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
    pclmulqdq pdpe1gb perfctr_llc perfctr_nb pfthreshold pge pni popcnt proc_feedback pse pse36
    rdtscp rep_good sep skinit ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 svm_lock syscall topoext
    tsc tsc_scale vme vmmcall wdt xsave xsaveopt
  Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl
  Type: spectre_v2 mitigation: Retpolines; STIBP: disabled; RSB filling; PBRSB-eIBRS: Not
    affected; BHI: Not affected
  Type: vmscape status: Not affected
  Device-1: Advanced Micro Devices [AMD/ATI] Kabini [Radeon HD 8210] vendor: Acer Incorporated ALI
    driver: radeon v: kernel alternate: amdgpu arch: GCN-2 code: Sea Islands
    process: GF/TSMC 16-28nm built: 2013-17 ports: active: eDP-1 empty: DP-1,VGA-1 bus-ID: 00:01.0
    chip-ID: 1002:9834 class-ID: 0300
  Device-2: Suyin HD WebCam driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
    mode: 2.0 bus-ID: 2-1:2 chip-ID: 064e:c400 class-ID: 0e02
  Display: server: X.org v: 1.21.1.21 driver: X: loaded: radeon unloaded: modesetting
    alternate: fbdev,vesa dri: radeonsi gpu: radeon tty: 170x48
  Monitor-1: eDP-1 model: AU Optronics 0x325c built: 2012 res: 1366x768 dpi: 136 gamma: 1.2
    chroma: red: x: 0.584 y: 0.333 green: x: 0.337 y: 0.573 blue: x: 0.157 y: 0.133 white: x: 0.314
    y: 0.329 size: 256x144mm (10.08x5.67") diag: 294mm (11.6") ratio: 16:9 modes: 1366x768,
    1280x720, 1152x768, 1024x768, 800x600, 848x480, 720x480, 640x480
  API: EGL v: 1.5 hw: drv: amd radeonsi platforms: device: 0 drv: radeonsi device: 1 drv: swrast
    surfaceless: drv: radeonsi inactive: gbm,wayland,x11
  API: OpenGL v: 4.5 vendor: mesa v: 26.0.2-arch1.1 note: console (EGL sourced)
    renderer: (radeonsi kabini ACO DRM 2.51 6.18.18-1-MANJARO), llvmpipe (LLVM 22.1.1 256 bits)
  Info: Tools: api: eglinfo,glxinfo de: xfce4-display-settings x11: xprop,xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Kabini HDMI/DP Audio vendor: Acer Incorporated ALI
    driver: snd_hda_intel v: kernel bus-ID: 00:01.1 chip-ID: 1002:9840 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] FCH Azalia vendor: Acer Incorporated ALI
    driver: snd_hda_intel v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
  API: ALSA v: k6.18.18-1-MANJARO status: kernel-api with: aoss type: oss-emulator
  Server-3: PipeWire v: 1.6.2 status: off with: 1: pipewire-pulse status: off 2: wireplumber
    status: off 3: pipewire-alsa type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Broadcom BCM43142 802.11b/g/n vendor: Foxconn driver: N/A pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 01:00.0 chip-ID: 14e4:4365 class-ID: 0280
  WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
  Device-1: Foxconn / Hon Hai BCM43142A0 broadcom bluetooth driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 4-2:2 chip-ID: 0489:e055 class-ID: fe01
    serial: <filter>
  Local Storage: total: 524.36 GiB used: 71.42 GiB (13.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD5000LPVX-22V0TT0 size: 465.76 GiB
    block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
    fw-rev: 1A01 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 model: N/A size: 58.59 GiB block-size: physical: 512 B
    logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter>
    fw-rev: 3.00 scheme: GPT
  ID-1: /mnt/hdd1 raw-size: 207.86 GiB size: 204.41 GiB (98.34%) used: 52.14 GiB (25.5%) fs: ext4
    dev: /dev/sda6 maj-min: 8:6 label: N/A uuid: 41d389c6-b013-485c-b553-64ff177f3e1b
  ID-2: /mnt/usb1 raw-size: 50 GiB size: 50 GiB (100.00%) used: 19.28 GiB (38.6%) fs: ntfs
    dev: /dev/sdb3 maj-min: 8:19 label: Files NTFS uuid: 3B0CA7591F81164F
  ID-1: /dev/dm-0 maj-min: 253:0 mapped: ventoy size: 4.99 GiB fs: iso9660
  ID-2: /dev/dm-1 maj-min: 8:17 mapped: sdb1 size: 8.56 GiB fs: exfat label: Ventoy
    uuid: 57C3-4DC0
  ID-3: /dev/sda1 maj-min: 8:1 size: 300 MiB fs: ntfs label: Recovery uuid: F23EE8D53EE893BF
  ID-4: /dev/sda2 maj-min: 8:2 size: 100 MiB fs: vfat label: N/A uuid: A6EC-6AB3
  ID-5: /dev/sda3 maj-min: 8:3 size: 128 MiB fs: <superuser required> label: N/A uuid: N/A
  ID-6: /dev/sda4 maj-min: 8:4 size: 133.43 GiB fs: ntfs label: N/A uuid: C0F2F556F2F550E0
  ID-7: /dev/sda5 maj-min: 8:5 size: 48.83 GiB fs: ext4 label: N/A
    uuid: fed6a536-36d0-4a19-b0bc-d317b8dcb0d8
  ID-8: /dev/sda7 maj-min: 8:7 size: 4 GiB fs: swap label: N/A
    uuid: 34530ace-b604-4b18-beac-2b1957baf563
  ID-9: /dev/sda8 maj-min: 8:8 size: 46.71 GiB fs: ext4 label: N/A
    uuid: 3503f7ee-74fa-44ad-94ae-0b696a9a4903
  ID-10: /dev/sda9 maj-min: 8:9 size: 24.41 GiB fs: ext4 label: N/A
    uuid: a87d1f3c-2117-4a83-ac85-ab1500586749
  ID-11: /dev/sdb1 maj-min: 8:17 size: 8.56 GiB fs: exfat label: Ventoy uuid: 57C3-4DC0
  ID-12: /dev/sdb2 maj-min: 8:18 size: 32 MiB fs: vfat label: VTOYEFI uuid: E039-AD96
  Hub-1: 1-0:1 info: full speed or root hub ports: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 chip-ID: 1d6b:0002 class-ID: 0900
  Hub-2: 2-0:1 info: full speed or root hub ports: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
  Device-1: 2-1:2 info: Suyin HD WebCam type: video driver: uvcvideo interfaces: 2 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 500mA chip-ID: 064e:c400 class-ID: 0e02
