Error: manjaro-keyring: signature is unknown trust
I was trying to update my OS, then this error showed up:
Preparing...
Warning: installing db (6.2.32-1) breaks dependency 'db=5.3.28' required by lib32-db
Add lib32-db to remove
Resolving dependencies...
Checking inter-conflicts...
Warning: dependency cycle detected:
Warning: bashrc-manjaro will be installed before its bash dependency
Warning: harfbuzz will be installed before its freetype2 dependency
Warning: mesa will be installed before its libglvnd dependency
Warning: libcamera-ipa will be installed before its libcamera dependency
Warning: lib32-harfbuzz will be installed before its lib32-freetype2 dependency
Warning: lib32-mesa will be installed before its lib32-libglvnd dependency
Warning: mhwd-db will be installed before its mhwd-nvidia dependency
Warning: mhwd-nvidia-390xx will be installed before its mhwd dependency
Warning: mhwd-nvidia-470xx will be installed before its mhwd dependency
Warning: phonon-qt5-gstreamer will be installed before its phonon-qt5 dependency
Download of manjaro-system (20230401-1) started
Download of manjaro-system (20230401-1) finished
Checking keyring...
Checking integrity...
Error: manjaro-keyring: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
Error: manjaro-system: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
Removing invalid files and retrying...
Download of manjaro-keyring (20230318-1) started
Download of manjaro-keyring (20230318-1) finished
Checking keyring...
Failed to commit transaction:
invalid or corrupted package (PGP signature):
Moderator edit: Removed email address from subject line to prevent web spiders crawling it and sending me spam
Use the search function for broken keys to fix this.
When did you last update?
I’m thinking not that long ago…
But yeah, @op should search a bit, this has been asked and answered multiple times…
I’m still beginner, and I don’t really understand what does this mean!
can you demystify it for me?
A very long time ago
Not something you should so with Manjaro - it’s rolling-release, meaning you’ve got to roll with the changes, ma’n.
You don’t have to be advanced to know how a search function works:
https://i.imgur.com/Rt88wpk.png
There are many solved results that would’ve answered your question.
There is also a tutorials section, where you’d have noticed:
https://i.imgur.com/UcyYVwj.png
Which is:
