Error manjaro-keyring
  Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=d55e34cd-d5db-4872-9026-1143db0f9cfa rw quiet apparmor=1
  security=apparmor resume=UUID=3076da9a-cf5e-4d94-a57f-1eee492199f3
  udev.log_priority=3
  Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: Hewlett-Packard product: HP Pavilion dv2500 Notebook PC
  v: F.2E serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: Wistron model: 30CD v: 80.52 serial: <filter> BIOS: Phoenix v: F.2E
  date: 12/01/2008
  ID-1: BAT0 charge: 1.9 Wh (0.3%) condition: 707.6/47.5 Wh (1489.0%)
  volts: 11.8 min: 10.8 model: DP-SAN44 VE06047 type: Li-ion serial: <filter>
  status: Unknown
  RAM: total: 2.91 GiB used: 1.31 GiB (44.9%)
  Info: Dual Core model: Intel Core2 Duo T5250 bits: 64 type: MCP
  arch: Core Merom family: 6 model-id: F (15) stepping: D (13) microcode: A4
  cache: L2: 2 MiB bogomips: 5986
  Speed: 1227 MHz min/max: 1000/1500 MHz Core speeds (MHz): 1: 1227 2: 1324
  Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc cpuid
  cx16 cx8 de ds_cpl dtes64 dtherm dts est fpu fxsr ht lahf_lm lm mca mce mmx
  monitor msr mtrr nopl nx pae pat pbe pdcm pebs pge pni pse pse36 pti
  rep_good sep sse sse2 ssse3 syscall tm tm2 tsc vme xtpr
  Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
  Type: mds
  status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
  Type: spectre_v2
  mitigation: Full generic retpoline, STIBP: disabled, RSB filling
  Device-1: Intel Mobile GM965/GL960 Integrated Graphics
  vendor: Hewlett-Packard driver: i915 v: kernel bus-ID: 00:02.0
  chip-ID: 8086:2a02 class-ID: 0300
  Device-2: Chicony VGA 30fps UVC Webcam type: USB driver: uvcvideo
  bus-ID: 2-5:3 chip-ID: 04f2:b016 class-ID: 0e02 serial: <filter>
  loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1280x800 s-dpi: 96 s-size: 338x211mm (13.3x8.3")
  s-diag: 398mm (15.7")
  Monitor-1: LVDS-1 res: 1280x800 hz: 60 dpi: 107 size: 304x190mm (12.0x7.5")
  diag: 358mm (14.1")
  OpenGL: renderer: Mesa DRI Intel 965GM (CL) v: 2.1 Mesa 21.2.3
  direct render: Yes
  Device-1: Intel 82801H HD Audio vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:284b
  class-ID: 0403
  Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.38 running: yes
  Device-1: Marvell 88E8039 PCI-E Fast Ethernet vendor: Hewlett-Packard
  driver: sky2 v: 1.30 port: 3000 bus-ID: 05:00.0 chip-ID: 11ab:4353
  class-ID: 0200
  IF: ens3 state: down mac: <filter>
  Device-2: Intel PRO/Wireless 4965 AG or AGN [Kedron] Network driver: iwl4965
  v: in-tree:d port: 3000 bus-ID: 07:00.0 chip-ID: 8086:4229 class-ID: 0280
  IF: wls5 state: up mac: <filter>
  Local Storage: total: 232.89 GiB used: 10.4 GiB (4.5%)
  ID-1: /dev/sda maj-min: 8:0 vendor: PNY model: CS900 250GB SSD
  size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
  type: SSD serial: <filter> rev: 06C3 scheme: MBR
  Optical-1: /dev/sr0 vendor: Slimtype model: DVD A DS8A1H rev: WH66
  dev-links: cdrom
  ID-1: / raw-size: 226.5 GiB size: 221.88 GiB (97.96%) used: 10.4 GiB (4.7%)
  fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
  uuid: d55e34cd-d5db-4872-9026-1143db0f9cfa
  ID-1: swap-1 type: partition size: 6.38 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/sda2 maj-min: 8:2 label: swap
  uuid: 3076da9a-cf5e-4d94-a57f-1eee492199f3
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
  Device-1: 2-5:3 info: Chicony VGA 30fps UVC Webcam type: Video
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
  chip-ID: 1d6b:0001 class-ID: 0900
  Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
  Device-1: 4-1:2 info: AuthenTec AES2501 Fingerprint Sensor
  type: <vendor specific> driver: N/A interfaces: 1 rev: 1.1 speed: 12 Mb/s
  power: 100mA chip-ID: 08ff:2580 class-ID: ff00
  Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
  Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
  Device-1: 6-1:2 info: Maxxter Wireless Receiver type: Mouse,Keyboard
  driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 50mA
  chip-ID: 248a:8514 class-ID: 0301
  Hub-7: 7-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
  System Temperatures: cpu: 41.0 C mobo: 40.0 C
  Processes: 169 Uptime: 25m wakeups: 11 Init: systemd v: 249 tool: systemctl
  Compilers: gcc: N/A Packages: pacman: 1198 lib: 331 flatpak: 0 Shell: Zsh
  v: 5.8 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
Hola ,instalé manjaro en la vieja laptop ,a la cual agregué memoria Ram y un SSD sata, todo bien con la instalación ,pero al momento de actualizar el sistema me da este error el cual copio aquí
[sudo] password for juliogl:
:: Sincronizando las bases de datos de los paquetes…
core está actualizado
extra está actualizado
community está actualizado
multilib está actualizado
:: Some packages should be upgraded first…
resolviendo dependencias…
buscando conflictos entre paquetes…
Paquetes (4) base-3-2 archlinux-keyring-20230320-1 manjaro-keyring-20230318-1 manjaro-system-20230401-1
Tamaño total de la descarga: 0,53 MiB
Tamaño total de la instalación: 2,31 MiB
Tamaño neto tras actualizar: 0,78 MiB
:: ¿Continuar con la instalación? [S/n] S
:: Obteniendo los paquetes…
manjaro-keyring-20230318-1-any 547,7 KiB 167 KiB/s 00:03 [#######################################################] 100%
(4/4) comprobando las claves del depósito [#######################################################] 100%
(4/4) verificando la integridad de los paquetes [#######################################################] 100%
error: manjaro-keyring: se desconoce el nivel de confianza de la firma de «Mark Wagie mark@manjaro.org»
:: El archivo /var/cache/pacman/pkg/manjaro-keyring-20230318-1-any.pkg.tar.zst está dañado (paquete no válido o dañado (firma PGP)).
¿Quiere eliminarlo? [S/n]
Y así con muchas de estas firmas y todo lo que quiera instalar me da error (paquete no válido o dañado (firma PGP))
Como solucionar esto?.
Muchas gracias
When was your last update? Kernel 513 is EOL since September 2021.
Please switch to a supported LTS version first and then we’ll go on with the update.
(It will be using the script from this thread: [HowTo] Work around gpg verification issue on left behind systems)
Edit: Sorry, I didn’t see the Spanish tag.
Utilice el script del hilo anterior. Y actualice su kernel a una versión compatible.
Hi, thank you for your replying
I’ve tried to update the Kernel but it gives me an error and could not install, I wanted to install Linux 6.1.
I’ll read the thread you sent to me.
Thank you very much again
Hay un montón de hilos creados con el mismo problema de firma no válida, probablemente porque llevas tiempo sin actualizar.
Si te corre prisa, aquí hay un sistema para salir del paso por la vida rápida:
Hola Arrababiski,sabes que encontre un post cfinnberg y me andubo a la perfección y son estas lineas
Hola, prueba a hacer esto:
sudo pacman -Sy archlinux-keyring manjaro-keyring
sudo pacman-key --populate archlinux manjaro
sudo pacman-key --refresh-keys
Asi que lo solucionó rápidamente.
Igualmente muchas gracias a todos