  Hub-3: 3-0:1 info: full speed or root hub ports: 4 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 chip-ID: 1d6b:0001 class-ID: 0900
  Device-1: 3-1:2 info: Areson Corp 2.4G Receiver type: keyboard,mouse
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 100mA chip-ID: 25a7:fa23 class-ID: 0301
  Hub-4: 4-0:1 info: full speed or root hub ports: 4 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
  Device-1: 4-2:2 info: Foxconn / Hon Hai BCM43142A0 broadcom bluetooth type: Bluetooth
    driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    chip-ID: 0489:e055 class-ID: fe01 serial: <filter>
  Device-2: 4-3:3 info: Elan Micro Touchscreen type: HID driver: hid-multitouch,usbhid
    interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
    chip-ID: 04f3:009d class-ID: 0300
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
  Device-1: 5-1:2 info: USB Disk 20 type: mass storage driver: usb-storage interfaces: 1
    rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 100mA chip-ID: 346d:5678
    class-ID: 0806 serial: <filter>
  Hub-6: 6-0:1 info: super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
    mode: 3.2 gen-1x1 chip-ID: 1d6b:0003 class-ID: 0900
  System Temperatures: cpu: 54.8 C mobo: N/A gpu: radeon temp: 54.0 C
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1161 libs: 338 tools: pamac pm: flatpak pkgs: 0
    1: https://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    2: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    3: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
    4: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    5: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    6: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    7: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    8: https://linorg.usp.br/manjaro/stable/$repo/$arch
    9: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    10: https://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
    11: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    12: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    13: https://mirror.fcix.net/manjaro/stable/$repo/$arch
    14: https://ftp.yz.yamagata-u.ac.jp/pub/linux/manjaro/stable/$repo/$arch
    15: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    16: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    17: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    18: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    19: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    20: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    21: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    22: https://manjaro.kurdy.org/stable/$repo/$arch
    23: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    24: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    25: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    26: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    27: https://manjaro.mirror.ac.za/stable/$repo/$arch
    28: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    29: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    30: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    31: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    32: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    33: https://manjaro.grena.ge/stable/$repo/$arch
    34: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    35: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    36: https://manjaro.syxpi.fr/manjaro/stable/$repo/$arch
    37: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    38: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    39: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    40: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    41: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    42: https://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    43: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    44: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    45: https://mirror.meowsmp.net/manjaro/stable/$repo/$arch
    46: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    47: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    48: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
    49: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    50: https://mirror.komelt.dev/manjaro/stable/$repo/$arch
    51: https://mirror.init7.net/manjaro/stable/$repo/$arch
    52: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    53: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    54: https://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    55: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    56: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    57: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    58: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    59: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    60: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    61: https://manjaro.nic.cz/stable/$repo/$arch
    62: https://mirror.bakertelekom.fr/manjaro/stable/$repo/$arch
    63: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    64: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
    65: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
    66: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    67: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    68: https://mirror.dc.uz/manjaro/stable/$repo/$arch
    69: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    70: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    71: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    72: https://manjaro.mirror-services.net/pub/stable/$repo/$arch
    73: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    74: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
    75: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    76: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    77: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    78: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    79: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    80: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    81: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    82: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    83: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    84: https://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    85: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    86: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    87: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    88: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    89: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
    90: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    91: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
    92: https://mirrors2.manjaro.org/stable/$repo/$arch
    93: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    94: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    95: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    96: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    97: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    98: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    99: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    100: https://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    101: https://mirror.23m.com/manjaro/stable/$repo/$arch
    102: https://manjaro.ynh.ovh/stable/$repo/$arch
    103: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
    104: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    105: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    106: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    107: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    108: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    109: https://mirror.mobinhost.com/manjaro/stable/$repo/$arch
    110: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    111: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
    112: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
    113: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    114: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
    115: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
    116: https://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    117: https://manjaro.mirrors.uk2.net/stable/$repo/$arch
    118: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    119: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    120: https://mirror.dimensiondata.com/mirrors/manjaro.org/stable/$repo/$arch
    121: https://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    122: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    123: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    124: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    125: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 118
  1: cpu: 1.8% command: -zsh pid: 2197 mem: 8.50 MiB (0.2%)
  2: cpu: 0.9% command: gpg-agent pid: 1160 mem: 4.40 MiB (0.1%)
  3: cpu: 0.5% command: init pid: 1 mem: 14.4 MiB (0.4%)
  4: cpu: 0.2% command: [kworker/1:1-events] pid: 38 mem: 0.00 MiB (0.0%)
  5: cpu: 0.2% command: lightdm-gtk-greeter pid: 1959 mem: 98.4 MiB (2.9%)
  Memory top: 5 of 118
  1: mem: 98.4 MiB (2.9%) command: lightdm-gtk-greeter pid: 1959 cpu: 0.2%
  2: mem: 93.7 MiB (2.7%) command: Xorg pid: 1935 cpu: 0.1%
  3: mem: 23.0 MiB (0.6%) command: NetworkManager pid: 1015 cpu: 0.0%
  4: mem: 14.4 MiB (0.4%) command: init pid: 1 cpu: 0.5%
  5: mem: 12.7 MiB (0.3%) command: ModemManager pid: 1146 cpu: 0.0%
  Processes: 118 Power: uptime: 17m states: freeze,mem,disk suspend: deep avail: s2idle wakeups: 0
    hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 1.21 GiB Init: systemd
    v: 259 default: graphical tool: systemctl
  Compilers: N/A Shell: Zsh (login) v: 5.9 running-in: tty 2 inxi: 3.3.40
CPU
Architecture:                            x86_64
CPU op-mode(s):                          32-bit, 64-bit
Address sizes:                           40 bits physical, 48 bits virtual
Byte Order:                              Little Endian
CPU(s):                                  2
On-line CPU(s) list:                     0,1
Vendor ID:                               AuthenticAMD
Model name:                              AMD A4-1250 APU with Radeon(TM) HD Graphics
CPU family:                              22
Model:                                   0
Thread(s) per core:                      1
Core(s) per socket:                      2
Socket(s):                               1
Stepping:                                1
CPU(s) scaling MHz:                      100%
CPU max MHz:                             1000.0000
CPU min MHz:                             800.0000
BogoMIPS:                                1996.02
Flags:                                   fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp lm constant_tsc rep_good nopl nonstop_tsc cpuid extd_apicid aperfmperf pni pclmulqdq monitor ssse3 cx16 sse4_1 sse4_2 movbe popcnt aes xsave avx f16c lahf_lm cmp_legacy extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw ibs skinit wdt topoext perfctr_nb bpext perfctr_llc hw_pstate proc_feedback ssbd vmmcall bmi1 xsaveopt arat npt lbrv svm_lock nrip_save tsc_scale flushbyasid decodeassists pausefilter pfthreshold overflow_recov
L1d cache:                               64 KiB (2 instances)
L1i cache:                               64 KiB (2 instances)
L2 cache:                                1 MiB (1 instance)
NUMA node(s):                            1
NUMA node0 CPU(s):                       0,1
Vulnerability Gather data sampling:      Not affected
Vulnerability Ghostwrite:                Not affected
Vulnerability Indirect target selection: Not affected
Vulnerability Itlb multihit:             Not affected
Vulnerability L1tf:                      Not affected
Vulnerability Mds:                       Not affected
Vulnerability Meltdown:                  Not affected
Vulnerability Mmio stale data:           Not affected
Vulnerability Old microcode:             Not affected
Vulnerability Reg file data sampling:    Not affected
Vulnerability Retbleed:                  Mitigation; untrained return thunk; SMT disabled
Vulnerability Spec rstack overflow:      Not affected
Vulnerability Spec store bypass:         Mitigation; Speculative Store Bypass disabled via prctl
Vulnerability Spectre v1:                Mitigation; usercopy/swapgs barriers and __user pointer sanitization
Vulnerability Spectre v2:                Mitigation; Retpolines; STIBP disabled; RSB filling; PBRSB-eIBRS Not affected; BHI Not affected
Vulnerability Srbds:                     Not affected
Vulnerability Tsa:                       Not affected
Vulnerability Tsx async abort:           Not affected
Vulnerability Vmscape:                   Not affected
Drivers
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 16h Processor Root Complex
	Subsystem: Acer Incorporated [ALI] Device 080d
00:01.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Kabini [Radeon HD 8210]
	Kernel driver in use: radeon
	Kernel modules: radeon, amdgpu
00:01.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Kabini HDMI/DP Audio
	Kernel driver in use: snd_hda_intel
	Kernel modules: snd_hda_intel
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 16h Processor Function 0
00:02.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 16h Processor Functions 5:1
	Subsystem: Advanced Micro Devices, Inc. [AMD] Device 1234
	Kernel driver in use: pcieport
	Kernel modules: shpchp
00:10.0 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB XHCI Controller (rev 01)
	Kernel driver in use: xhci_hcd
	Kernel modules: xhci_pci
00:11.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 40)
	Kernel driver in use: ahci
	Kernel modules: ahci
00:12.0 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB OHCI Controller (rev 39)
	Kernel driver in use: ohci-pci
	Kernel modules: ohci_pci
00:12.2 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB EHCI Controller (rev 39)
	Kernel driver in use: ehci-pci
	Kernel modules: ehci_pci
00:13.0 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB OHCI Controller (rev 39)
00:13.2 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB EHCI Controller (rev 39)
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 3a)
	Kernel modules: i2c_piix4, sp5100_tco
00:14.2 Audio device: Advanced Micro Devices, Inc. [AMD] FCH Azalia Controller (rev 02)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 11)
00:14.7 SD Host controller: Advanced Micro Devices, Inc. [AMD] FCH SD Flash Controller (rev 01)
	Kernel driver in use: sdhci-pci
	Kernel modules: sdhci_pci
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 16h Processor Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 16h Processor Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 16h Processor Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 16h Processor Function 3
	Kernel driver in use: k10temp
	Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 16h Processor Function 4
	Kernel driver in use: fam15h_power
	Kernel modules: fam15h_power
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 16h Processor Function 5
01:00.0 Network controller: Broadcom Inc. and subsidiaries BCM43142 802.11b/g/n (rev 01)
	Subsystem: Foxconn International, Inc. Device e078
Thanks in advance for the help
Welcome to Manjaro forum @joanters
Kernel 6.18.18 was included in Manjaro 26.0.4 ISOs released 2026-03-27
Try using 26.1 pre-release ISO released 2026-05-27 (with kernel 7.0.10)
Manjaro 26.1 Bian-May - Preview released
Thank you for your answer
The 26.1 pre-release ISO shows the same error.
Summary
  Kernel: 7.0.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1 clocksource: tsc
    misobasedir=manjaro misolabel=MANJARO_XFCE_2610PRE quiet systemd.show_status=1 splash
    apparmor=1 security=apparmor driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
    rdinit=/vtoy/vtoy
  ID-1: BAT0 charge: 17.7 Wh (69.9%) condition: 25.3/30 Wh (84.3%) volts: 12.55 min: 11.25
    model: SANYO AC13C34 type: Li-ion serial: <filter> charging: status: charging cycles: N/A
  System RAM: total: 4 GiB available: 3.27 GiB used: 939.5 MiB (28.1%)
    mode: 2.0 bus-ID: 3-1:2 chip-ID: 064e:c400 class-ID: 0e02
  Display: server: X.org v: 1.21.1.22 driver: X: loaded: radeon unloaded: modesetting
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: mesa v: 26.1.1-arch1.2 note: console (EGL sourced)
    renderer: (radeonsi kabini ACO DRM 2.51 7.0.10-1-MANJARO), llvmpipe (LLVM 22.1.5 256 bits)
  API: ALSA v: k7.0.10-1-MANJARO status: kernel-api with: aoss type: oss-emulator
  Server-3: PipeWire v: 1.6.5 status: off with: 1: pipewire-pulse status: off 2: wireplumber
    serial: <filter>
  Local Storage: total: 524.36 GiB used: 70.35 GiB (13.4%)
  ID-1: /mnt/hdd1 raw-size: 207.86 GiB size: 204.41 GiB (98.34%) used: 70.35 GiB (34.4%) fs: ext4
  ID-1: /dev/dm-0 maj-min: 253:0 mapped: ventoy size: 4.65 GiB fs: iso9660
    uuid: 57C3-4DC0
  ID-13: /dev/sdb3 maj-min: 8:19 size: 50 GiB fs: ntfs label: Files NTFS uuid: 3B0CA7591F81164F
  Hub-2: 2-0:1 info: full speed or root hub ports: 4 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
  Hub-3: 3-0:1 info: full speed or root hub ports: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
  Device-1: 3-1:2 info: Suyin HD WebCam type: video driver: uvcvideo interfaces: 2 rev: 2.0
  System Temperatures: cpu: 54.9 C mobo: N/A gpu: radeon temp: 55.0 C
  Packages: pm: pacman pkgs: 1153 libs: 338 tools: pamac pm: flatpak pkgs: 0
    1: https://manjaro.mirrors.uk2.net/stable/$repo/$arch
    2: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    3: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    4: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
    5: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    7: https://mirror.fcix.net/manjaro/stable/$repo/$arch
    8: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    9: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    10: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    11: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    12: https://mirror.mobinhost.com/manjaro/stable/$repo/$arch
    13: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    14: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    15: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    16: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    17: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    18: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    19: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    20: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    21: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    22: https://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
    23: https://manjaro.grena.ge/stable/$repo/$arch
    24: https://mirror.23m.com/manjaro/stable/$repo/$arch
    25: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
    26: https://mirror.init7.net/manjaro/stable/$repo/$arch
    27: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    28: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    29: https://mirror.dc.uz/manjaro/stable/$repo/$arch
    30: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    31: https://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    32: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    33: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    34: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    35: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    36: https://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    37: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    38: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    39: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    40: https://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    41: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    42: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    43: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    44: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    45: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    46: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    47: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    48: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    49: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    50: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    51: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    52: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    54: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    55: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    56: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
    57: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
    58: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    59: https://mirror.komelt.dev/manjaro/stable/$repo/$arch
    60: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    61: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    62: https://linorg.usp.br/manjaro/stable/$repo/$arch
    63: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    64: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    65: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    66: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    67: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
    68: https://manjaro.nic.cz/stable/$repo/$arch
    69: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    70: https://manjaro.mirror.ac.za/stable/$repo/$arch
    71: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
    72: https://mirror.meowsmp.net/manjaro/stable/$repo/$arch
    73: https://mirror.bakertelekom.fr/manjaro/stable/$repo/$arch
    74: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    75: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    76: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    77: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    78: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    79: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    80: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    81: https://mirrors2.manjaro.org/stable/$repo/$arch
    82: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    83: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    84: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    85: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    86: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    87: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    88: https://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    89: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    90: https://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    91: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
    92: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
    93: https://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    94: https://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    95: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    96: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    97: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    98: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
    99: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    100: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    101: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    102: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    103: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    104: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    105: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    106: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    107: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    108: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    109: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
    110: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    111: https://manjaro.mirror-services.net/pub/stable/$repo/$arch
    112: https://manjaro.kurdy.org/stable/$repo/$arch
    113: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    114: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    116: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
    117: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    118: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    119: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    120: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    121: https://mirror.dimensiondata.com/mirrors/manjaro.org/stable/$repo/$arch
    122: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    123: https://ftp.yz.yamagata-u.ac.jp/pub/linux/manjaro/stable/$repo/$arch
    124: https://manjaro.ynh.ovh/stable/$repo/$arch
    125: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 117
  1: cpu: 2.5% command: -zsh pid: 1899 mem: 9.39 MiB (0.2%)
  2: cpu: 2.2% command: gpg-agent pid: 1150 mem: 4.57 MiB (0.1%)
  3: cpu: 1.0% command: [kworker/u8:1-events_unbound] pid: 13 mem: 0.00 MiB (0.0%)
  4: cpu: 0.9% command: init pid: 1 mem: 15.1 MiB (0.4%)
  5: cpu: 0.8% command: Xorg pid: 1405 mem: 92.8 MiB (2.7%)
  Memory top: 5 of 117
  1: mem: 92.8 MiB (2.7%) command: Xorg pid: 1405 cpu: 0.8%
  2: mem: 87.0 MiB (2.6%) command: xfce4-session pid: 1438 cpu: 0.3%
  3: mem: 23.9 MiB (0.7%) command: NetworkManager pid: 1006 cpu: 0.1%
  4: mem: 15.1 MiB (0.4%) command: init pid: 1 cpu: 0.9%
  5: mem: 13.1 MiB (0.3%) command: systemd-udevd pid: 741 cpu: 0.2%
  Processes: 117 Power: uptime: 10m states: freeze,mem,disk suspend: deep avail: s2idle wakeups: 0
    v: 260 default: graphical tool: systemctl
Yes i think it’s
(notice my remark about the cpu was ironic)
Yes it seems the same problem
https://github.com/manjaro/release-review/issues/40#issuecomment-4449327793
Editing the boot entry gives the same error.
Just tried it on my 2009 macbook. Easy fix, don’t touch anything, go away for 5min, come back and hit Enter…, no kidding.
Same “solution” here, with a virtualbox VM :grinning:
So it was Plymouth or a combination of gpu, driver and Plymouth?
I have always said that abomination of a software belongs in the trash and not in the iso.
